3161 connectés
  Modding
  Extreme - X79 - i7-3930k - 3 Way Sli - Full Watercooling 2012
n°2254284
danexmod
Water & Air Mod
Posté le 06-11-2012 à 20:33:14  profilanswer
Boujour :hello:
Je vous présente mon PC gaming 2012 que je me suis fait pour le plaisir :)
Les composantes pour ce build :
Boîtier : NZXT Switch 810 Full ATX Steel Case 4X5.25 6X3.5 2XUSB3.0 Audio and Mic Input - Black
PSU : CORSAIR Professional Series Gold AX 1200 Watts ou le OCZ ZX Series 1250W Fully-Modular 80PLUS Gold
Carte mère : ASRock X79 Extreme3 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel
CPU : Intel Core i7-3930k Sandy Bridge-E 3.2GHz
Mémoire : 16GO G.ZKILL RipjawsZ 2133 black WC
GPU : 3 way GTX 480
SSD : 2x OCZ Vertex 3 SATA III 2.5" SSD 60GB (Raid0 OS)
1x OCZ Vertex 3 SATA III 2.5" SSD 120GB (Jeux)
HDD : 1x WD Caviar Blue 1TB (FILM) 2x WD Caviar Black 640GB (Backup) 2x WD Caviar Black 640GB RAID0 (Jeux)
DVD : 1x ASUS DRW-24B1ST 24X SATA DVD Writer OEM Black
Power Management :
1x APC Performance SurgeArrest 11 Outlet Surge Protector with Phone and Coaxial Protection
Système de refroidissement :
1x APOGEE HD
1x Slim High Density Triple 140mm Radiator XSPC EX420
1x Single 140mm Radiator Coolgate
1x 360 TFX, Radiator Mounting Bracket
2x Pompe D5 +dressing
3x EK waterblock 480
3x EK backplate 480
2x Bitspower Universal RAM Module Water Cooling Set (2 Banks)
1x Resevoir EK-Multioption X2 RES 250 ADVANCED - Ver 2 60mm
13x Bitspower 3/8"ID - 5/8"OD Straight Compression Fitting Black
3x Bitspower 3/8" ID Tubing - Barb - Matt Black
8x Bitspower 3/8" ID Tubing 90 Degree Rotary - Barb - Matt Black
2x Bitspower 3/8" ID Tubing 90 Degree - Barb - Matt Black
6x Bitspower 45 Degree M/F G1/4" Adapter Extender - Matte Black
1x Tube Blanc Primochill Primoflex Pro LRT 3/8IN ID 5/8IN OD
13x Fans blanc NZXT FN-140RB 140MM 1300RPM 62CFM
6x Fans Scythe 120mm 110CFM
1x Scythe Kaze Master Pro 5.25IN Bay 6 Channel Fan Controller With Temperature and Fan Alarm Black
1x Scythe 5.25IN Bay 4 Channel Fan Controller With Temperature and Fan Alarm Black
3x XSPC Sleeved 5mm Single LED Module - White
2x IceDragonCooling - IceDragonCooling Nono Fluid - White
2x Swiftech Thermal Compaund 1g
http://i38.servimg.com/u/f38/17/18/42/87/img_2420.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2414.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2417.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2352.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2355.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2410.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2610.jpg
http://i38.servimg.com/u/f38/17/18/42/87/img_2611.jpg
Message édité par danexmod le 06-11-2012 à 20:56:26
n°2254286
danexmod
Water & Air Mod
Posté le 06-11-2012 à 20:34:55  profilanswer
Message édité par danexmod le 06-11-2012 à 20:37:54
n°2254287
danexmod
Water & Air Mod
Posté le 06-11-2012 à 20:36:48  profilanswer
Oups! Désolé pour le double post  :??:
n°2254291
Bynaris
Posté le 06-11-2012 à 20:45:37  profilanswer
tuyaux blanc ?
Très joli au passage (surtout le pont ram)
n°2254296
Caake
Posté le 06-11-2012 à 20:50:33  profilanswer
Les CG et le pont SLI  :love:
n°2254297
danexmod
Water & Air Mod
Posté le 06-11-2012 à 20:53:08  profilanswer
Merci !
Tuyaux opaque blanc Primochill Primoflex Pro LRT 3/8IN ID 5/8IN OD
Message édité par danexmod le 06-11-2012 à 20:53:37
n°2254403
waterouf
Posté le 07-11-2012 à 11:46:42  profilanswer
Très top !
n°2254405
Static-X-
Posté le 07-11-2012 à 12:00:53  profilanswer
Sympas tout plein, j'ai une extreme 9 et je trouves cette game vraiment chouette :)
Possible d'avoir d'autre photos ? exemple vue de l'ensemble de la tour, les Rad extérieur etc ?
n°2254436
danexmod
Water & Air Mod
Posté le 07-11-2012 à 14:05:11  profilanswer
Merci  :)
Oui bien sûr. Je vais prendre quelques photos ce soir.
n°2254585
T-8rD
Posté le 08-11-2012 à 00:18:03  profilanswer
Combien de litre de ldr tu as utilisé
n°2254595
danexmod
Water & Air Mod
Posté le 08-11-2012 à 02:59:16  profilanswer
1.5 litres environ  :)
 http://i38.servimg.com/u/f38/17/18/42/87/img_2411.jpg
Message édité par danexmod le 08-11-2012 à 03:03:48
n°2254596
danexmod
Water & Air Mod
Posté le 08-11-2012 à 03:06:23  profilanswer
[quote="danny3333"]
http://i48.servimg.com/u/f48/17/18/42/87/img_1822.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_1817.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3249.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3250.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3251.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3252.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3253.jpg
http://i48.servimg.com/u/f48/17/18/42/87/img_3254.jpg
Message édité par danexmod le 08-11-2012 à 04:46:38
n°2254597
Bynaris
Posté le 08-11-2012 à 04:46:05  profilanswer
ah berk, j'aime pas les radiateur externe sans rien (pas de "camouflage" ).
Par contre les nouvelles bouteilles de ice dragon sont juste waouh !
n°2254599
danexmod
Water & Air Mod
Posté le 08-11-2012 à 04:53:13  profilanswer
Bynaris a écrit :
ah berk, j'aime pas les radiateur externe sans rien (pas de "camouflage";).
Pour un 3 way sli 480 pas le choix  ;)  Efficace et performance en overclocking  :jap:
Message édité par danexmod le 08-11-2012 à 04:54:32
n°2254603
balrogmorg​oth
Posté le 08-11-2012 à 07:10:09  profilanswer
Ice dragon a modifié les bouteilles, car ils ont eu des soucis, style des bouteilles aux 2/3 remplis dans leur chaine de production, ils sont donc passé sur ses bouteilles transparentes
Pas mal, cette machine !
  Modding
Montage premier watercooling, besoin de conseilModding - Bitfenix - Z77- Watercooling
Fréquence CPU ne redescend pas en IDLE et reste en FULLun liquide watercooling qu'on voit circuler?
sens du watercoolingWatercooling externe et usage en tant que chauffage
Proc i7 2700K et RAM 2133Mhz compatible ou non ?Premier Watercooling
un ventirad full cuivrewatercooling dans xpredator
Plus de sujets relatifs à : Extreme - X79 - i7-3930k - 3 Way Sli - Full Watercooling 2012
