5093 connectés
  Linux et OS Alternatifs
  Installation
  PROBLEME : mod_security
n°525837
_XaM_
Posté le 22-07-2004 à 19:46:49  profilanswer
Bonjour  :pfff: , j'ai un ptit probléme lors de l'ajout du module mod_security pour apache2 avec la commande apsx:
# pwd
.../mod_security-1.8.3/apache2
# /usr/local/bin/apache2/bin/apxs -cia mod_security.c
/usr/local/bin/apache2/build/libtool --silent --mode=compile gcc -prefer-pic  -DAP_HAVE_DESIGNATED_INITIALIZER -DLINUX=2 -D_REENTRANT -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -D_SVID_SOURCE -D_GNU_SOURCE -g -O2 -pthread -I/usr/local/bin/apache2/include  -I/usr/local/bin/apache2/include   -I/usr/local/bin/apache2/include   -c -o mod_security.lo mod_security.c && touch mod_security.slo
/usr/local/bin/apache2/build/libtool --silent --mode=link gcc -o mod_security.la  -rpath /usr/local/bin/apache2/modules -module -avoid-version    mod_security.lo
/usr/local/bin/apache2/build/instdso.sh SH_LIBTOOL='/usr/local/bin/apache2/build/libtool' mod_security.la /usr/local/bin/apache2/modules
/usr/local/bin/apache2/build/libtool --mode=install cp mod_security.la /usr/local/bin/apache2/modules/
cp .libs/mod_security.lai /usr/local/bin/apache2/modules/mod_security.la
cp .libs/mod_security.a /usr/local/bin/apache2/modules/mod_security.a
ranlib /usr/local/bin/apache2/modules/mod_security.a
chmod 644 /usr/local/bin/apache2/modules/mod_security.a
PATH="$PATH:/sbin" ldconfig -n /usr/local/bin/apache2/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Warning!  dlname not found in /usr/local/bin/apache2/modules/mod_security.la.
Assuming installing a .so rather than a libtool archive.
chmod 755 /usr/local/bin/apache2/modules/mod_security.so
chmod: getting attributes of `/usr/local/bin/apache2/modules/mod_security.so': No such file or directory
apxs:Error: Command failed with rc=65536
Merci d'avance pour vos reponses :^) .
  Installation
problème avec cutprobleme avec mplayer et xmms
FC2 : apt-get problème : Error while running transactionProbleme recompilation driver hsflinmodem-5.03.03.L3
[Debian] Petit problème avec une carte TVProblème avec ospfd ( Zebra )
problème : je ne peux plus devenir rootproblème clé usb et mandrake 10.0
Problème HD 160Go sous Mandrake 92.Probleme d'acces par le WEB sur Mandrake Security Firewall
Plus de sujets relatifs à : PROBLEME : mod_security
