8990 connectés
  C++
  Kylix 3 Open C++ : Problème de compilation, voilà le log
n°515496
juju-le-ba​rbare
Posté le 16-09-2003 à 10:27:41  profilanswer
J'ai installé Kylix 3 Open sur ma Mandrake 9.1.
J'ai eu divers problèmes avec time.h, mais je les ai résolus avec Google.
Maintenant, j'ai d'autres erreurs lorsque je veut compiler, voilà le log :
Code :
  1. Construction
  2.   [Lieur Erreur] Unresolved external 'Qt::QPaintDevice_x11AppDisplay()' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  3.   [Lieur Erreur] Unresolved external 'Qt::QWidget_winId(Qt::QWidgetH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  4.   [Lieur Erreur] Unresolved external 'Qt::QFontMetrics_create(Qt::QFontH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  5.   [Lieur Erreur] Unresolved external 'Qt::QLabel_alignment(Qt::QLabelH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  6.   [Lieur Erreur] Unresolved external 'Qt::QFontMetrics_boundingRect(Qt::QFontMetricsH *, Types::TRect *, int, int, int, int, int, System::WideString *, int, int, int *, char * *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  7.   [Lieur Erreur] Unresolved external 'Qt::QFrame_frameWidth(Qt::QFrameH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  8.   [Lieur Erreur] Unresolved external 'Qt::QFrame_contentsRect(Qt::QFrameH *, Types::TRect *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  9.   [Lieur Erreur] Unresolved external 'Qt::QFontMetrics_destroy(Qt::QFontMetricsH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  10.   [Lieur Erreur] Unresolved external 'Qt::QApplication_desktop()' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  11.   [Lieur Erreur] Unresolved external 'Qt::QWidget_width(Qt::QWidgetH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
  12.   [Lieur Erreur] Unresolved external 'Qt::QWidget_height(Qt::QWidgetH *)' referenced from /home/coder/kylix3/lib/obj/QOpenBanner.o
Comment corriger ce problème ?
Merci @++
juju
n°515501
Taz
bisounours-codeur
Posté le 16-09-2003 à 10:30:08  profilanswer
ben tu tritouilles l'interface graphique pour dire à l'éditeur de lien de faire son job avec les bidules QT
n°515513
chrisbk
Posté le 16-09-2003 à 10:47:54  profilanswer
Lieur Erreur
ben les VF pour les compilos, je sais pas si je suis pour
n°515519
LetoII
Le dormeur doit se réveiller
Posté le 16-09-2003 à 11:01:19  profilanswer
Rajoute le chemin de la bibliothéque QT dans la liste des chemins des lib
Le Tyran
n°515575
juju-le-ba​rbare
Posté le 16-09-2003 à 12:50:13  profilanswer
OK très bien. Et elle se trouve la bibliothèque QT ?
Merci @++
n°515588
LetoII
Posté le 16-09-2003 à 13:08:30  profilanswer
Merci @++
 :heink: C pas à moi de connaître ton système à ta place  :sarcastic:
Le Tyran
n°515589
chrisbk
Posté le 16-09-2003 à 13:09:45  profilanswer
si d'ailleurs grouille, son tp c pour dans deux semaines alors ca serait bien que tu le finisses, et oublie pas de commenter le code hein ?
n°515593
juju-le-ba​rbare
Posté le 16-09-2003 à 13:11:32  profilanswer
Ben c'est sûr, mais bon Qt a été installé par défaut en même temps que le reste du système, pourrais-tu me donner un moyen de savoir où est située la librairie QT ?
Tant qu'on y est, comment avec Kylix C++ générer un exécutable autonaume des librairies de Borland ?
Merci @++
n°515595
juju-le-ba​rbare
Posté le 16-09-2003 à 13:13:18  profilanswer
Non non on ne fait malheureusement pas de Kylix à l'IUT, j'aimerais juste coder une interface graphique pour mes programmes. Seulement je m'y connait très peu en graphique pour le moment, je suis un habitué de la console ...
Mais ma femme a du mal à utiliser ces programmes, c'est pour ça que je veut coder une interface !
N'y aurait-il ici que des jeunes boutonneux qui ne pensent qu'à reçevoir des infos gratuites pour leur projet pour que tu penses à ça ?
Message édité par juju-le-barbare le 16-09-2003 à 13:17:13
n°515610
LetoII
Posté le 16-09-2003 à 13:20:20  profilanswer
Merci @++
find / -name *qt*
Le Tyran
n°515612
juju-le-ba​rbare
Posté le 16-09-2003 à 13:21:05  profilanswer
LetoII a écrit :
find / -name *qt*
Danke  ;)
n°515675
os2
Posté le 16-09-2003 à 14:28:43  profilanswer
Code :
  1. Construction
Merci @++
juju
as-tu installé les patch pour kylix?
http://www.kylix-patch.de.vu/
Borland rulez: http://pages.infinit.net/borland
n°516708
juju-le-ba​rbare
Posté le 17-09-2003 à 18:18:43  profilanswer
je les ai installés. En fait j'ai résolu le problème en créant un lien dans /usr/lib vers ~/kylix3/bin/libborqt-6.9.0-qt2.3.so
Merci @++
n°516709
kadreg
profil: Utilisateur
Posté le 17-09-2003 à 18:23:27  profilanswer
 [:vomi]
brisez les rêves des gens, il en restera toujours quelque chose...  -- laissez moi troller sur discu !
n°518152
VisualC_n3​T
Boolays élevés au grain
Posté le 19-09-2003 à 12:58:46  profilanswer
Tu pourrais me dire comment tu as fait pour les problemes de time.h ?
Human Forever
n°613413
juju-le-ba​rbare
Posté le 16-01-2004 à 13:20:44  profilanswer
ben quoi ?
  C++
Kylix C++ Builder : problème avec time.h !probleme de liste deroulante
[Java] Problème de classpath avec un fichier Jar[Delphi] Problème de transparence d'images
Probleme avec le russephpBB2 : problème de frame
[HTML] Problème de bordure avec une image...Problème de marge
[Java][Swing] Problème de taille avec JSplitPane [résolu]
Plus de sujets relatifs à : Kylix 3 Open C++ : Problème de compilation, voilà le log
