2645 connectés
  Linux et OS Alternatifs
  Installation
  UDF-fs kernel panic 2.6.15
n°768362
Pierre-Luc
Posté le 06-01-2006 à 05:27:33  profilanswer
Après avoir essayé de toutes les manières de compiler le noyau 2.6, voici le message d'erreur que j'obtiens à tout coup:
kernel-panic:UDF-FS: No partition found not syncing :VFS unable to mount root fs on unknow block (3,1)
Ce qui est étrange c'est que ce truc de UDF-FS semble avoir rapport aux supports amovibles du genre DVD.
J'ai compilé EXT2, EXT3 et reiserfs en built-in et aussi IDE.
/etc/lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/hda
message = /boot/boot_message.txt
prompt
timeout = 1200
# Override dangerous defaults that rewrite the partition table:
change-rules
reset
# VESA framebuffer console @ 1024x768x256
vga = 773
# Normal VGA console
# vga = normal
# VESA framebuffer console @ 1024x768x64k
# vga=791
# VESA framebuffer console @ 1024x768x32k
# vga=790
# vga=773
# VESA framebuffer console @ 800x600x64k
# vga=788
# VESA framebuffer console @ 800x600x32k
# vga=787
# VESA framebuffer console @ 800x600x256
# vga=771
# VESA framebuffer console @ 640x480x64k
# vga=785
# VESA framebuffer console @ 640x480x32k
# vga=784
# VESA framebuffer console @ 640x480x256
# vga=769
# End LILO global section
# Windows bootable partition config begins
other = /dev/hdb1
label = Windows
table = /dev/hdb
# Windows bootable partition config ends
# Linux bootable partition config begins
image = /boot/vmlinuz
root = /dev/hda1
label = Linux
read-only
# Linux bootable partition config ends
/etc/fstab
/dev/hda2 swap swap defaults 0 0
/dev/hda1 / reiserfs defaults 1 1
/dev/hdb1 /windows ntfs ro 1 0
/dev/cdrom /mnt/cdrom auto noauto,owner,ro 0 0
/dev/fd0 /mnt/floppy auto noauto,owner 0 0
devpts /dev/pts devpts gid=5,mode=620 0 0
proc /proc proc defaults 0 0
Le contrôleur IDE est le suivant:
00:1f.1 IDE interface: Intel Corporation 82801BA IDE U100 (rev 12)
L'option "PIIXn Intel" dans le menu de configuration est mis à * par défaut. Je crois que c'est le bon module de toute façon...
J'ai compilé le kernel "from scratch" et non pas "make oldconfig".
  Installation
kernel panic au boot quand j'enleve le lecteur CD[grub] kernel panic aléatoire sous Ubuntu
Compilation Module Kernelkernel 0.01 ouioui vous avez bien vu 0.01!
Demarrage Ubuntu => Kernel panicoù trouver les sources de mon kernel ?
[ Debian ] Nouveau Kernel 2.6.8 et souris USB
Plus de sujets relatifs à : UDF-fs kernel panic 2.6.15
