3319 connectés
  Memoire CORSAIR CAS2 (timing???)
n°969340
sharantyr
Posté le 22-02-2004 à 17:51:13  profilanswer
Salut!
D abord, ma config:
-Processeur BARTON 2500+ o/c a 3200+
-CM Abit NF7
-Memoire 2*256 Mo Corsair (pack twinx) pc 3200 CAS 2
J ai vu a beaucoup d endroits que les timing pour ma moire devriaent etre 5,2,2,2 mais moi, quand je la mets comme ca, une fois arrivé sous windows le pc redemarre tout seul :sarcastic: donc jaimerais savoir quels sont les bon timing pour ma memoire.. La je suis en 8,3,3,2 Et voltage au maximum des reglages possibles via le bios.
Voici ce que cpu-z me donne:
CPU-Z version 1.21
Memory Modules Serial Presence Detect (SPD)
Module #1
General
Memory type  DDR-SDRAM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size   256 MBytes
Max bandwidth  PC3200 (200 MHz)
Part number  CMX256A-3200C2
Attributes
Number of banks  1
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Timings table
Frequency (MHz)  166 200
CAS#   2.0 2.5
RAS# to CAS# delay 3 3
RAS# Precharge  3 3
TRAS#   7 8
Module #2
General
Size   256 MBytes
Attributes
Number of banks  1
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Timings table
CAS#   2.0 2.5
RAS# Precharge  3 3
TRAS#   7 8
CPU-Z Report
CPU-Z version 1.21.
CPU(s)
Number of CPUs 1
Code Name Barton
Specification AMD Athlon(tm) XP 3200+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 2194.3 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 199.5 MHz
Bus Speed 399.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2194.3 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer http://www.abit.com.tw/
Motherboard model NF7-S/NF7 (nVidia-nForce2), 2.X
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 12/24/2020
Chipset nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP-T rev. C1
Sensor chip Winbond W83627HF
AGP Status enabled, rev. 3.0
AGP Data Transfert Rate 8x
AGP Side Band Addressing supported, not enabled
AGP Aperture Size 128 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 199.5 MHz
FSB:DRAM 1:1
CAS# Latency 2.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC3200 - 256 MBytes
Module 1 Corsair DDR-SDRAM PC3200 - 256 MBytes
Software
Windows version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
Help plz  :jap:
n°969598
sharantyr
Posté le 23-02-2004 à 00:38:28  profilanswer
Personne? :(
n°969600
djakette[z​erezo]
Posté le 23-02-2004 à 00:43:19  profilanswer
Mets 11-3-3-2 déja.
Et tests 11-3-2-2 ou 11-2-3-2 pour voir si ca reboot pareil.
n°969604
sharantyr
Posté le 23-02-2004 à 00:46:49  profilanswer
Lequel de ces chiffres devrait etre le plus bas en fait?parceque je suis en 8 3 3 2 et passer en 11 2 3 2 ca augment plus que ca baisse menfin moi jy comprends pas grd chose :?
n°969682
DivX
Posté le 23-02-2004 à 08:21:49  profilanswer
sur nforce 2 les meilleurs timings possibles sont 11/2/2/2
cela représente en théorie une baisse de perfs, mais le nforce 2 est une exception: les perfs augmentent avec ces timings.
si 5/2/2/2 ne passe pas, essaie tout d'abord 11/2/2/2 car il est possible que ça passe comme ça.
si ça ne passe tjrs pas change un par un les autres timings sans toucher au "11" pour voir quel timing pose pb: 11/3/2/2, 11/2/3/2 et 11/2/2/2.5.
tu seras ainsi fixé sur le meilleur timing que tu peux faire...
mais je pense que 11/2/2/2 passera car ma mémoire fait pareil: elle ne passe pas à 5/2/2/2 mais accepte 11/2/2/2 ;)
n°969690
reivax59
Posté le 23-02-2004 à 09:07:49  profilanswer
idem chez moi sur un kt400 avec 2 barettes non-twinx
@166 elles tournent by spd en 2-3-3-7. je vais voir en 2-2-2-11
Strava
n°969972
sharantyr
Posté le 23-02-2004 à 17:47:34  profilanswer
Bon ben ca marche toujours pas
Elles tournent donc en 200Mhz (a cause de l o/c proco) et le 11-2-2-2 ca passe pas meme voltage a fond. Donc la je suis en
cas latency: 2.0
ras to cas: 3
ras precharge: 2
cycle time(tras): 7
frequency: 199.5Mhz
FSB/DRAM: 1/1
Message édité par sharantyr le 23-02-2004 à 17:47:58
n°969982
Gigathlon
Quad-neurones natif
Posté le 23-02-2004 à 18:09:15  profilanswer
Les 3200C2 ne sont certifiées qu'en 2/3/3/6 à 200, même si une (rare) série a été équipée de BH-5 et pouvait fonctionner sans souci en 2/2/2/5 ce n'est pas le cas de toutes...
Tes barrettes sont très certainement basées sur du BH-6, CH-6 ou CH-5, il suffit de regarder ce qui est écrit dessus et de l'entrer dans Google pour avoir la réponse.
Message édité par Gigathlon le 23-02-2004 à 18:09:28
n°970003
sharantyr
Posté le 23-02-2004 à 18:22:26  profilanswer
J ai ete sur le site a corsair (javais abandonne la premiere fois je trouvais pas) et jai cherché cette reference. Donc oui comme tu dis c est bien 2-3-3-6 @ 200 Mhz moi je suis en
cas latency: 2.0
ras to cas: 3
ras precharge: 2
cycle time(tras): 7
(je sais pas dasn quel ordre les ecrire) donc je vais descendre le 7 a 6 et je verais mais le ras to cas a 2 et ras precharge a 2 en meme temps ca passe pas du tout
n°970938
DivX
Posté le 25-02-2004 à 08:28:13  profilanswer
pour info sharanty je répète ce que j'ai dit précédemment:
le tras il faut l'augmenter pas le baisser pour avoir les meilleurs performances possibles sur ta carte mère nf7...
si tu le fais passer de 7 à 6 tu auras des perfs moins bonnes.
remonte le à 11
n°971435
sharantyr
Posté le 25-02-2004 à 23:37:22  profilanswer
Ben c est que je suis un peu perplexe, t a des explications un peu tehcniques pour m expliquer? Parceque le but du jeu etant daller vite, je vois pas comment augmenter le temps de cycle d une charge decharge (est ce ca?) aiderais a aller plus vite
n°971438
DivX
Posté le 25-02-2004 à 23:40:33  profilanswer
un lien du forum où ça a été étudié en long en large et en travers...
http://forum.hardware.fr/hardwaref [...] 575878.htm
si tu veux je pe te trouver une dizaine d'autres sites qui on testé et qui arrivent tous à la même conclusion  [:m-power-bmw]
n°971470
sharantyr
Posté le 26-02-2004 à 00:17:55  profilanswer
merci je vias faire ca! :)
Réglage timming mémoire HELPdebridage du bus memoire
Corsair et P4Corsair TWINX 2x512 Mo DDR-SDRAM PC4400 : Meilleure RAM du moment ?
quelle barette de mémoire fo t'il pour un p4c2.4 overcloké à 3.4 ghzmoi et le timing on repassera
o/c memoireFSB et Fréquence mémoire
corsair hydrocool 200Memoire Generique Avec Chip SAMSUNG PC3200
Plus de sujets relatifs à : Memoire CORSAIR CAS2 (timing???)
