3977 connectés
  VB/VBA/VBS
  Ouvrir et femer le lecteur cdrom
n°661321
ads75
Posté le 02-03-2004 à 19:13:05  profilanswer
Salut
Je voudrais savoir si c possible de controler l'ouverture et la fermeture du lecteur cdrom par un bouton de commande en vb.net ou vb6
n°661929
pumpkin031​2
Posté le 03-03-2004 à 12:35:50  profilanswer
Tu peux peut-être t'inspirer de ça :
Private Declare Function GetDriveType Lib "kernel32" Alias "GetDriveTypeA" (ByVal nDrive As String) As Long
Private Declare Function mciExecute Lib "winmm.dll" (ByVal lpstrCommand As String) As Long
Function ouvre()
Dim a
a = OpenCloseCD(GetListCDDrive, True, False)
End Function
Function ferme()
Dim a
a = OpenCloseCD(GetListCDDrive, False, False)
End Function
Public Function GetListCDDrive() As String
    Dim I As Integer
    Dim nCDDrive As String
    Dim RetCDDrive As String
    Const DRIVE_CDROM = 5
    For I = 65 To 90
        nCDDrive = Chr$(I) & ":\"
        If GetDriveType(nCDDrive) = DRIVE_CDROM Then
            RetCDDrive = RetCDDrive & nCDDrive & ";" '
        End If
    Next 'i
    GetListCDDrive = Left(RetCDDrive, Len(RetCDDrive) - 1)
End Function
Public Function GetFirstCDDrive() As String
    Dim I As Integer
    For I = 65 To 90
            GetFirstCDDrive = nCDDrive
            Exit For
        End If
    Next 'i
End Function
Public Function OpenCloseCD(Optional Drive As String, Optional ByVal OpenClose As Boolean = True, Optional FindFirstCDDrive As Boolean) As Boolean
    Dim nDrive As String
    Dim nExec  As String
    Dim nAlias As String
    Dim nResult As Long
    If FindFirstCDDrive Then
        nDrive = GetFirstCDDrive()
    Else
        nDrive = Trim$(Drive)
        If Len(nDrive) Then
            nDrive = Left$(nDrive, 1)
            If nDrive Like "[a-z]" Then
                If GetDriveType(nDrive & ":\" ) <> DRIVE_CDROM Then
                    Exit Function
                End If
            End If
        End If
    End If
    If Len(nDrive) Then
        nAlias = "CDDrive" & nDrive
        nExec = "Open " & nDrive & ": Type CDAudio Alias " & nAlias
        nResult = mciExecute(nExec)
        If nResult Then
            If OpenClose Then
                nExec = "Set " & nAlias & " Door Open"
            Else
                nExec = "Set " & nAlias & " Door Closed"
            End If
            If nResult Then
                nExec = "Close " & nAlias
                OpenCloseCD = True
            End If
        End If
    End If
End Function
  VB/VBA/VBS
Comment ouvrir une page HTML en mode plein écrancréer et ouvrir une requete SELECT en VBA
Mettre un lien .MP3 sans l'ouvrir directement dans le navigateur[ACCESS] ouvrir outlook et internet explorer
ouvrir un fichierfemer la fenetre DOS a la fin d'un Batch sous W95 ?
realisation d'un lecteur cd sous linuxCréer un lien pour ouvrir l'explorer windows
Ouvrir un user form à l'ouverture d'un fichier excelOuvrir un image dans une fentre a la taille ?
Plus de sujets relatifs à : Ouvrir et femer le lecteur cdrom
