6146 connectés
  Divers
  faut-il vraiment préférer l'ARTICLEAN au dissolvant classique?
n°1243309
nioubizz
Posté le 04-05-2005 à 05:31:54  profilanswer
salut,
j'aimerais avoir l'avis des spécialistes sur les disolvants de pate thermique..
 l'extrait ci-dessous tiré du site Arcticsilver est-il un pur argument marketing ou une véritable information SVP?
http://www.arcticsilver.com/arcticlean.htm
D'avance merci pour vos réponses ;)
Most solvents and cleaning products leave residue on the CPU and heatsink that negatively affects the performance of any subsequently applied thermal interface material. ArctiClean 1 Thermal Surface Purifier removes the residue of citrus or petroleum based cleaners and inhibits flash corrosion on a copper or aluminum heatsink.
Why Not Just Use Isopropyl Alcohol or Acetone?
Put isopropyl alcohol or acetone on a thermal pad and 10 minutes later you will have...
A thermal pad.
Only with a lot of rubbing and scrubbing will you be able to remove the pad. While the alcohol or acetone may soften the pad, neither actually dissolves the pad.
Although less visible, it is the same cleaning thermal greases with alcohol or acetone.
ArctiClean 1 totally emulsifies thermal pads and thermal greases. The waxes, oils, and fillers of the thermal material are suspended within the ArctiClean 1 so they can be cleaned off completely. This emulsification allow ArctiClean to remove the thermal material in the microscopic imperfections in the heatsink or heat spreader that non-emulsifying cleaners cannot touch.
The flash corrosion inhibitors in ArctiClean 2 then significantly reduce the corrosion layer on the copper or aluminum, improving the interface between the metal and the new thermal material and maximizing thermal transfer
http://forum.hardware.fr/hardwaref [...] 0252-1.htm pré-VENDS Ventilateur super silencieux TEXTORM_dB_Killer_120mm NEUF FACTURE
n°1243914
nioubizz
Posté le 05-05-2005 à 00:29:10  profilanswer
up
n°1243918
kane o_O
Ah bon ?!
Posté le 05-05-2005 à 00:44:56  profilanswer
Je crois que les mecs de chez Arcticsilver utilisent de l'eau et pas de l'acétone :o.
C'est simplement des blaireaux [:xman].
Ou alors ils nessuient pas avec un chiffon ===> le truc des 10 minutes plus tard vous obtenez un pad thermique ===> ben logique l'alcool et l'acétone s'évaporent, donc faut essuyer avec un chiffon imbibé :pfff:
M'enfin bon si on a pas d'acétone, et pis un pad thermique ça s'enleve sans alcool ou acétone ===> lame de cutter ou scalpel powaaaa. :jap:
Choix de matos WC pour les gens qui en ont marre du bruit | Je suis le seul à pas être adepte du SMS staÿle ????
n°1243925
nioubizz
Posté le 05-05-2005 à 01:26:06  profilanswer
carrément? au cutter sur le core d'un AMD socketA ????!  :heink:
n°1243933
Alisteroid
Posté le 05-05-2005 à 03:57:03  profilanswer
Ton pad thermique à l'origine il est colé sur ton rad pas sur le core de ton proc  :heink:
n°1243964
swissforev​er
i7 Inside
Posté le 05-05-2005 à 10:50:10  profilanswer
+1 :)
n°1244326
nioubizz
Posté le 06-05-2005 à 00:48:40  profilanswer
à l'origine certes, mais en l'occurence mon cpu et mon rad ont été assemblés et fonctionnent ainsi depuis qques semaines déja ;)
et le pad ou chewing gum gris a fondu et plus ou moins séché
je le sais car j'ai démonté le proco pour le changer de mobo..
voili..
donc ma question initiale concerne le pad ou la pate thermique qui se trouve sur le proco ;)
  Divers
C'est vraiment si révolutionnaire que ça les heatpipes ?O/C un Dell, vraiment IMPOSSIBLE ?
Aide pour un OVERCLOCKING vraiment bizarre!o/c barton 3000 xp+ sur asus a7n8x e deluxe vraiment efficace?
Ventilo pour chipset vraiment silencieux...vraiment bizard ce vcore!
l'aperture size a vraiment une utilité !!!Overclocker le Bus AGP, dangereux ? Vraiment utile ?
Est-il vraiment impossible d'oc un Dell?utilité des dissolvant pour pâte thermique?es-ce que c'est dangereux?
Plus de sujets relatifs à : faut-il vraiment préférer l'ARTICLEAN au dissolvant classique?
