7767 connectés
hdb: read_intr
n°565145
rancor
Posté le 02-10-2004 à 15:57:56  profilanswer
Bonjour, je viens d'installer une suse 9.1 et j'ai un soucis à chaque démarrage :
Code :
  1. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499264, high=153, low=8585216, sector=2575499264
  2. <4>end_request: I/O error, dev hdb, sector 2575499264
  3. <3>Buffer I/O error on device hdb4, logical block 0
  4. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  5. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  6. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  7. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  8. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  9. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  10. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  11. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  12. <4>ide0: reset: success
  13. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  14. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  15. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  16. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  17. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  18. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  19. <4>hdb: read_intr: status=0x51 { DriveReady SeekComplete Error }
  20. <4>hdb: read_intr: error=0x10 { SectorIdNotFound }, LBAsect=2575499280, high=153, low=8585232, sector=2575499280
  21. <4>ide0: reset: success
Et ça me fait ça pendant 5 minutes avant de passer a la suite du boot.
Une fois que ça a booté je n'ai pas accés à ma partition ntfs de mon second disque.
En fait il me détecte ça comme disque dur :
http://rancor.free.fr/capture.png
C'est cool 2 fois 800 Go ca laisse de la place.  :D
En réalité il n'y a qu'une seule partition qui prend la totalité du disque soit 120 Go.
Tout ce que j'ai trouvé sur le net a propos de ces messages d'erreur concluent à un disque mort. Cependant lorsque je retourne sous windows j'y accède sans problème. J'ai aussi fait un test hardware du disque avec les softs fournis par western digital et tout est ok.
Quequ'un aurait il une idée pour que je puisse booter plus vite et accéder à ma partition depuis linux?
n°565148
mirtouf
Light is right !
Posté le 02-10-2004 à 16:01:33  profilanswer
Vérifie la géométrie de ton disque et essaye smartmontools.
n°566530
rancor
Posté le 05-10-2004 à 12:43:23  profilanswer
Salut tout d'abord merci de ta réponse. J'ai essayé smartmontools mais il ne détecte rien de suspect.
Par contre je n'ai surement pas bien compris comment vérifier la géométrie de mon disque.
Dans mon bios J'ai les valeurs suivantes:
disque 0 : Cyl-->22076 Head-->16 Sect-->255
disque 1 : Cyl-->57461 Head-->16 Sect-->255
Par contre en lançant Grub et en demandant la géométrie j'ai :
(hd0) : 65535/16/63 correspond à /dev/hda
(hd1) : Error 21 Selected disk does not exist
La géométrie ne correspond pas même pour le disque qui fonctionne ou alors j'ai pas tout compris.
J'ai par contre maintenant accés à ma partittion ntfs du disque 1 en la montant manuellement.
J'en ai profité pour la rajouter dans /etc/fstab et pour y virer les conneries qu'il y avait faisant référence à plusieurs partitions sur le disque 1.
Il ne me reste donc plus que le problème de lenteur au démarrage à cause des erreurs.
n°566562
mirtouf
Light is right !
Posté le 05-10-2004 à 13:04:15  profilanswer
Forcer le LBA dans le BIOS ?
n°566723
rancor
Posté le 05-10-2004 à 16:03:00  profilanswer
Tu me demandes de le faire ou c'est une question ?
Si c'est une question ma réponse est non j'ai juste fait une détection automatique de mes disques dans le bios.
n°566791
mirtouf
Light is right !
Posté le 05-10-2004 à 17:19:19  profilanswer
Alors il faut forcer le LBA.
n°567173
rancor
Posté le 06-10-2004 à 10:31:47  profilanswer
Même problème en forçant le LBA [:airforceone]
Tu penses qu'en changeant de boot loader ça risque de marcher mieux?
J'avais pas de problème avec une mandrake et Lilo.
Message édité par rancor le 06-10-2004 à 10:33:08
n°567187
mirtouf
Light is right !
Posté le 06-10-2004 à 11:06:48  profilanswer
Avec quel outil ont été crées les partitions ?
Il faut également voir ça :
http://forum.hardware.fr/forum2.ph [...] =0#t327790
à adapter bien sûr. :D
Message édité par mirtouf le 06-10-2004 à 11:07:17
n°567240
rancor
Posté le 06-10-2004 à 12:18:42  profilanswer
Merci je regarde ça.
E : Read Error - (21 is a directory) / Apt refuse le dvd comme sourceSamba : Modifier l'attribut Read-Only depuis l'explorateur windows
Impossible de monter / en read-write[Scripting] Pb avec read et découpage de mots
j'importe une base de EasyPHP sur ma Debian : read-only [résolu][debian]lilo : part_nowrite: read:: Input/output error ???
unable to read superblock et apres?[MySQL] Toutes mes tables sont en read Only
problème lilo : volid read error[DEBIAN] Erreur bizarre au démarrage ( I/O error et task_no_data_intr)
Plus de sujets relatifs à : hdb: read_intr
