4619 connectés
  Linux et OS Alternatifs
  Installation
  [Ubuntu] Xorg et drivers proprio Nvidia
n°757290
yugo
Posté le 29-11-2005 à 21:50:33  profilanswer
Bonsoir a tous,
J'ai un soucis d'installation des drivers proprio Nvidia sur ma nouvelle Ubuntu. Ma CG est une FX5200 sur une A7N8X-X.
J'ai suivi les étapes de l'artcile http://wiki.ubuntu-fr.org/materiel/nvidia
mais au moment de redémarrer xorg, il plante.
Dans le log de xorg (je ne le reproduis pas car il est trés long), il commence par scanner les port PCI, puis passe en revue ses drivers de carte graphiques (MGA,GLINT,NV,TGA,S3,S3VIRGE,SIS,RENDITION,NEOMAGIC,I740,TDFX,SAVAGE,CIRRUS,ATI,RADEON,.......... mais pas de NVIDIA) puis il fini par:
(II) VESA: driver for VESA chipsets: vesa
(II) VGA: Generic VGA driver (version 4.0) for chipsets: generic
(II) DUMMY: Driver for Dummy chipsets: dummy
(II) FBDEV: driver for framebuffer: fbdev, afb
(II) v4l driver for Video4Linux
(II) Primary Device is: PCI 02:00:0
(EE) No devices detected.
Fatal server error:
no screens found
Pour info mon xorg.conf:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg-dbg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg-dbg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg-dbg
Section "Files"
        FontPath        "/usr/share/X11/fonts/misc"
#       FontPath        "/usr/share/X11/fonts/cyrillic"
        FontPath        "/usr/share/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/share/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/share/X11/fonts/Type1"
#       FontPath        "/usr/share/X11/fonts/CID"
        FontPath        "/usr/share/X11/fonts/100dpi"
        FontPath        "/usr/share/X11/fonts/75dpi"
        # paths to defoma fonts
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
        FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
        Load    "GLcore"
        Load    "i2c"
        Load    "bitmap"
        Load    "ddc"
#       Load    "dri"
        Load    "extmod"
        Load    "freetype"
        Load    "glx"
        Load    "int10"
        Load    "type1"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "kbd"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xorg"
        Option          "XkbModel"      "pc105"
        Option          "XkbLayout"     "fr"
        Option          "XkbVariant"    "latin9"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "ImPS/2"
        Option          "Emulate3Buttons"       "true"
        Option          "ZAxisMapping"          "4 5"
EndSection
Section "Device"
        Identifier      "NVIDIA Corporation NV34 [GeForce FX 5200]"
        Driver          "nv"
#       Driver          "nvidia"
#       BusID           "PCI:2:0:0"
EndSection
Section "Monitor"
        Identifier      "Acer AL707"
        Option          "DPMS"
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "NVIDIA Corporation NV34 [GeForce FX 5200]"
        Monitor         "Acer AL707"
        DefaultDepth    16
        SubSection "Display"
                Depth           1
                Modes           "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480"
        EndSubSection
                Depth           4
        EndSubSection
                Depth           8
        EndSubSection
                Depth           15
        EndSubSection
                Depth           16
        EndSubSection
                Depth           24
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
EndSection
Section "DRI"
        Mode    0666
EndSection
Ca fait un moment que je tourne en rond, si je remet le driver nv, forcément ca marche mais pas d'accélération....
Quelqu'un aurait-il une idée de solution ?
Message édité par yugo le 30-11-2005 à 22:19:44
n°757318
Kornwall
Posté le 29-11-2005 à 23:20:51  profilanswer
salut :)
ben deja on peut po lire tes messages :D ni ton xorg.conf donc deja cest un peu dure
mais si ca peut taider j'ai eu un pb pour installer les pilotes nvidia pour ma ti4200
le pb cest qu'avant j'avais pas installé le linux kernel 686smp (jai un p4c)
et ca faisait foiré l'installation des pilotes nvidia
enfin voila si ca peut taider :D
essaye de mettre le linux kernel 686 + pilotes nvidia
peut etre ke ca marchera ;)
n°757826
yugo
Posté le 30-11-2005 à 22:26:39  profilanswer
En effet, c'est bizarre ce [spoiler] faut cliquer dedans pour voir le texte.
Bon, c'est corrigé ;)
Sinon, J'ai testé l'install sur le kernel de l'installation : 2.6.12-10-i386 mais aussi celui dédié a mon Athlon XP: 2.6.12-10-k7 avec les headers et le restricted modules.
n°757875
Kornwall
Posté le 01-12-2005 à 00:06:32  profilanswer
Section "Device"
        Driver          "nv"
#       Driver          "nvidia"
#       BusID           "PCI:2:0:0"
EndSection
tu devrais, si j'etais toi, virer une des 2 lignes "driver"
y'en a une de trop la :D
Message édité par Kornwall le 01-12-2005 à 00:06:46
n°757921
bobuse
Posté le 01-12-2005 à 09:11:26  profilanswer
KornWall> il y en a pas une de trap, puisque la 2ème est en commentaire
yugo> tente un "sudo dpkg-reconfigure nvidia-glx"
get amaroK plugin
n°758140
yugo
Posté le 01-12-2005 à 18:48:34  profilanswer
En effet, la seconde linge Driver est commenté ;)
Bobuse> je viens de tenter et re-belotte, le seveur ne veut pas démarer:
Fatal server error:
no screens found
Alors que qu'avec le drvier nv:
(--) Chipset GeForce FX 5200 found
(II) resource ranges after xf86ClaimFixedResources() call:
        [0] -1  0       0xffe00000 - 0xffffffff (0x200000) MX[B](B)
Du coup j'ai essayer l'install par la "vieille" methode: télécharger le fichjier .run chez nvidia mais il m'insulte au sujet de GCC :/
Mais a choisir je préfèrerais avoir l'install propre par ubuntu.
n°758454
umag
deux yeux sinon rien
Posté le 02-12-2005 à 18:51:03  profilanswer
J'ai eu le même problème, que j'ai résolu en installant le paquet "linux-restricted-module" adapté à mon noyau (le 2.6.12-10-k7 pour moi).
On dirait que c'est le patch du noyau pour pouvoir faire fonctionner le driver nvidia.
n°759152
yugo
Posté le 04-12-2005 à 21:24:35  profilanswer
J'avais bien installé ce paquet donc j'ai continuer a tourner en rond pendant un  petit moment.
En fait j'ai l'impression que j'ai perdu l'accélération nvidia en mettant a jour le kernel. Je n'ai pas réussi a trouver d'où venait le pb donc j'ai craquer: j'ai réinstaller Ubuntu en passant au nouveau noyau puis en installant les drivers Nvidia et ca marche !
Ceci dit, j'ai pas eu grand chose a refaire puisque j'ai gardé mon /home donc je n'ai eu réinstaller que les applis, tous les paramètres étant sauvegardés ;)
Merci a tous  :)
  Installation
Probleme d'installation Ubuntu : "booting the kernel"[xorg] dual screen : mauvais écran par défaut
installation kernel source Ubuntu[ubuntu] divX super saccade avec totem
[Ubuntu] PXE => Ok, Kickstart => Souci[ubuntu] Activer une interface réseau et faire marcher le wifi
Pas de son sous Ubuntuwifi D-LINK G520+ avec ubuntu - pas de connexion au point d'accès
Probleme drivers ATI et OpenglChanger de kernel && drivers ati
Plus de sujets relatifs à : [Ubuntu] Xorg et drivers proprio Nvidia
