9159 connectés
  Linux et OS Alternatifs
  Installation
  Probleme dans Xorg.0.log
n°808925
dipapa
j'veux plus viellir
Posté le 11-05-2006 à 00:32:29  profilanswer
J'ai des problèmes de font dans Xorg.0.log  si quelqu'un veux bien m'aiguiller cela serait sympa.
Voici le Log:
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux debian 2.6.16-1-486 #2 Thu May 4 18:15:54 UTC 2006 i686
Build Date: 16 March 2006
 Before reporting problems, check http://wiki.x.org
 to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
 (++) from command line, (!!) notice, (II) informational,
 (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed May 10 23:02:02 2006
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "IIyama vision master pro 513"
(**) |   |-->Device "NVIDIA Corporation NV25 [GeForce4 Ti 4200]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
 Entry deleted from font path.
(**) FontPath set to "/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/usr/share/fonts/X11/misc/,/usr/share/fonts/X11/TTF/,/usr/share/fonts/X11/OTF,/usr/share/fonts/X11/Type1/,/usr/share/fonts/X11/CID/,/usr/share/fonts/X11/100dpi/,/usr/share/fonts/X11/75dpi/"
(==) RgbPath set to "/usr/share/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Module ABI versions:
 X.Org ANSI C Emulation: 0.2
 X.Org Video Driver: 0.8
 X.Org XInput driver : 0.5
 X.Org Server Extension : 0.2
 X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.0.0
 Module class: X.Org Font Renderer
 ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
 ABI class: X.Org Video Driver, version 0.8
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0691 card 1043,8017 rev c4 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8598 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:04:0: chip 1106,0596 card 1043,8017 rev 23 class 06,01,00 hdr 80
(II) PCI: 00:04:1: chip 1106,0571 card 0000,0000 rev 10 class 01,01,8a hdr 00
(II) PCI: 00:04:2: chip 1106,3038 card 0925,1234 rev 11 class 0c,03,00 hdr 00
(II) PCI: 00:04:3: chip 1106,3050 card 0000,0000 rev 30 class 06,00,00 hdr 00
(II) PCI: 00:09:0: chip 1274,5880 card 1274,2000 rev 02 class 04,01,00 hdr 00
(II) PCI: 00:0b:0: chip 1186,1300 card 1186,1301 rev 10 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0253 card 0000,0000 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
 [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
 [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
 [0] -1 0 0xd6000000 - 0xd76fffff (0x1700000) MX[B]
(II) Bus 1 prefetchable memory range:
 [0] -1 0 0xd7700000 - 0xe3ffffff (0xc900000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:4:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV25 [GeForce4 Ti 4200] rev 163, Mem @ 0xd6000000/24, 0xd8000000/27, 0xd7800000/19, BIOS @ 0xd77e0000/17
(II) Addressable bus resource ranges are
 [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
 [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
 [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
 [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
 [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
 [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
 [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe4000000 from 0xe7ffffff to 0xe3ffffff
(II) Active PCI resource ranges:
 [0] -1 0 0xd5800000 - 0xd58000ff (0x100) MX[B]
 [1] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
 [2] -1 0 0xd77e0000 - 0xd77fffff (0x20000) MX[B](B)
 [3] -1 0 0xd7800000 - 0xd787ffff (0x80000) MX[B](B)
 [4] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
 [5] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B](B)
 [6] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
 [7] -1 0 0x0000d000 - 0x0000d03f (0x40) IX[B]
 [8] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
 [9] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
 [5] -1 0 0xd5800000 - 0xd58000ff (0x100) MX[B]
 [6] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
 [7] -1 0 0xd77e0000 - 0xd77fffff (0x20000) MX[B](B)
 [8] -1 0 0xd7800000 - 0xd787ffff (0x80000) MX[B](B)
 [9] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
 [10] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B](B)
 [11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [12] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [13] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
 [14] -1 0 0x0000d000 - 0x0000d03f (0x40) IX[B]
 [15] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
 [16] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
(II) LoadModule: "i2c"
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.2.0
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
 Module class: X.Org Server Extension
 ABI class: X.Org Server Extension, version 0.2
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
 compiled for 7.0.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
 compiled for 4.0.2, module version = 1.0.8756
 ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
 Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.0.1
 Module class: X.Org XInput Driver
 ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 1.0.4
(II) NVIDIA X Driver  1.0-8756  Wed Mar 29 14:29:06 PST 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
 ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
 compiled for 7.0.0, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
 [11] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
 [12] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
 [13] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
 [14] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [15] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [16] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
 [17] -1 0 0x0000d000 - 0x0000d03f (0x40) IX[B]
 [18] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
 [19] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
 [20] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
 [21] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce4 Ti 4200 at PCI:1:0:0
(--) NVIDIA(0): VideoRAM: 65536 kBytes
(--) NVIDIA(0): VideoBIOS: 04.25.00.27.00
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce4 Ti 4200 at PCI:1:0:0:
(--) NVIDIA(0):     Iiyama MA203D DT (CRT-1)
(--) NVIDIA(0): Iiyama MA203D DT (CRT-1): 350 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "1920x1440"
(II) NVIDIA(0):     "1920x1200"
(II) NVIDIA(0):     "1856x1392"
(II) NVIDIA(0):     "1792x1344"
(II) NVIDIA(0):     "1680x1050"
(II) NVIDIA(0):     "1600x1200"
(II) NVIDIA(0):     "1440x900"
(II) NVIDIA(0):     "1400x1050"
(II) NVIDIA(0):     "1280x1024"
(II) NVIDIA(0):     "1280x960"
(II) NVIDIA(0):     "1280x800"
(II) NVIDIA(0):     "1280x768"
(II) NVIDIA(0):     "1152x864"
(II) NVIDIA(0):     "1152x768"
(II) NVIDIA(0):     "1024x768"
(II) NVIDIA(0):     "800x600"
(II) NVIDIA(0):     "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1920 x 1440
(++) NVIDIA(0): DPI set to (100, 100); computed from -dpi X commandline option
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
 [0] 0 0 0xd7800000 - 0xd787ffff (0x80000) MX[B]
 [1] 0 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B]
 [2] 0 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B]
 [3] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
 [4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
 [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
 [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
 [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
 [8] -1 0 0xd5800000 - 0xd58000ff (0x100) MX[B]
 [9] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
 [10] -1 0 0xd77e0000 - 0xd77fffff (0x20000) MX[B](B)
 [11] -1 0 0xd7800000 - 0xd787ffff (0x80000) MX[B](B)
 [12] -1 0 0xd8000000 - 0xdfffffff (0x8000000) MX[B](B)
 [13] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MX[B](B)
 [14] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
 [15] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
 [16] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
 [17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [19] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
 [20] -1 0 0x0000d000 - 0x0000d03f (0x40) IX[B]
 [21] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
 [22] -1 0 0x0000d800 - 0x0000d80f (0x10) IX[B]
 [23] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
 [24] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1920x1440"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(**) Option "dpms"
(**) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
error opening security policy file /etc/X11/xserver/SecurityPolicy
(**) Option "CoreKeyboard"
(**) Generic Keyboard: Core Keyboard
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "fr"
(**) Generic Keyboard: XkbLayout: "fr"
(**) Option "XkbVariant" "latin9"
(**) Generic Keyboard: XkbVariant: "latin9"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ExplorerPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ExplorerPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Configured Mouse: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Configured Mouse: Buttons: 11
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "NVIDIA Event Handler" (type: Other)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/TTF/, removing from list!
Could not init font path element /usr/share/fonts/X11/OTF, removing from list!
Could not init font path element /usr/share/fonts/X11/CID/, removing from list!
(II) NVIDIA(0): Setting mode "1600x1200"
n°808965
shaddy
j'aime la gym
Posté le 11-05-2006 à 10:24:27  profilanswer
OK, mais c'est quoi le problème ? Je veux dire concrètement dans ton utilisation.
Ce n'est pas parce qu'il ne trouve pas des fonts que c'est problématique, si tu ne les utilise pas.
n°809512
dipapa
j'veux plus viellir
Posté le 13-05-2006 à 00:06:54  profilanswer
Je voudrais savoir pourquoi il ne les trouve pas, ça fait pas nickel et voir si c'est un bug ou si c'est moi qui a fauter dans l'install
n°809758
shaddy
j'aime la gym
Posté le 14-05-2006 à 01:08:31  profilanswer
OK, donc ton système marche bien, pas de problème concret ou apparent de xorg. Déjà il faut voir si ces polices de sont utiles (et du coup à quoi elle servent je sais pas en vrai). Maintenant, il est possible que ce soit des lignes en trop dans ton xorg.conf. Montre zy voir le bidule ! (le xorg.conf)
  Installation
Debian testing + Xorg, problème de sourisDebian testing / Xorg / Matrox G200 / probleme de curseur
Xorg 6.9 : Problème d'installation sous Solaris[Résolu][FC4] Xorg problème de résolution d'écran.
debian - xorg probleme clavierproblème d'affichage xorg.conf
Problème d'installation de xorg 6.7 sous mandrake 10.1problème souris ou clavier sous xorg
[Gentoo] Probleme Xorg 6.8.0[Xorg] Problème au démarrage avec Xorg & Mandrake 10.1 Community
Plus de sujets relatifs à : Probleme dans Xorg.0.log
