3652 connectés
 Page :   1  2
Page Précédente
Mon Mountain Mods U2FO
n°2265317
T-8rD
Posté le 31-12-2012 à 16:24:00  profilanswer
http://img837.imageshack.us/img837/7038/sr21280x720.png
  • Hardware
- Xigmatek Elysium
- EVGA SR2
- 2x Xeon 5650
- 24go DDR3 Gskill 2133mhz
- Sli GTX 680
- Enermax Platimax 1500W
- Raid0 de SSD Samsung 830 256Go
  • Watercooling
-Tuyaux 13/19
- Raccord Coiffe TFC
-Pompe MCP 655+Top
-Phobya Radiateur - G-Changer - 560 V.2
-Ventilateur xigmatek 140mm
  • Photos
http://img651.imageshack.us/img651/8628/1006286i.jpg
http://img69.imageshack.us/img69/3999/1006299v.jpg
http://img209.imageshack.us/img209/3449/1006300.jpg
http://img266.imageshack.us/img266/7024/1006301.jpg
http://img94.imageshack.us/img94/5651/1006302v.jpg
http://img20.imageshack.us/img20/6454/1006406j.jpg
http://img831.imageshack.us/img831/3428/1006407s.jpg
http://img9.imageshack.us/img9/6541/1006412b.jpg
http://img707.imageshack.us/img707/8375/1006413r.jpg
http://img11.imageshack.us/img11/6639/1006424v.jpg
http://img805.imageshack.us/img805/6232/1006436o.jpg
http://img233.imageshack.us/img233/5185/1006457j.jpg
http://img163.imageshack.us/img163/5573/1006483h.jpg
http://img441.imageshack.us/img441/7048/1006485i.jpg
http://img99.imageshack.us/img99/5554/1006486.jpg
http://img833.imageshack.us/img833/8357/1006491ah.jpg
http://img842.imageshack.us/img842/5462/1006494i.jpg
http://img96.imageshack.us/img96/8301/1006496z.jpg
http://img23.imageshack.us/img23/4732/1006497n.jpg
http://img9.imageshack.us/img9/7480/1006631c.jpg
http://img39.imageshack.us/img39/4012/1006632q.jpg
http://img341.imageshack.us/img341/3605/1006637w.jpg
Message édité par T-8rD le 03-03-2013 à 01:21:54
n°2265323
aurelienbo​uchet
Posté le 31-12-2012 à 16:42:41  profilanswer
salut
je vais suivre ton topic car moi aussi je me lance dans le meme boitier mais sans avoir de grand talent dans le modding.
ca sera mon premier
n°2265325
Scouto
Air Cooling Rules !
Posté le 31-12-2012 à 16:58:16  profilanswer
[:michrone]
n°2265327
T-8rD
Posté le 31-12-2012 à 17:11:21  profilanswer
Voila des photos Sorry pour a qualité des photos
n°2265340
zzaherr
Posté le 31-12-2012 à 18:51:04  profilanswer
oui qualité de payday les photos :D il faut sortir le bel appareil numérique maintenant!
n°2265360
erase
Posté le 31-12-2012 à 21:45:05  profilanswer
Woot joli matos et montage du wc très propre ! Tu gagne des perf avec un raid de ssd, quid du trim aussi ?
Message édité par erase le 31-12-2012 à 21:46:46
n°2265433
cruzen
Posté le 01-01-2013 à 17:57:08  profilanswer
joli matos :)
http://forum.hardware.fr/hfr/Achat [...] 9919_1.htm   Mon feedback
n°2268000
aurelienbo​uchet
Posté le 13-01-2013 à 10:49:06  profilanswer
salut
je viens de finir le montage watercooling de mon elisium
j'ai uniquement le cpu(non overclocké) de watercoolé avec un waterblock phobia 420 en top et un Swiftech H2O-220 Edge en facade le tout avec un reservoir EK en baie
sur le 420 j'ai 3 ventillos 140mm noiseblocker et sur le 240 jai deux ventillos NF-F12 NOCTUA.
les ventillos des block sont en aspi et le ventillo de 200mm de cote aspire l'air frais de l'exterieur a l'interieur du boitier. le ventillo a l'arriere du boitier extrait l'air chaud du boitier a l'exterieur
et bien je ne gagne aucune perf en refroiddissement par rapport a mon ancien watercooling avec uniquement le Swiftech H2O-220 Edge??????
les temps du proc au repos est de 38-40 DEGRES et 44-45 en full pour un I7 950 sur une P6T-SE.les temps sont prise avec AI SUITE de chez ASUS logiciel livre avec la carte mere
pas d'air dans le circuit et la pompe fonctionne correctement l'indicateur de mouvement de liquide du reservoir en baie tourne assez vite.
est-ce normal??? car la je ne m'attendais absoluement pas a ca!!!!!
vos conseils svp.
une idee?
Message édité par aurelienbouchet le 13-01-2013 à 12:05:19
n°2268021
polomod
www.polomod.fr
Posté le 13-01-2013 à 12:52:01  profilanswer
tu les as eu où tes xigmatek ?
www.polomod.fr   fermé    -     Facebook PoLoMoD
n°2268045
T-8rD
Posté le 13-01-2013 à 13:34:48  profilanswer
Acheter d'ocaz avec le boitier
n°2268063
zzzsleepin​g
Posté le 13-01-2013 à 14:24:00  profilanswer
Joli PC et tres bon matos
Juste une chose
Un seul rad pour un Bi Cpu et un Sli c'est bien peu meme si c'est un 560
A part ca pas mal continue
n°2268065
Sassanou
Posté le 13-01-2013 à 14:26:44  profilanswer
Juste une chose
Faux :)
Sur ma config avec un tri crossfire de 7970 et un seul rad 480, les temperatures etaient bonnes.
Le nombre de rad en soit ne veut rien dire.
n°2268067
T-8rD
Posté le 13-01-2013 à 14:32:58  profilanswer
Je confirme
Si je me trompe pas j'ai donner a sassanou les tempé en load
n°2268072
zzzsleepin​g
Posté le 13-01-2013 à 14:38:36  profilanswer
Sassanou a écrit :
Faux :)
Faux ???
Un rad a bien un niveau maxi de dissipation n'est ce pas ?
Un rad classique 45 à 50mm d'epaisseur en push c'est environ 100W de chaleur dissipée
D'ou ma réponse voila
Bye
n°2268075
polomod
www.polomod.fr
Posté le 13-01-2013 à 14:39:18  profilanswer
un 360 (épais) est amplement suffisant pour un CPU + Bi-GPU donc un 560 pour un CPU en plus ... est très correct aussi ;)
n°2268076
Sassanou
Posté le 13-01-2013 à 14:44:24  profilanswer
Faux ???
Bye
Je disais "faux" a ta remarque comme quoi un seul 560 pour un cross de 7970 etait bien peu, je n'ai jamais dit qu'il ne pouvait pas avoir de temps plus basses ;)
Mais a un moment il faut se poser une question : quel interet d'avoir un rad pour des cg à 50° ou bien 5 rads pour gagner 5° de moins ?
Parce qu'a part pour des benchs et monter en oc, ça ne sert a rien (et quand bien meme, des fois meme 5° n'aident pas a monter).
De plus quand je dis que le nombre de rad ne veut rien dire, je dis ça pour preciser qu'il faut voir plutot l’homogénéité du circuit : quel type de pompe, ventilos en push ou pull ou les deux, quel boitier, etc etc.
Parce qu'avoir 12 rads avec une pompe de merde et juste en push peut etre largement moins bon que 3 rads en push pull avec une bonne pompe dans un boitier bien ventilé.
n°2268078
zzzsleepin​g
Posté le 13-01-2013 à 14:53:22  profilanswer
Okok Zen
D'accord que le matos de qualité compte ca je sais tkt
Mais de la a dire faux sur mes propos je n'atais pas d'accord sans ton developpement suivant
La c'est plus clair
Apres j'ai vu sur un autre topic ou j'ai repondu, l'inverse
Bon sinon comment avoir des rensiegnements clairs sans se faire massacré ici
(des qu'on dit un truc de travers ya tous les hypocrites qui debarquent :lol:  )
Car comme par enchantement mon topic a été fermé car j'ai soit disant mal parlé :lol:
Merci A+
Corsair 800D / MSI Mpower / I7 3770K / Sapphire 7970 3go / G.Skill Ripjaws Z 16go 2133 Cas 9
n°2268080
Sassanou
Posté le 13-01-2013 à 14:58:46  profilanswer
Okok Zen
La c'est plus clair
Merci A+
Mais je suis detendu là ^^
Disons qu'en fait (et je ne t'agresse pas, je precise de suite :o ) c'est que tu as l'air tout le temps d'etre soit sur l’extrême défensive, soit tellement sur de toi qu'on a l'air de passer pour des cons ^^
Tu sais, moi meme j'en apprends tous les jours et suis content de ce que j'apprends et je le prends positivement, je n'essaie pas de vouloir demontrer que je sais/savais/ai raison ;)
Si tu veux des vraies reponses concretes sur le water, ici il y a un mec VRAIMENT calé qui est une bible pour nous, son pseudo c'est Poisson Rouge ;)
EDIT : ceux que tu appelles hypocrites, je dirais l'inverse, des mecs francs qui disent ce qu'ils pensent réellement, et ça je trouve ça bien non ? :p
Message édité par Sassanou le 13-01-2013 à 15:00:33
n°2268082
aurelienbo​uchet
Posté le 13-01-2013 à 15:07:15  profilanswer
le mien je l'ai eu sur rueducommerce.
un petit up pour mon probleme svp
Message édité par aurelienbouchet le 13-01-2013 à 15:08:14
n°2268087
zzzsleepin​g
Posté le 13-01-2013 à 15:19:19  profilanswer
Salut
Je suis tout sauf sur de moi en WC  :lol:
Mais ya des jours comme hier ou j'etais aussi enervé qu'impatient et je me suis emballé suite aux critiques de certains c'est tout
Je n'en veux a personne tkt
Je voulais juste des reponses car j'ai trop envie de commencer mon projet
J'ai deja tout les composants reste plus que le WC
Comment recommencé et quel topic créer sans me refaire incendier car tout le monde va me reconnaitre
Perso je pense que c'est mort  :lol:  :lol:
Merci a toi fin du HS
On peut se parler en MP ou non ?
n°2268103
Sassanou
Posté le 13-01-2013 à 15:41:00  profilanswer
Ouais, on peut papoter en MP ;)
Mais t'enerves pas si je reponds pas a la minute, c'est pas mon fort ça ^^
n°2268107
zzzsleepin​g
Posté le 13-01-2013 à 15:43:04  profilanswer
On dirait pas a la premiere impression que j'ai fait mais je suis d'un temperemment zen dans 99.99% du temps
A de suite en MP
n°2268116
elpolloloc​o
Posté le 13-01-2013 à 16:02:35  profilanswer
C'est quoi la référence/modèle du clebs photos n°7 ? :D
Sinon j'ai remarqué que le sticker sur l'alim est posé à l'arrache :o
Mais rien que pour la config bi-cpu-gpu-ram je kiff :love:
n°2268154
T-8rD
Posté le 13-01-2013 à 17:54:07  profilanswer
american staff bull terrier  :love:
n°2268187
elpolloloc​o
Posté le 13-01-2013 à 20:00:55  profilanswer
T'échanges ? J'ai un carlin et franchement il est pas aussi véloce que je le pensais :o
n°2268189
T-8rD
Posté le 13-01-2013 à 20:04:33  profilanswer
Le miens est jeune tous juste 1ans
n°2268192
elpolloloc​o
Posté le 13-01-2013 à 20:08:41  profilanswer
Le mien a 4 mois maintenant, il fait ses débuts, je l'inscris bientôt au MMA catégorie canine pour lui apprendre la dure loi de la nature.
n°2268198
T-8rD
Posté le 13-01-2013 à 20:14:06  profilanswer
ok
n°2269040
T-8rD
Posté le 16-01-2013 à 21:46:57  profilanswer
bientôt une grosse mise a jours de ma config SR2
Mega love
n°2269053
damsxx
Posté le 16-01-2013 à 22:17:03  profilanswer
3 tgt ?
Loxapac j'adore ! ^^
n°2269054
guigui26
technoloGEEK
Posté le 16-01-2013 à 22:18:48  profilanswer
c est quoi c est config de fou !!!!!
Message édité par guigui26 le 16-01-2013 à 22:19:15
Rien
n°2269057
T-8rD
Posté le 16-01-2013 à 22:25:28  profilanswer
Non
Quad sli GTX 580 EVGA
Il me manque juste un WB j'arrive pas en trouver
n°2269090
Scouto
Air Cooling Rules !
Posté le 17-01-2013 à 01:07:08  profilanswer
P'tin le four que ça va être la dedans  :pt1cable:
n°2269091
T-8rD
Posté le 17-01-2013 à 01:18:15  profilanswer
Non je fait un rajout d'un rad en plus faut juste que je trouve pour faire un beau tubing
pas facile
n°2269142
Scouto
Air Cooling Rules !
Posté le 17-01-2013 à 12:50:01  profilanswer
Ouais mais la chaleur dégagée doit bien aller quelque part :D
Ça sera ta chambre le four alors :whistle: Parce que 4x580 :pt1cable:
En tout cas c'est une config qui fait rêver  :love:
n°2271285
T-8rD
Posté le 25-01-2013 à 15:45:58  profilanswer
Voila je travaille un peux sur mon boitier
Il manque encore 2 580 pas eu le courage de monter les block
Les tuyaux son provisoire
http://img571.imageshack.us/img571/3703/1006842.jpg
http://img515.imageshack.us/img515/667/1006843.jpg
http://img831.imageshack.us/img831/4681/1006844u.jpg
http://img832.imageshack.us/img832/2006/1006845.jpg
http://img707.imageshack.us/img707/1668/1006852n.jpg
http://img24.imageshack.us/img24/9816/1006857f.jpg
Message édité par T-8rD le 25-01-2013 à 17:06:09
n°2271318
calagan57
BF3 : calagan57
Posté le 25-01-2013 à 17:02:58  profilanswer
Drap!
y a du matos de malade par ici!!! :love:
Fais nous une oeuvre d'art!  :hello:
Waterbox
n°2271413
T-8rD
Posté le 26-01-2013 à 00:25:53  profilanswer
Voila les 4 CG
http://img715.imageshack.us/img715/4461/1006868.jpg
http://img94.imageshack.us/img94/1637/1006871z.jpg
http://img259.imageshack.us/img259/6306/1006872f.jpg
http://img248.imageshack.us/img248/8494/1006873.jpg
http://img22.imageshack.us/img22/6223/1006874.jpg
Message édité par T-8rD le 26-01-2013 à 01:55:38
n°2271563
polomod
www.polomod.fr
Posté le 26-01-2013 à 14:44:05  profilanswer
vivement les tuyaux rouge :)
n°2271570
alucard24
Posté le 26-01-2013 à 15:01:59  profilanswer
et les ventilos rouges alors et vire moi cet immonde collier au dessus du gpu 1 :)
c'est quand même joli un quad ... meme si c'est completement useless :D
Message édité par alucard24 le 26-01-2013 à 15:02:44
 Page :   1  2
Page Précédente
[ avis ] ventilo 120mm xigmatekWC double loop dans Xigmatek Elysium , conseiler,choix et assemblage
Nuisance sonore : Xigmatek XLF-F1256[workblog] Elysium acide MAJ 02/05
[WorkLog] Xigmatek Elysium Blue&Red WaterXigmatek Balder sd1283 : PWM innactif ?
[Workblog] XIgmatek Elysium "Dark-Purity" 100% et news photos ...Xigmatek Elysium Bi-Xeon
[WorkBlog] Watercooling WC - Xigmatek Elysium[Workblog] Intégration Xigmatek Elysium (Anciennement Lexa S)
Plus de sujets relatifs à : Mon Mountain Mods U2FO
