3044 connectés
  Water & Xtreme Cooling
  [WorkLog] "Numéro 0251" - CoSMoS N3v3R 3NDZZ
 Page :   1  2  3
Page Précédente
n°1947044
astharo
Posté le 30-10-2009 à 14:19:06  profilanswer
Bonjour à tous,
Projet de mise en place d'un système de WC interne dans Cosmos.
Galerie photos 1
Galerie photos 2
Purple rain
Watercooling Stuff:
System:
Case: Cooler Master Cosmos Black Label No. 0251
CPU: Intel Core i7 860
Motherboard: EVGA P55 FTW
CPU Overclock Speed: to do
Video Card & Quantity: SAPPHIRE HD5970 OC
Videocard Overclock: to do
Watercooling:
CPU Block: HK Rev 3.0 LT Nickel Plated
NorthBridge Block: Stock
SouthBridgeBlock: Stock
Mosfet Block: Stock
Videocard WB/WBs: EK FC5970 Nickel-Acetal
Radiator & Quantity: PA 140.3 + RS240 + RS120
Radiator Fans & Quantity: 3x NB PK3 + 2x NB PL2 + 1x NB PL2
Radiator Location: 140.3 Top / RS240 stand / RS120 3.25" bay
Radiator Fan Direction: 140mm push – 120mm push
Reservoir: EK Multioption 150ml
Tubing & Size: Primoflex LRT Pro Black 7/16” ID – 5/4” OD
Barb/Fitting Size: BP 1/2” barb + BP 1/2" rotary + compression fittings for 5/4”OD
Pump & Quantity: Laing DDC-1 (MCP355) + Watercool  LT Acetal Top
Pumps-Series/Parallel: No
MISC:
- Backplate EK Noire pour 5970
- LAMPTRON FC-2 Black
- Sleeving tools
- MDPC Sleeve
- Schéma de montage: A VENIR
A acheter:
- Jeux de lumières
Liste des tâches:
1- Montage Air cooling - OK
1'- Flash Bios CM - OK
1"- Flash Bios HD5970 - OK
2- Tests Air cooling  - OK
2'-  Unigine Heaven 1080p stock speed: 1557
2"- Unigine Heaven 2.0 1080p stock speed:
2"'- 3dMark Vantage stock speed: P20903 - X13318
2""- 3dMark06 1080p-AA8x-AF16x stock speed:19412
3- Moding de la tour - OK
4- Moding du support de la CM -OK
5- Remontage composant - OK
6- Montage WC - OK
7- Test de fuite - OK
8- Test en condition réelle - OK
9- OC Processeur @4GHZ (20x200) HT ON
10- OC CG @960-1300
3DMark Results:
- Vantage: P30010 (GPU 32284) - X17602 (GPU 17341)
- 06: TO DO
"[...]Would be relesead: when it's done!" => IT'S DONE & It RoCKZ !
Message édité par astharo le 18-10-2010 à 15:48:34
Projet 0251 - En cours :D
n°1947097
boetnroll
Posté le 30-10-2009 à 15:38:00  profilanswer
[:drapal]
  • Les 2 RX semblent suffisants, effectivement.
  • Je pense que oui, au pire, tu peux la modder en 18W. :jap:
  • Non, car théoriquement, l'eau est à la même température en tout point. Cependant, ça reste théorique, et des tests te donneront la réponse.
  • Non. Mais je me pose la question : Le HK est en cuivre non ? Pourquoi mettre des blocks recouverts de Nickel pour les GPUs ? Pas de risque de corrosion toussa ? Question ouverte à tout le monde.. si vous avez la réponse :)
Message édité par boetnroll le 30-10-2009 à 15:38:51
n°1948336
astharo
Posté le 03-11-2009 à 16:07:15  profilanswer
Je pense pas que le CU et le Nickel fasse une mauvaise cohabitation dans les systèmes car à ma connaissance tous les WB CPU (mis à part le HK Nickel Plated - et encore je sais pas si le maze l'est aussi et non pas simplement l'extérieur) ont des bases Cu. Après je me trompe peut être.
n°1948339
juan1972
Posté le 03-11-2009 à 16:13:31  profilanswer
pourquoi tu ne mets pas les deux RX in,un sur le top et l'autre au bas,tu a plus de trois disques dur?
n°1948358
astharo
Posté le 03-11-2009 à 16:53:58  profilanswer
ben si j'avais prévu un RX240 avec seulement 3 DD, avec un mod de la tour ça aurait pu passer, mais la pour un CF de 5850 il me faut un RX360 et il passe pas en longueur :( Ca fait quand même 410mm de long xD
J'avais vu un gars qui avait glissé un MCR320 sous le boitier, entre les pieds, et profiter des deux emplacement 120 du bas plus l'aspi de l'alim pour le refroidir. Néanmoins, cela demande de faire des pieds aux pieds de la tour sinon tu appuis le rad par terre.
n°1948364
juan1972
Posté le 03-11-2009 à 17:16:27  profilanswer
pour te donner une idée de la chose
http://www.monalbum.fr/Foto-VZ4JZJIE.jpg
et un 360 passe aussi en bas,mais tout juste,j'ai la place pour un RS 360 c'est certain car j'ai mesurer
pou l'air de l'alim j'ai fais comme ça,pour ne pas qu'elle prenne l'air chaud,l'air s'échappe par l'avant
http://www.monalbum.fr/Foto-6GH7O6RQ.jpg
d'ailleurs deux RS 360 devrais te suffire,ça fais une bonne économie,80€ c'est pas négligeable
Message édité par juan1972 le 03-11-2009 à 17:29:20
n°1948640
astharo
Posté le 04-11-2009 à 14:05:43  profilanswer
Je pense pas que 2 RS360 suffisent. Partant du fait que:
- 2x 5850 s'affichent à 340W
- Core i7 860@4GHz+ frôle les 300W
- un RS360 + Push Fan@1000tpm dissipe 260W
- un RX360 + Push Fan@1000tpm dissipe 360W
Si je sais bien lire et interpréter les graphiques, je pense pas avoir le choix :( Et puis les possibilités d'évolutions sont immenses si je passe avec des Fan@1200tpm, un RX360 dissipe 500W !!!
Et puis du coup si c'est pour claquer les 80 euros dans des Fans hors de prix pour avoir un bon flux d'air + bonne pression je pense que c'est plus rentable de les dépenser dans le rad.
n°1949075
astharo
Posté le 05-11-2009 à 17:17:31  profilanswer
Tiens autre chose, avant de finaliser mon achat de matos, je voudrais savoir s'il y a une réelle différence à l'usage et en perf entre la laing DDC 10W 440l/h et la version "plus" qui consomme 18W et donne 600 l/h. Dans un circuit traversant autant d'élément que le mien j'ai un peu peur que la DDC 10W soit un peu juste.
Quand pensez vous?
Message édité par astharo le 05-11-2009 à 17:21:12
n°1949080
Cubensia
Men Sana In Corpore Sano
Posté le 05-11-2009 à 17:40:10  profilanswer
astharo a écrit :
Quand pensez vous?
Tout le temps  :pt1cable:
Sinon la 10W suffit à pousser de la flotte dans un paquet d'éléments , je n'avais qu'une 10W a mon époque full wc ( + de 7 blocs 2 rads etc.. ) et çà marchait très bien
Message édité par Cubensia le 05-11-2009 à 17:40:25
Mon Feedback - Mes Ventes - Simplexity 650D
n°1949110
juan1972
Posté le 05-11-2009 à 18:49:22  profilanswer
Quand pensez vous?
perso j'ai les deux et la DDC 18W pousse bien plus,c'est clair,d'ailleurs j'ai bien vu la différence quand j'ai refais mon montage,je me demande même si je ne vais pas refaire mes circuits en mono avec
n°1949358
t0xine
Force et honneur
Posté le 06-11-2009 à 10:05:44  profilanswer
J'adore s'te vanne... meme si tu la sors à chaque fois, elle me plait toujours autant :D
sinon +1 pour la 10w ;)
-=Mes ventes=-   -=Black & White Fractal R2=-
n°1950518
astharo
Posté le 09-11-2009 à 12:57:17  profilanswer
Bonjour à tous,
Merci pour ces réponses sur la pompe. Vu la différence de prix (8 euros) je pense que je vais prendre la version Plus MCP355.
Je me posais aussi une question de naab soudaine: dans mon circuit je fais mon retour au res par le dessus de celui-ci. Donc pour pouvoir remplir le circuit au fur et à mesure lors de première mise en eau, je vais y coller un     Bitspower Rotary Fitting "Q", afin d'avoir le retour du rad, mais aussi une arrivée pour le remplissage. Bon une fois la première mise en route, l'eau va chasser l'air du circuit, et celui-ci voudra s'échapper par le conduit de remplissage (sa seule alternative). Du coup, lors du remplissage, ne vais je pas, soit emprisonner l'air à l'intérieur et ne jamais m'en défaire, soit créer une panique dans l'entonnoir avec bulles et éclaboussures?
Une fois l'air chassé du circuit, quand j'éteins la pompe, je me demande comment l'eau va se positionner dans le circuit au niveau du retour res puisqu'il n'y a pas de continuité (il existe toujours une chambre d'air entre l'eau en retour de rad et le niveau dans le res).
Questions qui en découlent:
- n'y-a-t'il pas là une erreur de conception de ma part?
- une fois l'air chassé, et une fois la pompe éteinte, pourrais-je démonter le tuyau de remplissage et tranquillement mettre un bouchon sur le "Q" sans risquer de débordement pendant la manip au moment du changement de l'embout par le bouchon?
Je suis preneur de conseils et de retours d'expériences :)
Merci beaucoup.
Message édité par astharo le 09-11-2009 à 13:00:31
n°1950540
t0xine
Force et honneur
Posté le 09-11-2009 à 14:07:15  profilanswer
En ce qui concerne la question de "Q" (:D) je n'en sait rien, je ne connait pas cette piece.
Par contre en ce qui concerne le retour par le haut, il te faut absolument un tube qui relie l'entrée de ton réservoir (en partie haute) au LDR... car si tu as un espace d'air au retour du rad (donc en partie haute de ton réservoir si j'ai bien compris), une fois la pompe arrêté l'air va remonter dans le circuit :/ (je le sais je me suis déja fait avoir :()
Message édité par t0xine le 09-11-2009 à 14:07:58
n°1950584
astharo
Posté le 09-11-2009 à 15:53:51  profilanswer
Pour le "Q" c'est "ICI" ATTENTION contenue hautement sensible, on peut lui insérer des embouts dans ses 3 trous... :pt1cable:
Donc si j'ai bien compris il faut que je mette un bout de tuyau qui va du top du réservoir dans le liquide contenu pour avoir une continuité. Bon ok, mais du coup est-ce que les réservoirs sont prévue ou une bidouille est nécessaire pour plugger le tuyau? je viens de regarder cette MDBOX et c'est ce qu'il fait mais comprend pas comment le tuyau à l'intérieur du réservoir est connecté. Une idée?
Message édité par astharo le 09-11-2009 à 15:54:10
n°1957301
astharo
Posté le 27-11-2009 à 16:16:06  profilanswer
Bon petite maj - le CF de HD5850 sera remplacé par une "simple" HD5970 version Sapphire OC Edition - En commande - Reste à attendre la dispo sur les waterblock EK... Mouarf j'en tremble rien qu'à l'idée :D
n°1961188
astharo
Posté le 09-12-2009 à 08:55:15  profilanswer
Petite MaJ, HD5970 reçue :)
Message édité par astharo le 18-03-2010 à 16:37:01
n°2003602
astharo
Posté le 23-04-2010 à 15:10:27  profilanswer
DING "MAJ" :D
- matos reçu
- montage aircooling ok et ça dépote déjà pas mal tout en mode "stock" xD
http://images1.hiboox.com/images/1610/6ef27d5790abf6eceeff7f30fcce34f0.jpg
Ensuite quelques photos en vrac du matériel pc + water (désolé la qualité est assez disparate...)
L'EK FC5970
http://images1.hiboox.com/images/1610/2a41f43a0946838c6d8b31d8b95f19bc.jpg
http://images1.hiboox.com/images/1610/40dd56479bd5219c4b8293a58fbbc8b7.jpg
http://images1.hiboox.com/images/1610/8a6ac78082f7b6a7cec9b028520986b4.jpg
La CM:
http://images1.hiboox.com/images/1610/406ed2ddfabab183149510faab83fc2c.jpg
http://images1.hiboox.com/images/1610/5ea59c6f25150cd4c619c600b2776241.jpg
http://images1.hiboox.com/images/1610/87aee199da9a296f97733e8656b9aad1.jpg
La RAM:
http://images1.hiboox.com/images/1610/9d11ff3a78a06df891eee09fb9fcd1ad.jpg
Le HK LT que tout le monde connait :)
http://images1.hiboox.com/images/1610/751cd91ddee799617aa6f90f6d23985e.jpg
Le top Laing Watercool LT qu'on voit pas souvent:
http://images1.hiboox.com/images/1610/7969ac7e6656d48a768e567ed1740e9a.jpg
La tour désossée:
http://images1.hiboox.com/images/1610/e3fa79f4f6b56fe89d885d6465b394be.jpg
http://images1.hiboox.com/images/1610/2bff8f8bae4e4d51b3738d679c0688c2.jpg
Vrac:
http://images1.hiboox.com/images/1610/436640c1ecc8b585b1e6d1418a0e9d35.jpg
http://images1.hiboox.com/images/1610/9588be6456d293d7b2399fd6ba12d647.jpg
PA140.3:
http://images1.hiboox.com/images/1610/7bca5f95b88175a620adae17ccd1b81f.jpg
http://images1.hiboox.com/images/1610/49cf6fb6b14716ae52f8a3f0ffb3c751.jpg
Test montage PA140.3 "so tight! ":
http://images1.hiboox.com/images/1610/1cc6176a9cdbd19ac065bbdf5a299d91.jpg
http://images1.hiboox.com/images/1610/0a9988af7a741ac2738b776279123aaa.jpg
http://images1.hiboox.com/images/1610/9fef6baa473d121b11c7e3bb244c8f3d.jpg
http://images1.hiboox.com/images/1610/7269ef123f37f5c6ba07f61a9e6d0773.jpg
http://images1.hiboox.com/images/1610/2e8431484fa1e0d033f3e2f725abe5c7.jpg
http://images1.hiboox.com/images/1610/761dfc6d8ac3051dfb18cb4f879ab4be.jpg
Et pour finir la "scotch de peintre protection avant drémélisation xD":
http://images1.hiboox.com/images/1610/d946c1dd70564d2818f308149c39c7f3.jpg
Voilà d'autres choses à venir semaine prochaine je pense  :hello:
n°2003606
crev360
1155 Inside :D
Posté le 23-04-2010 à 15:28:45  profilanswer
C'est beau tout sa, mais sa gache tout le reserve atx :(
Achats / Ventes
n°2003608
astharo
Posté le 23-04-2010 à 15:36:35  profilanswer
NO Stress! Ce n'est pas un montage en reverse :) Là c'est "à l'envers" parce que je n'ai pas vissé le rad. j'ai juste présenté pour savoir si j'avais bien calculé au niveau espace et autre ^^"
Message édité par astharo le 23-04-2010 à 15:36:56
n°2003627
crev360
1155 Inside :D
Posté le 23-04-2010 à 16:29:42  profilanswer
ah :D j'ai eu peur^^^
j'ai hate de voir la suite!
Achats / Ventes
n°2004337
astharo
Posté le 26-04-2010 à 13:25:50  profilanswer
Pffiou! découpe dremel fini ce WE. Mon dieu que c'est long! 2h30 pour faire la découpe + passage du papier ponce pour ébavurer...et 17 suicides dans ma résidence à force d'entendre bzzzz, grooooiiinnnnn, biiizz gruuuiinnnnnn pendant tout ce temps xD
photos à venir ;)
n°2004340
juan1972
Posté le 26-04-2010 à 13:49:23  profilanswer
et pour l'autre rad,tu le pose ou?
Achats/V€nt€s / G€€k Room by Juan
n°2004355
astharo
Posté le 26-04-2010 à 16:39:37  profilanswer
L'autre je vais le poser en bas de la tour, à côté de l'alim dans l'emplacement 120mm déjà prévu d'origine. En push ou push/pull ça dépendra de mon humeur :)
EDIT: En cherchant des vis noires pour le montage de mon PA140.3 je viens de voir que Chilled PC faisait du plaquage sur les waterblock. Aller, gogo le LT en Nickel plated  :love:
Message édité par astharo le 26-04-2010 à 16:50:29
n°2004363
juan1972
Posté le 26-04-2010 à 17:18:27  profilanswer
comme j'ai fais alors
n°2004496
astharo
Posté le 27-04-2010 à 08:08:51  profilanswer
Oui obligé, le PA140.3 est tellement épais que ça passe pas dans l'emplacement 120mm à l'arrière de la tour. Mais je réfléchis à d'autres possibilités... ;)
n°2004761
widowsorro​w2
Posté le 27-04-2010 à 23:13:18  profilanswer
drap
n°2004831
astharo
Posté le 28-04-2010 à 13:17:45  profilanswer
Merci :)
Voici les photos promises de la mise à jour après découpe:
http://images1.hiboox.com/images/1710/fb5cfae02b27d5dd8b17823ad65614fc.jpg
http://images1.hiboox.com/images/1710/ffa82570659f4e175a4b167293405a3c.jpg
http://images1.hiboox.com/images/1710/5d446c1480b5f390d12c1fc5909f2f60.jpg
http://images1.hiboox.com/images/1710/a49d34ea2c5c230a049b9aed7f952fba.jpghttp://images1.hiboox.com/images/1710/ac893ed5113d41257dd1c755f7a631a3.jpg
Et voici le premier essai de montage du RS120 + vidange:
http://images1.hiboox.com/images/1710/fd975bab8430ce715a5bacc3a8318251.jpg
http://images1.hiboox.com/images/1710/577871d929c0d698828bb619fbb9b716.jpg
http://images1.hiboox.com/images/1710/2c5e05b54cbcda1a9c9e76540d6f09b0.jpg
http://images1.hiboox.com/images/1710/0085c900be04b1d2b056da4c427e69ff.jpg
Voilà pour aujourd'hui  :hello:
Message édité par astharo le 28-04-2010 à 13:24:10
n°2007198
astharo
Posté le 05-05-2010 à 13:42:09  profilanswer
Salut à tous,
Ici une petite maj de mon taf de ce WE. Découpe de la backplate de la CM sur le boitier + montage et photo shoot du block EK-FC5970 sur ma Sapphire 5970 OC :D
http://images1.hiboox.com/images/1810/d4fa394cb6c2425eb5704d69556246e4.jpg
Il manque le "U channel" pour enrober la découpe :)
http://images1.hiboox.com/images/1810/a98cf0a199eb6d39b5147df595e7c47b.jpg
Et maintenant le plat de résistance:
- on rassemble les éléments:
http://images1.hiboox.com/images/1810/e383fef2245e35aaa0dc51febfb9c84a.jpg
- on démonte le tout:
http://images1.hiboox.com/images/1810/f45e41bc67a9dca48c4914a33cc9ef68.jpg
http://images1.hiboox.com/images/1810/6cb66ba9d909efffce07c0b555e304eb.jpg
- on pose les pad thermiques:
http://images1.hiboox.com/images/1810/7071ede5fc6c79d2f36d1c0477cc3b03.jpg
http://images1.hiboox.com/images/1810/5a0afa2dc8310a71b3d11c98fb8fa7fd.jpg
http://images1.hiboox.com/images/1810/f127fdc2111d3a0d95dbaf7e7ba95367.jpg
- le bloc FC5970:
http://images1.hiboox.com/images/1810/1065524c44b0b390fbff65b9597746a9.jpg
http://images1.hiboox.com/images/1810/ab69bb8183b7d2b4abdd85a6a3b34bfc.jpg
http://images1.hiboox.com/images/1810/3b7118c86ad2b42793bb11feb2a03c63.jpg
- on assemble le tout:
http://images1.hiboox.com/images/1810/3057e4af11fe74284b682a4603e14c54.jpg
- ajout de la backplate EK et le tour est joué :sol: :
http://images1.hiboox.com/images/1810/14736ea0f5d10bad6a12aa78e7e202e7.jpg
** Photo Shoot **
http://images1.hiboox.com/images/1810/9a0d60477bbabfd7e3c817a346520734.jpg
http://images1.hiboox.com/images/1810/2958b322880ca2fef7da37ef2b2a1334.jpg
http://images1.hiboox.com/images/1810/c76eb68d94c4b396aa98b800482890f2.jpg
http://images1.hiboox.com/images/1810/f36261e7f78e9594d731d69da6d595ee.jpg
http://images1.hiboox.com/images/1810/f60942aa6f615584926ab12084afa282.jpg
http://images1.hiboox.com/images/1810/c13c27d58bcd0fc08659eb309c421f0c.jpg
http://images1.hiboox.com/images/1810/c75ad17fba7b7ecb684af828ab5d18fe.jpg
http://images1.hiboox.com/images/1810/142b6adffff8abe5cc8007aa13140797.jpg
http://images1.hiboox.com/images/1810/0a8109827afe589fe59e7dfcc7331d36.jpg
C'est fini - j'espère que vous avez apprécié. @ bientôt :hello:
Message édité par astharo le 06-05-2010 à 14:28:12
n°2007241
WyRm92
Posté le 05-05-2010 à 16:00:32  profilanswer
Un ami à moi veux faire la même chose, dans un Cosmos S mais sans le Water  :pfff:
J'ai donc vraiment hâte de voir la suite  :bounce:
Topic vente
n°2007247
belkav
Posté le 05-05-2010 à 16:27:34  profilanswer
Les photos sont bien faites
Ma Chaine YouTube
n°2007771
astharo
Posté le 07-05-2010 à 12:09:25  profilanswer
Salut!
Merci pour vos commentaires sympas :)
Voici le "leaked photos shoot" des mises à jour à venir... ;) Enjoy :hello:
http://images1.hiboox.com/images/1810/97ffc58228ae54d018f2d4554f4c6e84.jpg
http://images1.hiboox.com/images/1810/027931774eab5751b212d79e47f56480.jpg
http://images1.hiboox.com/images/1810/8bd991f316d2ca6b54c9285a2a60d496.jpg
http://images1.hiboox.com/images/1810/3e22c6665216657286883a160b6b7f7b.jpg
http://images1.hiboox.com/images/1810/066ad22d882d3c447fdec47e849f151e.jpg
http://images1.hiboox.com/images/1810/69db18c2eaf5165946e4275494b4ae55.jpg
http://images1.hiboox.com/images/1810/1480adefd6aea223aa22ec1169bb6611.jpg
http://images1.hiboox.com/images/1810/56b683a75d87d3f2981c21d5b6de6e77.jpg
Message édité par astharo le 07-05-2010 à 12:10:27
n°2007784
crev360
1155 Inside :D
Posté le 07-05-2010 à 13:36:01  profilanswer
Whaou, énorme la 5970 :o
Bien le montage du wb :D
avec de jolie photo le top!
Achats / Ventes
n°2015922
astharo
Posté le 01-06-2010 à 13:59:04  profilanswer
Petite mise à jour:
- Mon HK 3.0 LT est de retour avec sa nouvelle robe "nickel plated"
- Le montage avance doucement mais sûrement, le RS240 a trouvé sa place
Et pour finir je viens de valider la commande pour le sleeving chez MDPC :)
Voilà, les photos sont à venir sous peu :D
n°2016297
Posté le 02-06-2010 à 14:40:20  answer
J'adore !! Surtout la HD5970 !
La couleur du boitier va trop bien avec la carte mère  :love:  :love:
n°2017498
astharo
Posté le 07-06-2010 à 12:04:55  profilanswer
Merci beaucoup  :jap: - vraiment heureux que vous preniez aussi plaisir à suivre ce mod :D
Et pour le plaisir, ma nouvelle galerie de photo sur les composants (toujours en cours de réa pour l'ensemble) ^^
Galerie complète sur LyS CoMPuTeR pARTs
n°2017534
astharo
Posté le 07-06-2010 à 15:05:20  profilanswer
Allez pour les flémmards qui veulent pas ouvrir un autre onglet, voici une sélection :D - EnJoY
http://images1.hiboox.com/images/2310/291bc2729301ddbc1805c1d1c460260f.jpg
http://images1.hiboox.com/images/2310/bf48ad719b3ea2ba94aea900e50608e4.jpg
http://images1.hiboox.com/images/2310/49f6215de39048d22f2d4f80fc2149c7.jpg
http://images1.hiboox.com/images/2310/6215582e1dbe646060e31d43a71e2379.jpg
http://images1.hiboox.com/images/2310/f6df2b470742cf20f56f11317f02dd6f.jpg
Message édité par astharo le 09-06-2010 à 16:50:25
n°2017535
snake_eyes​_bfm
○○○○ϾϿ
Posté le 07-06-2010 à 15:07:13  profilanswer
jolie tout ça bon courage  :)
J'espère que tu n'aura pas de problème de freeze avec la 5970 car bcp en souffre apparemment!!
Message édité par snake_eyes_bfm le 07-06-2010 à 15:07:32
n°2017571
khakhaone
Posté le 07-06-2010 à 17:22:18  profilanswer
Dommage que les photos soit trop grande
n°2017572
Posté le 07-06-2010 à 17:33:08  answer
J'adore !! Trop beau  :love:  :love:
n°2018120
astharo
Posté le 09-06-2010 à 17:13:40  profilanswer
Petite maj: le gainage MDPC est arrivé! :love:
Les photos bientôt :D
@KhaKhaOne: les images seront dimensionnées correctement dorénavant :)
 Page :   1  2  3
Page Précédente
[Worklog]Cosmos-S Black and White "News photos !!!"[▀▄▀▄▀rkBlg] CM Storm SCOUT watercooled - Photos postées
[MOD mini-ITX]Lian-Li PC-Q07+WC(défi accomplis!!!, photos page 2)vos réalisations home made (poster vos photos)
[WorkLog] Métisse[MOD] Antec Nine Hundred by war0x. Gros Upgrade! Photos!!
Premier Watercooling - maj - photos[Projet] Mountain Mods UFO H20cooled [MAJ 11/09/09] Photos+Screens
Plus de sujets relatifs à : [WorkLog] "Numéro 0251" - CoSMoS N3v3R 3NDZZ
