3279 connectés
  probleme bizarre en C aussi ;)
n°65709
godbout
Génial.
Posté le 17-10-2001 à 11:20:31  profilanswer
void ControlMAJ(char *catalogue)
 int repexist;
 int fileexist;
 strcat(catalogue, "\\Test" );
 repexist = PathIsDirectory(catalogue);
 //Si rep = true
 //C'est que le catalogue a ete installe sur la machine
 if (repexist > 0 )
  strcat(catalogue, "\\MERGE" );
  //On regarde si le fichier existe
  fileexist = access(catalogue, 0);
Salut a tous :hello:
Alors mon petit pb du jour est que avant la fonction access, catalogue = "C:\blablabla".
Et apres, elle devient vide :??:
J'aimerais comprendre pourquoi ?
Je sais bien qu'il y a d'autre moyen (par exemple essayer d'ouvrir le fichier, ou encore faire un strcpy avant et apres la fonction) mais comme ca me le fait deja avec 3 fonctions j'aimerais comprendre ou je fais la faute.
Merci ;)
n°65718
chrisbk
Posté le 17-10-2001 à 11:44:51  profilanswer
fire the debugger
n°65722
BENB
100% Lux.
Posté le 17-10-2001 à 11:48:07  profilanswer
access(2)                                                         access(2)
 NAME
      access - determine accessibility of a file
 SYNOPSIS
      #include <unistd.h>
      int access(char *path, int amode);
 DESCRIPTION
      The access() system call checks the file pointed to by path for
      accessibility according to the bit pattern contained in amode.
      access() uses the real user ID, not the effective user ID, and the
      real group ID, not the effective group ID.
      The value of amode is either the bit-wise inclusive OR of the access
      permissions to be checked, or the existence test.  You can use the
      following symbolic constants, defined in <unistd.h>, to test for
      permissions:
           R_OK      Read access
           W_OK      Write access
           X_OK      Execute (search) access
           F_OK      Check existence of file
      The owner of a file has permission checked with respect to the "user"
      read, write, and execute mode bits.  Members of the file's group other
      than the owner have permissions checked with respect to the "group"
      mode bits.  All others have permissions checked with respect to the
      "other" mode bits.
      If a file is currently open for execution, access() reports that it is
      not writable, regardless of the setting of its mode.
    Access Control Lists - HFS File Systems Only
      Read, write, and execute/search permissions are checked against the
      file's access control list (ACL).  Each mode is checked separately
      since different ACL entries can grant different permissions.  The real
      user ID is combined with the process's real group ID and each group in
      its supplementary groups list, and the access control list is searched
      for a match.  Search proceeds in order of specificity and ends when
      one or more matching entries are found at a specific level.  More than
      one user.group or %.group entry can match a user if that user has a
      nonnull supplementary groups list.  If any matching entry has the
      appropriate permission bit set, access is permitted.
      If a shared text file is currently open for execution, access()
      reports that it is not writable, regardless of its access control
      list.  However, access() does not report that a shared text file open
      for writing is not executable, since the check is not easily done.
 Hewlett-Packard Company            - 1 -  HP-UX Release 11.00: October 1997
 access(2)                                                         access(2)
      It also reports that a file on a read-only file system is not
      writable.
 RETURN VALUE
      access() returns the following values:
           0   Successful completion.  The requested access is permitted.
                If the path is valid and the real user ID is superuser,
                access() always returns 0, except when amode includes X_OK,
                the path is not a directory, and none of the execute bits
                are set in the file's mode.
           -1   Failure.  errno is set to indicate the error.
 ERRORS
      If access() fails, errno is set to one of the following values.
           [EACCES]       Search permission is denied on a component of the
                          path prefix.
           [EACCES]       The access control list does not permit the
                          requested access and the real user ID is not a
                          user with appropriate privileges.
           [EFAULT]       path points outside the allocated address space
                          for the process.  The reliable detection of this
                          error is implementation dependent.
           [ELOOP]        Too many symbolic links were encountered in
                          translating the path name.
           [ENAMETOOLONG] The length of the specified path name exceeds
                          PATH_MAX bytes, or the length of a component of
                          the path name exceeds NAME_MAX bytes while
                          _POSIX_NO_TRUNC is in effect.
           [ENOENT]       Read, write, or execute (search) permission is
                          requested for a null path name.
           [ENOENT]       The named file does not exist.
           [ENOTDIR]      A component of the path prefix is not a directory.
           [EROFS]        Write access is requested for a file on a read-
                          only file system.
           [ETXTBSY]      Write access is requested for a pure procedure
                          (shared text) file that is being executed.
 Hewlett-Packard Company            - 2 -  HP-UX Release 11.00: October 1997
 access(2)                                                         access(2)
 SEE ALSO
      chmod(2), stat(2), setacl(2), acl(5), unistd(5).
 STANDARDS CONFORMANCE
      access(): AES, SVID2, SVID3, XPG2, XPG3, XPG4, FIPS 151-2, POSIX.1
 Hewlett-Packard Company            - 3 -  HP-UX Release 11.00: October 1997
Il n'est pas dit que access ne modifie pas la chaine qui lui est passe, et s'il ne la modifiait pas ne devrait-il pas prendre un
const char * ? Ceci dit s'il la modifie ca devrait etre dit...
n°65727
godbout
Génial.
Posté le 17-10-2001 à 12:04:34  profilanswer
Il ne la modifie pas puisque si je lui donne un argument qui n'est pas argument dans ma fonction, alors il ne change rien.
D'ailleurs y a un truc assez etrange:
Si je fais ca catalogue ressort avec ""
strcpy(cattemp, catalogue);
strcpy(catalogue, cattemp);
La aussi catalogue ressort avec "", mais je lui remet sa valeur apres.
fileexist = access(cattemp, 0);
Par contre la aussi, c'est bien catalogue qui ressort avec "", alors que cattemp n'a pas bouge :??:
La je ne suis plus.
J'ai eu les meme pb avec la fonction PathIsDirectory
n°65761
gilou
Modosaurus Rex
Posté le 17-10-2001 à 13:43:35  profilanswer
Je peux pas dire a priori pourquoi access se comporte ainsi, mais a vue de nez, tes strcat sont dangereux: as tu assez de place allouee dans catalog?
A+,
n°65764
godbout
Génial.
Posté le 17-10-2001 à 13:50:50  profilanswer
Ben voila ce que j'ai a l'appel de la fonction:
chemin = (char *)malloc(128*sizeof(char *));
     strcpy(chemin, "" );
     chemin = FindPath("Product databases" );
     ControlMAJ(chemin, "\\Test" );
Donc j'ai bien fait un malloc de 128, ca suffit, mais dans la fonction je fais pas de malloc, parce que si j'en fait un il me vire ce que contient ma variable.
n°65768
gilou
Modosaurus Rex
Posté le 17-10-2001 à 13:56:28  profilanswer
Ben a vue de nez, ton affectation chemin = FindPath("Product databases" ); perd le buffer alloue.
D'autre par, ControlMAJ(chemin, "\\Test" ); a 2 parametres, et ce n'est pas ce que tu avait ecrit plus haut.
A+,
n°65769
godbout
Génial.
Posté le 17-10-2001 à 13:58:32  profilanswer
Pour le ControlMAJ c'est parce que j'ai rajoute un arg, mais t'inquiete ca n'a rien a voir.
Je crois en effet aussi que l'allocation est perdu au niveau du passage d'argument.
Je sais pas pourquoi.
Ce que je pense faire c'est recree un char*, allouer, et copier l'argument dedans.
Je crois que c'est la seule solution.
n°65770
gilou
Modosaurus Rex
Posté le 17-10-2001 à 14:01:57  profilanswer
Non, ce que je te dis, c'est que chemin = FindPath("Product databases" );  remplace le buffer alloue par ce qui est pointe en retour de ta fonction.
Soit tu as une fonction FindPath1(chemin, "Product databases" ); qui va remplir chemin, soit tu fais strcpy(chemin,FindPath("Product databases" )); afin de copier le resultat de findpath dans le buffer que tu as alloue.
A+,
n°65789
godbout
Génial.
Posté le 17-10-2001 à 14:24:26  profilanswer
Tu pourrais m'expliquer comment je pourrais faire avec FindPath1(chemin, "Product Databases" ); ?
Parce que je remplis bien a l'interieur de la fonction le path, mais chemin est toujours egal a vide.
n°65798
godbout
Génial.
Posté le 17-10-2001 à 14:40:12  profilanswer
ou alors je la met en global ?
Mais alors la j'ai plus besoin de le mettre dans la fonction !
J'suis paume sur le coup la :(
n°65799
BENB
100% Lux.
Posté le 17-10-2001 à 14:42:32  profilanswer
juste une remarque qui ne change rien a ton Pb :
chemin = (char *)malloc(128*sizeof(char * ));
enleve l'etoile en rouge...
[edtdd]--Message édité par BENB--[/edtdd]
n°65836
godbout
Génial.
Posté le 17-10-2001 à 16:17:44  profilanswer
ok merci :)
n°65938
gilou
Modosaurus Rex
Posté le 18-10-2001 à 05:13:23  profilanswer
Pourquoi ne fais tu pas un strcpy(chemin,FindPath("Product databases" ));  comme je te le suggerais??
A+,
n°65941
godbout
Génial.
Posté le 18-10-2001 à 08:04:55  profilanswer
A+,
Si bien sur ;)
Mais j'ai pas seulement envie de faire un prog qui fonctionne, j'ai envie de comprendre d'ou vient le pb lorsque que quelquechose ne marche pas.
Mais c'est bon j'ai trouve
Merci ;)
probleme bizarre en C[Pascal] problème de nombres ... ???
[Access] problème de runtimeprobleme d' ASP...please help Urgent!!!!!
[MFC] Problème de rafraichissement d'une CView et CWinApp:OnIdleProblème accents : conversion BDD DBASE en MYSQL
[PHP] Setcookie et header("location:...") Problème???????[phpBB] Ben oui, j'ai un probléme.......
[Delphi] Problème avec winsock (pour un chat)
Plus de sujets relatifs à : probleme bizarre en C aussi ;)
