6002 connectés
 Page :   1  2  3  4  5  6
[Work Blog]Bureau D'ordinateur Ultime
n°2106769
El-Gato
jambe
Posté le 31-03-2011 à 20:54:22  profilanswer
ultimatedesk a écrit :
Eh bien, le project c'est dans les images, non? I got all of the 3D models from Google Sketchup Warehouse:
http://sketchup.google.com/3dwarehouse/
Ah ok ! Je savais pas qu'il y avait tant de choses sur google warehouse !
Je suis attentivement ton topic en tout cas ;)
n°2106784
k0rnmuz3
Posté le 31-03-2011 à 21:25:59  profilanswer
Can't wait for the next step :love:
n°2110830
ultimatede​sk
Posté le 12-04-2011 à 17:27:42  profilanswer
arkrom a écrit :
yess  :love:
hope somes assembli pictures soon
Thanks, they're coming soon!
Fredo428 a écrit :
Yeahh good products !
Thanks!
KaiserCz a écrit :
What a nice stuff ! :o
Thank you!
Oui, c'est vraiment encroyable, non? Il y a ten de modeles pour tout vos projects 3D! Excuse mon Francais lol, je peu le parlez, mais ecrire, c'est une autre chose!
So - it's been sometime since I've posted an update - apologies, things have been very busy lately.
With the parts from Danger Den having arrived, I could now move on to some more specific details with both of the cabinets that will contain the computers.
Once again, I started with a test fitting, this time, it was a very accurate fitting, requiring quite a bit of sanding and fiddling around to get as close to the final product as possible.
http://img863.imageshack.us/img863/8083/img5599e.jpg
http://img856.imageshack.us/img856/6528/img5606z.jpg
http://img40.imageshack.us/img40/3326/img5607s.jpg
I then placed some test parts for fitting, and traced some outlines on the wood. The motherboard tray was placed on some thin strips of packing foam that I cut up, to help isolate any vibration from the CPU Heatsink.
http://img402.imageshack.us/img402/8474/img5611r.jpg
http://img25.imageshack.us/img25/2696/img5612yt.jpg
Installed some new blades on the jigsaw, put my biggest drill bit in the drill, and went to town!
http://img851.imageshack.us/img851/8239/img5615u.jpg
http://img20.imageshack.us/img20/193/img5619ca.jpg
Part 2 coming right up!
n°2110832
ultimatede​sk
Posté le 12-04-2011 à 17:28:25  profilanswer
After doing the rough cut with the jigsaw, I took out the router and free-handed with a straight bit to smooth out the edges.
http://img801.imageshack.us/img801/1871/img5623w.jpg
The semi-finished air intake for the left-hand cabinet:
http://img860.imageshack.us/img860/3656/img5627w.jpg
The power supply rough cut:
http://img59.imageshack.us/img59/3681/img5631tg.jpg
http://img854.imageshack.us/img854/6972/img5632.jpg
I decided that the PSU bolts will need a little more clearance around the screw holes.
http://img543.imageshack.us/img543/5792/img5634w.jpg
The I/O Shield cut out was a bit tricky to measure, but I think I did a pretty decent job:
http://img96.imageshack.us/img96/8025/img5635u.jpg
http://img856.imageshack.us/img856/1241/img5636n.jpg
http://img684.imageshack.us/img684/2381/img5637br.jpg
And a final shot from above and below:
http://img685.imageshack.us/img685/6210/img5638z.jpg
http://img850.imageshack.us/img850/1996/img5640l.jpg
Next update, I'll have pics of actual assembly of the left hand cabinet, and then more cutting, and biscuit joining on the right-hand cabinet.
n°2110833
genghis77
-_-'
Posté le 12-04-2011 à 17:31:08  profilanswer
:love:
the router the ultimate tool for finishing
great work
Je sais que je plais pas à tout le monde... mais quand je vois à qui je plais pas... je me demande si ça me dérange vraiment
n°2110834
Fredo428
Posté le 12-04-2011 à 17:31:15  profilanswer
n°2112054
Cat121
Lucky l'up
Posté le 16-04-2011 à 23:35:05  profilanswer
Where is this bell... Oh yeah ! *suscribe*
Man, this is really an awesome job !
I didn't expect to find such a nice project on the forum.
Nothing more to say, just waiting for the following pictures !
Keep on this way :jap:
Topic AV - inactif
n°2113183
ultimatede​sk
Posté le 20-04-2011 à 22:48:12  profilanswer
genghis77 a écrit :
:love:
great work
Thanks for the kind words everyone :)
It's been a while, but I can assure you, progress is still moving forward with the Ultimate Computer Desk!
I finally got around to assembling the left-hand cabinet - here it is, all glued and clamped together. It's a really solid unit - the dado cuts lined up really well, and the structure is rock solid.
http://img809.imageshack.us/img809/7446/img5643um.jpg
http://img545.imageshack.us/img545/8811/img5645p.jpg
Here I am doing a mock-up of the right-hand cabinet. This one was a little trickier to put together. There is a pretty specific order of assembly, otherwise, you're left with a piece that just doesn't want to fit properly.
http://img585.imageshack.us/img585/8231/img5647y.jpg
Some outlines for the motherboard I/O and power supply
http://img15.imageshack.us/img15/5172/img5652h.jpg
I remember mentioning that I free-handed the holes with the router for the left-hand cabinet. I decided to play a safer route for the right-hand cabinet.
I took a piece of wood, lined it up with my straight edge, and ran my router on top of the wood with a straight bit - this game me a perfect "stencil". What I can do then, is take the stencil, line up the edge with a line that I've drawn on the target piece, place a straight edge behind the stencil, clamp down the straight edge, remove the stencil, and run my router across the straight edge for a straight, accurate line.
Wow, that was a mouthful.
http://img718.imageshack.us/img718/3053/img5654b.jpg
http://img696.imageshack.us/img696/9985/img5656q.jpg
And the end product:
http://img857.imageshack.us/img857/2135/img5657.jpg
http://img708.imageshack.us/img708/3526/img5661y.jpg
And then I made a pretty huge mistake...
Here is the suspect:
http://img19.imageshack.us/img19/7803/img5662f.jpg
Bam. Can you guess why this was a bad idea?
http://img31.imageshack.us/img31/941/img5658m.jpg
n°2113194
Kurchak
Bourrin inside
Posté le 20-04-2011 à 23:12:54  profilanswer
great work but i guess the bad idea was to drill the big whole on your main desk board, you could have daly touch the front of it...
Am I right?
By the way the whole job is crazy!!!
Quand tu me parles de ton mac, j'ai l'impression de lire "tu sais que je suis en chaise roulante, je peux pas atteindre l'étagère du haut ...mais j'ai des franges sur les poignées alors c'est joli" - DTC.com /// "Vieux, gros, roux et gaucher" :(
n°2113198
Fredo428
Posté le 20-04-2011 à 23:15:30  profilanswer
Yeahh good job !
n°2115370
ultimatede​sk
Posté le 29-04-2011 à 21:57:25  profilanswer
Am I right?
Fredo428 a écrit :
Yeahh good job !
Thanks, but the mistake, as you'll see is a bit worse than that! Next update!
I've been terribly sick lately, sorry for the no show on the updates. Here are some kittens to keep you content until I get some more work done ;)
These are pictures from when they were 3 weeks to 8 weeks old.
http://img41.imageshack.us/img41/4378/img5707gf.jpg
http://img3.imageshack.us/img3/6731/img5710nx.jpg
http://img825.imageshack.us/img825/5954/img5718w.jpg
http://img222.imageshack.us/img222/8063/img5822l.jpg
http://img163.imageshack.us/img163/4263/img5881p.jpg
http://img839.imageshack.us/img839/6695/img5882l.jpg
http://img233.imageshack.us/img233/765/img5913o.jpg
http://img600.imageshack.us/img600/174/img5928t.jpg
Hopefully I'll have something interesting for you on Monday
n°2115373
Madwolf70
Posté le 29-04-2011 à 22:14:56  profilanswer
I want him
*___*
Good recovery man and we wait for your fuckin' good job :D  :ouch:
Message édité par Madwolf70 le 29-04-2011 à 22:15:24
n°2115420
KaiserCz
bros before hoes
Posté le 30-04-2011 à 02:08:49  profilanswer
Gimme your cats :o
Wan' them, they are so fuckin' cute :love:
n°2115432
etiennedef​qvx
Posté le 30-04-2011 à 08:09:31  profilanswer
:love:²
I'm found about your cats ! But I already have some home, it won't be possible :whistle:
Message édité par etiennedefqvx le 30-04-2011 à 08:09:42
White Li : WorkBlog / Ventes
n°2115436
Fredo428
Posté le 30-04-2011 à 09:38:08  profilanswer
:love:
n°2115437
Cat121
Lucky l'up
Posté le 30-04-2011 à 09:42:59  profilanswer
Fredo, you can't afford to have a kitteh, it would finished hanged with one of the wire in your mess :P
I really like the fourth picture, these two little innocent faces, ready to disturb you during the night and running all over the house :D
Topic AV - inactif
n°2115475
KaiserCz
bros before hoes
Posté le 30-04-2011 à 13:00:36  profilanswer
But your GF seems pretty also :D
(jk :p)
Message édité par KaiserCz le 30-04-2011 à 13:13:17
n°2115477
etiennedef​qvx
Posté le 30-04-2011 à 13:05:45  profilanswer
(jk :p)
I Agree ^^
Message édité par etiennedefqvx le 10-05-2011 à 19:22:40
n°2115480
KaiserCz
bros before hoes
Posté le 30-04-2011 à 13:13:37  profilanswer
@etienne corrige ma faute dans ta citation ^^' :o
n°2116300
Zanskar03
Posté le 03-05-2011 à 10:20:38  profilanswer
I  :love:  the kittens and also the desk  :D
n°2120130
ultimatede​sk
Posté le 16-05-2011 à 22:45:01  profilanswer
Holy moly, I'm really sorry for the lack of updates folks - I've been sick for quite a while and the weather has been miserable so I haven't had much time to work on the desk. Apparently I had cedar poisoning! Wonderful!
Thanks for all the wonderful comments about the kittens - they are super cute aren't they! And oh yes, they DO blast around the house at 4 in the morning fairly regularly...
Anyways - back on track!
Those of you who guessed it right - yes, I shouldn't have made the hole in the first place. I don't know what I was thinking. This is the right-hand cabinet.
http://img825.imageshack.us/img825/5168/img5663h.jpg
Whoops!
http://img717.imageshack.us/img717/5238/img5664u.jpg
Here's the biscuit joiner I was using. It worked pretty well for what it is. The tricky part was determining the order of which pieces/faces/sides to glue first and how to keep it all from falling apart before completion.
http://img861.imageshack.us/img861/3576/img5667.jpg
http://img690.imageshack.us/img690/9776/img5668z.jpg
http://img841.imageshack.us/img841/158/img5671p.jpg
http://img695.imageshack.us/img695/7764/img5672tw.jpg
Here's the left-hand cabinet all dried and ready for some trim
http://img24.imageshack.us/img24/6984/img5675c.jpg
And voila, my erm.. elegant clamping solution (I need to grab some cauls!)
http://img852.imageshack.us/img852/4132/img5676.jpg
http://img815.imageshack.us/img815/5046/img5677d.jpg
Hope you enjoy! Rest assured, this project WILL BE FINISHED! Just.. mm, I don't really know when. I'm moving in a month and a half, so all the staining/sanding will have to be done, at a minimum.
Take care!
n°2120291
mansonic
luv' maille paycay
Posté le 17-05-2011 à 17:27:01  profilanswer
cu soon!
si tu lis ça alors c'est que tu surveilles pas ta petite soeur...
n°2120363
k0rnmuz3
Posté le 17-05-2011 à 20:42:12  profilanswer
You're a god of mod :love:
n°2121251
ultimatede​sk
Posté le 20-05-2011 à 20:28:54  profilanswer
Yes!
lolol, I have never heard that one before! Thanks!
This part of the project took a better part of a month. There was a lot of sanding, waiting, and sweating as I put on each thin layer of polyurethane on the desk surface.
Here it is at the start of the phase - what a mess!
http://img850.imageshack.us/img850/4030/img5696e.jpg
http://img191.imageshack.us/img191/4941/img5697x.jpg
You can see there was still sanding to do from when I put in the wood filler back in... November!
http://img703.imageshack.us/img703/900/img5699l.jpg
All cleaned up, ready to rock the stain. It was starting to get nice as well so it was time to lube up the 'ol bike chain as well!
http://img828.imageshack.us/img828/2443/img5871e.jpg
http://img196.imageshack.us/img196/8398/img5700gc.jpg
Part way through the first coat
http://img42.imageshack.us/img42/784/img5874pe.jpg
Note that this is the bottom of the desk surface. I did this intially without any kind of pre-stain or wood treatment to see if I could get away with it.
http://img24.imageshack.us/img24/8962/img5876g.jpg
http://img268.imageshack.us/img268/51/img5878t.jpg
I actually noticed a significant amount of dark spots and uneveness, so for the top of the desk, and for all future staining, I went with a pre-stain, and two coats of Old Masters Gel Stain. Here is the desk surface approximately a month later with around 8 coats of polyurethane on top. It will be getting a good ol fashion rubbing out in another month from now once it has fully cured.
http://img851.imageshack.us/img851/221/img5959.jpg
Have a good weekend everyone!
n°2121271
Kurchak
Bourrin inside
Posté le 20-05-2011 à 22:51:17  profilanswer
You've got a three day WE to finish this mod, you'd better hurry!!!
nice work so far, really...
n°2121272
Schmittoun​et
Posté le 20-05-2011 à 22:51:31  profilanswer
This mod is pretty impresive !
All things you've done are awesome !
Since some weeks i'm dreaming about a desk looking like this, and you're just doing it ! AWESOME !
Hope to see something like this in a few years in some store ^^
Congrats !
Keep working on it !
n°2121326
sogetel20
enfin un Phenom II x6 1055T !
Posté le 21-05-2011 à 03:32:42  profilanswer
beautiful desktop
not loose your work is progressing well
sogetel20
demi gameur Phenom Ii x6 1055T Deepcool Gammax 200T a 42 degres full
n°2121659
Invite_Sur​prise
Racaille de Shanghaï
Posté le 22-05-2011 à 13:35:37  profilanswer
Super boulot !  :love:
Mais je pense que tu as trouvé ton maître :
http://tof.canardpc.com/preview2/34fb5541-b523-4c23-96ef-47771cf30026.jpg
http://tof.canardpc.com/preview2/2503e9bf-ba71-447e-8fb8-ad1689a5082c.jpg
Le bureau ultime existe déjà [:sir_knumskull]
Workblog :
http://forum.coolermaster.com/view [...] 49&t=14742
n°2121664
KaiserCz
bros before hoes
Posté le 22-05-2011 à 13:53:33  profilanswer
Not the same type of desktop, still waiting for the next step !
Love wood job :D
n°2121914
djmonster
59Hardware.net
Posté le 23-05-2011 à 09:03:45  profilanswer
Love it :)
Mes ventes
n°2122739
ultimatede​sk
Posté le 25-05-2011 à 22:58:35  profilanswer
Hehe, thanks, I was able to get quite a bit done this weekend actually!
Congrats !
Thank you, maybe one day Ikea will have something like this!
sogetel20 a écrit :
beautiful desktop
sogetel20
Thanks!
Workblog :
Yes, I've seen that many times when doing my initial research - too much bling for me!
Love wood job :D
Thanks!
Thank you!
So, with the main desk surface out of the way, it was time to start focusing on the top shelf portion, which, at this point, hadn't been sanded, cut perfectly, or assembled. Here were all the pieces required.
http://img857.imageshack.us/img857/1160/img5961.jpg
A quick mock up:
http://img806.imageshack.us/img806/6571/img5972.jpg
A few tests with the biscuit joiner to make sure I was aligned properly:
http://img684.imageshack.us/img684/1158/img5974j.jpg
http://img703.imageshack.us/img703/1872/img5978x.jpg
http://img815.imageshack.us/img815/3474/img5983n.jpg
I couldn't get it exactly in the center - the bottom of the joiner is a bit concave and it made lining it up a little difficult. The tool is generally used to join boards end to end, so there wasn't really any facility for on-face joining like this.
Assembly and glue up time:
http://img9.imageshack.us/img9/5091/img5987g.jpg
http://img847.imageshack.us/img847/8205/img5988.jpg
http://img232.imageshack.us/img232/5572/img5989b.jpg
Enjoy! You can never have too many clamps you know? I couldn't continue on doing the side pods until this stuff dried up first.
n°2123157
ultimatede​sk
Posté le 27-05-2011 à 20:54:17  profilanswer
With the first phase of the top shelf all solid and dried, I could continue on to the two side pods. Here's the initial mockup.
http://img29.imageshack.us/img29/8959/img5993p.jpg
http://img833.imageshack.us/img833/2354/img5995tp.jpg
Notice the pencil lines for the biscuits I'll be installing.
http://img16.imageshack.us/img16/1999/img5996i.jpg
Those biscuits are so dark and moody... lol!
http://img41.imageshack.us/img41/8507/img5999dv.jpg
Aaand, some gratuitous clamping shots. Like that extra-long setup? Yeah, that worked this time, but I don't recommend it. It wasn't too stable, but there wasn't really anything else I could clamp on to for that end-pressure required.
http://img717.imageshack.us/img717/289/img6002u.jpg
http://img694.imageshack.us/img694/5504/img6009g.jpg
http://img821.imageshack.us/img821/9900/img6010s.jpg
Mmmm glue.
http://img23.imageshack.us/img23/1399/img6013b.jpg
So that's it for this update, I know it's a pretty simple one, but hey, it's one more phase done. Just needs to have some trim stuck on and then staining!
Have a good weekend!
n°2123212
Fredo428
Posté le 28-05-2011 à 09:29:08  profilanswer
Yeah !
Do you add screws after ?
(Sorry for the english)
n°2123216
benmohaa19​45
Aka RedBen
Posté le 28-05-2011 à 10:44:35  profilanswer
Fredo428 a écrit :
Yeah !
Will you add screws later ?  :jap:
Message édité par benmohaa1945 le 28-05-2011 à 10:45:53
n°2123329
Kurchak
Bourrin inside
Posté le 28-05-2011 à 17:24:06  profilanswer
They don't use screws alot here...
they often use glue or nails...
By the way I love the big clamp :D
How many do you have at home? it costs you a fortune no?
n°2123332
etiennedef​qvx
Posté le 28-05-2011 à 17:31:50  profilanswer
+1 :love:
n°2123336
kaari
Fuck Yeah !
Posté le 28-05-2011 à 17:45:39  profilanswer
Nice Impressive project and really an artistic and technical task !
When an Ikea desk like that ? xD (with cats included ^^).
n°2123524
colina2
un matos addict
Posté le 29-05-2011 à 19:27:37  profilanswer
Super boulot, vraiment  [:le talus]
n°2129361
ultimatede​sk
Posté le 20-06-2011 à 21:33:31  profilanswer
Fredo428 a écrit :
Yeah !
No screws. I hardly used any. With the biscuits and glue, it should be very, very strong.
Well, it's not like they were free, but I always bought them when there was a sale, so it didn't cost too much. They are the cheap kind as well, not the really nice ones!
Thanks!
Hehe, that would be interesting. I don't know if Ikea will ever make anything as strong as this though!
Merci beaucoup!
Ok, so it's been a little while since an update eh?
I've been busy, sorry folks, life seems to speed up in the summertime!
As a peace offering, here are the kiddo's, at about 4 months old now!
http://img32.imageshack.us/img32/3982/img6018k.jpg
http://img805.imageshack.us/img805/6026/img6036.jpg
And, back to the desk!
I had a bunch of solid maple cut into more 1/4" strips so I could finish doing the trim on the top shelf and the cabinets.
http://img862.imageshack.us/img862/889/img6059b.jpg
My trusty compound mitre saw - got it reconditioned at a bargain place for like 60 dollars, and it's been pretty reliable for a number of years now. It's loud as all heck though!
http://img84.imageshack.us/img84/9342/img6064a.jpg
And, my favorite part - clamping up!
http://img864.imageshack.us/img864/9176/img6069hm.jpg
http://img197.imageshack.us/img197/6272/img6071he.jpg
http://img228.imageshack.us/img228/6817/img6074e.jpg
And, since there was nowhere to place clamps in between this area, I had to improvise with a small block of wood!
http://img151.imageshack.us/img151/4002/img6076b.jpg
n°2129362
ultimatede​sk
Posté le 20-06-2011 à 21:33:54  profilanswer
After the trim was glued on and then sanded flush, I proceeded with the staining and poly
http://img32.imageshack.us/img32/1046/img6083a.jpg
Looks good, eh?
http://img841.imageshack.us/img841/715/img6085t.jpg
I also finally decided to buckle down and build myself a quick rig to store all my clamps. Since I'm moving soon, it'll also make it easier to move them to the new place! Nice lap joints eh!!
http://img856.imageshack.us/img856/912/img6086l.jpg
I proceeded to the cabinet drawers, where I finally sanded off the wood filler that's been attached for weeks (months?)
http://img11.imageshack.us/img11/5186/img6090o.jpg
Lined up the drawer faces, glued them on (Was going to screw them on after, from behind. Lol)
http://img220.imageshack.us/img220/9973/img6091s.jpg
And put a bit of weight on top..
http://img101.imageshack.us/img101/2296/img6093y.jpg
Walked away for a bit, and realized... maybe it was a bad idea to glue them on first! Uh oh!
n°2129363
ultimatede​sk
Posté le 20-06-2011 à 21:34:17  profilanswer
I decided that it might actually be a lot easier to line up the drawer faces if I attached them AFTER I had attached the drawers to the drawer slides, to I ripped em off.
So, next on the list - staining the actual drawers!
Pre-stain on!
http://img204.imageshack.us/img204/4817/img6098pv.jpg
Mmm, they look so good
http://img585.imageshack.us/img585/9258/img6101.jpg
http://img189.imageshack.us/img189/8686/img6103r.jpg
And, poly of course
http://img34.imageshack.us/img34/3993/img6110nl.jpg
http://img836.imageshack.us/img836/194/img6112dm.jpg
Done!
http://img846.imageshack.us/img846/6017/img6115u.jpg
And just so ya know, it really did basically take a month just to finish the top shelf and the drawers... more to come soon!
 Page :   1  2  3  4  5  6
[Mini work blog] Tango NSK3480[WorkBlog] Cosmos 1000, intégration WC (Noiseblocker) = Terminé !
[Blog Justbam] Cosmos Pure BlackProblème d'overclock d'un E8400 sur Asus P5N-D
Température ordinateuraméliorer les performances de mon ordinateur
D'abord j'achette, après,... je me demande comment je fais :p[OC] Overclocking global sous bureau Windows
Plus de sujets relatifs à : [Work Blog]Bureau D'ordinateur Ultime
