2852 connectés
  Java
  Problème lors de la génération de la javadoc
n°2185078
t0um
Posté le 10-04-2013 à 03:00:09  profilanswer
Salut tout le monde,
j'ai un petit soucis quand j'essaye de générer la javadoc de mon projet... Voici les erreurs que netbeans retourne :
Warning: Leaving out empty argument '-windowtitle'
Generating Javadoc
Javadoc execution
Loading source file E:\JavaWorkspace\java-v2\src\java\Business\Manager.java...
warning: [options] bootstrap class path not set in conjunction with -source 1.6
Loading source file E:\JavaWorkspace\java-v2\src\java\Controller\Controller.java...
error: unsupported encoding: ${source.encoding}
Loading source file E:\JavaWorkspace\java-v2\src\java\Data\ConnexionSingleton.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Data\DbAccess.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Exception\DataException.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Attribution.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Budget.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Demande.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\GroupeUnite.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Personne.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Section.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Statut.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Transaction.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\Model\Unite.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddBudgetFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddDemandFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AddTransactionFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllAttributionsModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDemandsModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllDepQuotModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\AllTradeModel.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\CenterRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\ComptaRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\EtatCellEditor.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\GestionFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\InfoSectionPane.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\LoginFrame.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\Main.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\StateRenderer.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\WindowListenerPerso.java...
Loading source file E:\JavaWorkspace\java-v2\src\java\View\budgetPreviewPanel.java...
31 errors
1 warning
E:\JavaWorkspace\java-v2\nbproject\build-impl.xml:1133: Javadoc returned 1
BUILD FAILED (total time: 0 seconds)
J'ai viré tous les caractères spéciaux de mes annotations mais rien n'y fait...
Quelqu'un a une solution ou sait d'où ça vient??
Merci ;)
Message édité par t0um le 10-04-2013 à 03:01:31
  Java
problème de manipulation/réorganisation de fichiersProblème query PDO
Problème HttpHostConnectExceptionProblème: Un autre site à la place du mien !
[Input et BDD] problème complex...probleme mise a jour de ma base de données
Problème avec mon LoopGénération de doc pdf sur base d'un formulaire
Problème mise en ligne de mon site, suis je un boulet ???Problème jointure requête sql.
Plus de sujets relatifs à : Problème lors de la génération de la javadoc
