7635 connectés
 Page :   1  2
Page Suivante
utilisateurs!
n°367316
udok
La racaille des barbus ©clémen
Posté le 29-11-2003 à 22:58:10  profilanswer
dRfELL a écrit :
udok  => t'as jabber ou autre ? sinon donne moi ta conf vsftpd
oué, j'ai jabber
voilà ma conf :
# Example config file /etc/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Run standalone?  vsftpd can run either from an inetd or as a standalone
# daemon started from an initscript.
#listen=YES
# Run standalone with IPv6?
# Like the listen parameter, except vsftpd will listen on an IPv6 socket
# instead of an IPv4 one. This parameter and the listen parameter are mutually
# exclusive.
#listen_ipv6=YES
# Allow anonymous FTP? (Beware - allowed by default if you comment this out).
anonymous_enable=YES
# Uncomment this to allow local users to log in.
#local_enable=YES
# Uncomment this to enable any form of FTP write command.
#write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
#local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
pasv_enable=NO
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format
#xferlog_std_format=YES
# You may change the default value for timing out an idle session.
idle_session_timeout=120
# You may change the default value for timing out a data connection.
#data_connection_timeout=300
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
nopriv_user=ftp
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that turning on ascii_download_enable enables malicious remote parties
# to consume your I/O resources, by issuing the command "SIZE /big/file" in
# ASCII mode.
# These ASCII options are split into upload and download because you may wish
# to enable ASCII uploads (to prevent uploaded scripts etc. from breaking),
# without the DoS risk of SIZE and ASCII downloads. ASCII mangling should be
# on the client anyway..
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may restrict local users to their home directories.  See the FAQ for
# the possible risks in this before using chroot_local_user or
# chroot_list_enable below.
#chroot_local_user=YES
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
ls_recurse_enable=YES
Non au projet de loi DADVSI ! (droits d'auteurs)
n°367317
dRfELL
I want to believe.
Posté le 29-11-2003 à 22:59:26  profilanswer
tu peux m'expliquer alors comment je peux faire pour que mon user puisse ecrire dans un dossier abec proftpd?
n°367318
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 22:59:43  profilanswer
dRfELL a écrit :
méheuuuu ne vous foutez pas de me gueule tout le monde debute un jour ;)
Ca fait quand même 3 mois que tu débutes  :o
n°367320
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:01:05  profilanswer
n°367321
dRfELL
I want to believe.
Posté le 29-11-2003 à 23:01:17  profilanswer
donne ton user jabber :)
n°367325
udok
Posté le 29-11-2003 à 23:04:12  profilanswer
non, je sais pas faire ça
je chercherais bien dans la doc, mais je me sentirais franchement insolent à ton égard de chercher à ta place ... ça voudrait dire que j'éstime être plus apte que toi à chercher dans une doc et je ne te sens pas stupide à ce point :)
n°367326
udok
Posté le 29-11-2003 à 23:04:32  profilanswer
n°367327
dRfELL
I want to believe.
Posté le 29-11-2003 à 23:05:06  profilanswer
pourquoi?!
n°367330
udok
Posté le 29-11-2003 à 23:06:29  profilanswer
bah je le file pas à n'importe qui :)
pis y-a rawcut qui t'a filé un bon lien
tu devrais potasser ce site, il est parfait pour les noob :p
n°367331
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:10:13  profilanswer
L'enculer :D
n°367332
dRfELL
I want to believe.
Posté le 29-11-2003 à 23:10:32  profilanswer
je suis pas n'importe qui ;) bon pas grave
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName   "Serveur FTP de dRfELL!!"
ServerType   standalone
DefaultServer   on
# Allow FTP resuming.
# Remember to set to off if you have an incoming ftp for upload.
AllowStoreRestart  on
# Port 21 is the standard FTP port.
Port    21924
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask    022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances   30
# Set the user and group under which the server will run.
User    nobody
Group    nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
MaxLoginAttempts  2
AccessGrantMsg   "%u bienvenue sur le serveur de dRfELL !! (en passant, vive Ferrari !)"
DeferWelcome   on
# Normally, we want files to be overwriteable.
<Directory />
  AllowOverwrite  on
</Directory>
# Needed for NIS.
PersistentPasswd              off
# Default root can be used to put users in a chroot environment.
# As an example if you have a user foo and you want to put foo in /home/foo
# chroot environment you would do this:
# DefaultRoot /home/foo foo
Message édité par dRfELL le 29-11-2003 à 23:14:28
n°367333
udok
Posté le 29-11-2003 à 23:10:48  profilanswer
n°367338
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:13:23  profilanswer
#DefaultRoot ~
La ligne est commenté comment tu veux que ca marche ???
Ensuite t'a meme pas de partie <global> dans ton fichier... c n'importe quoi, t'as rien configurer du tout la !
n°367344
dRfELL
I want to believe.
Posté le 29-11-2003 à 23:18:15  profilanswer
<Global>
  DefaultRoot                  ~
  AllowOverwrite               yes
  MaxClients                   2
  MaxClientsPerHost            1
  UseFtpUsers                  on
  AllowForeignAddress          on
  ServerIdent                  on       "ProFTP dRfELL's Server Ready"
  AccessGrantMsg               "Bienvenue %u sur le serveur de dRfELL"
</Global>
n°367346
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:19:04  profilanswer
On va pas y passer la nuit, voila une conf qui marche, qui chroot, et limite la bande passante pour celui qui se logue via le port 21
ServerName                      "tralalala"
DeferWelcome                    off
MultilineRFC2228                on
DefaultServer                   on
ShowSymlinks                    on
AllowOverwrite                  on
TimeoutNoTransfer               600
TimeoutStalled                  600
TimeoutIdle                     1200
DisplayLogin                    welcome.msg
DisplayFirstChdir               .message
ListOptions                "-l"
DenyFilter                      \*.*/
#PersistentPasswd               off
Port                            21
MaxInstances                    30
# Set the user and group that the server normally runs at.
User                            nobody
Group                           nogroup
LogFormat AUTH "%v [%P] %h %t \"%r\" %s"
<Global>
DefaultRoot           ~
AllowOverwrite        yes
MaxClients            4
MaxClientsPerHost     2
#TransferRate RETR 40
#TransferRate APPE,STOR 16
UseFtpUsers           on
ServerIdent           on   "FTP tralala"
AccessGrantMsg        "plop"
ExtendedLog /var/log/messages AUTH
</Global>
<VirtualHost 127.0.0.1>
ServerName            "Virtual FTP"
DefaultRoot           ~
Port                  3100
AllowOverwrite        yes
MaxClients            4
MaxClientsPerHost     2
UseFtpUsers           on
ServerIdent           on   "FTP * LOCALE *"
AccessGrantMsg        "Max BP !"
</VirtualHost>
<Directory /*>
  # Umask 022 is a good standard umask to prevent new files and dirs
  # (second parm) from being group and world writable.
  Umask                         022  022
  AllowOverwrite                on
</Directory>
n°367352
udok
Posté le 29-11-2003 à 23:23:14  profilanswer
rawcut a écrit :
#DefaultRoot ~
[:rofl]
il va se faire massacrer là [:joce]
bon et la mandrake elle conf pas ça correctement normalement ?
n°367354
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:24:14  profilanswer
udok a écrit :
[:rofl]
Elle laisse le fichier par defaut : ftp anonyme qui tue :D
n°367356
udok
Posté le 29-11-2003 à 23:25:46  profilanswer
bah moi je suis en anonyme sur mon vsftpd, quazi par défaut et je pense pas avoir de pb si ? [:spamafote]
n°367365
rawcut
tw: @_rawcut
Posté le 29-11-2003 à 23:34:06  profilanswer
J'en sais foutre rien en vérité, ce que je constate c que "chezmoicamarche" :D
 Page :   1  2
Page Suivante
Utilisateurs d'Enlightenment, vous utilisez quoi comme panel ?Pure-ftpd & utilisateurs virtuels, comprends pas
Utilisateurs de logiciels libres sur PauPrendre du courrier par POP3 et le distribuer à plusieurs utilisateurs
Serveur Mail sous Linux: Gestion de Groupes d'Utilisateurs[GENTOO] samba et ses utilisateurs
droits utilisateurs : accès internet impossible (groupe DIP activé)Limiter la bande passante des utilisateurs...
[ADDUSER] Comment gagner du tps pour ajouter bcp d'utilisateurs ?[MAC OS X] logiciel pour que les utilisateurs s'ecrivent en reseau
Plus de sujets relatifs à : utilisateurs!
