2081 connectés
  Java
  Erreur code java String[][]
n°2078818
futuring
Posté le 27-05-2011 à 23:17:22  profilanswer
j'ai crée la classe suivante :
public class operation {
public String[][] operationn(@WebParam(name = "key" )
String key) {
String [][]data =null;
try {
//TODO write your implementation code here:
String[] columnNames = {"Videos", "Information"};
//---------Cconnexion à la base de données:----------------------
String username = "root";
String password = "0000";
Statement stmt;
ResultSet rs;
Class.forName("com.mysql.jdbc.Driver" ).newInstance();
String url = "jdbc:mysql://localhost:3306/mabase";
Connection conn = null;
conn = (Connection) DriverManager.getConnection(url, username, password);
System.out.println("OK connexion réussie..." );
stmt = (Statement) conn.createStatement();
rs = stmt.executeQuery("select * from videos where nomVideo='" + key + "'" );
rs.last();
int NbreResultats = rs.getRow();// n' a pas de sens non?
System.out.println("Le nombre des résultats vaut " + NbreResultats); // to del
data = new String[NbreResultats][columnNames.length];
rs.beforeFirst();
String NEWLINE = System.getProperty("line.separator" );
while (rs.next()) {
String im = rs.getString("lien" );
System.out.println(im); // to del
String Info = ""+" Nom de la vidèo :" + rs.getString("nomVideo" ) + NEWLINE + " Catégorie :" + rs.getString("categorie" ) + NEWLINE + " Durée :" + rs.getString("duree" ) + NEWLINE;
System.out.println(Info);
int i=0;
data[i][0] =rs.getString("vignette" );
data[i][1] = Info;
i++;
rs.close();
stmt.close();
} catch (SQLException ex) {
//System.out.println("erreur sqlex" );//
Logger.getLogger(operation.class.getName()).log(Level.SEVERE, null, ex);
} catch (InstantiationException ex) {
// System.out.println("erreur Inst" ); //
} catch (IllegalAccessException ex) {
// System.out.println("erreur ill" );//
} catch (ClassNotFoundException ex) {
// System.out.println("erreur class not found" );
return data;
public static void main (String [] args){
operation op = new operation();
System.out.println(op.operationn("exemple" ));
pas d'erreur mais comme output il m'affiche [[Ljava.lang.String;@b32e13d !!!!!!
c'est quoi le probléme SVP?
merci d'avance
n°2078819
brisssou
8-/
Posté le 28-05-2011 à 00:04:36  profilanswer
quelle output ? t'en as plein
sinon, ça c'est un probable tableau de String balancé tel quel à system.out.println(), il faut que tu boucles sur les éléments pour les afficher un à un
Message édité par brisssou le 28-05-2011 à 00:04:46
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
n°2078822
futuring
Posté le 28-05-2011 à 00:15:14  profilanswer
merci bien pour votre réponse ,
oui je parle de "data"
vous avez raison
mais il n'y a pas un moyen de retouner toue le tableau
j'en ai besoin ce code comme opération dans un web service
n°2078824
brisssou
8-/
Posté le 28-05-2011 à 00:23:17  profilanswer
tu peux retourner le tableau oui, d'ailleurs c'est ce que fait ta méthode operation, ça marche.
mais pour l'afficher en texte quelque part (dans la console ici), non pas d'autre moyen que de boucler
n°2078826
futuring
Posté le 28-05-2011 à 00:41:01  profilanswer
d'accord merci bien
mais quand je teste mon web service qui retourne String[] [[Ljava.lang.String;@b32e13d
j'ai doute si ça fonctionnera en l'associant à un client later
qu'en pensez vous?
n°2078829
brisssou
8-/
Posté le 28-05-2011 à 01:08:29  profilanswer
xml ? ou (bien mieux) json ?
tu pourras sérialiser ton objet pour le faire passer par ton web service.
Message édité par brisssou le 28-05-2011 à 01:09:09
n°2078835
futuring
Posté le 28-05-2011 à 02:29:44  profilanswer
XML  càd avec SOAP
j'utilise netbeans comme IDE , ile me semble assez facile quant à la manipulation des Web services
mais sincérement je suis assez débutante en web service , quand un tel probléme m'en face je me suis bloquée .
comment je peux sérialiser un objet ?
merci infiniment
  Java
API java pour Garmin GPS18 USBMenu deroulant java
[??] Création dynamique de page sur Mediawiki (à partir de code PHP)bouton play, pause, java, html
débutant absolu n'arrive pas à faire fonctionner un javaaidez moi svp dans la compréhension de ce code
SSH via applet javaSauvegarde fichier mon code n'est pas parfait
Application mode Cloud [JAVA]erreur de syntaxe, probleme langage C
Plus de sujets relatifs à : Erreur code java String[][]
