3417 connectés
  CPU
  [bsod whea - Overclock ?] comment résoudre ce soucis
n°2482474
NaeNae
Posté le 26-11-2017 à 20:34:00  profilanswer
Bonsoir à tous,
j'ai un soucis sur ma nouvelle configuration :
[spoiler]Summary
  Operating System
   Windows 10 Professionnel 64-bit
  CPU
   Intel Core i7 7820X @ 3.60GHz 31 °C
   Skylake-X 14nm Technology
  RAM
   64,0 Go Unknown @ 1066MHz (15-15-15-36)
  Motherboard
   Gigabyte Technology Co. Ltd. X299 AORUS Gaming 7 35 °C
  Graphics
   ZOWIE XL LCD (1920x1080@240Hz)
   C49HG9x (3840x1080@120Hz)
   3071MB NVIDIA GeForce GTX 1080 Ti (Gigabyte) 55 °C
  Storage
   953GB Samsung SSD 960 PRO 1TB (Unknown)
   3726GB Seagate ST4000VN008-2DR166 (SATA) 32 °C
   931GB TOSHIBA External USB 3.0 USB Device (USB (SATA)) 32 °C
   58GB UFD 3.0 Silicon-Power64G USB Device (USB)
  Optical Drives
   No optical disk drives detected
  Audio
   Realtek High Definition Audio
Operating System
 Computer type: Desktop
 Installation Date: 19/11/2017 18:56:06
 Serial Number: R3HB7-X6HMH-F48J3-8XJVP-9QBP9
  Windows Security Center
   User Account Control (UAC) Enabled
   Notify level 2 - Default
   Firewall Enabled
  Windows Update
   AutoUpdate Not configured
  Windows Defender
   Windows Defender Enabled
  Antivirus
   Antivirus Enabled
   Display Name Windows Defender
   Virus Signature Database Up to date
  .NET Frameworks installed
   v4.7 Full
   v4.7 Client
   v3.5 SP1
   v3.0 SP2
   v2.0 SP2
  Internet Explorer
   Version 11.64.16299.0
  PowerShell
   Version 5.1.16299.15
  Environment Variables
   USERPROFILE C:\Users\alexa
   SystemRoot C:\WINDOWS
    User Variables
     OneDrive C:\Users\alexa\OneDrive
     Path C:\Users\alexa\AppData\Local\Microsoft\WindowsApps
     TEMP C:\Users\alexa\AppData\Local\Temp
     TMP C:\Users\alexa\AppData\Local\Temp
    Machine Variables
     ComSpec C:\WINDOWS\system32\cmd.exe
     NUMBER_OF_PROCESSORS 16
     OS Windows_NT
     Path C:\Program Files (x86)\Intel\iCLS Client\
     C:\Program Files\Intel\iCLS Client\
     C:\Windows\system32
     C:\Windows
     C:\Windows\System32\Wbem
     C:\Windows\System32\WindowsPowerShell\v1.0\
     C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
     C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL
     C:\Program Files\Intel\Intel Management Engine Components\DAL
     C:\Program Files (x86)\Intel\Intel Management Engine Components\IPT
     C:\Program Files\Intel\Intel Management Engine Components\IPT
     C:\WINDOWS\system32
     C:\WINDOWS
     C:\WINDOWS\System32\Wbem
     C:\WINDOWS\System32\WindowsPowerShell\v1.0\
     PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
     PROCESSOR_ARCHITECTURE AMD64
     PROCESSOR_IDENTIFIER Intel64 Family 6 Model 85 Stepping 4, GenuineIntel
     PROCESSOR_LEVEL 6
     PROCESSOR_REVISION 5504
     PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
     C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
     C:\Program Files\Intel\Wired Networking\
     TEMP C:\WINDOWS\TEMP
     TMP C:\WINDOWS\TEMP
     USERNAME SYSTEM
     windir C:\WINDOWS
  Power Profile
   Active power scheme Utilisation normale
   Hibernation Enabled
   Turn Off Monitor after: (On AC Power) 10 min
   Turn Off Hard Disk after: (On AC Power) 20 min
   Suspend after: (On AC Power) 30 min
   Screen saver Disabled
  Uptime
    Current Session
     Current Time 26/11/2017 20:22:58
     Current Uptime 398 sec (0 d, 00 h, 06 m, 38 s)
     Last Boot Time 26/11/2017 20:16:20
  Services
   Running Accès aux données utilisateur_4a0b7
   Running Alimentation
   Running Appel de procédure distante (RPC)
   Running Assistance IP
   Running Assistance NetBIOS sur TCP/IP
   Running Assistant Connexion avec un compte Microsoft
   Running AtherosSvc
   Running Audio Windows
   Running Client de stratégie de groupe
   Running Client de suivi de lien distribué
   Running Client DHCP
   Running Client DNS
   Running Configuration automatique des périphériques connectés au réseau
   Running Connaissance des emplacements réseau
   Running Consommation des données
   Running Conteneur Microsoft Passport
   Running CoreMessaging
   Running Données de contacts_4a0b7
   Running Découverte SSDP
   Running Détection matériel noyau
   Running Expériences des utilisateurs connectés et télémétrie
   Running Fournisseur du Groupement résidentiel
   Running Gestionnaire d'authentification Xbox Live
   Running Gestionnaire de comptes de sécurité
   Running Gestionnaire de comptes web
   Running Gestionnaire de session locale
   Running Gestionnaire des connexions d’accès à distance
   Running Gestionnaire des connexions Windows
   Running Gestionnaire des utilisateurs
   Running Gestionnaire d’informations d’identification
   Running Gestionnaires des paiements et des éléments sécurisés NFC
   Running Générateur de points de terminaison du service Audio Windows
   Running Hôte du fournisseur de découverte de fonctions
   Running Hôte système de diagnostics
   Running Informations d’application
   Running Infrastructure de gestion Windows
   Running Intel PROSet Monitoring Service
   Running Isolation de clé CNG
   Running Journal d’événements Windows
   Running Killer Network Service
   Running Lanceur de processus serveur DCOM
   Running Mappeur de point de terminaison RPC
   Running Microsoft Passport
   Running Moteur de filtrage de base
   Running NVIDIA Display Container LS
   Running NVIDIA LocalSystem Container
   Running NVIDIA Telemetry Container
   Running Pare-feu Windows Defender
   Running Planificateur de tâches
   Running Plug-and-Play
   Running Publication des ressources de découverte de fonctions
   Running Qualcomm Atheros WLAN Driver Service
   Running Serveur
   Running Serveur de modèles de données de vignette
   Running Service antivirus Windows Defender
   Running Service Broker des événements système
   Running Service Broker pour les connexions réseau
   Running Service Broker pour les événements horaires
   Running Service Centre de sécurité Windows Defender
   Running Service de cache de police Windows
   Running Service de configuration automatique WLAN
   Running Service de découverte automatique de Proxy Web pour les services HTTP Windows
   Running Service de déploiement AppX (AppXSVC)
   Running Service de géolocalisation
   Running Service de l’Assistant Compatibilité des programmes
   Running Service de notification d’événements système
   Running Service de plateforme des appareils connectés
   Running Service de prise en charge Bluetooth
   Running Service de profil utilisateur
   Running Service de rapport d’erreurs Windows
   Running Service de stratégie de diagnostic
   Running Service du clavier tactile et du volet d’écriture manuscrite
   Running Service du périphérique d’interface utilisateur
   Running Service du système de notifications Push Windows
   Running Service d’association de périphérique
   Running Service d’infrastructure des tâches en arrière-plan
   Running Service hôte WDIServiceHost
   Running Service Inspection du réseau de l’antivirus Windows Defender
   Running Service Interface du magasin réseau
   Running Service Liste des réseaux
   Running Service pour utilisateur de plateforme d’appareils connectés_4a0b7
   Running Service State Repository (StateRepository)
   Running Service utilisateur de notifications Push Windows_4a0b7
   Running Service Énumérateur d’appareil mobile
   Running Services de chiffrement
   Running Service SSTP (Secure Socket Tunneling Protocol)
   Running Spouleur d’impression
   Running Station de travail
   Running Steam Client Service
   Running Stockage des données utilisateur_4a0b7
   Running Superfetch
   Running Système d’événement COM+
   Running Thèmes
   Running Windows Search
   Running Windows Update
   Stopped Acquisition d’image Windows (WIA)
   Stopped Agent de stratégie IPsec
   Stopped Application système COM+
   Stopped Assistant Connectivité réseau
   Stopped Authentification naturelle
   Stopped BattlEye Service
   Stopped BranchCache
   Stopped Cache de police de Windows Presentation Foundation 3.0.0.0
   Stopped Carte de performance WMI
   Stopped Carte à puce
   Stopped Centre de sécurité
   Stopped Cliché instantané des volumes
   Stopped Collecteur d’événements de Windows
   Stopped Configuration automatique de réseau câblé
   Stopped Configuration des services Bureau à distance
   Stopped Connexions réseau
   Stopped Coordinateur de transactions distribuées
   Stopped Diagnostic Execution Service
   Stopped Disque virtuel
   Stopped dmwappushsvc
   Stopped Dossiers de travail
   Stopped Détection de services interactifs
   Stopped EasyAntiCheat
   Stopped Explorateur d’ordinateurs
   Stopped Expérience audio-vidéo haute qualité Windows
   Stopped Fichiers hors connexion
   Stopped Flux d’appareils_4a0b7
   Stopped Fournisseur de cliché instantané de logiciel Microsoft
   Stopped Gestion des niveaux de stockage
   Stopped Gestion d’applications
   Stopped Gestion à distance de Windows (Gestion WSM)
   Stopped Gestionnaire des cartes téléchargées
   Stopped Gestionnaire des connexions automatiques d’accès à distance
   Stopped Gestionnaire d’identité réseau homologue
   Stopped Gestionnaire d’installation de périphérique
   Stopped GraphicsPerfSvc
   Stopped Groupement de mise en réseau de pairs
   Stopped Hôte de DLL de compteur de performance
   Stopped Hôte de périphérique UPnP
   Stopped Hôte de synchronisation_4a0b7
   Stopped Identité de l’application
   Stopped Intel Capability Licensing Service TCP IP Interface
   Stopped Intel Dynamic Application Loader Host Interface Service
   Stopped Intel Management and Security Application Local Management Service
   Stopped Intel Optane Memory Service
   Stopped Intel Rapid Storage Technology
   Stopped Intel TPM Provisioning Service
   Stopped Interface de services d’invité Hyper-V
   Stopped Interruption SNMP
   Stopped Jeu sauvegardé sur Xbox Live
   Stopped Journaux & alertes de performance
   Stopped Localisateur d’appels de procédure distante (RPC)
   Stopped Mappage de découverte de topologie de la couche de liaison
   Stopped MessagingService_4a0b7
   Stopped Microsoft App-V Client
   Stopped Mode incorporé
   Stopped Modules de génération de clés IKE et AuthIP
   Stopped Netlogon
   Stopped NVIDIA NetworkService Container
   Stopped Optimisation de livraison
   Stopped Optimiser les lecteurs
   Stopped Ouverture de session secondaire
   Stopped Partage de connexion Internet (ICS)
   Stopped Printer Extensions and Notifications
   Stopped PrintWorkflow_4a0b7
   Stopped Prise en charge de l’application Rapports et solutions aux problèmes du Panneau de configuration
   Stopped Programme de mise à jour automatique du fuseau horaire
   Stopped Programme d’installation ActiveX (AxInstSV)
   Stopped Programme d’installation pour les modules Windows
   Stopped Propagation du certificat
   Stopped Protection logicielle
   Stopped Protocole EAP (Extensible Authentication Protocol)
   Stopped Protocole PNRP
   Stopped Préparation des applications
   Stopped Redirecteur de port du mode utilisateur des services Bureau à distance
   Stopped Registre à distance
   Stopped Requête du service VSS Microsoft Hyper-V
   Stopped Routage et accès distant
   Stopped Sauvegarde Windows
   Stopped Serveur de trame de la Caméra Windows
   Stopped Serveur Gestionnaire de licences Windows
   Stopped Service Arrêt de l’invité Microsoft Hyper-V
   Stopped Service AssignedAccessManager
   Stopped Service Broker de découverte en arrière-plan DevQuery
   Stopped Service Collecteur standard du concentrateur de diagnostic Microsoft
   Stopped Service Configuration du réseau
   Stopped Service d'hôte HV
   Stopped Service d'inscription de la gestion des périphériques
   Stopped Service d'installation du Windows Store
   Stopped Service de biométrie Windows
   Stopped Service de capteur
   Stopped Service de chiffrement de lecteur BitLocker
   Stopped Service de configuration automatique WWAN
   Stopped Service de configuration de conversion IP
   Stopped Service de données spatiales
   Stopped Service de démo du magasin
   Stopped Service de gestion des applications d'entreprise
   Stopped Service de gestion radio
   Stopped Service de la passerelle de la couche Application
   Stopped Service de licences de client (ClipSVC)
   Stopped Service de l’Assistant de profil local
   Stopped Service de mise en réseau Xbox Live
   Stopped Service de moteur de sauvegarde en mode bloc
   Stopped Service de partage de ports Net.Tcp
   Stopped Service de partage des données
   Stopped Service de perception Windows
   Stopped Service de publication des noms d’ordinateurs PNRP
   Stopped Service de routeur AllJoyn
   Stopped Service de stockage
   Stopped Service de surveillance des capteurs
   Stopped Service de transfert intelligent en arrière-plan
   Stopped Service de virtualisation Bureau à distance Hyper-V
   Stopped Service Données de capteur
   Stopped Service d’historique des fichiers
   Stopped Service d’installation de périphérique
   Stopped Service d’énumération de périphériques de carte à puce
   Stopped Service Gestionnaire d’accès aux fonctionnalités
   Stopped Service Google Update (gupdate)
   Stopped Service Google Update (gupdatem)
   Stopped Service Hyper-V PowerShell Direct
   Stopped Service hôte du fournisseur de chiffrement Windows
   Stopped Service Initiateur iSCSI de Microsoft
   Stopped Service KtmRm pour Distributed Transaction Coordinator
   Stopped Service mains libres Bluetooth
   Stopped Service Moniteur infrarouge
   Stopped Service Partage réseau du Lecteur Windows Media
   Stopped Service Point d'accès sans fil mobile Windows
   Stopped Service Protection avancée contre les menaces Windows Defender
   Stopped Service Pulsation Microsoft Hyper-V
   Stopped Service PushToInstall de Windows
   Stopped Service Routeur SMS Microsoft Windows.
   Stopped Service Synchronisation date/heure Microsoft Hyper-V
   Stopped Service téléphonique
   Stopped Service User Experience Virtualization
   Stopped Service Wi-Fi Direct Service de gestionnaire de connexions
   Stopped Service Windows Insider
   Stopped Service Échange de données Microsoft Hyper-V
   Stopped Services Bureau à distance
   Stopped Shared PC Account Manager
   Stopped SMP de l’Espace de stockages Microsoft
   Stopped Stratégie de retrait de la carte à puce
   Stopped Système de fichiers EFS (Encrypting File System)
   Stopped Temps Windows
   Stopped Télécopie
   Stopped Téléphonie
   Stopped Update Orchestrator Service
   Stopped Vérificateur de points
   Stopped WalletService
   Stopped WarpJITSvc
   Stopped WebClient
   Stopped Windows Connect Now - Registre de configuration
   Stopped Windows Installer
   Stopped Xbox Accessory Management Service
   Stopped Xbox Game Monitoring
   Stopped Écouteur du Groupement résidentiel
   Stopped Événements d’acquisition d’images fixes
  TimeZone
   TimeZone GMT +1:00 Hours
   Language Français (France)
   Location France
   Format Français (France)
   Currency €
   Date Format dd/MM/yyyy
   Time Format HH:mm:ss
  Scheduler
   26/11/2017 20:36; GoogleUpdateTaskMachineUA
   27/11/2017 07:20; OneDrive Standalone Update Task-S-1-5-21-679199858-828136731-3189641600-1001
   27/11/2017 17:36; GoogleUpdateTaskMachineCore
   CCleanerSkipUAC
   ExclusiveTool
   Launcher GIGABYTE AORUS GRAPHICS ENGINE
  Hotfixes
    Installed
      26/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.998.0)
       Installez cette mise à jour pour actualiser les fichiers de définition
       utilisés pour détecter les virus, les logiciels espions et autres
       programmes potentiellement indésirables. Une fois l'installation
       effectuée, aucune suppression ne sera possible.
      26/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.993.0)
      25/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.967.0)
      24/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.940.0)
      24/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.930.0)
      23/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.886.0)
      22/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.835.0)
      21/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.788.0)
      20/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.713.0)
      19/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.702.0)
      19/11/2017  Logitech - WebCam - HD Pro Webcam C920
       Logitech WebCam software update released in October, 2012
      19/11/2017  Logitech - WebCam - Logitech HD Pro Webcam C920
      19/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.700.0)
      19/11/2017  2017-11 Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1709 sur systèmes x64 (KB4048951)
       Un problème de sécurité qui pourrait avoir un impact sur votre
       système a été identifié dans un produit logiciel Microsoft. Vous
       pouvez renforcer la protection de votre système en installant
       cette mise à jour de Microsoft. Pour consulter la liste complète
       des problèmes résolus par cette mise à jour et en savoir plus,
       reportez-vous à l'article correspondant de la Base de connaissances
       Microsoft. Une fois la mise à jour installée, vous serez peut-être
       amené à redémarrer l’ordinateur.
      19/11/2017  Update for Windows 10 Version 1709 for x64-based Systems (KB4041994)
       Install this update to resolve issues in Windows. For a complete
       listing of the issues that are included in this update, see the
       associated Microsoft Knowledge Base article for more information.
       After you install this item, you may have to restart your computer.
      19/11/2017  Mise à jour de fonctionnalité vers Windows 10, version 1709
       Installez la dernière mise à jour pour Windows 10 : Windows 10
       Fall Creators Update.
    Not Installed
  System Folders
   Application Data C:\ProgramData
   Cookies C:\Users\alexa\AppData\Local\Microsoft\Windows\INetCookies
   Desktop C:\Users\alexa\Desktop
   Documents C:\Users\Public\Documents
   Fonts C:\WINDOWS\Fonts
   Global Favorites C:\Users\alexa\Favorites
   Internet History C:\Users\alexa\AppData\Local\Microsoft\Windows\History
   Local Application Data C:\Users\alexa\AppData\Local
   Music C:\Users\Public\Music
   Path for burning CD C:\Users\alexa\AppData\Local\Microsoft\Windows\Burn\Burn
   Physical Desktop C:\Users\alexa\Desktop
   Pictures C:\Users\Public\Pictures
   Program Files C:\Program Files
   Public Desktop C:\Users\Public\Desktop
   Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
   Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
   Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
   Templates C:\ProgramData\Microsoft\Windows\Templates
   Temporary Internet Files C:\Users\alexa\AppData\Local\Microsoft\Windows\INetCache
   User Favorites C:\Users\alexa\Favorites
   Videos C:\Users\Public\Videos
   Windows Directory C:\WINDOWS
   Windows/System C:\WINDOWS\system32
  Process List
    AdminService.exe
     Process ID 3792
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\AdminService.exe
     Memory Usage 8.58 MB
     Peak Memory Usage 8.58 MB
    AORUS.exe
     Process ID 7460
     User alexa
     Domain DESKTOP-SO2TEKJ
     Path C:\Program Files (x86)\GIGABYTE\AORUS GRAPHICS ENGINE\AORUS.exe
     Memory Usage 45 MB
     Peak Memory Usage 50 MB
    audiodg.exe
     Process ID 11912
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Windows\System32\audiodg.exe
     Memory Usage 17 MB
     Peak Memory Usage 34 MB
    backgroundTaskHost.exe
     Process ID 10224
     User alexa
     Path C:\Windows\System32\backgroundTaskHost.exe
     Memory Usage 45 MB
     Peak Memory Usage 51 MB
    conhost.exe
     Process ID 7532
     User alexa
     Path C:\Windows\System32\conhost.exe
     Memory Usage 8.89 MB
     Peak Memory Usage 9.81 MB
    csrss.exe
     Process ID 712
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\csrss.exe
     Memory Usage 5.06 MB
     Peak Memory Usage 5.19 MB
    csrss.exe
     Process ID 824
     User Système
     Domain AUTORITE NT
     Memory Usage 8.66 MB
     Peak Memory Usage 13 MB
    ctfmon.exe
     Process ID 6624
     User alexa
     Path C:\Windows\System32\ctfmon.exe
     Memory Usage 14 MB
     Peak Memory Usage 14 MB
    CUE.exe
     Process ID 10432
     User alexa
     Path C:\Program Files (x86)\Corsair\Corsair Utility Engine\CUE.exe
     Memory Usage 111 MB
     Peak Memory Usage 127 MB
    dasHost.exe
     Process ID 6256
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Windows\System32\dasHost.exe
     Memory Usage 14 MB
    Discord.exe
     Process ID 9252
     User alexa
     Path C:\Users\alexa\AppData\Local\Discord\app-0.0.298\Discord.exe
     Memory Usage 127 MB
     Peak Memory Usage 150 MB
    Discord.exe
     Process ID 11560
     User alexa
     Memory Usage 38 MB
     Peak Memory Usage 63 MB
    Discord.exe
     Process ID 11392
     User alexa
     Memory Usage 82 MB
     Peak Memory Usage 86 MB
    dllhost.exe
     Process ID 2008
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\dllhost.exe
     Memory Usage 5.92 MB
     Peak Memory Usage 5.92 MB
    dllhost.exe
     Process ID 1580
     User Système
     Domain AUTORITE NT
     Memory Usage 6.18 MB
     Peak Memory Usage 6.18 MB
    dwm.exe
     Process ID 1216
     User DWM-1
     Domain Window Manager
     Path C:\Windows\System32\dwm.exe
     Memory Usage 52 MB
     Peak Memory Usage 68 MB
    explorer.exe
     Process ID 6440
     User alexa
     Path C:\Windows\explorer.exe
     Memory Usage 118 MB
     Peak Memory Usage 141 MB
    fontdrvhost.exe
     Process ID 128
     User UMFD-0
     Domain Font Driver Host
     Path C:\Windows\System32\fontdrvhost.exe
     Memory Usage 3.77 MB
     Peak Memory Usage 3.84 MB
    fontdrvhost.exe
     Process ID 1044
     User UMFD-1
     Memory Usage 13 MB
    GoogleUpdate.exe
     Process ID 6100
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
     Memory Usage 1.86 MB
     Peak Memory Usage 9.88 MB
    IAStorIcon.exe
     Process ID 11116
     User alexa
     Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorIcon.exe
     Memory Usage 33 MB
     Peak Memory Usage 33 MB
    IPROSetMonitor.exe
     Process ID 3804
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\IPROSetMonitor.exe
     Memory Usage 5.33 MB
     Peak Memory Usage 5.36 MB
    KillerControlCenter.exe
     Process ID 11980
     User alexa
     Path C:\Program Files\Killer Networking\Killer Control Center\KillerControlCenter.exe
     Memory Usage 103 MB
     Peak Memory Usage 106 MB
    KillerNetworkService.exe
     Process ID 3892
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\Killer Networking\Killer Control Center\KillerNetworkService.exe
     Memory Usage 58 MB
     Peak Memory Usage 58 MB
    lsass.exe
     Process ID 888
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\lsass.exe
     Memory Usage 16 MB
     Peak Memory Usage 16 MB
    MBLed.exe
     Process ID 12544
     User alexa
     Path C:\Program Files (x86)\GIGABYTE\AORUS GRAPHICS ENGINE\MBLed.exe
     Memory Usage 70 MB
     Peak Memory Usage 70 MB
    Memory Compression
     Process ID 2780
     User Système
     Domain AUTORITE NT
     Memory Usage 4.00 KB
     Peak Memory Usage 4.00 KB
    MSASCuiL.exe
     Process ID 11100
     User alexa
     Path C:\Program Files\Windows Defender\MSASCuiL.exe
     Memory Usage 9.44 MB
     Peak Memory Usage 9.52 MB
    MsMpEng.exe
     Process ID 3924
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\Windows Defender\MsMpEng.exe
     Memory Usage 186 MB
     Peak Memory Usage 200 MB
    NisSrv.exe
     Process ID 7800
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Program Files\Windows Defender\NisSrv.exe
     Memory Usage 11 MB
     Peak Memory Usage 38 MB
    nvcontainer.exe
     Process ID 5720
     User alexa
     Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
     Memory Usage 22 MB
     Peak Memory Usage 25 MB
    nvcontainer.exe
     Process ID 5752
     User alexa
     Memory Usage 27 MB
     Peak Memory Usage 55 MB
    nvcontainer.exe
     Process ID 3856
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
     Memory Usage 25 MB
     Peak Memory Usage 26 MB
    NVDisplay.Container.exe
     Process ID 2228
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
     Memory Usage 14 MB
     Process ID 2672
     User Système
     Domain AUTORITE NT
     Memory Usage 41 MB
     Peak Memory Usage 65 MB
    NVIDIA Share.exe
     Process ID 10156
     User alexa
     Path C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
     Memory Usage 57 MB
    NVIDIA Share.exe
     Process ID 11304
     User alexa
     Memory Usage 59 MB
     Peak Memory Usage 60 MB
    NVIDIA Web Helper.exe
     Process ID 6332
     User alexa
     Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
     Memory Usage 47 MB
    nvsphelper64.exe
     Process ID 10036
     User alexa
     Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
     Memory Usage 13 MB
    NvTelemetryContainer.exe
     Process ID 3908
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
     Memory Usage 15 MB
     Peak Memory Usage 19 MB
    OneDrive.exe
     Process ID 10172
     User alexa
     Path C:\Users\alexa\AppData\Local\Microsoft\OneDrive\OneDrive.exe
     Memory Usage 49 MB
     Peak Memory Usage 53 MB
    QcomWlanSrvx64.exe
     Process ID 3840
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\QcomWlanSrvx64.exe
     Memory Usage 6.39 MB
     Peak Memory Usage 6.43 MB
    RtkNGUI64.exe
     Process ID 11180
     User alexa
     Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
     Memory Usage 14 MB
     Peak Memory Usage 15 MB
    RuntimeBroker.exe
     Process ID 7988
     User alexa
     Path C:\Windows\System32\RuntimeBroker.exe
     Memory Usage 23 MB
     Peak Memory Usage 23 MB
    RuntimeBroker.exe
     Process ID 7488
     User alexa
     Memory Usage 29 MB
     Peak Memory Usage 30 MB
    RuntimeBroker.exe
     Process ID 2964
     User alexa
     Memory Usage 18 MB
     Peak Memory Usage 20 MB
    RuntimeBroker.exe
     Process ID 8884
     User alexa
     Memory Usage 13 MB
    RuntimeBroker.exe
     Process ID 9960
     User alexa
     Memory Usage 22 MB
    RuntimeBroker.exe
     Process ID 5528
     User alexa
     Memory Usage 14 MB
    SearchFilterHost.exe
     Process ID 7200
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SearchFilterHost.exe
     Memory Usage 12 MB
     Peak Memory Usage 32 MB
    SearchIndexer.exe
     Process ID 6944
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SearchIndexer.exe
     Memory Usage 37 MB
     Peak Memory Usage 44 MB
    SearchProtocolHost.exe
     Process ID 7088
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SearchProtocolHost.exe
     Memory Usage 15 MB
    SearchUI.exe
     Process ID 7348
     User alexa
     Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
     Memory Usage 99 MB
     Peak Memory Usage 104 MB
    SecurityHealthService.exe
     Process ID 3916
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SecurityHealthService.exe
     Memory Usage 11 MB
     Peak Memory Usage 11 MB
    services.exe
     Process ID 880
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\services.exe
     Memory Usage 10 MB
     Peak Memory Usage 10 MB
    SettingSyncHost.exe
     Process ID 8356
     User alexa
     Path C:\Windows\System32\SettingSyncHost.exe
     Memory Usage 32 MB
     Peak Memory Usage 35 MB
    ShellExperienceHost.exe
     Process ID 1856
     User alexa
     Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
     Memory Usage 73 MB
     Peak Memory Usage 75 MB
    sihost.exe
     Process ID 5808
     User alexa
     Path C:\Windows\System32\sihost.exe
     Memory Usage 26 MB
    SkypeHost.exe
     Process ID 8080
     User alexa
     Path C:\Program Files\WindowsApps\Microsoft.SkypeApp_12.8.487.0_x64__kzf8qxf38zg5c\SkypeHost.exe
     Memory Usage 59 MB
     Peak Memory Usage 76 MB
    smartscreen.exe
     Process ID 8672
     User alexa
     Path C:\Windows\System32\smartscreen.exe
     Memory Usage 20 MB
     Peak Memory Usage 21 MB
    smss.exe
     Process ID 504
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\smss.exe
     Memory Usage 1.21 MB
     Peak Memory Usage 1.22 MB
    Speccy64.exe
     Process ID 2340
     User alexa
     Path C:\Program Files\Speccy\Speccy64.exe
     Memory Usage 29 MB
     Peak Memory Usage 29 MB
    spoolsv.exe
     Process ID 3500
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\spoolsv.exe
     Memory Usage 15 MB
    Steam.exe
     Process ID 11816
     User alexa
     Path D:\Steam\Steam.exe
     Memory Usage 74 MB
    SteamService.exe
     Process ID 12996
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Common Files\Steam\SteamService.exe
     Memory Usage 16 MB
    steamwebhelper.exe
     Process ID 12856
     User alexa
     Path D:\Steam\bin\cef\cef.win7\steamwebhelper.exe
     Memory Usage 19 MB
    steamwebhelper.exe
     Process ID 12820
     User alexa
     Memory Usage 35 MB
    svchost.exe
     Process ID 3816
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Windows\System32\svchost.exe
     Memory Usage 17 MB
     Peak Memory Usage 182 MB
    svchost.exe
     Process ID 3824
     User Système
     Domain AUTORITE NT
     Memory Usage 15 MB
    svchost.exe
     Process ID 3848
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 6.57 MB
     Peak Memory Usage 6.68 MB
    svchost.exe
     Process ID 3864
     User Système
     Domain AUTORITE NT
     Memory Usage 20 MB
    svchost.exe
     Process ID 3872
     User Système
     Domain AUTORITE NT
     Memory Usage 28 MB
     Peak Memory Usage 28 MB
    svchost.exe
     Process ID 3880
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 9.93 MB
     Peak Memory Usage 9.93 MB
    svchost.exe
     Process ID 3900
     User Système
     Domain AUTORITE NT
     Memory Usage 5.63 MB
     Peak Memory Usage 5.73 MB
    svchost.exe
     Process ID 4352
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 6.09 MB
     Peak Memory Usage 6.17 MB
    svchost.exe
     Process ID 2316
     User SERVICE LOCAL
     Domain AUTORITE NT
    svchost.exe
     Process ID 4436
     User Système
     Domain AUTORITE NT
     Memory Usage 28 MB
     Peak Memory Usage 43 MB
    svchost.exe
     Process ID 4176
     User Système
     Domain AUTORITE NT
     Memory Usage 16 MB
    svchost.exe
     Process ID 5124
     User Système
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 5376
     User Système
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 5856
     User alexa
     Memory Usage 23 MB
    svchost.exe
     Process ID 5932
     User alexa
     Memory Usage 36 MB
     Peak Memory Usage 37 MB
    svchost.exe
     Process ID 6168
     User Système
     Domain AUTORITE NT
     Memory Usage 15 MB
    svchost.exe
     Process ID 1364
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 6596
     User Système
     Domain AUTORITE NT
     Memory Usage 6.27 MB
     Peak Memory Usage 6.37 MB
    svchost.exe
     Process ID 1012
     User Système
     Domain AUTORITE NT
     Memory Usage 3.85 MB
     Peak Memory Usage 3.93 MB
    svchost.exe
     Process ID 4400
     User Système
     Domain AUTORITE NT
     Memory Usage 9.02 MB
     Peak Memory Usage 9.23 MB
    svchost.exe
     Process ID 7068
     User Système
     Domain AUTORITE NT
     Memory Usage 7.53 MB
     Peak Memory Usage 7.64 MB
    svchost.exe
     Process ID 7132
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 8.90 MB
     Peak Memory Usage 9.03 MB
    svchost.exe
     Process ID 144
     User Système
     Domain AUTORITE NT
     Memory Usage 25 MB
    svchost.exe
     Process ID 1080
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 12 MB
     Peak Memory Usage 12 MB
    svchost.exe
     Process ID 1128
     User Système
     Domain AUTORITE NT
     Memory Usage 7.62 MB
     Peak Memory Usage 7.71 MB
    svchost.exe
     Process ID 7264
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 7.60 MB
     Peak Memory Usage 7.78 MB
    svchost.exe
     Process ID 1308
     User Système
     Domain AUTORITE NT
     Memory Usage 7.61 MB
     Peak Memory Usage 7.75 MB
    svchost.exe
     Process ID 1356
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 5.48 MB
     Peak Memory Usage 5.54 MB
    svchost.exe
     Process ID 1412
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 20 MB
    svchost.exe
     Process ID 1480
     User Système
     Domain AUTORITE NT
     Memory Usage 15 MB
    svchost.exe
     Process ID 1516
     User Système
     Domain AUTORITE NT
     Memory Usage 9.66 MB
     Peak Memory Usage 9.89 MB
    svchost.exe
     Process ID 1524
     User Système
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 1532
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 1624
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 8.64 MB
     Peak Memory Usage 8.68 MB
    svchost.exe
     Process ID 1736
     User Système
     Domain AUTORITE NT
     Memory Usage 5.98 MB
     Peak Memory Usage 6.12 MB
    svchost.exe
     Process ID 1744
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 7.59 MB
    svchost.exe
     Process ID 1840
     User Système
     Domain AUTORITE NT
     Memory Usage 8.88 MB
     Peak Memory Usage 9.18 MB
    svchost.exe
     Process ID 9336
     User Système
     Domain AUTORITE NT
     Memory Usage 16 MB
    svchost.exe
     Process ID 1904
     User Système
     Domain AUTORITE NT
     Memory Usage 7.22 MB
     Peak Memory Usage 7.31 MB
    svchost.exe
     Process ID 1944
     User Système
     Domain AUTORITE NT
     Memory Usage 6.98 MB
     Peak Memory Usage 7.17 MB
    svchost.exe
     Process ID 1952
     User Système
     Domain AUTORITE NT
     Memory Usage 12 MB
    svchost.exe
     Process ID 1960
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 21 MB
    svchost.exe
     Process ID 10548
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 20 MB
    svchost.exe
     Process ID 2052
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 12 MB
    svchost.exe
     Process ID 2144
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 8.25 MB
     Peak Memory Usage 8.38 MB
    svchost.exe
     Process ID 10476
     User Système
     Domain AUTORITE NT
     Memory Usage 5.95 MB
     Peak Memory Usage 6.05 MB
    svchost.exe
     Process ID 10196
     User Système
     Domain AUTORITE NT
     Peak Memory Usage 8.00 MB
    svchost.exe
     Process ID 2344
     User Système
     Domain AUTORITE NT
     Memory Usage 12 MB
    svchost.exe
     Process ID 2352
     User Système
     Domain AUTORITE NT
     Memory Usage 5.87 MB
     Peak Memory Usage 5.94 MB
    svchost.exe
     Process ID 2360
     User SERVICE LOCAL
     Domain AUTORITE NT
     Peak Memory Usage 7.97 MB
    svchost.exe
     Process ID 2528
     User Système
     Domain AUTORITE NT
     Memory Usage 8.32 MB
     Peak Memory Usage 8.47 MB
    svchost.exe
     Process ID 2564
     User Système
     Domain AUTORITE NT
     Memory Usage 8.65 MB
     Peak Memory Usage 8.79 MB
    svchost.exe
     Process ID 2572
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 11 MB
    svchost.exe
     Process ID 2712
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 9.94 MB
    svchost.exe
     Process ID 2932
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 7.39 MB
     Peak Memory Usage 7.72 MB
    svchost.exe
     Process ID 2968
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 9.36 MB
     Peak Memory Usage 9.66 MB
    svchost.exe
     Process ID 3044
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 13 MB
    svchost.exe
     Process ID 6928
     User alexa
     Memory Usage 21 MB
     Peak Memory Usage 24 MB
    svchost.exe
     Process ID 12644
     User Système
     Domain AUTORITE NT
     Peak Memory Usage 6.33 MB
    svchost.exe
     Process ID 1700
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 9.98 MB
    svchost.exe
     Process ID 2956
     User Système
     Domain AUTORITE NT
     Memory Usage 18 MB
     Peak Memory Usage 49 MB
    svchost.exe
     Process ID 3132
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 14 MB
    svchost.exe
     Process ID 3224
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 6.48 MB
     Peak Memory Usage 6.65 MB
    svchost.exe
     Process ID 3232
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 13 MB
    svchost.exe
     Process ID 3328
     User Système
     Domain AUTORITE NT
     Memory Usage 15 MB
    svchost.exe
     Process ID 12396
     User Système
     Domain AUTORITE NT
     Memory Usage 6.08 MB
     Peak Memory Usage 6.45 MB
    svchost.exe
     Process ID 1324
     User Système
     Domain AUTORITE NT
     Memory Usage 8.09 MB
     Peak Memory Usage 8.09 MB
    svchost.exe
     Process ID 3396
     User Système
     Domain AUTORITE NT
     Memory Usage 12 MB
    svchost.exe
     Process ID 3428
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 12 MB
    svchost.exe
     Process ID 3564
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Peak Memory Usage 8.36 MB
    System
     Process ID 4
     Memory Usage 784 KB
     Peak Memory Usage 4.34 MB
    System Idle Process
     Process ID 0
    taskhostw.exe
     Process ID 6796
     User alexa
     Path C:\Windows\System32\taskhostw.exe
     Memory Usage 16 MB
    Thermaltake RGB Fan Controller.exe
     Process ID 12152
     User alexa
     Path C:\Program Files (x86)\Tt\Riing RGB Radiator Fan TT Premium Edition\Thermaltake RGB Fan Controller.exe
     Memory Usage 54 MB
     Peak Memory Usage 57 MB
    Twitch.exe
     Process ID 8072
     User alexa
     Path C:\Users\alexa\AppData\Roaming\Twitch\Bin\Twitch.exe
     Memory Usage 127 MB
     Peak Memory Usage 132 MB
    TwitchUI.exe
     Process ID 12380
     User alexa
     Path C:\Users\alexa\AppData\Roaming\Twitch\Bin\Electron\TwitchUI.exe
     Memory Usage 105 MB
    TwitchUI.exe
     Process ID 11868
     User alexa
     Memory Usage 65 MB
     Peak Memory Usage 67 MB
    TwitchUI.exe
     Process ID 8236
     User alexa
     Memory Usage 53 MB
    TwitchUI.exe
     Process ID 12316
     User alexa
     Memory Usage 11 MB
    wininit.exe
     Process ID 808
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\wininit.exe
     Memory Usage 6.52 MB
     Peak Memory Usage 6.62 MB
    winlogon.exe
     Process ID 140
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\winlogon.exe
     Memory Usage 9.92 MB
    WmiPrvSE.exe
     Process ID 5572
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Path C:\Windows\System32\wbem\WmiPrvSE.exe
     Memory Usage 19 MB
    WmiPrvSE.exe
     Process ID 3948
     User Système
     Domain AUTORITE NT
     Memory Usage 8.62 MB
     Peak Memory Usage 8.62 MB
    WUDFHost.exe
     Process ID 2164
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Windows\System32\WUDFHost.exe
     Memory Usage 8.50 MB
     Peak Memory Usage 8.59 MB
  Security Options
   Accès réseau : chemins et sous-chemins de Registre accessibles à distance System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
   Accès réseau : les autorisations spécifiques des utilisateurs appartenant au groupe Tout le monde s’appliquent aux utilisateurs anonymes Désactivé
   Accès réseau : les canaux nommés qui sont accessibles de manière anonyme
   Accès réseau : les chemins de Registre accessibles à distance System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
   Accès réseau : les partages qui sont accessibles de manière anonyme Non défini
   Accès réseau : modèle de partage et de sécurité pour les comptes locaux Classique - les utilisateurs locaux s’authentifient eux-mêmes
   Accès réseau : ne pas autoriser l’énumération anonyme des comptes et partages SAM Désactivé
   Accès réseau : ne pas autoriser l’énumération anonyme des comptes SAM Activé
   Accès réseau : Permet la traduction de noms/SID anonymes Désactivé
   Accès réseau : restreindre l’accès anonyme aux canaux nommés et aux partages Activé
   Accès réseau : ne pas autoriser le stockage de mots de passe et d’informations d’identification pour l’authentification du réseau Désactivé
   Accès réseau : restreindre les clients autorisés à effectuer des appels distants vers SAM
   Arrêt : effacer le fichier d’échange de mémoire virtuelle Désactivé
   Arrêt : permet au système d’être arrêté sans avoir à se connecter Activé
   Audit : arrêter immédiatement le système s’il n’est pas possible de se connecter aux audits de sécurité Désactivé
   Audit : auditer l’accès des objets système globaux Désactivé
   Audit : auditer l’utilisation des privilèges de sauvegarde et de restauration Désactivé
   Audit : force les paramètres de sous-catégorie de stratégie d’audit (Windows Vista ou version ultérieure) à se substituer aux paramètres de catégorie de stratégie d’audit Non défini
   Chiffrement système : utilisez des algorithmes compatibles FIPS pour le chiffrement, le hachage et la signature Désactivé
   Client réseau Microsoft : communications signées numériquement (lorsque le serveur l’accepte) Activé
   Client réseau Microsoft : communications signées numériquement (toujours) Désactivé
   Client réseau Microsoft : envoyer un mot de passe non chiffré aux serveurs SMB tierce partie Désactivé
   Comptes : renommer le compte administrateur Administrateur
   Comptes : renommer le compte Invité Invité
   Comptes : restreindre l’utilisation de mots de passe vides par le compte local à l’ouverture de session console Activé
   Comptes : statut du compte Administrateur Désactivé
   Comptes : statut du compte Invité Désactivé
   Comptes : bloquer les comptes Microsoft Non défini
   Connexion interactive : afficher les informations relatives à l’utilisateur lorsque la session est verrouillée Non défini
   Console de récupération : autoriser l’ouverture de session d’administration automatique Non défini
   Console de récupération : autoriser la copie de disquettes et l’accès à tous les lecteurs et dossiers Non défini
   Contrôle de compte d’utilisateur : mode Approbation administrateur pour le compte Administrateur intégré Non défini
   Contrôle de compte d’utilisateur : passer au Bureau sécurisé lors d’une demande d’élévation Activé
   Contrôle de compte d’utilisateur : autoriser les applications UIAccess à demander l’élévation sans utiliser le bureau sécurisé Désactivé
   Contrôle de compte d’utilisateur : comportement de l’invite d’élévation pour les administrateurs en mode d’approbation Administrateur Demande de consentement pour les binaires non Windows
   Contrôle de compte d’utilisateur : comportement de l’invite d’élévation pour les utilisateurs standard Demande d’informations d’identification
   Contrôle de compte d’utilisateur : détecter les installations d’applications et demander l’élévation Activé
   Contrôle de compte d’utilisateur : élever uniquement les applications UIAccess installées à des emplacements sécurisés Activé
   Contrôle de compte d’utilisateur : élever uniquement les exécutables signés et validés Désactivé
   Contrôle de compte d’utilisateur : exécuter les comptes d’administrateurs en mode d’approbation d’administrateur Activé
   Contrôle de compte d’utilisateur : virtualiser les échecs d’écritures de fichiers et de Registre dans des emplacements définis par utilisateur Activé
   Contrôleur de domaine : conditions requises pour la signature de serveur LDAP Non défini
   Contrôleur de domaine : permettre aux opérateurs du serveur de planifier des tâches Non défini
   Contrôleur de domaine : refuser les modifications de mot de passe du compte ordinateur Non défini
   Cryptographie système : force une protection forte des clés utilisateur enregistrées sur l’ordinateur Non défini
   DCOM : Restrictions d’accès à un ordinateur au format du langage SDDL (Security Descriptor Definition Language) Non défini
   DCOM : Restrictions de démarrage d’ordinateur au format du langage SDDL (Security Descriptor Definition Language) Non défini
   Membre de domaine : ancienneté maximale du mot de passe du compte ordinateur 30 jours
   Membre de domaine : chiffrer numériquement les données des canaux sécurisés (lorsque cela est possible) Activé
   Membre de domaine : chiffrer ou signer numériquement les données des canaux sécurisés (toujours) Activé
   Membre de domaine : désactive les modifications de mot de passe du compte ordinateur Désactivé
   Membre de domaine : nécessite une clé de session forte (Windows 2000 ou ultérieur) Activé
   Membre de domaine : signer numériquement les données des canaux sécurisés (lorsque cela est possible) Activé
   Objets système : les différences entre majuscules et minuscules ne doivent pas être prises en compte pour les sous-systèmes autres que Windows Activé
   Objets système : renforcer les autorisations par défaut des objets système internes (comme les liens de symboles) Activé
   Ouverture de session interactive : comportement lorsque la carte à puce est retirée Aucune action
   Ouverture de session interactive : contenu du message pour les utilisateurs essayant de se connecter
   Ouverture de session interactive : ne pas afficher le nom de l’utilisateur lors de la connexion Non défini
   Ouverture de session interactive : ne pas afficher le nom du dernier utilisateur connecté Désactivé
   Ouverture de session interactive : ne pas demander la combinaison de touches Ctrl+Alt+Suppr. Non défini
   Ouverture de session interactive : nécessite l’authentification par le contrôleur de domaine pour le déverrouillage de la station de travail. Désactivé
   Ouverture de session interactive : prévenir l’utilisateur qu’il doit changer son mot de passe avant qu’il n’expire 5 jours
   Ouverture de session interactive : titre du message pour les utilisateurs essayant de se connecter
   Ouverture de session interactive : Windows Hello Entreprise ou carte à puce nécessaire Désactivé
   Ouverture de session interactive : limite d’inactivité de l’ordinateur Non défini
   Ouverture de session interactive : seuil de verrouillage du compte d’ordinateur Non défini
   Ouvertures de sessions interactives : nombre d’ouvertures de sessions précédentes réalisées en utilisant le cache (lorsqu’aucun contrôleur de domaine n’est disponible) 10 Ouvertures de session
   Paramètres système : Sous-systèmes optionnels
   Paramètres système : utiliser les règles de certificat avec les exécutables Windows pour les stratégies de restriction logicielle Désactivé
   Périphériques : autoriser l’accès au CD-ROM uniquement aux utilisateurs ayant ouvert une session localement Non défini
   Périphériques : autoriser le retrait sans ouverture de session préalable Activé
   Périphériques : empêcher les utilisateurs d’installer des pilotes d’imprimante Désactivé
   Périphériques : ne permettre l’accès aux disquettes qu’aux utilisateurs connectés localement Non défini
   Périphériques : permettre le formatage et l’éjection des médias amovibles Non défini
   Sécurité réseau : conditions requises pour la signature de client LDAP Négociation des signatures
   Sécurité réseau : forcer la fermeture de session quand les horaires de connexion expirent Désactivé
   Sécurité réseau : ne pas stocker de valeurs de hachage de niveau LAN Manager sur la prochaine modification de mot de passe Activé
   Sécurité réseau : niveau d’authentification LAN Manager Non défini
   Sécurité réseau : sécurité de session minimale pour les clients basés sur NTLM SSP (y compris RPC sécurisé) Exiger un niveau de chiffrement à 128 bits
   Sécurité réseau : sécurité de session minimale pour les serveurs basés sur NTLM SSP (y compris RPC sécurisé) Exiger un niveau de chiffrement à 128 bits
   Sécurité réseau : Autoriser le retour à des sessions NULL avec SystèmeLocal Non défini
   Sécurité réseau : autoriser les demandes d’authentification PKU2U auprès de cet ordinateur pour utiliser les identités en ligne.
 Non défini
   Sécurité réseau : Autoriser Système local à utiliser l’identité de l’ordinateur pour NTLM Non défini
   Sécurité réseau : Configurer les types de chiffrement autorisés pour Kerberos Non défini
   Sécurité réseau : Restreindre NTLM : Ajouter des exceptions de serveurs dans ce domaine Non défini
   Sécurité réseau : Restreindre NTLM : Ajouter des exceptions de serveurs distants pour l’authentification NTLM Non défini
   Sécurité réseau : Restreindre NTLM : Auditer l’authentification NTLM dans ce domaine Non défini
   Sécurité réseau : Restreindre NTLM : Auditer le trafic NTLM entrant Non défini
   Sécurité réseau : Restreindre NTLM : Authentification NTLM dans ce domaine Non défini
   Sécurité réseau : Restreindre NTLM : Trafic NTLM entrant Non défini
   Sécurité réseau : Restreindre NTLM : Trafic NTLM sortant vers des serveurs distants Non défini
   Serveur réseau Microsoft : communications signées numériquement (lorsque le serveur l’accepte) Désactivé
   Serveur réseau Microsoft : communications signées numériquement (toujours) Désactivé
   Serveur réseau Microsoft : déconnecter les clients à l’expiration du délai de la durée de session Activé
   Serveur réseau Microsoft : durée d’inactivité avant la suspension d’une session Non défini
   Serveur réseau Microsoft : niveau de validation du nom de la cible de serveur SPN Non défini
   Serveur réseau Microsoft : tentative de S4U2Self d’obtenir des informations relatives aux revendications Non défini
  Device Tree
    PC ACPI avec processeur x64
      Système compatible ACPI Microsoft
       Bouton d'alimentation ACPI
       Bouton de fonctionnalité définie ACPI
       Bouton veille ACPI
       Interface de gestion Microsoft Windows pour ACPI
       Ressources de la carte mère
        Périphérique module ACPI
         Intel Core i7-7820X CPU @ 3.60GHz
        Racine complexe PCI Express
         APIC (Advanced Programmable Interrupt Controller)
         Intel 200 Series Chipset Family PCI Express Root Port #1 - A290
         Intel 200 Series Chipset Family PCI Express Root Port #17 -
Message édité par NaeNae le 26-11-2017 à 20:50:47
Workblog Phoenix Modding Cooling
n°2482477
NaeNae
Posté le 26-11-2017 à 20:50:54  profilanswer
Intel 200 Series Chipset Family PMC - A2A1
         Intel 200 Series Chipset Family SMBUS - A2A3
         Intel Ethernet Connection (2) I219-V
         Intel Management Engine Interface
         Intel Xeon processor P family/Core i7 CBDMA Registers - 2021
         Intel Xeon processor P family/Core i7 DMI3 Port - 2020
         Intel Xeon processor P family/Core i7 IOAPIC - 2026
         Intel Xeon processor P family/Core i7 MM/Vt - d Configuration Registers - 2024
         Intel Xeon processor P family/Core i7 RAS - 2025
         Intel Xeon processor P family/Core i7 Ubox Registers - 2014
         Intel Xeon processor P family/Core i7 Ubox Registers - 2015
         Intel Xeon processor P family/Core i7 Ubox Registers - 2016
          Contrôleur hôte Intel(R) USB 3.0 eXtensible - 1.0 (Microsoft)
            Hub USB racine (USB 3.0)
              Concentrateur USB SuperSpeed générique
                Dispositif de stockage de masse USB
              Concentrateur USB générique
                Périphérique d’entrée USB
                 Souris HID
                C922 Pro Stream Webcam
                   Microphone (C922 Pro Stream Webcam)
                 Périphérique fournisseur HID
              Qualcomm Atheros QCA61x4 Bluetooth 4.1
               Bluetooth Device (Personal Area Network)
               Bluetooth Device (RFCOMM Protocol TDI)
               Pilote de prise en charge du protocole Microsoft Bluetooth
               Énumérateur Microsoft Bluetooth LE
                 Logitech BT Adapter
                 Logitech BT Adapter Stereo
          Contrôleur AHCI SATA standard
           ST4000VN008-2DR166
          Intel(R) 200 Series Chipset Family PCI Express Root Port #2 - A291
            Killer Wireless-n/a/ac 1535 Wireless Network Adapter
             Microsoft Wi-Fi Direct Virtual Adapter
          Intel(R) 200 Series Chipset Family PCI Express Root Port #3 - A292
           Killer E2500 Gigabit Ethernet Controller
          Intel(R) 200 Series Chipset Family PCI Express Root Port #5 - A294
            Contrôleur hôte ASMedia USB 3.1 eXtensible - 1.10 (Microsoft)
                    Périphérique USB composite
                       Périphérique clavier PIH
                       Périphérique de contrôle consommateur conforme aux Périphériques d'interface utilisateur (HID)
          Intel(R) 200 Series Chipset Family PCI Express Root Port #7 - A296
          Intel(R) 200 Series Chipset Family PCI Express Root Port #9 - A298
            Samsung NVMe Controller
          Intel(R) 200 Series Chipset Family LPC Controller (X299) - A2D2
           Compteur d'événement de haute précision
           Contrôleur d'accès direct à la mémoire
           Contrôleur d'interruptions programmable
           Coprocesseur arithmétique
           Haut-parleur système
           Horloge système
           Horloge système CMOS/en temps réel
          Contrôleur High Definition Audio
             Haut-parleurs (Realtek High Definition Audio)
             Microphone (Realtek High Definition Audio)
             Realtek Digital Output (Realtek High Definition Audio)
         Intel Xeon processor P family/Core i7 CHA Registers - 2054
         Intel Xeon processor P family/Core i7 CHA Registers - 2055
         Intel Xeon processor P family/Core i7 CHA Registers - 2056
         Intel Xeon processor P family/Core i7 CHA Registers - 2057
         Intel Xeon processor P family/Core i7 CHA Registers - 208D
         Intel Xeon processor P family/Core i7 CHA Registers - 208E
         Intel Xeon processor P family/Core i7 Intel VT - D - 2034
         Intel Xeon processor P family/Core i7 IOxAPIC Configuration Registers - 2036
         Intel Xeon processor P family/Core i7 PCU Registers - 2080
         Intel Xeon processor P family/Core i7 PCU Registers - 2081
         Intel Xeon processor P family/Core i7 PCU Registers - 2082
         Intel Xeon processor P family/Core i7 PCU Registers - 2083
         Intel Xeon processor P family/Core i7 PCU Registers - 2084
         Intel Xeon processor P family/Core i7 PCU Registers - 2085
         Intel Xeon processor P family/Core i7 PCU Registers - 2086
         Intel Xeon processor P family/Core i7 RAS Configuration Registers - 2035
         Intel Xeon processor P family/Core i7 DECS Channel 2 - 2048
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2040
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2041
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2042
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2043
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2044
         Intel Xeon processor P family/Core i7 Integrated Memory Controller - 2066
         Intel Xeon processor P family/Core i7 LM Channel 1 - 2045
         Intel Xeon processor P family/Core i7 LM Channel 2 - 2049
         Intel Xeon processor P family/Core i7 LMDP Channel 1 - 2047
         Intel Xeon processor P family/Core i7 LMDP Channel 2 - 204B
         Intel Xeon processor P family/Core i7 LMS Channel 1 - 2046
         Intel Xeon processor P family/Core i7 LMS Channel 2 - 204A
          Intel(R) Xeon(R) processor P family/Core i7 PCI Express Root Port 1A - 2030
             Moniteur Plug-and-Play générique
              NVIDIA High Definition Audio
               C49HG9x-4 (NVIDIA High Definition Audio)
               ZOWIE XL LCD-0 (NVIDIA High Definition Audio)
         Intel Xeon processor P family/Core i7 M2PCI Registers - 2018
         Intel Xeon processor P family/Core i7 M3KTI Registers - 204C
         Intel Xeon processor P family/Core i7 M3KTI Registers - 204D
         Intel Xeon processor P family/Core i7 M3KTI Registers - 204E
CPU
  Intel Core i7 7820X
   Cores 8
   Threads 16
   Name Intel Core i7 7820X
   Code Name Skylake-X
   Package Socket 2066 LGA
   Technology 14nm
   Specification Intel Core i7-7820X CPU @ 3.60GHz
   Family 6
   Extended Family 6
   Model 5
   Extended Model 55
   Stepping 4
   Revision H0
   Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3
   Virtualization Supported, Enabled
   Hyperthreading Supported, Enabled
   Fan Speed 1132 RPM
   Stock Core Speed 3600 MHz
   Stock Bus Speed 100 MHz
   Average Temperature 31 °C
    Caches
     L1 Data Cache Size 8 x 32 KBytes
     L1 Instructions Cache Size 8 x 32 KBytes
     L2 Unified Cache Size 8 x 1024 KBytes
     L3 Unified Cache Size 11264 KBytes
    Cores
      Core 0
       Core Speed 1200.0 MHz
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 32 °C
       Threads APIC ID: 0, 1
      Core 1
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 30 °C
       Threads APIC ID: 2, 3
      Core 2
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 30 °C
       Threads APIC ID: 4, 5
      Core 3
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 31 °C
       Threads APIC ID: 6, 7
      Core 4
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 30 °C
       Threads APIC ID: 8, 9
      Core 5
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 31 °C
       Threads APIC ID: 10, 11
      Core 6
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 31 °C
       Threads APIC ID: 12, 13
      Core 7
       Multiplier x 12.0
       Bus Speed 100.0 MHz
       Temperature 31 °C
       Threads APIC ID: 14, 15
RAM
  Memory
   Type Unknown
   Size 65238 MBytes
   DRAM Frequency 1066.7 MHz
   CAS# Latency (CL) 15 clocks
   RAS# to CAS# Delay (tRCD) 15 clocks
   RAS# Precharge (tRP) 15 clocks
   Cycle Time (tRAS) 36 clocks
   Command Rate (CR) 2T
  Physical Memory
   Memory Usage 7 %
   Total Physical 64 GB
   Available Physical 59 GB
   Total Virtual 73 GB
   Available Virtual 68 GB
  SPD
   Number Of SPD Modules 0
Motherboard
 Manufacturer Gigabyte Technology Co. Ltd.
 Model X299 AORUS Gaming 7
 Version x.x
 Chipset Vendor Intel
 Chipset Model Skylake-X
 Chipset Revision 04
 Southbridge Vendor Intel
 Southbridge Model X299
 Southbridge Revision 00
 System Temperature 35 °C
  BIOS
   Brand American Megatrends Inc.
   Version F7
   Date 14/09/2017
  Voltage
   CPU CORE 1.788 V
   MEMORY CONTROLLER 1.980 V
   VIN2 2.016 V
   VIN3 1.980 V
   VIN4 1.200 V
   VIN5 0.840 V
   VIN6 1.200 V
   VIN7 1.680 V
  PCI Data
    Slot PCI-E
     Slot Type PCI-E
     Slot Usage In Use
     Data lanes x16
     Slot Designation J6B2
     Characteristics 3.3V, Shared, PME
     Slot Number 0
    Slot PCI-E
     Slot Type PCI-E
     Slot Usage In Use
     Data lanes x1
     Slot Designation J6B1
     Slot Number 1
    Slot PCI-E
     Slot Type PCI-E
     Slot Usage In Use
     Data lanes x1
     Slot Designation J6D1
     Slot Number 2
    Slot PCI-E
     Slot Type PCI-E
     Slot Usage In Use
     Data lanes x1
     Slot Designation J7B1
     Slot Number 3
    Slot PCI-E
     Slot Type PCI-E
     Slot Usage In Use
     Data lanes x1
     Slot Designation J8B4
     Slot Number 4
Graphics
  Monitor 1
   Name ZOWIE XL LCD on NVIDIA GeForce GTX 1080 Ti
   Current Resolution 1920x1080 pixels
   Work Resolution 1920x1040 pixels
   State Enabled
   Multiple displays Extended, Primary, Enabled
   Monitor Width 1920
   Monitor Height 1080
   Monitor BPP 32 bits per pixel
   Monitor Frequency 240 Hz
   Device \\.\DISPLAY1\Monitor0
  Monitor 2
   Name C49HG9x on NVIDIA GeForce GTX 1080 Ti
   Current Resolution 3840x1080 pixels
   Work Resolution 3840x1040 pixels
   State Enabled
   Multiple displays Extended, Secondary, Enabled
   Monitor Width 3840
   Monitor Height 1080
   Monitor Frequency 120 Hz
   Device \\.\DISPLAY2\Monitor0
   Manufacturer NVIDIA
   Model GeForce GTX 1080 Ti
   Device ID 10DE-1B06
   Revision A2
   Subvendor Gigabyte (1458)
   Bus Interface PCI Express x16
   Temperature 55 °C
   Driver version 23.21.13.8831
   BIOS Version 86.02.39.00.9e
   Physical Memory 3071 MB
   Virtual Memory 3072 MB
Storage
  Hard drives
     Manufacturer SAMSUNG
     Interface Unknown
     Capacity 953 GB
     Real size 1 024 209 543 168 bytes
     RAID Type None
      S.M.A.R.T
       S.M.A.R.T not supported
      Partition 0
       Partition ID Disk #0, Partition #0
       File System NTFS
       Volume Serial Number E824D525
       Size 499 MB
       Used Space 32,2 MB (6%)
       Free Space 467 MB (94%)
      Partition 1
       Partition ID Disk #0, Partition #1
       Disk Letter C:
       File System NTFS
       Volume Serial Number F8268F14
       Size 952 GB
       Used Space 175 GB (18%)
       Free Space 777 GB (82%)
      Partition 2
       Partition ID Disk #0, Partition #2
       File System NTFS
       Volume Serial Number BC8FC511
       Size 469 MB
       Used Space 387 MB (82%)
       Free Space 82 MB (18%)
    ST4000VN008-2DR166
     Manufacturer Seagate
     Heads 16
     Cylinders 486 401
     Tracks 124 032 255
     Sectors 7 814 032 065
     SATA type SATA-III 6.0Gb/s
     Device type Fixed
     ATA Standard ACS3
     Serial Number WDH304KE
     Firmware Version Number SC60
     LBA Size 48-bit LBA
     Power On Count 22 times
     Power On Time 2,7 days
     Speed 5980 RPM
     Features S.M.A.R.T., APM, NCQ
     Max. Transfer Mode SATA III 6.0Gb/s
     Used Transfer Mode SATA III 6.0Gb/s
     Interface SATA
     Capacity 3726 GB
     Real size 4 000 787 030 016 bytes
     RAID Type None
      S.M.A.R.T
       Status Good
       Temperature 32 °C
       Temperature Range OK (less than 50 °C)
        S.M.A.R.T attributes
          01
           Attribute name Read Error Rate
           Real value 0
           Current 84
           Worst 65
           Threshold 44
           Raw Value 000E27A154
           Status Good
          03
           Attribute name Spin-Up Time
           Real value 0 ms
           Current 94
           Worst 93
           Threshold 0
           Raw Value 0000000000
           Status Good
          04
           Attribute name Start/Stop Count
           Real value 29
           Current 100
           Worst 100
           Threshold 20
           Raw Value 000000001D
           Status Good
          05
           Attribute name Reallocated Sectors Count
           Real value 0
           Current 100
           Worst 100
           Threshold 10
           Status Good
          07
           Attribute name Seek Error Rate
           Real value 0
           Current 68
           Worst 60
           Threshold 45
           Raw Value 00005A35FB
           Status Good
          09
           Attribute name Power-On Hours (POH)
           Real value 2d 16h
           Current 100
           Worst 100
           Threshold 0
           Raw Value 0000000040
           Status Good
          0A
           Attribute name Spin Retry Count
           Real value 0
           Current 100
           Worst 100
           Threshold 97
           Status Good
          0C
           Attribute name Device Power Cycle Count
           Real value 22
           Current 100
           Worst 100
           Threshold 20
           Raw Value 0000000016
           Status Good
          B8
           Attribute name End-to-End error / IOEDC
           Real value 0
           Current 100
           Worst 100
           Threshold 99
           Status Good
          BB
           Attribute name Reported Uncorrectable Errors
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          BC
           Attribute name Command Timeout
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          BD
           Attribute name High Fly Writes (WDC)
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          BE
           Attribute name Airflow Temperature
           Real value 32 °C
           Current 68
           Worst 63
           Threshold 40
           Raw Value 0020200020
           Status Good
          BF
           Attribute name G-sense error rate
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C0
           Attribute name Power-off Retract Count
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C1
           Attribute name Load/Unload Cycle Count
           Real value 667
           Current 100
           Worst 100
           Threshold 0
           Raw Value 000000029B
           Status Good
          C2
           Attribute name Temperature
           Real value 32 °C
           Current 32
           Worst 40
           Threshold 0
           Raw Value 0000000020
           Status Good
          C5
           Attribute name Current Pending Sector Count
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C6
           Attribute name Uncorrectable Sector Count
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C7
           Attribute name UltraDMA CRC Error Count
           Real value 0
           Current 200
           Worst 200
           Threshold 0
           Status Good
          F0
           Attribute name Head Flying Hours
           Real value 1d 18h
           Current 100
           Worst 253
           Threshold 0
           Raw Value 000000002A
           Status Good
          F1
           Attribute name Total LBAs Written
           Real value 638 694 105
           Current 100
           Worst 253
           Threshold 0
           Raw Value 002611B2D9
           Status Good
          F2
           Attribute name Total LBAs Read
           Real value 192 283 150
           Current 100
           Worst 253
           Threshold 0
           Raw Value 000B76020E
           Status Good
      Partition 0
       Partition ID Disk #1, Partition #0
       Disk Letter D:
       File System NTFS
       Volume Serial Number A8C1120F
       Size 3725 GB
       Used Space 177 GB (4%)
       Free Space 3547 GB (96%)
     Manufacturer TOSHIBA
     Heads 16
     Cylinders 121 601
     Tracks 31 008 255
     Sectors 1 953 520 065
     SATA type SATA-II 3.0Gb/s
     Device type Fixed
     ATA Standard ATA8-ACS
     Serial Number 1474SL3XS
     Firmware Version Number AX001U
     LBA Size 48-bit LBA
     Power On Count 1707 times
     Power On Time 463,8 days
     Speed 5400 RPM
     Max. Transfer Mode SATA II 3.0Gb/s
     Used Transfer Mode SATA II 3.0Gb/s
     Interface USB (SATA)
     Capacity 931 GB
     Real size 1 000 204 886 016 bytes
     RAID Type None
      S.M.A.R.T
       Status Good
       Temperature 32 °C
          01
           Real value 0
           Current 100
           Worst 100
           Threshold 50
           Status Good
          02
           Attribute name Throughput Performance
           Real value 0
           Current 100
           Worst 100
           Threshold 50
           Status Good
          03
           Real value 2754 ms
           Current 100
           Worst 100
           Threshold 1
           Raw Value 0000000AC2
           Status Good
          04
           Real value 6 908
           Current 100
           Worst 100
           Threshold 0
           Raw Value 0000001AFC
           Status Good
          05
           Real value 0
           Current 100
           Worst 100
           Threshold 50
           Status Good
          07
           Real value 0
           Current 100
           Worst 100
           Threshold 50
           Status Good
          08
           Attribute name Seek Time Performance
           Real value 0
           Current 100
           Worst 100
           Threshold 50
           Status Good
          09
           Real value 463d 18h
           Current 73
           Worst 73
           Threshold 0
           Raw Value 0000002B7A
           Status Good
          0A
           Real value 0
           Current 237
           Worst 100
           Threshold 30
           Status Good
          0C
           Real value 1 707
           Current 100
           Worst 100
           Threshold 0
           Raw Value 00000006AB
           Status Good
          BF
           Real value 4
           Current 100
           Worst 100
           Threshold 0
           Raw Value 0000000004
           Status Good
          C0
           Real value 552
           Current 99
           Worst 99
           Threshold 0
           Raw Value 0000000228
           Status Good
          C1
           Real value 13 047
           Current 99
           Worst 99
           Threshold 0
           Raw Value 00000032F7
           Status Good
          C2
           Real value 32 °C
           Current 100
           Worst 100
           Threshold 0
           Raw Value 00000A0020
           Status Good
          C4
           Attribute name Reallocation Event Count
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C5
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C6
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          C7
           Real value 0
           Current 200
           Worst 200
           Threshold 0
           Status Good
          DC
           Attribute name Disk Shift
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          DE
           Attribute name Loaded Hours
           Real value 1 430
           Current 97
           Worst 97
           Threshold 0
           Raw Value 0000000596
           Status Good
          DF
           Attribute name Load/Unload Retry Count
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          E0
           Attribute name Load Friction
           Real value 0
           Current 100
           Worst 100
           Threshold 0
           Status Good
          E2
           Attribute name Load 'In'-time
           Real value 182
           Current 100
           Worst 100
           Threshold 0
           Raw Value 00000000B6
           Status Good
          F0
           Real value 0h
           Current 100
           Worst 100
           Threshold 1
           Status Good
      Partition 0
       Partition ID Disk #2, Partition #0
       Disk Letter E:
       File System NTFS
       Volume Serial Number 78152663
       Size 931 GB
       Used Space 371 GB (39%)
       Free Space 559 GB (61%)
  Flash drives
    UFD 3.0 Silicon-Power64G USB Device
     Interface USB
     Capacity 58 GB
     Real size 63 222 841 344 bytes
     RAID Type None
      S.M.A.R.T
      Partition 0
       Partition ID Disk #3, Partition #0
       Disk Letter F:
       File System FAT32
       Volume Serial Number 16073D1B
       Size 58 GB
       Used Space 2,41 MB (0%)
       Free Space 58 GB (100%)
Optical Drives
 No optical disk drives detected
Audio
  Sound Cards
   Périphérique audio USB
   NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
  Playback Devices
   Haut-parleurs (Realtek High Definition Audio) (default)
  Recording Devices
   Microphone (Realtek High Definition Audio) (default)
Peripherals
   Device Kind Keyboard
   Device Name Périphérique clavier PIH
   Vendor Unknown
   Location Corsair composite virtual input device
    Driver
     Date 6-21-2006
     Version 10.0.16299.15
     File C:\WINDOWS\system32\DRIVERS\kbdhid.sys
     File C:\WINDOWS\system32\DRIVERS\kbdclass.sys
   Vendor Unknown
    Driver
     Date 6-21-2006
   Vendor Unknown
   Location Périphérique d’entrée USB
    Driver
     Date 6-21-2006
   Vendor Unknown
    Driver
     Date 6-21-2006
  Souris HID
   Device Kind Mouse
   Device Name Souris HID
   Vendor Unknown
    Driver
     Date 6-21-2006
     File C:\WINDOWS\system32\DRIVERS\mouhid.sys
     File C:\WINDOWS\system32\DRIVERS\mouclass.sys
  Souris HID
   Device Kind Mouse
   Vendor Unknown
    Driver
     Date 6-21-2006
  Souris HID
   Device Kind Mouse
   Vendor Unknown
    Driver
     Date 6-21-2006
   Device Kind Audio device
   Device Name Périphérique audio USB
   Vendor Logitech
   Comment C922 Pro Stream Webcam
   Location C922 Pro Stream Webcam
    Driver
     Date 9-28-2017
     File C:\WINDOWS\system32\drivers\USBAUDIO.sys
     File C:\WINDOWS\system32\DRIVERS\drmk.sys
     File C:\WINDOWS\system32\DRIVERS\portcls.sys
     File C:\WINDOWS\system32\WMALFXGFXDSP.dll
     File C:\WINDOWS\system32\SysFxUI.dll
  External USB 3.0
   Device Kind Portable Device
   Device Name External USB 3.0
   Vendor TOSHIBA
   Comment Nouveau nom
   Location Volume
    Driver
     Date 6-21-2006
     File C:\WINDOWS\system32\DRIVERS\WUDFRd.sys
  Silicon-Power64G
   Device Name Silicon-Power64G
   Vendor UFD_3.0
   Comment SP UFD U3
   Location Volume
    Driver
     Date 6-21-2006
  Printers
    Fax
     Printer Port SHRFAX:
     Print Processor winprint
     Availability Always
     Priority 1
     Duplex None
     Print Quality 200 * 200 dpi Monochrome
     Status Unknown
      Driver
       Driver Name Microsoft Shared Fax Driver (v4.00)
       Driver Path C:\WINDOWS\system32\spool\DRIVERS\x64\3\FXSDRV.DLL
    Microsoft Print to PDF (Default Printer)
     Printer Port PORTPROMPT:
     Availability Always
     Priority 1
     Duplex None
     Print Quality 600 * 600 dpi Color
     Status Unknown
      Driver
       Driver Name Microsoft Print To PDF (v6.03)
       Driver Path C:\WINDOWS\System32\DriverStore\FileRepository\ntprint.inf_amd64_ab738c05d09b470b\Amd64\mxdwdrv.dll
    Microsoft XPS Document Writer
     Availability Always
     Priority 1
     Duplex None
     Status Unknown
      Driver
       Driver Name Microsoft XPS Document Writer v4 (v6.03)
Network
 You are connected to the internet
 Connected through Killer E2500 Gigabit Ethernet Controller
 IP Address 192.168.1.15
 Subnet mask 255.255.255.0
 Gateway server 192.168.1.1
 Preferred DNS server 192.168.1.1
 DHCP Enabled
 DHCP server 192.168.1.1
 External IP Address 86.194.211.247
 Adapter Type Ethernet
 NetBIOS over TCP/IP Enabled via DHCP
 NETBIOS Node Type Hybrid node
 Link Speed 0 Bps
  Computer Name
   NetBIOS Name DESKTOP-SO2TEKJ
   DNS Name DESKTOP-SO2TEKJ
   Membership Part of workgroup
   Workgroup WORKGROUP
  Remote Desktop
   Disabled
    Console
     State Active
  WinInet Info
   Connexion réseau
   Local system uses a local area network to connect to the Internet
   Local system has RAS to connect to the Internet
  Wi-Fi Info
   Using native Wi-Fi API version 2
   Available access points count 6
    Wi-Fi ()
     SSID
     Frequency 2412000 kHz
     Channel Number 1
     Name No name
     Signal Strength/Quality 86
     Security Disabled
     State The interface is not connected to any network
     Dot11 Type Infrastructure BSS network
     Network Connectible
     Network Flags There is a profile for this network
     Cipher Algorithm to be used when joining this network No Cipher algorithm is enabled/supported
     Default Auth used to join this network for the first time IEEE 802.11 Open System authentication algorithm
    Wi-Fi (FreeWifi)
     SSID FreeWifi
     Channel Number 1
     Name FreeWifi
     Signal Strength/Quality 74
     Security Disabled
     Network Connectible
    Wi-Fi (FreeWifi_secure)
     SSID FreeWifi_secure
     Frequency 2472000 kHz
     Channel Number 13
     Name FreeWifi_secure
     Security Enabled
     Network Connectible
     Cipher Algorithm to be used when joining this network AES-CCMP algorithm
     Default Auth used to join this network for the first time 802.11i Robust Security Network Association (RSNA) algorithm (WPA2 is one such algorithm)
    Wi-Fi (Freebox-0D6FA6)
     SSID Freebox-0D6FA6
     Channel Number 13
     Name Freebox-0D6FA6
     Signal Strength/Quality 42
     Security Enabled
     Network Connectible
     Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK
    Wi-Fi (Livebox-D8BA)
     SSID Livebox-D8BA
     Frequency 5500000 kHz
     Channel Number 100
     Name Livebox-D8BA
     Signal Strength/Quality 100
     Security Enabled
     Network Connectible
    Wi-Fi (freebox_marie)
     SSID freebox_marie
     Channel Number 1
     Name freebox_marie
     Signal Strength/Quality 68
     Security Enabled
     Network Connectible
     Default Auth used to join this network for the first time WPA algorithm that uses preshared keys (PSK)
  WinHTTPInfo
   WinHTTPSessionProxyType No proxy
   Session Proxy
   Session Proxy Bypass
   Connect Retries 5
   Connect Timeout (ms) 60 000
   HTTP Version HTTP 1.1
   Max Connects Per 1.0 Servers INFINITE
   Max Connects Per Servers INFINITE
   Max HTTP automatic redirects 10
   Max HTTP status continue 10
   Send Timeout (ms) 30 000
   IEProxy Auto Detect Yes
   IEProxy Auto Config
   IEProxy
   IEProxy Bypass
   Default Proxy Config Access Type No proxy
   Default Config Proxy
   Default Config Proxy Bypass
  Sharing and Discovery
   Network Discovery Enabled
   File and Printer Sharing Disabled
   File and printer sharing service Enabled
   Simple File Sharing Enabled
   Administrative Shares Enabled
  Adapters List
    Enabled
       Connection Name Connexion réseau Bluetooth
       DHCP enabled Yes
       MAC Address 9C-B6-D0-1E-26-16
      Intel(R) Ethernet Connection (2) I219-V
       Connection Name Ethernet
       DHCP enabled Yes
       MAC Address E0-D5-5E-22-BF-36
       Connection-specific DNS Suffix home
       Connection Name Ethernet 2
       NetBIOS over TCPIP Yes
       DHCP enabled Yes
       MAC Address E0-D5-5E-22-BF-34
       DHCP 192.168.1.1
       DNS Server 192.168.1.1
       Connection Name Wi-Fi
       DHCP enabled Yes
       MAC Address 9C-B6-D0-1E-26-15
  Network Shares
   No network shares
  Current TCP Connections
    C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe (10156)
     Local 127.0.0.1:49810 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 127.0.0.1:49811 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 192.168.1.15:49816 CLOSE-WAIT Remote 35.177.223.105:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49815 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 192.168.1.15:49832 CLOSE-WAIT Remote 8.36.112.54:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49814 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 127.0.0.1:49809 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 127.0.0.1:49812 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
     Local 127.0.0.1:49803 ESTABLISHED Remote 127.0.0.1:49794 (Querying... )
    C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe (6332)
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49810 (Querying... )
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49811 (Querying... )
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49812 (Querying... )
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49814 (Querying... )
     Local 127.0.0.1:49794 LISTEN
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49803 (Querying... )
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49809 (Querying... )
     Local 127.0.0.1:49794 ESTABLISHED Remote 127.0.0.1:49815 (Querying... )
    C:\Program Files (x86)\Tt\Riing RGB Radiator Fan TT Premium Edition\Thermaltake RGB Fan Controller.exe (12152)
     Local 0.0.0.0:5487 LISTEN
    C:\Program Files\WindowsApps\Microsoft.SkypeApp_12.8.487.0_x64__kzf8qxf38zg5c\SkypeHost.exe (8080)
     Local 192.168.1.15:49749 ESTABLISHED Remote 13.79.241.202:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49753 ESTABLISHED Remote 13.79.241.202:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49755 ESTABLISHED Remote 13.79.241.202:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49764 ESTABLISHED Remote 13.107.3.128:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49754 ESTABLISHED Remote 13.79.241.202:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49763 ESTABLISHED Remote 40.114.149.220:443 (Querying... ) (HTTPS)
    C:\Users\alexa\AppData\Local\Discord\app-0.0.298\Discord.exe (11392)
     Local 192.168.1.15:49831 ESTABLISHED Remote 104.16.59.37:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49868 ESTABLISHED Remote 104.16.13.231:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49830 ESTABLISHED Remote 104.16.59.5:443 (Querying... ) (HTTPS)
    C:\Users\alexa\AppData\Local\Discord\app-0.0.298\Discord.exe (9252)
     Local 127.0.0.1:6463 LISTEN
    C:\Users\alexa\AppData\Local\Microsoft\OneDrive\OneDrive.exe (10172)
     Local 192.168.1.15:49797 ESTABLISHED Remote 40.114.149.220:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49798 ESTABLISHED Remote 40.114.149.220:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49813 ESTABLISHED Remote 40.90.136.1:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49817 ESTABLISHED Remote 40.90.136.1:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49825 ESTABLISHED Remote 40.77.229.24:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49826 ESTABLISHED Remote 23.101.79.119:443 (Querying... ) (HTTPS)
    C:\Users\alexa\AppData\Roaming\Twitch\Bin\Electron\TwitchUI.exe (11868)
     Local 192.168.1.15:49853 ESTABLISHED Remote 151.101.194.167:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49847 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 127.0.0.1:49848 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 192.168.1.15:49871 ESTABLISHED Remote 104.16.104.24:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49872 ESTABLISHED Remote 104.16.104.24:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49852 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 192.168.1.15:49874 ESTABLISHED Remote 104.16.81.211:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49875 ESTABLISHED Remote 104.16.103.24:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49881 ESTABLISHED Remote 35.167.79.137:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49849 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 192.168.1.15:49883 ESTABLISHED Remote 34.210.113.185:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49850 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 127.0.0.1:49851 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 127.0.0.1:49854 CLOSE-WAIT Remote 127.0.0.1:49837 (Querying... )
     Local 127.0.0.1:49857 ESTABLISHED Remote 127.0.0.1:49838 (Querying... )
     Local 192.168.1.15:49873 ESTABLISHED Remote 52.208.230.72:443 (Querying... ) (HTTPS)
    C:\Users\alexa\AppData\Roaming\Twitch\Bin\Twitch.exe (8072)
     Local 192.168.1.15:49835 ESTABLISHED Remote 13.33.242.155:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49840 ESTABLISHED Remote 104.16.61.226:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:8849 LISTEN
     Local 127.0.0.1:49838 ESTABLISHED Remote 127.0.0.1:49857 (Querying... )
     Local 127.0.0.1:49838 LISTEN
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49854 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49852 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49851 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49850 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49849 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49848 (Querying... )
     Local 127.0.0.1:49837 FIN-WAIT-2 Remote 127.0.0.1:49847 (Querying... )
     Local 127.0.0.1:49837 LISTEN
     Local 192.168.1.15:49899 ESTABLISHED Remote 52.94.232.194:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49836 LISTEN
     Local 192.168.1.15:49846 ESTABLISHED Remote 104.16.81.211:443 (Querying... ) (HTTPS)
    C:\Windows\System32\backgroundTaskHost.exe (10224)
     Local 192.168.1.15:49736 ESTABLISHED Remote 13.107.21.200:443 (Querying... ) (HTTPS)
    C:\Windows\System32\svchost.exe (5932)
     Local 192.168.1.15:49778 ESTABLISHED Remote 40.90.136.1:443 (Querying... ) (HTTPS)
    C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe (7348)
     Local 192.168.1.15:49734 ESTABLISHED Remote 13.107.21.200:443 (Querying... ) (HTTPS)
    D:\Steam\Steam.exe (11816)
     Local 192.168.1.15:49821 ESTABLISHED Remote 173.223.11.40:80 (Querying... ) (HTTP)
     Local 192.168.1.15:49900 SYN-SENT Remote 146.66.154.10:80 (Querying... ) (HTTP)
     Local 127.0.0.1:27060 LISTEN
     Local 0.0.0.0:27036 LISTEN
    lsass.exe (888)
     Local 0.0.0.0:49758 LISTEN
    nvcontainer.exe (3856)
     Local 127.0.0.1:65000 LISTEN
     Local 127.0.0.1:49776 ESTABLISHED Remote 127.0.0.1:65001 (Querying... )
     Local 127.0.0.1:65001 LISTEN
     Local 127.0.0.1:65001 ESTABLISHED Remote 127.0.0.1:49776 (Querying... )
    services.exe (880)
     Local 0.0.0.0:49669 LISTEN
    spoolsv.exe (3500)
     Local 0.0.0.0:49668 LISTEN
    svchost.exe (10548)
     Local 192.168.1.15:49783 ESTABLISHED Remote 52.236.42.239:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:5040 LISTEN
     Local 192.168.1.15:49784 ESTABLISHED Remote 52.236.42.239:443 (Querying... ) (HTTPS)
    svchost.exe (1080)
     Local 0.0.0.0:135 (DCE) LISTEN
    svchost.exe (1412)
     Local 0.0.0.0:49665 LISTEN
    svchost.exe (1480)
     Local 0.0.0.0:49666 LISTEN
    svchost.exe (3864)
     Local 192.168.1.15:49679 ESTABLISHED Remote 40.77.229.29:443 (Querying... ) (HTTPS)
    System Process
     Local 127.0.0.1:49695 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 192.168.1.15:49675 TIME-WAIT Remote 40.77.226.249:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49670 TIME-WAIT Remote 40.77.226.246:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49861 TIME-WAIT Remote 127.0.0.1:49862 (Querying... )
     Local 127.0.0.1:49865 TIME-WAIT Remote 127.0.0.1:49866 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49793 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49785 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49673 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49674 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49792 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49789 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49680 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49774 (Querying... )
     Local 192.168.1.15:49897 TIME-WAIT Remote 8.36.113.113:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49672 TIME-WAIT Remote 127.0.0.1:65000 (Querying... )
     Local 127.0.0.1:49677 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49678 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49687 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49688 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:65000 TIME-WAIT Remote 127.0.0.1:49775 (Querying... )
     Local 127.0.0.1:49702 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49706 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49709 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49718 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49721 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49732 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 127.0.0.1:49769 TIME-WAIT Remote 127.0.0.1:5357 (Querying... )
     Local 192.168.1.15:49896 TIME-WAIT Remote 8.36.113.113:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49886 TIME-WAIT Remote 173.223.11.11:80 (Querying... ) (HTTP)
     Local 192.168.1.15:49882 TIME-WAIT Remote 216.58.209.238:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49870 TIME-WAIT Remote 54.230.79.94:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49863 TIME-WAIT Remote 65.55.252.202:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49833 TIME-WAIT Remote 54.230.79.129:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49795 TIME-WAIT Remote 8.36.112.54:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49790 TIME-WAIT Remote 8.36.120.11:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49779 TIME-WAIT Remote 134.170.178.116:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49839 TIME-WAIT Remote 216.58.209.228:80 (Querying... ) (HTTP)
     Local 192.168.1.15:49766 TIME-WAIT Remote 134.170.29.148:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49760 TIME-WAIT Remote 134.170.178.116:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49756 TIME-WAIT Remote 134.170.178.103:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49746 TIME-WAIT Remote 134.170.179.91:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49745 TIME-WAIT Remote 40.90.136.1:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49743 TIME-WAIT Remote 23.210.41.203:80 (Querying... ) (HTTP)
     Local 192.168.1.15:49737 TIME-WAIT Remote 185.48.81.162:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49730 TIME-WAIT Remote 134.170.178.103:443 (Querying... ) (HTTPS)
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49841 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49842 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49843 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49844 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49845 (Querying... )
     Local 192.168.1.15:49729 TIME-WAIT Remote 204.79.197.213:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49728 TIME-WAIT Remote 134.170.179.91:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49726 TIME-WAIT Remote 40.90.136.1:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49723 TIME-WAIT Remote 134.170.178.97:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49719 TIME-WAIT Remote 8.36.120.11:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49703 TIME-WAIT Remote 8.36.120.11:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49698 TIME-WAIT Remote 52.178.147.240:80 (Querying... ) (HTTP)
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49856 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49858 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49859 (Querying... )
     Local 127.0.0.1:49837 TIME-WAIT Remote 127.0.0.1:49860 (Querying... )
     Local 192.168.1.15:49697 TIME-WAIT Remote 40.90.136.1:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49691 TIME-WAIT Remote 13.107.21.200:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49690 TIME-WAIT Remote 40.77.226.250:443 (Querying... ) (HTTPS)
     Local 192.168.1.15:49682 TIME-WAIT Remote 185.48.81.162:443 (Querying... ) (HTTPS)
    System Process
     Local 0.0.0.0:445 (Windows shares) LISTEN
     Local 0.0.0.0:5357 LISTEN
     Local 192.168.1.15:139 (NetBIOS session service) LISTEN
    wininit.exe (808)
     Local 0.0.0.0:49664 LISTEN
Generated with Speccy v1.31.732[/spoiler]
J'ai un bsod whea_uncorrectable_error en jouant simplement à CSGO (je fais tourner des jeux bien plus gourmand sans avoir de BSOD pendant des heures) ou en streaming avec OBS plus jouant à n'importe quel jeu ( après le lancement du stream, 2-5mn plus tard je me mange un bsod whea_uncorrectable_error).
J'ai tenté :
1- formatage complet
2- installation de tous les pilotes à mettre à jour
3- enlever 4 barrettes de ram sur les 8
4- faire un clear cmos du bios
La 4ème étape m'a d'ailleurs montré ceci :
https://img15.hostingpics.net/pics/968586171126194918.png
on voit clairement que la fréquence de base de mon processeur est de 3.6GHz mais dans le bios il est cadencé à 4GHz !
A moins de n'avoir pas tout saisit, ma carte mère overclock de base mon CPU ?! et qui plus ai, même un clear cmos n'a rien changé ? il n'est pas revenu à sa fréquence de base ?
apparemment cela serai possiblement la source de mon bsod.
si vous avez des suggestions je suis tout ouïe.
n°2482484
NaeNae
Posté le 26-11-2017 à 22:40:07  profilanswer
n°2482487
NaeNae
Posté le 26-11-2017 à 23:29:29  profilanswer
j'ai tenté de comprendre pourquoi la fréquence est overclock de base par le bios, et je n'arrive pas à la mettre dans sa fréquence de base dans le bios, si quelqu'un à une idée, je commence à secher, cela fait plus d'une semaine que je tente plusieurs choses sans succès.
Je suis preneur de nouveaux tests, le stream et csgo sont importants pour moi
n°2482500
Tigrou
Sans accroc
Posté le 27-11-2017 à 10:11:20  profilanswer
Profession :  Technicien Informatique
   :sarcastic:
Feedback - Stacy's mom
n°2482541
NaeNae
Posté le 27-11-2017 à 18:09:02  profilanswer
eeeeeeeeeetttt oui, comme quoi même quelqu'un de spécialisé peut avoir des lacunes ;)
n°2482549
corkynatio​n
Levieuxcaps
Posté le 27-11-2017 à 19:33:46  profilanswer
tiens compare avec le miens, ici ça marche
Summary
  Operating System
   Windows 10 Professionnel 64-bit
  CPU
   Intel Xeon E5649 @ 2.53GHz 25 °C
   Westmere-EP 32nm Technology
   Intel Xeon E5649 @ 2.53GHz 26 °C
  RAM
   20,0 Go Triple-Channel DDR3 @ 666MHz (9-9-9-24)
  Motherboard
   Supermicro X8DT3 (CPU 2) 17 °C
  Graphics
   PLE2403WS (1920x1200@59Hz)
   2047MB NVIDIA GeForce GTX 670 (MSI) 44 °C
  Storage
   119GB SAMSUNG SSD 830 Series ATA Device (SSD) 24 °C
  Optical Drives
  Audio
Operating System
 Computer type: Main system chassis
 Installation Date: 19/10/2017 08:59:46
 Serial Number:  :o
  Windows Security Center
   User Account Control (UAC) Enabled
   Notify level 2 - Default
   Firewall Enabled
  Windows Update
   AutoUpdate Not configured
  Windows Defender
   Windows Defender Enabled
  Antivirus
   Antivirus Enabled
   Display Name Windows Defender
   Virus Signature Database Up to date
  .NET Frameworks installed
   v4.7 Full
   v4.7 Client
   v3.5 SP1
   v3.0 SP2
   v2.0 SP2
  Internet Explorer
   Version 11.64.16299.0
  PowerShell
   Version 5.1.16299.15
  Java
    Java Runtime Environment
     Path C:\Program Files (x86)\Java\jre1.8.0_144\bin\java.exe
     Version 8.0
     Update 144
     Build 01
  Environment Variables
   USERPROFILE C:\Users\
   SystemRoot C:\WINDOWS
    User Variables
     OneDrive C:\Users\gaetan\OneDrive
     Path C:\Users\\AppData\Local\Microsoft\WindowsApps
     TEMP C:\Users\\AppData\Local\Temp
     TMP C:\Users\\AppData\Local\Temp
    Machine Variables
     ComSpec C:\WINDOWS\system32\cmd.exe
     NUMBER_OF_PROCESSORS 24
     OS Windows_NT
     Path C:\ProgramData\Oracle\Java\javapath
     C:\Windows\system32
     C:\Windows
     C:\Windows\System32\Wbem
     C:\Windows\System32\WindowsPowerShell\v1.0\
     C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
     C:\WINDOWS\system32
     C:\WINDOWS
     C:\WINDOWS\System32\Wbem
     C:\WINDOWS\System32\WindowsPowerShell\v1.0\
     PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
     PROCESSOR_ARCHITECTURE AMD64
     PROCESSOR_IDENTIFIER Intel64 Family 6 Model 44 Stepping 2, GenuineIntel
     PROCESSOR_LEVEL 6
     PROCESSOR_REVISION 2c02
     PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
     C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
     TEMP C:\WINDOWS\TEMP
     TMP C:\WINDOWS\TEMP
     USERNAME SYSTEM
     windir C:\WINDOWS
  Power Profile
   Active power scheme Utilisation normale
   Hibernation Enabled
   Turn Off Monitor after: (On AC Power) 10 min
   Turn Off Hard Disk after: (On AC Power) 20 min
   Suspend after: (On AC Power) 30 min
   Screen saver Disabled
  Uptime
    Current Session
     Current Time 27/11/2017 19:31:43
     Current Uptime 156 399 sec (1 d, 19 h, 26 m, 39 s)
     Last Boot Time 26/11/2017 00:05:04
  Services
   Running Accès aux données utilisateur_25fff6b
   Running Acquisition d’image Windows (WIA)
   Running Alimentation
   Running Appel de procédure distante (RPC)
   Running Assistance IP
   Running Assistance NetBIOS sur TCP/IP
   Running Audio Windows
   Running Centre de sécurité
   Running Client de stratégie de groupe
   Running Client de suivi de lien distribué
   Running Client DHCP
   Running Client DNS
   Running Connaissance des emplacements réseau
   Running Consommation des données
   Running CoreMessaging
   Running Données de contacts_25fff6b
   Running Découverte SSDP
   Running Détection matériel noyau
   Running Expériences des utilisateurs connectés et télémétrie
   Running Gestionnaire de comptes de sécurité
   Running Gestionnaire de comptes web
   Running Gestionnaire de session locale
   Running Gestionnaire des connexions d’accès à distance
   Running Gestionnaire des connexions Windows
   Running Gestionnaire des utilisateurs
   Running Gestionnaire d’identité réseau homologue
   Running Gestionnaire d’informations d’identification
   Running Gestionnaires des paiements et des éléments sécurisés NFC
   Running Générateur de points de terminaison du service Audio Windows
   Running Hôte de synchronisation_25fff6b
   Running Hôte système de diagnostics
   Running Informations d’application
   Running Infrastructure de gestion Windows
   Running Isolation de clé CNG
   Running Journal d’événements Windows
   Running Lanceur de processus serveur DCOM
   Running Logitech Gaming Registry Service
   Running Mappeur de point de terminaison RPC
   Running Moteur de filtrage de base
   Running NVIDIA Display Container LS
   Running NVIDIA LocalSystem Container
   Running NVIDIA Telemetry Container
   Running Pare-feu Windows Defender
   Running Planificateur de tâches
   Running Plug-and-Play
   Running Protocole PNRP
   Running Razer Game Scanner
   Running Razer Surround Audio Service
   Running Serveur
   Running Serveur de modèles de données de vignette
   Running Serveur Gestionnaire de licences Windows
   Running Service antivirus Windows Defender
   Running Service Broker des événements système
   Running Service Broker pour les connexions réseau
   Running Service Broker pour les événements horaires
   Running Service Centre de sécurité Windows Defender
   Running Service Configuration du réseau
   Running Service de cache de police Windows
   Running Service de découverte automatique de Proxy Web pour les services HTTP Windows
   Running Service de géolocalisation
   Running Service de licences de client (ClipSVC)
   Running Service de l’Assistant Compatibilité des programmes
   Running Service de notification d’événements système
   Running Service de partage des données
   Running Service de plateforme des appareils connectés
   Running Service de profil utilisateur
   Running Service de stockage
   Running Service de stratégie de diagnostic
   Running Service de transfert intelligent en arrière-plan
   Running Service du clavier tactile et du volet d’écriture manuscrite
   Running Service du périphérique d’interface utilisateur
   Running Service du système de notifications Push Windows
   Running Service d’association de périphérique
   Running Service d’infrastructure des tâches en arrière-plan
   Running Service hôte WDIServiceHost
   Running Service Inspection du réseau de l’antivirus Windows Defender
   Running Service Interface du magasin réseau
   Running Service Liste des réseaux
   Running Service pour utilisateur de plateforme d’appareils connectés_25fff6b
   Running Service State Repository (StateRepository)
   Running Service utilisateur de notifications Push Windows_25fff6b
   Running Services de chiffrement
   Running Service SSTP (Secure Socket Tunneling Protocol)
   Running Spouleur d’impression
   Running Station de travail
   Running Steam Client Service
   Running Stockage des données utilisateur_25fff6b
   Running Superfetch
   Running Système d’événement COM+
   Running Thèmes
   Running Windows Search
   Running Windows Update
   Stopped Agent de stratégie IPsec
   Stopped Application système COM+
   Stopped Assistant Connectivité réseau
   Stopped Assistant Connexion avec un compte Microsoft
   Stopped Authentification naturelle
   Stopped BattlEye Service
   Stopped BranchCache
   Stopped Cache de police de Windows Presentation Foundation 3.0.0.0
   Stopped Carte de performance WMI
   Stopped Carte à puce
   Stopped Cliché instantané des volumes
   Stopped Collecteur d’événements de Windows
   Stopped Configuration automatique de réseau câblé
   Stopped Configuration automatique des périphériques connectés au réseau
   Stopped Configuration des services Bureau à distance
   Stopped Connexions réseau
   Stopped Conteneur Microsoft Passport
   Stopped Coordinateur de transactions distribuées
   Stopped Diagnostic Execution Service
   Stopped Disque virtuel
   Stopped dmwappushsvc
   Stopped Dossiers de travail
   Stopped Détection de services interactifs
   Stopped Explorateur d’ordinateurs
   Stopped Expérience audio-vidéo haute qualité Windows
   Stopped Fichiers hors connexion
   Stopped Flux d’appareils_25fff6b
   Stopped Fournisseur de cliché instantané de logiciel Microsoft
   Stopped Fournisseur du Groupement résidentiel
   Stopped Gestion des niveaux de stockage
   Stopped Gestion d’applications
   Stopped Gestion à distance de Windows (Gestion WSM)
   Stopped Gestionnaire d'authentification Xbox Live
   Stopped Gestionnaire des cartes téléchargées
   Stopped Gestionnaire des connexions automatiques d’accès à distance
   Stopped Gestionnaire d’installation de périphérique
   Stopped GraphicsPerfSvc
   Stopped Groupement de mise en réseau de pairs
   Stopped Hôte de DLL de compteur de performance
   Stopped Hôte de périphérique UPnP
   Stopped Hôte du fournisseur de découverte de fonctions
   Stopped Identité de l’application
   Stopped Interface de services d’invité Hyper-V
   Stopped Interruption SNMP
   Stopped Jeu sauvegardé sur Xbox Live
   Stopped Journaux & alertes de performance
   Stopped Localisateur d’appels de procédure distante (RPC)
   Stopped Mappage de découverte de topologie de la couche de liaison
   Stopped MessagingService_25fff6b
   Stopped Microsoft App-V Client
   Stopped Microsoft Passport
   Stopped Mode incorporé
   Stopped Modules de génération de clés IKE et AuthIP
   Stopped Netlogon
   Stopped NVIDIA NetworkService Container
   Stopped Optimisation de livraison
   Stopped Optimiser les lecteurs
   Stopped Ouverture de session secondaire
   Stopped Partage de connexion Internet (ICS)
   Stopped Printer Extensions and Notifications
   Stopped PrintWorkflow_25fff6b
   Stopped Prise en charge de l’application Rapports et solutions aux problèmes du Panneau de configuration
   Stopped Programme de mise à jour automatique du fuseau horaire
   Stopped Programme d’installation ActiveX (AxInstSV)
   Stopped Programme d’installation pour les modules Windows
   Stopped Propagation du certificat
   Stopped Protection logicielle
   Stopped Protocole EAP (Extensible Authentication Protocol)
   Stopped Préparation des applications
   Stopped Publication des ressources de découverte de fonctions
   Stopped Redirecteur de port du mode utilisateur des services Bureau à distance
   Stopped Registre à distance
   Stopped Requête du service VSS Microsoft Hyper-V
   Stopped Routage et accès distant
   Stopped Sauvegarde Windows
   Stopped Serveur de trame de la Caméra Windows
   Stopped Service Arrêt de l’invité Microsoft Hyper-V
   Stopped Service AssignedAccessManager
   Stopped Service Broker de découverte en arrière-plan DevQuery
   Stopped Service Collecteur standard du concentrateur de diagnostic Microsoft
   Stopped Service d'hôte HV
   Stopped Service d'inscription de la gestion des périphériques
   Stopped Service d'installation du Windows Store
   Stopped Service de biométrie Windows
   Stopped Service de capteur
   Stopped Service de chiffrement de lecteur BitLocker
   Stopped Service de configuration automatique WLAN
   Stopped Service de configuration automatique WWAN
   Stopped Service de configuration de conversion IP
   Stopped Service de données spatiales
   Stopped Service de démo du magasin
   Stopped Service de déploiement AppX (AppXSVC)
   Stopped Service de gestion des applications d'entreprise
   Stopped Service de gestion radio
   Stopped Service de la passerelle de la couche Application
   Stopped Service de l’Assistant de profil local
   Stopped Service de mise en réseau Xbox Live
   Stopped Service de moteur de sauvegarde en mode bloc
   Stopped Service de partage de ports Net.Tcp
   Stopped Service de perception Windows
   Stopped Service de prise en charge Bluetooth
   Stopped Service de publication des noms d’ordinateurs PNRP
   Stopped Service de rapport d’erreurs Windows
   Stopped Service de routeur AllJoyn
   Stopped Service de surveillance des capteurs
   Stopped Service de virtualisation Bureau à distance Hyper-V
   Stopped Service Données de capteur
   Stopped Service d’historique des fichiers
   Stopped Service d’installation de périphérique
   Stopped Service d’énumération de périphériques de carte à puce
   Stopped Service Gestionnaire d’accès aux fonctionnalités
   Stopped Service Google Update (gupdate)
   Stopped Service Google Update (gupdatem)
   Stopped Service Hyper-V PowerShell Direct
   Stopped Service hôte du fournisseur de chiffrement Windows
   Stopped Service Initiateur iSCSI de Microsoft
   Stopped Service KtmRm pour Distributed Transaction Coordinator
   Stopped Service mains libres Bluetooth
   Stopped Service Moniteur infrarouge
   Stopped Service Partage réseau du Lecteur Windows Media
   Stopped Service Point d'accès sans fil mobile Windows
   Stopped Service Protection avancée contre les menaces Windows Defender
   Stopped Service Pulsation Microsoft Hyper-V
   Stopped Service PushToInstall de Windows
   Stopped Service Routeur SMS Microsoft Windows.
   Stopped Service Synchronisation date/heure Microsoft Hyper-V
   Stopped Service téléphonique
   Stopped Service User Experience Virtualization
   Stopped Service Wi-Fi Direct Service de gestionnaire de connexions
   Stopped Service Windows Insider
   Stopped Service Échange de données Microsoft Hyper-V
   Stopped Service Énumérateur d’appareil mobile
   Stopped Services Bureau à distance
   Stopped Shared PC Account Manager
   Stopped SMP de l’Espace de stockages Microsoft
   Stopped Stratégie de retrait de la carte à puce
   Stopped Système de fichiers EFS (Encrypting File System)
   Stopped Temps Windows
   Stopped Télécopie
   Stopped Téléphonie
   Stopped Update Orchestrator Service
   Stopped Vérificateur de points
   Stopped WalletService
   Stopped WarpJITSvc
   Stopped WebClient
   Stopped Windows Connect Now - Registre de configuration
   Stopped Windows Installer
   Stopped Xbox Accessory Management Service
   Stopped Xbox Game Monitoring
   Stopped Écouteur du Groupement résidentiel
   Stopped Événements d’acquisition d’images fixes
  TimeZone
   TimeZone GMT +1:00 Hours
   Language Français (France)
   Location France
   Format Français (France)
   Currency €
   Date Format dd/MM/yyyy
   Time Format HH:mm:ss
  Scheduler
   27/11/2017 20:18;
   28/11/2017 04:24;
   28/11/2017 06:18;
   CCleanerSkipUAC
  Hotfixes
    Installed
      27/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.1007.0)
       Installez cette mise à jour pour actualiser les fichiers de définition
       utilisés pour détecter les virus, les logiciels espions et autres
       programmes potentiellement indésirables. Une fois l'installation
       effectuée, aucune suppression ne sera possible.
      25/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.967.0)
      25/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.961.0)
      24/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.940.0)
      22/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.841.0)
      21/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.788.0)
      20/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.738.0)
      20/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.713.0)
      18/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.660.0)
      17/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.637.0)
      16/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.579.0)
      15/11/2017  2017-11 Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1709 sur systèmes x64 (KB4048951)
       Un problème de sécurité qui pourrait avoir un impact sur votre
       système a été identifié dans un produit logiciel Microsoft. Vous
       pouvez renforcer la protection de votre système en installant
       cette mise à jour de Microsoft. Pour consulter la liste complète
       des problèmes résolus par cette mise à jour et en savoir plus,
       reportez-vous à l'article correspondant de la Base de connaissances
       Microsoft. Une fois la mise à jour installée, vous serez peut-être
       amené à redémarrer l’ordinateur.
      15/11/2017  2017-11 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes amd64 (KB4048955)
       Installez cette mise à jour pour résoudre des problèmes dans
       Windows. Pour consulter la liste complète des problèmes résolus
       par cette mise à jour, reportez-vous à l'article correspondant
       de la Base de connaissances Microsoft. Une fois cette installation
       terminée, vous serez peut-être amené à redémarrer l'ordinateur.
      15/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.539.0)
      14/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.478.0)
      13/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.429.0)
      12/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.387.0)
      11/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.364.0)
      10/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.313.0)
      09/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.257.0)
      08/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.247.0)
      08/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.243.0)
      07/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.201.0)
      06/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.132.0)
      05/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.114.0)
      04/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.100.0)
      04/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.99.0)
      03/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.70.0)
      02/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.257.12.0)
      01/11/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.346.0)
      31/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.312.0)
      30/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.252.0)
      29/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.210.0)
      29/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.209.0)
      28/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.163.0)
      27/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.160.0)
      26/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.113.0)
      25/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.60.0)
      24/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.255.2.0)
      23/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.253.1089.0)
      22/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.253.1052.0)
      21/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.253.1036.0)
      20/10/2017  Mise à jour des définitions pour Windows Defender – KB2267602 (Définition 1.253.1015.0)
      19/10/2017  2017-10 Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1709 sur systèmes x64 (KB4049179)
      19/10/2017  Update for Windows 10 Version 1709 for x64-based Systems (KB4041994)
       Install this update to resolve issues in Windows. For a complete
       listing of the issues that are included in this update, see the
       associated Microsoft Knowledge Base article for more information.
       After you install this item, you may have to restart your computer.
    Not Installed
  System Folders
   Application Data C:\ProgramData
   Cookies C:\Users\\AppData\Local\Microsoft\Windows\INetCookies
   Desktop C:\Users\\Desktop
   Documents C:\Users\Public\Documents
   Fonts C:\WINDOWS\Fonts
   Global Favorites C:\Users\\Favorites
   Internet History C:\Users\\AppData\Local\Microsoft\Windows\History
   Local Application Data C:\Users\\AppData\Local
   Music C:\Users\Public\Music
   Path for burning CD C:\Users\\AppData\Local\Microsoft\Windows\Burn\Burn
   Physical Desktop C:\Users\\Desktop
   Pictures C:\Users\Public\Pictures
   Program Files C:\Program Files
   Public Desktop C:\Users\Public\Desktop
   Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
   Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
   Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
   Templates C:\ProgramData\Microsoft\Windows\Templates
   Temporary Internet Files C:\Users\\AppData\Local\Microsoft\Windows\INetCache
   User Favorites C:\Users\\Favorites
   Videos C:\Users\Public\Videos
   Windows Directory C:\WINDOWS
   Windows/System C:\WINDOWS\system32
  Process List
    audiodg.exe
     Process ID 4304
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Windows\System32\audiodg.exe
     Memory Usage 22 MB
     Peak Memory Usage 24 MB
    chrome.exe
     Process ID 10484
     User gaetan
     Domain DESKTOP-A1TEFNO
     Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
     Memory Usage 9.35 MB
     Peak Memory Usage 9.39 MB
    chrome.exe
     Process ID 6664
     User gaetan
     Memory Usage 8.57 MB
     Peak Memory Usage 8.61 MB
    chrome.exe
     Process ID 2980
     User gaetan
     Memory Usage 115 MB
     Peak Memory Usage 124 MB
    chrome.exe
     Process ID 1264
     User gaetan
     Memory Usage 85 MB
     Peak Memory Usage 139 MB
    chrome.exe
     Process ID 2760
     User gaetan
     Memory Usage 86 MB
     Peak Memory Usage 95 MB
    conhost.exe
     Process ID 10288
     User gaetan
     Path C:\Windows\System32\conhost.exe
     Memory Usage 348 KB
     Peak Memory Usage 9.78 MB
    csrss.exe
     Process ID 756
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\csrss.exe
     Memory Usage 5.07 MB
     Peak Memory Usage 5.56 MB
    csrss.exe
     Process ID 3404
     User Système
     Domain AUTORITE NT
     Memory Usage 4.87 MB
     Peak Memory Usage 16 MB
    ctfmon.exe
     Process ID 7052
     User gaetan
     Path C:\Windows\System32\ctfmon.exe
     Memory Usage 14 MB
     Peak Memory Usage 14 MB
    dllhost.exe
     Process ID 10504
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\dllhost.exe
     Memory Usage 5.97 MB
     Peak Memory Usage 5.97 MB
    dllhost.exe
     Process ID 3088
     User gaetan
     Memory Usage 11 MB
     Peak Memory Usage 11 MB
    dllhost.exe
     Process ID 7076
     User Système
     Domain AUTORITE NT
     Memory Usage 6.27 MB
     Peak Memory Usage 6.27 MB
    dwm.exe
     Process ID 10612
     User DWM-5
     Domain Window Manager
     Path C:\Windows\System32\dwm.exe
     Memory Usage 48 MB
     Peak Memory Usage 69 MB
    explorer.exe
     Process ID 6924
     User gaetan
     Path C:\Windows\explorer.exe
     Memory Usage 89 MB
     Peak Memory Usage 97 MB
    fontdrvhost.exe
     Process ID 4272
     User UMFD-5
     Domain Font Driver Host
     Path C:\Windows\System32\fontdrvhost.exe
     Memory Usage 7.71 MB
     Peak Memory Usage 7.71 MB
    fontdrvhost.exe
     Process ID 868
     User UMFD-0
     Memory Usage 6.95 MB
     Peak Memory Usage 7.61 MB
    GameScannerService.exe
     Process ID 3388
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe
     Memory Usage 100 MB
     Peak Memory Usage 100 MB
    GoogleCrashHandler.exe
     Process ID 8832
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Google\Update\1.3.33.7\GoogleCrashHandler.exe
     Memory Usage 27 MB
     Peak Memory Usage 27 MB
    GoogleCrashHandler64.exe
     Process ID 8840
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Google\Update\1.3.33.7\GoogleCrashHandler64.exe
     Memory Usage 23 MB
     Peak Memory Usage 23 MB
    LCore.exe
     Process ID 1716
     User gaetan
     Path C:\Program Files\Logitech Gaming Software\LCore.exe
     Memory Usage 54 MB
     Peak Memory Usage 58 MB
    LockApp.exe
     Process ID 8960
     User gaetan
     Path C:\Windows\SystemApps\Microsoft.LockApp_cw5n1h2txyewy\LockApp.exe
     Memory Usage 45 MB
     Peak Memory Usage 49 MB
    LogiRegistryService.exe
     Process ID 3380
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.exe
     Memory Usage 16 MB
    logitechg_discord.exe
     Process ID 5688
     User gaetan
     Path C:\Program Files\Logitech Gaming Software\ArxApplets\Discord\logitechg_discord.exe
     Memory Usage 23 MB
    lsass.exe
     Process ID 944
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\lsass.exe
     Memory Usage 39 MB
     Peak Memory Usage 44 MB
    Memory Compression
     Process ID 2056
     User Système
     Domain AUTORITE NT
     Memory Usage 9.17 MB
     Peak Memory Usage 454 MB
    MSASCuiL.exe
     Process ID 11340
     User gaetan
     Path C:\Program Files\Windows Defender\MSASCuiL.exe
     Memory Usage 9.46 MB
     Peak Memory Usage 9.46 MB
    MsMpEng.exe
     Process ID 3352
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\Windows Defender\MsMpEng.exe
     Memory Usage 131 MB
     Peak Memory Usage 496 MB
    NisSrv.exe
     Process ID 5604
     User SERVICE LOCAL
     Domain AUTORITE NT
     Path C:\Program Files\Windows Defender\NisSrv.exe
     Memory Usage 3.69 MB
     Peak Memory Usage 38 MB
    nvcontainer.exe
     Process ID 3340
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
     Memory Usage 57 MB
    nvcontainer.exe
     Process ID 1552
     User
     Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
     Memory Usage 21 MB
     Peak Memory Usage 25 MB
    nvcontainer.exe
     Process ID 3076
     User
     Memory Usage 27 MB
     Peak Memory Usage 54 MB
    NVDisplay.Container.exe
     Process ID 1720
     User Système
     Domain AUTORITE NT
     Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
     Memory Usage 33 MB
     Peak Memory Usage 35 MB
     Process ID 2660
     User Système
     Domain AUTORITE NT
     Memory Usage 24 MB
     Peak Memory Usage 39 MB
    NVIDIA Share.exe
     Process ID 11928
     User gaetan
     Path C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
     Memory Usage 55 MB
     Peak Memory Usage 60 MB
    NVIDIA Share.exe
     Process ID 9416
     User gaetan
     Memory Usage 48 MB
     Peak Memory Usage 57 MB
     Process ID 5572
     User gaetan
     Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
     Memory Usage 9.10 MB
     Peak Memory Usage 50 MB
    nvsphelper64.exe
     Process ID 10452
     User gaetan
     Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
     Memory Usage 12 MB
     Peak Memory Usage 12 MB
    NvTelemetryContainer.exe
     Process ID 3396
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
     Memory Usage 35 MB
     Peak Memory Usage 40 MB
    OneDrive.exe
     Process ID 10024
     User gaetan
     Path C:\Users\gaetan\AppData\Local\Microsoft\OneDrive\OneDrive.exe
     Memory Usage 43 MB
    RuntimeBroker.exe
     Process ID 1004
     User gaetan
     Path C:\Windows\System32\RuntimeBroker.exe
     Memory Usage 16 MB
    RuntimeBroker.exe
     Process ID 11404
     User gaetan
     Memory Usage 25 MB
     Peak Memory Usage 28 MB
    RuntimeBroker.exe
     Process ID 11604
     User
     Memory Usage 24 MB
     Peak Memory Usage 31 MB
    RzSurroundVADStreamingService.exe
     Process ID 3508
     User Système
     Domain AUTORITE NT
     Path C:\ProgramData\Razer\Synapse\Devices\Razer Surround\Driver\RzSurroundVADStreamingService.exe
     Memory Usage 39 MB
    RzSynapse.exe
     Process ID 10812
     User gaetan
     Path C:\Program Files (x86)\Razer\Synapse\RzSynapse.exe
     Memory Usage 119 MB
    SearchIndexer.exe
     Process ID 7584
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SearchIndexer.exe
     Memory Usage 64 MB
    SearchUI.exe
     Process ID 1356
     User
     Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
     Memory Usage 107 MB
     Peak Memory Usage 111 MB
    SecurityHealthService.exe
     Process ID 3360
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\SecurityHealthService.exe
     Memory Usage 15 MB
    services.exe
     Process ID 928
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\services.exe
     Memory Usage 9.30 MB
     Peak Memory Usage 10 MB
    SettingSyncHost.exe
     Process ID 9792
     User gaetan
     Path C:\Windows\System32\SettingSyncHost.exe
     Memory Usage 7.94 MB
     Peak Memory Usage 32 MB
    ShellExperienceHost.exe
     Process ID 8072
     User gaetan
     Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
     Memory Usage 88 MB
    sihost.exe
     Process ID 8660
     User gaetan
     Path C:\Windows\System32\sihost.exe
     Memory Usage 24 MB
    SkypeHost.exe
     Process ID 2036
     User gaetan
     Path C:\Program Files\WindowsApps\Microsoft.SkypeApp_12.8.487.0_x64__kzf8qxf38zg5c\SkypeHost.exe
     Memory Usage 576 KB
    smartscreen.exe
     Process ID 11964
     User gaetan
     Path C:\Windows\System32\smartscreen.exe
     Memory Usage 16 MB
    smss.exe
     Process ID 612
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\smss.exe
     Memory Usage 1.09 MB
     Peak Memory Usage 1.23 MB
    Speccy64.exe
     Process ID 1840
     User gaetan
     Path C:\Program Files\Speccy\Speccy64.exe
     Memory Usage 33 MB
     Peak Memory Usage 33 MB
    spoolsv.exe
     Process ID 2780
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\spoolsv.exe
     Memory Usage 30 MB
    Steam.exe
     Process ID 1128
     User gaetan
     Path C:\Program Files (x86)\Steam\Steam.exe
     Memory Usage 64 MB
     Peak Memory Usage 70 MB
    SteamService.exe
     Process ID 9312
     User Système
     Domain AUTORITE NT
     Path C:\Program Files (x86)\Common Files\Steam\SteamService.exe
     Memory Usage 14 MB
     Peak Memory Usage 19 MB
    steamwebhelper.exe
     Process ID 11728
     User gaetan
     Path C:\Program Files (x86)\Steam\bin\cef\cef.win7\steamwebhelper.exe
     Memory Usage 19 MB
     Peak Memory Usage 20 MB
    steamwebhelper.exe
     Process ID 10304
     User gaetan
     Memory Usage 35 MB
    svchost.exe
     Process ID 3680
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\svchost.exe
     Memory Usage 38 MB
    svchost.exe
     Process ID 3752
     User Système
     Domain AUTORITE NT
     Memory Usage 14 MB
    svchost.exe
     Process ID 3876
     User Système
     Domain AUTORITE NT
     Memory Usage 19 MB
    svchost.exe
     Process ID 3908
     User Système
     Domain AUTORITE NT
     Memory Usage 72 MB
     Peak Memory Usage 116 MB
    svchost.exe
     Process ID 5844
     User Système
     Domain AUTORITE NT
     Memory Usage 28 MB
    svchost.exe
     Process ID 5900
     User Système
     Domain AUTORITE NT
     Memory Usage 16 MB
    svchost.exe
     Process ID 2216
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 18 MB
    svchost.exe
     Process ID 9080
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 19 MB
     Peak Memory Usage 21 MB
    svchost.exe
     Process ID 9348
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 19 MB
    svchost.exe
     Process ID 10184
     User Système
     Domain AUTORITE NT
     Memory Usage 6.99 MB
    svchost.exe
     Process ID 9376
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 7.99 MB
     Peak Memory Usage 8.64 MB
    svchost.exe
     Process ID 1772
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 6.80 MB
     Peak Memory Usage 7.48 MB
    svchost.exe
     Process ID 7712
     User Système
     Domain AUTORITE NT
     Memory Usage 13 MB
     Peak Memory Usage 42 MB
    svchost.exe
     Process ID 7280
     User Système
     Domain AUTORITE NT
     Memory Usage 5.71 MB
     Peak Memory Usage 6.16 MB
    svchost.exe
     Process ID 9736
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 5.46 MB
     Peak Memory Usage 6.34 MB
    svchost.exe
     Process ID 7548
     User SERVICE LOCAL
     Domain AUTORITE NT
     Peak Memory Usage 5.49 MB
    svchost.exe
     Process ID 9996
     User Système
     Domain AUTORITE NT
     Memory Usage 8.70 MB
    svchost.exe
     Process ID 9036
     User Système
     Domain AUTORITE NT
     Memory Usage 5.47 MB
     Peak Memory Usage 6.21 MB
    svchost.exe
     Process ID 1596
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 25 MB
    svchost.exe
     Process ID 668
     User Système
     Domain AUTORITE NT
     Memory Usage 10 MB
    svchost.exe
     Process ID 544
     User Système
     Domain AUTORITE NT
     Memory Usage 44 MB
     Peak Memory Usage 47 MB
    svchost.exe
     Process ID 1120
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 22 MB
    svchost.exe
     Process ID 1160
     User Système
     Domain AUTORITE NT
     Memory Usage 16 MB
     Peak Memory Usage 17 MB
    svchost.exe
     Process ID 7964
     User gaetan
     Memory Usage 18 MB
    svchost.exe
     Process ID 8412
     User gaetan
     Memory Usage 30 MB
    svchost.exe
     Process ID 1364
     User Système
     Domain AUTORITE NT
     Memory Usage 20 MB
    svchost.exe
     Process ID 1496
     User Système
     Domain AUTORITE NT
     Memory Usage 36 MB
    svchost.exe
     Process ID 1504
     User Système
     Domain AUTORITE NT
     Memory Usage 34 MB
    svchost.exe
     Process ID 1512
     User Système
     Domain AUTORITE NT
     Memory Usage 35 MB
    svchost.exe
     Process ID 1704
     User Système
     Domain AUTORITE NT
     Memory Usage 18 MB
    svchost.exe
     Process ID 1736
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 16 MB
    svchost.exe
     Process ID 1788
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 1820
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 21 MB
    svchost.exe
     Process ID 1852
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 31 MB
     Peak Memory Usage 34 MB
    svchost.exe
     Process ID 1888
     User Système
     Domain AUTORITE NT
     Memory Usage 13 MB
    svchost.exe
     Process ID 7440
     User gaetan
     Memory Usage 25 MB
    svchost.exe
     Process ID 1896
     User Système
     Domain AUTORITE NT
     Memory Usage 22 MB
    svchost.exe
     Process ID 1904
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 16 MB
    svchost.exe
     Process ID 2012
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 21 MB
     Peak Memory Usage 22 MB
    svchost.exe
     Process ID 1228
     User Système
     Domain AUTORITE NT
     Memory Usage 19 MB
    svchost.exe
     Process ID 1344
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 18 MB
     Peak Memory Usage 18 MB
    svchost.exe
     Process ID 2104
     User Système
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 2112
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 2360
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 27 MB
    svchost.exe
     Process ID 2508
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 25 MB
     Peak Memory Usage 26 MB
    svchost.exe
     Process ID 2560
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 14 MB
     Peak Memory Usage 15 MB
    svchost.exe
     Process ID 2556
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 19 MB
    svchost.exe
     Process ID 2624
     User Système
     Domain AUTORITE NT
     Memory Usage 34 MB
    svchost.exe
     Process ID 2680
     User Système
     Domain AUTORITE NT
     Memory Usage 21 MB
    svchost.exe
     Process ID 2720
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 11952
     User Système
     Domain AUTORITE NT
     Memory Usage 19 MB
    svchost.exe
     Process ID 2896
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 4324
     User Système
     Domain AUTORITE NT
     Memory Usage 5.63 MB
     Peak Memory Usage 5.73 MB
    svchost.exe
     Process ID 8812
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 5.53 MB
     Peak Memory Usage 5.57 MB
    svchost.exe
     Process ID 3120
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Memory Usage 26 MB
    svchost.exe
     Process ID 3128
     User Système
     Domain AUTORITE NT
     Memory Usage 29 MB
    svchost.exe
     Process ID 3136
     User Système
     Domain AUTORITE NT
     Memory Usage 43 MB
     Peak Memory Usage 43 MB
    svchost.exe
     Process ID 3148
     User Système
     Domain AUTORITE NT
     Memory Usage 13 MB
    svchost.exe
     Process ID 3156
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 18 MB
    svchost.exe
     Process ID 8436
     User Système
     Domain AUTORITE NT
     Memory Usage 7.17 MB
     Peak Memory Usage 7.21 MB
    svchost.exe
     Process ID 5416
     User Système
     Domain AUTORITE NT
     Memory Usage 6.74 MB
     Peak Memory Usage 6.84 MB
    svchost.exe
     Process ID 3164
     User Système
     Domain AUTORITE NT
     Memory Usage 45 MB
    svchost.exe
     Process ID 7660
     User Système
     Domain AUTORITE NT
     Memory Usage 8.10 MB
     Peak Memory Usage 8.10 MB
    svchost.exe
     Process ID 3172
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 47 MB
     Peak Memory Usage 122 MB
    svchost.exe
     Process ID 3180
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 17 MB
    svchost.exe
     Process ID 3528
     User SERVICE LOCAL
     Domain AUTORITE NT
     Memory Usage 13 MB
     Peak Memory Usage 13 MB
    svchost.exe
     Process ID 10252
     User Système
     Domain AUTORITE NT
     Memory Usage 6.29 MB
     Peak Memory Usage 6.93 MB
    System
     Process ID 4
     Memory Usage 148 KB
     Peak Memory Usage 9.15 MB
    System Idle Process
     Process ID 0
    taskhostw.exe
     Process ID 5788
     User gaetan
     Path C:\Windows\System32\taskhostw.exe
     Memory Usage 14 MB
    wininit.exe
     Process ID 856
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\wininit.exe
     Memory Usage 6.43 MB
     Peak Memory Usage 7.41 MB
    winlogon.exe
     Process ID 11684
     User Système
     Domain AUTORITE NT
     Path C:\Windows\System32\winlogon.exe
     Memory Usage 8.43 MB
    WmiPrvSE.exe
     Process ID 6120
     User SERVICE RÉSEAU
     Domain AUTORITE NT
     Path C:\Windows\System32\wbem\WmiPrvSE.exe
     Memory Usage 20 MB
    WmiPrvSE.exe
     Process ID 8224
     User Système
     Domain AUTORITE NT
     Memory Usage 11 MB
  Security Options
   Accès réseau : chemins et sous-chemins de Registre accessibles à distance System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
   Accès réseau : les autorisations spécifiques des utilisateurs appartenant au groupe Tout le monde s’appliquent aux utilisateurs anonymes Désactivé
   Accès réseau : les canaux nommés qui sont accessibles de manière anonyme
   Accès réseau : les chemins de Registre accessibles à distance System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
   Accès réseau : les partages qui sont accessibles de manière anonyme Non défini
   Accès réseau : modèle de partage et de sécurité pour les comptes locaux Classique - les utilisateurs locaux s’authentifient eux-mêmes
   Accès réseau : ne pas autoriser l’énumération anonyme des comptes et partages SAM Désactivé
   Accès réseau : ne pas autoriser l’énumération anonyme des comptes SAM Activé
   Accès réseau : Permet la traduction de noms/SID anonymes Désactivé
   Accès réseau : restreindre l’accès anonyme aux canaux nommés et aux partages Activé
   Accès réseau : ne pas autoriser le stockage de mots de passe et d’informations d’identification pour l’authentification du réseau Désactivé
   Accès réseau : restreindre les clients autorisés à effectuer des appels distants vers SAM
   Arrêt : effacer le fichier d’échange de mémoire virtuelle Désactivé
   Arrêt : permet au système d’être arrêté sans avoir à se connecter Activé
   Audit : arrêter immédiatement le système s’il n’est pas possible de se connecter aux audits de sécurité Désactivé
   Audit : auditer l’accès des objets système globaux Désactivé
   Audit : auditer l’utilisation des privilèges de sauvegarde et de restauration Désactivé
   Audit : force les paramètres de sous-catégorie de stratégie d’audit (Windows Vista ou version ultérieure) à se substituer aux paramètres de catégorie de stratégie d’audit Non défini
   Chiffrement système : utilisez des algorithmes compatibles FIPS pour le chiffrement, le hachage et la signature Désactivé
   Client réseau Microsoft : communications signées numériquement (lorsque le serveur l’accepte) Activé
   Client réseau Microsoft : communications signées numériquement (toujours) Désactivé
   Client réseau Microsoft : envoyer un mot de passe non chiffré aux serveurs SMB tierce partie Désactivé
   Comptes : renommer le compte administrateur Administrateur
   Comptes : renommer le compte Invité Invité
   Comptes : restreindre l’utilisation de mots de passe vides par le compte local à l’ouverture de session console Activé
   Comptes : statut du compte Administrateur Désactivé
   Comptes : statut du compte Invité Désactivé
   Comptes : bloquer les comptes Microsoft Non défini
   Connexion interactive : afficher les informations relatives à l’utilisateur lorsque la session est verrouillée Non défini
   Console de récupération : autoriser l’ouverture de session d’administration automatique Non défini
   Console de récupération : autoriser la copie de disquettes et l’accès à tous les lecteurs et dossiers Non défini
je t'épargne la seconde page :o
Message édité par corkynation le 27-11-2017 à 19:38:23
n°2482739
NaeNae
Posté le 29-11-2017 à 23:52:59  profilanswer
J'ai modifié le voltage, j'ai testé à 1.20, ça a crasher au bout de 15mn, puis j'ai testé à 1.25, aléatoire entre 30mn à 2h, là j'ai testé à 1.30, pour l'instant plus de crash....
Workblog Phoenix Modding Cooling
n°2482790
NaeNae
Posté le 30-11-2017 à 17:50:11  profilanswer
bon jusqu'à présent plus de soucis, je vais tester intensivement pendant 1 semaine, je verrai si je passe en résolu, ça pourrai aider quelques personnes qui ont le même soucis que cette solution
n°2483050
NaeNae
Posté le 03-12-2017 à 23:45:15  profilanswer
J'ai eu quelques BSOD après plusieurs heures de cessions sur CSGO et uniquement sur CSGO, que ce soit en stream ou non...
Je le passe en résolu car j'ai arrêté d'y jouer, avec les autres jeux aucun soucis. :)
  CPU
  [bsod whea - Overclock ?] comment résoudre ce soucis
Overclock 7700k et Gskill trident z 3866mhz !!overclock MSI GeForce GTX 1080 Armor OC
Overclock 3570K - Asrock Z77E-ITX ErreurOverclock GPU : Validation par OCCT GPU fiable?
[RESOLU] Ryzen-Ram Corsair 3000mhz impossible au delà de 2100Mhz QVLOverclock core 2 duo
Besoin d'aide OVERCLOCK Ryzen 3 1200Quel ventirad pour un Overclock d'i5 4670k à 4,2/4,3 Ghtz ?
OC EVGA 980 SC design réf AIO + soucis validation hwbotOverclock i7-6700
Plus de sujets relatifs à : [bsod whea - Overclock ?] comment résoudre ce soucis
