2669 connectés
  Java
  jaaavaaaaa!!!!! help :((((
n°2144160
lizouz
Posté le 31-05-2012 à 12:22:56  profilanswer
bonjour,
mon application comprend l'enregistrement des données sur PHPMYAdmin via netbeans, et donc tout marche bien du moin pour les premiére valeurs enregistrées puis ben une exeption est affiché du genre:
Exception in thread "AWT-EventQueue-0" java.lang.IndexOutOfBoundsException: Index: 1082429, Size: 1082429
 at java.util.ArrayList.RangeCheck(ArrayList.java:547)
 at java.util.ArrayList.get(ArrayList.java:322)
 at memoire.MemoireView.jButton1ActionPerformed(MemoireView.java:663)
 at memoire.MemoireView.access$800(MemoireView.java:49)
 at memoire.MemoireView$4.actionPerformed(MemoireView.java:154)
 at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
 at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
 at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
 at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
 at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
 at java.awt.Component.processMouseEvent(Component.java:6263)
 at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
 at java.awt.Component.processEvent(Component.java:6028)
 at java.awt.Container.processEvent(Container.java:2041)
 at java.awt.Component.dispatchEventImpl(Component.java:4630)
 at java.awt.Container.dispatchEventImpl(Container.java:2099)
 at java.awt.Component.dispatchEvent(Component.java:4460)
 at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
 at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
 at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
 at java.awt.Container.dispatchEventImpl(Container.java:2085)
 at java.awt.Window.dispatchEventImpl(Window.java:2478)
 at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
 at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
de l'aide SVP! merci d'avance
n°2144161
brisssou
8-/
Posté le 31-05-2012 à 13:29:31  profilanswer
for (i=0 ; i<tableau_vachement_long.size(); i++)
tu noteras le <, et non pas <=
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
n°2144167
gilou
Modérateur
Modosaurus Rex
Posté le 31-05-2012 à 15:02:59  profilanswer
Et on peut même dire que tableau_vachement_long.size() vaut 1082429 :whistle:
Lire la première ligne d'un log d'erreur, c'est pas si dur...
A+,
There's more than what can be linked! --  Le capitaine qui ne veut pas obéir à la carte finira par obéir aux récifs. -- Il ne faut plus dire Sarkozy, mais Sarkozon -- (╯°□°)╯︵ ┻━┻
n°2144169
lizouz
Posté le 31-05-2012 à 15:13:00  profilanswer
Mercii ! effectivement ...sté ça le probléme !
n°2144171
brisssou
8-/
Posté le 31-05-2012 à 15:20:45  profilanswer
cool :)
le prochain coup, tu nous mets un titre descriptif ?
  Java
HELP ! Impossible de creer dossier partagé...SVN help please
[HELP]Ma page ne fonctionne pashelp! sccript batch qui permet de comparer et supprimer des fichiers
SVP HELP Programateur d'eprom[HELP] Analyseur de logs
file_get_contents vers URL, ne marche pas... ? helpjavascript HELP !!!!!!!!!
Help comparaison de deux fichier perlHelp please un site de collecte d'adresses emails
Plus de sujets relatifs à : jaaavaaaaa!!!!! help :((((
