4171 connectés
  Water & Xtreme Cooling
  [Topic Unique] Waterblock 4090 RTX
n°2584068
hellion666
Posté le 23-01-2023 à 16:06:39  profilanswer
liste WB 4090RTX, dispo ou à venir.
Topic reddit dédié : https://www.reddit.com/r/watercooli [...] readsheet/
table dédié : https://docs.google.com/spreadsheet [...] edit#gid=0
Alphacool propose un moteur de recherche pour les PCB des cartes graphiques : https://www.hwconfig.com/waterblock-finder
Note : Ajouter des liens vers les illustrations plus tard
EK store :
https://www.ekwb.com/shop/quantum/g [...] series-wb/
https://www.ekwb.com/configurator/
- EK-Quantum Vector² FE RTX 4090 D-RGB - Nickel + Plexi => 241
- EK-Quantum Vector² Master RTX 4090 D-RGB - Nickel + Plexi => 267 => Aorus GeForce RTX 4090 Master Gigabyte GeForce RTX 4090 GAMING Gigabyte GeForce RTX 4090 GAMING OC
- EK-Quantum Vector² Strix/TUF RTX 4090 D-RGB - Nickel + Plexi => 267 => ROG Strix and ASUS TUF GeForce RTX 4090
- EK-Quantum Vector² Trio RTX 4090 D-RGB - Nickel + Plexi => 267 => MSI Trio and MSI SUPRIM GeForce RTX 4090
- EK-Quantum Vector² AMP/Trinity RTX 4090 D-RGB - Nickel + Plexi => 267 => Zotac AMP Extreme AIRO and Trinity RTX 4090
alphacool :
https://www.aquatuning.fr/search?sSearch=4090
Alphacool Core Geforce RTX 4090 Founders Edition with Backplate => 201 => Nvidia GeForce RTX 4090 Founders Edition
-Alphacool Core Geforce RTX 4090 Reference Design with Backplate => 201 =>
  • INNO3D GeForce RTX 4090 X3 OC, 24GB GDDR6X (N40903-246XX-18332989)
  • INNO3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X (C40903-246XX-1833VA47)
  • INNO3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X (C4090-246XX-1833FB)
  • INNO3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X (C4090-246XX-18330005)
  • PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1-O)
  • PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan, 24GB GDDR6X (VCG409024TFXXPB1)
  • KFA2 GeForce RTX 4090 SG (1-Click OC), 24GB GDDR6X (49NXM5MD6DSK)
- Alphacool Eisblock Aurora Geforce RTX 4090 Strix + TUF with Backplate => 161 =>
  • ASUS TUF Gaming GeForce RTX 4090 OC, TUF-RTX4090-O24G-GAMING, 24GB GDDR6X (90YV0IE0-M0NA00)
  • ASUS TUF Gaming GeForce RTX 4090, TUF-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0IE1-M0NA00)
  • ASUS ROG Strix GeForce RTX 4090 OC, ROG-STRIX-RTX4090-O24G-GAMING, 24GB GDDR6X (90YV0ID0-M0NA00)
  • ASUS ROG Strix GeForce RTX 4090, ROG-STRIX-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0ID1-M0NA00)
- Alphacool Eisblock Aurora Geforce RTX 4090 Aorus Master - Gaming with Backplate => 161 =>
  • GIGABYTE GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
  • GIGABYTE AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Alphacool Eisblock Aurora Geforce RTX 4090 GameRock + Phantom with Backplate => 161 =>
  • Palit GeForce RTX 4090 GameRock, 24GB GDDR6X (NED4090019SB-1020G)
  • Palit GeForce RTX 4090 GameRock OC, 24GB GDDR6X (NED4090S19SB-1020G)
  • Gainward GeForce RTX 4090 Phantom, 24GB GDDR6X
  • Gainward GeForce RTX 4090 Phantom GS, 24GB GDDR6X (3413)
- Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Suprim avec Backplate => 161 =>
  • MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X, HDMI, 3x DP
  • MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X, HDMI, 3x DP
  • MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X, HDMI, 3x DP
- Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Reference mit Backplate => 161 =>
  • Nvidia Geforce RTX 4090 Reference Design
  • INNO3D GeForce RTX 4090 X3 OC, 24GB GDDR6X, HDMI, 3x DP (N40903-246XX-18332989)
  • INNO3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X, HDMI, 3x DP (C40903-246XX-1833VA47)
  • INNO3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X, HDMI, 3x DP (C4090-246XX-1833FB)
  • INNO3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X, HDMI, 3x DP (C4090-246XX-18330005)
  • PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Overclocked Triple Fan, 24GB GDDR6X, HDMI, 3x DP (VCG409024TFXXPB1-O) (*)
  • PNY GeForce RTX 4090 XLR8 Gaming Verto Epic-X RGB Triple Fan, 24GB GDDR6X, HDMI, 3x DP (VCG409024TFXXPB1) (*)
  • KFA2 GeForce RTX 4090 SG (1-Click OC), 24GB GDDR6X, HDMI, 3x DP (49NXM5MD6DSK)
(* The cooler is compatible with the GPU, but the rear part of the PCB is not covered. This has no negative effect on the cooling performance!)
Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Founders Edition avec Backplate => 161 => Nvidia GeForce RTX 4090 Founders Edition
Optimus USA
https://optimuspc.com/products/sign [...] waterblock
SIGNATURE 4090 STRIX/TUF GPU WATERBLOCK => 399dollars => ASUS Strix 4090 OC Edition
- ASUS Strix 4090
- ASUS TUF 4090 OC Edition
- ASUS TUF 4090
Watercool.de :
https://shop.watercool.de/GPU-Kuehler
- HEATKILLER V PRO FOR RTX 4090 ASUS STRIX/TUF => à définir
- HEATKILLER V PRO FOR RTX 4090 FE - ACRYL NI ARGB => 249 => NVIDIA RTX 4090 Founders Edition
- HEATKILLER V PRO FOR RTX 4090 FE - ACRYL NI-BL ARGB => 249 => NVIDIA RTX 4090 Founders Edition
Bykski
https://www.bykski.us/
- Bykski Full Coverage GPU Water Block and Backplate for Zotac Gaming RTX 4090 Series (N-ST4090TQ-X-V2) => 189dollars =>
- Bykski Full Coverage GPU Water Block and Backplate for Gigabyte AORUS GeForce RTX 4090 Master 24G (N-GV4090AORUS-X) => 194dollars
- Bykski Full Coverage GPU Water Block and Backplate for Gigabyte RTX 4090 Windforce 24G (N-GV4090WF-X) => 194dollars
- Bykski Full Coverage GPU Water Block and Backplate for ASUS ROG Strix GeForce RTX 4090 (N-AS4090STRIX-X) => 194dollars
- Bykski Full Coverage GPU Water Block and Backplate for MSI GeForce RTX 4090 Gaming X Trio (N-MS4090TRIO-X) => 194dollars
- Bykski Full Coverage GPU Water Block and Backplate for nVidia GeForce RTX 4090 AIC Reference (N-RTX4090H-X) => 194dollars
Barrowch : rien
Bitspower:
https://shop.bitspower.com/index.ph [...] 67_102_405
- Bitspower Orion VGA Water Block for ASUS ROG Strix and TUF Gaming GeForce RTX 4090 series => 7950TWD+taxes => ROG Strix and ASUS TUF GeForce RTX 4090
- Bitspower Orion VGA Water Block for MSI GeForce RTX 4090 SUPRIM and GAMING series => 8250 TWD+taxes => GeForce RTX 4090 SUPRIM series GeForce RTX 4090 GAMING series
- Bitspower Orion VGA Water Block for GeForce RTX 4090 Founders Edition => 6750TWD+taxes=>  GeForce RTX 4090 Founders Edition
Phanteks
https://www.phanteks.com/Glacier-GPU.html
Achat europe : https://www.caseking.de/wasserkuehl [...] &sSort=103
- GLACIER G40 MSI GPU BLOCK FOR SUPRIM AND GAMING 4090 => 269
- GLACIER G40 GIGABYTE GPU BLOCK FOR AORUS MASTER AND GAMING 4090 => 249
- GLACIER G40 ASUS GPU BLOCK FOR ASUS ROG STRIX / TUF => 249
Corsair
https://www.corsair.com/fr/fr/Cat%C [...] tatingText
- Hydro X Series XG7 RGB 40-SERIES GPU Water Block (4090 SUPRIM/TRIO) => 239
- Waterblock pour carte graphique Hydro X Series XG7 RGB 40-SERIES (4090 FE) => 239
- Waterblock pour carte graphique Hydro X Series XG7 RGB 40-SERIES (4090 STRIX/TUF) => 239
Hybrid cooling Mod
https://hybridcooling-modding.fr/ho [...] age_nickel
- Waterblock RTX 4090 Founders Edition => 143
Message édité par hellion666 le 06-02-2023 à 11:19:28
n°2584069
hellion666
Posté le 23-01-2023 à 16:15:16  profilanswer
Focus sur les Waterblock pour Asus 4090 RTX Strix et TUF
Message édité par hellion666 le 23-01-2023 à 16:25:10
n°2584072
hellion666
Posté le 23-01-2023 à 16:25:44  profilanswer
Focus sur les Waterblock pour MSI 4090 RTX Triox et Suprim (X)
Note: je referais les illustration des que j ai letemps. la ce sont les liens vers les sites constructeurs.
  • EKWB :
https://www.ekwb.com/shop/media/catalog/product/cache/1/thumbnail/1600x1067/17f82f742ffe127f42dca9de82fb58b1/e/k/ek-quantum-vector2-trio-rtx-4090-d-rgb-nickel-plexi-front.jpeg
  • Alphacool :
https://www.aquatuning.fr/media/image/6e/92/3d/Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_4090_Suprim_mit_Backplate_1023358_02_600x600.jpg
  • Bykski:
https://cdn.shopify.com/s/files/1/0069/8102/5892/products/206054ab-9029-4525-8d18-20d7d54b58f2.jpg?v=1670445352
  • Bitspower :
https://shop.bitspower.com/image/cache/Newegg/BP-VG4090MT/BP-VG4090MT--4712914790019-PT03-1024x768.jpg
  • Phanteks :
https://static3.caseking.de/media/image/thumbnail/wach-804_wach_804_04_800x800.jpg
  • Corsair :
https://www.corsair.com/medias/sys_master/images/images/hfb/hf4/10326827139102/CX-9020021-WW/Gallery/XG7_RGB_40_SERIES_SUPRIM_TRIO_GPU_4090_01/-CX-9020021-WW-Gallery-XG7-RGB-40-SERIES-SUPRIM-TRIO-GPU-4090-01.png_1200Wx1200H
Message édité par hellion666 le 23-01-2023 à 16:38:46
n°2584110
hellion666
Posté le 24-01-2023 à 08:27:25  profilanswer
Focus sur les Waterblock pour 4090 RTX founder edition
Waterblock Zotac RTX 2070 Super MiniWC pour 13900k & 4090
Erreur 97 Asus - Watercooling RTX 3090Remplacement PAD Ram RTX 3090 Ti
Waterblock maudit et court-circuit, le topic de la poisseRecherche d'un vieux Waterblock Motherboard
ASUS ROG STRIX RTX 3080 OC V2 LHR changement de pads thermiques[ topic unique ] watercooling extreme exterieur
Conseil pour Waterblock
Plus de sujets relatifs à : [Topic Unique] Waterblock 4090 RTX
