6270 connectés
 Page :   1  2  3  4  5  ..  13  14  15  ..  20  21  22  23  24  25
[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?
n°641379
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 03:21:40  profilanswer
instructif
http://xbitlabs.com/mainboards/nfo [...] ndex2.html
n°641381
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 03:23:48  profilanswer
intéressant aussi dis donc :o
http://xbitlabs.com/storage/seagate-barracuda-ata5/
Message édité par Oxygen3 le 03-11-2002 à 03:28:38
n°641382
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 03:37:21  profilanswer
je continue ma revue de presse web:
http://zdnet.com.com/2100-1103-963942.html
ZDNet Reports : a écrit :
Hyper-Threading Pros & Cons
Hyperthreading has been available on workstations for HP, Dell and other workstation manufacturers but was turned off in their systems shipped. Both HP and Dell, though, make the technology easy to turn on.
Cons
If you are running single-threaded applications, it will reduce your performance. Problems could occur with single-threaded applications even on a multithreaded operating system.
If the processor is running two threads, the chip has to split its cache--a reservoir of memory located on the processor--and other shared resources. Regular software that?s run on computers with two chips runs worse than on single-processor boxes.
Most of the applications for workstations, predominately tailored for Windows 2000, don't take advantage of the technology.
Pros
Users could see performance benefits of up to 30 percent on select applications
Although a small number of applications might see a minor dip in performance, the vast majority of applications will benefit or, at a minimum, not be affected when running on Windows XP.
Users running two applications at once will see similar performance boosts and experience far fewer hang-ups.
Windows XP has been optimized for the technology and so have many applications
* Hyper-Threading is quite a cool technology however steps have to be taken correctly in order to enjoy the full benefits. First you will need P4 3.06Ghz and above, 533Mhz Intel chipset board (845E/PE/GE/850E), BIOS with HT feature turned on, fresh installation of OS to enable MP kernel. From our understanding, Hyper-Threading runs best with Windows XP Home or Professional therefore turn HT on if you running applications with this OS. Windows 2000 are not optimized for HT therefore you might wish to turn it off unless you are mostly running multi-threaded applications. Users running Linux will require 2.4.18 or later but it is up to the individual vendors on how they optimize their OSes and softwares for HT.
Message édité par Oxygen3 le 03-11-2002 à 03:37:38
n°641384
Learn
Tigre & Dragon
Posté le 03-11-2002 à 03:47:41  profilanswer
go to  :sleep:   :D
L'obscurité ne peut pas chasser l'obscurité ; seule la lumière le peut. La haine ne peut pas chasser la haine ; seul l'amour le peut. Martin Luther King
n°641385
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 03:53:20  profilanswer
Learn a écrit a écrit :
go to  :sleep:   :D
oué :)
n°641386
T@nker-xXx
Overclocker retraité
Posté le 03-11-2002 à 03:54:00  profilanswer
Oxygen3 a écrit a écrit :
oué :)
lol
Bosse.... bosse encore et toujours pour toute la nuit ..... pour toute la vie
n°641388
thieuma
Posté le 03-11-2002 à 04:32:15  profilanswer
:ouch:
n°641390
nicko500
Framerate is Life.
Posté le 03-11-2002 à 05:12:37  profilanswer
:hello:  [:tsouille]
n°641392
nicko500
Framerate is Life.
Posté le 03-11-2002 à 05:14:22  profilanswer
[:yaisse3]
n°641393
nicko500
Framerate is Life.
Posté le 03-11-2002 à 05:32:42  profilanswer
:sleep:  :hello:
n°641398
derfone
yepahhh
Posté le 03-11-2002 à 09:24:18  profilanswer
NiKoPOP a écrit a écrit :
Faudra pas ke j'oublie mes lunettes... :ange:
 [:xfred4]
n°641407
cpulloverc​lock
Posté le 03-11-2002 à 10:12:58  profilanswer
:hello: http://www.smilies.nl/groot/rabbit.gif
http://www.smilies.nl/groot/scream.gif
http://www.smilies.nl/groot/transformer.gif
Message édité par cpulloverclock le 03-11-2002 à 10:16:27
n°641420
nikopop
凸(`0´)凸
Posté le 03-11-2002 à 10:49:41  profilanswer
:hello:  [:youyou2224]
Votre Installation Home-Cinema ici : installations-home-cinema.eu
n°641431
derfone
yepahhh
Posté le 03-11-2002 à 11:09:45  profilanswer
[:milka]
n°641433
@poppof
Posté le 03-11-2002 à 11:15:04  profilanswer
ont en ai pas loin ds 240 stable en synchro...
ça va venir  :D
JEFF xtremesystem
kt400 8k9a2+
http://www.adventurevision.com/som [...] 502MHz.gif
corsair pc3000C2 256mb
It's an Epox 8K9A2+. The only bad thing is a 2.0v Vcore maximum(which I can only get to give 1.95v). Other than that, nothing bad and as you can see, it really knows how to manage memory.
BTW, that 238 isn't 100% stable. I get 100% stable at 234MHz with maximum timings and 3.2v.
le thread:
http://www.xtremesystems.org/forum [...] genumber=5
 :love: le fsb
mais pourquoi il ont baisser leur vcore chez epox :??:
n°641451
thieuma
Posté le 03-11-2002 à 11:52:11  profilanswer
Nicko500 a écrit a écrit :
 :hello:  [:tsouille]
kel mito !
n°641457
nasdak
Posté le 03-11-2002 à 12:14:53  profilanswer
n°641461
papayou
Coin Coin
Posté le 03-11-2002 à 12:19:50  profilanswer
chuis au boulot :(
6h-18h pour aujourd'hui...j'ai pas fini :/
n°641462
thieuma
Posté le 03-11-2002 à 12:20:53  profilanswer
mdr, et cpu ki nous sort ke 256 de ram suffisent.....  :sarcastic:
 http://site.voila.fr/thi3uma/images/HFR/doom.JPG
n°641463
cpulloverc​lock
Posté le 03-11-2002 à 12:23:03  profilanswer
ben oui
ca va la
n°641465
Marc
Chasseur de joce & sly
Posté le 03-11-2002 à 12:24:24  profilanswer
Ben oui ca lui suffit pour faire un bon score à Sandra, c'est tout ce qu'il fait de son PC alors [:spamafote]
n°641467
thieuma
Posté le 03-11-2002 à 12:27:50  profilanswer
cpulloverclock a écrit a écrit :
ben oui
ca va la
meme avec 512 ça rame à burne
fo 3 barettes de 256 pour ke ça commence à pas swaper tout le temps :ouch:  :eek2:
n°641469
nasdak
Posté le 03-11-2002 à 12:29:30  profilanswer
cé parce que c'est l'alpha  :D
n°641470
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 12:36:00  profilanswer
[:rofl]
(t'as oublié cpumark)
Metro-Pole ▬ Réseau A Suivre...: Annuseries|LeVillage|pErDUSA
n°641474
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 12:38:15  profilanswer
ouin :'(
http://www.abit.com.tw/abitweb/web [...] bullet.htm
ca va etre dur de choisir en epox et abit pour le nforce :(
n°641478
Learn
Tigre & Dragon
Posté le 03-11-2002 à 12:41:55  profilanswer
@poppof a écrit a écrit :
 :love: le fsb
 :hello:  all
ouai c'est dommage :/
Message édité par Learn le 03-11-2002 à 12:42:16
n°641480
Oxygen3
Tears from the moon
Posté le 03-11-2002 à 12:42:38  profilanswer
 :hello:  all
ca va permettre de resortir les fers !!
n°641481
Learn
Tigre & Dragon
Posté le 03-11-2002 à 12:43:43  profilanswer
 [:yaisse3]
n°641490
nasdak
Posté le 03-11-2002 à 12:49:54  profilanswer
j'ai fini fellowhip of the ring...
ilé sympa
n°641523
Mandrak
Lux vobiscum
Posté le 03-11-2002 à 13:27:31  profilanswer
Salut les Furieux !
Bon alors , qui le premier dans l'équipe nous fait pêter ses benchs avec un XP2400 O/C ????
autre passion >>  http://zupimages.net/viewer.php?id=19/35/p8a9.jpg
n°641526
cpulloverc​lock
Posté le 03-11-2002 à 13:28:20  profilanswer
MANDRAK a écrit a écrit :
Salut les Furieux !
:sleep:
n°641530
papayou
Coin Coin
Posté le 03-11-2002 à 13:29:22  profilanswer
Ca passe sur une KK 266 ces petites betes ?? [:markdavis]
n°641540
cpulloverc​lock
Posté le 03-11-2002 à 13:41:51  profilanswer
172 de fsb avec de la rambus et une P4T533  :eek2:
http://www2.gol.com/users/postbox/P4T533.jpg
n°641554
cpulloverc​lock
Posté le 03-11-2002 à 13:53:11  profilanswer
ya mieux encore
a 175 = 4346/4336
Bande passante de 5600MB/s
Message édité par cpulloverclock le 03-11-2002 à 13:54:16
n°641564
Mandrak
Lux vobiscum
Posté le 03-11-2002 à 13:55:52  profilanswer
oula... :ouch:
n°641566
cpulloverc​lock
Posté le 03-11-2002 à 13:56:40  profilanswer
ya pas mieux que la rambus quand meme
le 4346/4336 en DDR faudrait etre a 275 tt a fond et encore...
n°641576
Mandrak
Lux vobiscum
Posté le 03-11-2002 à 14:00:44  profilanswer
je pensais (à tort donc) :ouch:
que les mobo à base de rambus ne dépassaient pas 156 de fsb.
peu être seulement la P4T533.
n°641626
pierrotlem​aboule
Posté le 03-11-2002 à 14:09:18  profilanswer
la th72 passait les 180 de fsb mais fallit la modder ;)
mon topic de vente
n°641651
ultrastars
Posté le 03-11-2002 à 14:17:38  profilanswer
salut les vieux loup :)
je vient plus vraiment sur HFR mais suis toujours en vie :D
ya personne qui veut un 1,8@2,4 pour 150 euro frais de port inclus
je vient de me prendre un 2,4ghz bus 400 mhz (a monter sur une TH7-2 avec 512 mo de rambus)
j'ai po suivi toute les histoire de release et de stepping ca vaut quoi ca ?
BX80532PC2400DSL65R pour le code de production
A86793-002 pour la version
merci et bonjours a touts les furieux :)
Message édité par ultrastars le 03-11-2002 à 14:19:08
n°641659
nasdak
Posté le 03-11-2002 à 14:19:41  profilanswer
sl65r c'est du B0  :(
n°641661
ultrastars
Posté le 03-11-2002 à 14:20:45  profilanswer
donc de la merde ? :(
c'étais pas evident a trouver du 2,4 en bus 400
Message édité par ultrastars le 03-11-2002 à 14:21:42
[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?[ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?
Plus de sujets relatifs à : [ FOR OVERCLOCKERS FOUS ] ?¤¤ salon des habitués ¤¤?
