7092 connectés
  ca C 'est dla bonne ram
n°496948
Magicpanda
Pushing the envelope
Posté le 28-05-2002 à 18:47:40  profilanswer
Samsung today announced the industry's first DDR-II device, a high-density 512Mb DDR-II SDRAM, that it expects to be the next-generation mainstream DRAM technology for high-speed systems.
  Low 1.8-volt Vdd
Data transfer rates of 533Mbps that can be extended to a maximum of 667Mbps for networks and special system environments.
Off-chip driver calibration (OCD) to maintain optimum driver strength
On-die termination (ODT) to ensure optimum signal waveform
Posted CAS, a command control method to enhance bus efficiency.
60-ball BGA package maximizes performance
In March 2001, prior to the development of the 512Mb DDR-II SDRAM, Samsung created a 2.5V, 128Mb
DDR-II prototype. In parallel with Samsung's device design, and in an effort to validate the key DDR-II technology attributes, IBM developed a first-generation DDR-II memory interface chip in conjunction with a new registered DIMM. Samsung will commence volume production of the new 512Mb DDR-II SDRAM device in Q3 2003. The timely introduction of these next-generation DDR-II sample devices is in line with the company's strategy to expand its DDR DRAM market share to more than 50 percent in 2002. Samsung intends to maintain its leadership stance in high value-added memory by being first to market with leading-edge technologies in a wide range of configurations and densities
n°496955
Magicpanda
Posté le 28-05-2002 à 19:00:12  profilanswer
n°496957
Magicpanda
Posté le 28-05-2002 à 19:01:03  profilanswer
ca suffit quoi
n°496960
cpulloverc​lock
Posté le 28-05-2002 à 19:04:52  profilanswer
Hr a écrit a écrit :
Et ça va coûter la peau du cul... :cry:
dici mars on a le temps
n°496966
Magicpanda
Posté le 28-05-2002 à 19:07:26  profilanswer
mwai
mais ca me fait hesiter a acheter de la ram a 600 balle en ce moment quoi :/
Samsung DDR333 PC-2700 512Mo CAS2.5 bonne ram?Mon alim 400W TTGI moins bonne pour l'OC que ma 300W noname?!!
[ed] ca chauffe la tour ouverte!(ma sonde est la bonne?)Les teutons teste la bonne DDRam,... mise à jour
qui donne la bonne manip ???voir site.....c de la bonne ram chez carrouf???
Samsung PC2700 de chez grosbill... c de la bonne?bonne nouvelle
[URGENT] CM + bonne DDR pour o/c dans les 2000 frsMeilleur matos pour une bonne découpe de radiateurs ?
Plus de sujets relatifs à : ca C 'est dla bonne ram
