4715 connectés
  Linux et OS Alternatifs
  Installation
  Problème de Configuration Samba
n°901199
acetone802​000
J'aime les circuits imprimés
Posté le 07-04-2007 à 11:44:10  profilanswer
bonjour,
Je voudrais modifer ma configuration Samba sous debian pour ajouter un répertoire partagé par tous les utilisateurs.
J'ai créé un répertoire dans "/home" et j'ai ajouté une section dans le samba.conf mais je ne vois pas ce répertoire lorsque je me connecte.
Autre question Samba ne me demande plus de mote de passe pour me connecter. Comment modifier le fichier de configuration pour que le mot de passe soit a nouveau demandé.
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentary and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
 log file = /var/log/samba/log.%m
 dns proxy = no
 passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n *password\supdated\ssuccessfully* .
 server string = %h server
 socket options = TCP_NODELAY
 invalid users = root
 obey pam restrictions = yes
 workgroup = MSHOME
 os level = 20
 encrypt passwords = true
 syslog = 0
 passwd program = /usr/bin/passwd %u
 passdb backend = tdbsam
 panic action = /usr/share/samba/panic-action %d
 max log size = 1000
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
# server string is the equivalent of the NT Description field
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
;   wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
# What naming service and in what order should we use to resolve host names
# to IP addresses
;   name resolve order = lmhosts host wins bcast
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = true
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
# Put a capping on the size of the log files (in Kb).
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
;   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
# Do something sensible when Samba crashes: mail the admin a backtrace
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
# in the samba-doc package for details.
   security = user
# You may wish to use password encryption.  See the section on
# 'encrypt passwords' in the smb.conf(5) manpage before enabling.
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
;   guest account = nobody
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
;   unix password sync = no
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
;   pam password change = no
########## Domains ###########
# Is this machine able to authenticate users. Both PDC and BDC
# must have this setting enabled. If you are the BDC you must
# change the 'domain master' setting to no
;   domain logons = yes
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of the user's profile directory
# from the client point of view)
# The following required a [profiles] share to be setup on the
# samba server (see below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
;   logon path = \\%N\%U\profile
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
;   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
########## Printing ##########
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
;   load printers = yes
# lpr(ng) printing. You may wish to override the location of the
# printcap file
;   printing = bsd
;   printcap name = /etc/printcap
# CUPS printing.  See also the cupsaddsmb(8) manpage in the
# cupsys-client package.
;   printing = cups
;   printcap name = cups
# When using [print$], root is implicitly a 'printer admin', but you can
# also give this right to other users to add drivers and set printer
# properties
;   printer admin = @ntadmin
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
# for details
# You may want to add the following on a Linux system:
#         SO_RCVBUF=8192 SO_SNDBUF=8192
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
;   message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
# Domain Master specifies Samba to be the Domain Master Browser. If this
# machine will be configured as a BDC (a secondary logon server), you
# must set this to 'no'; otherwise, the default behavior is recommended.
;   domain master = auto
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
; The following was the default behaviour in sarge
; but samba upstream reverted the default because it might induce
; performance issues in large organizations
; See #368251 for some of the consequences of *not* having
; this setting and smb.conf(5) for all details
;   winbind enum groups = yes
;   winbind enum users = yes
#======================= Share Definitions =======================
[homes]
   comment = Home Directories
   browseable = no
# By default, the home directories are exported read-only. Change next
# parameter to 'yes' if you want to be able to write to them.
   writable = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# Restrict access to home directories
# to the one of the authenticated user
# This might need tweaking when using external authentication schemes
   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   writable = no
;   share modes = no
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
;   directory mask = 0700
[telechargement]
 create mask = 0644
 directory mask = 0755
 browseable = no
 writeable = yes
 valid users = francois,@francois
 path = /home/downloads
#valid users = francois
#public = yes
;[printers]
;   comment = All Printers
;   browseable = no
;   path = /var/spool/samba
;   printable = yes
;   public = no
;   writable = no
;   create mode = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
;[print$]
;   comment = Printer Drivers
;   path = /var/lib/samba/printers
;   browseable = yes
;   read only = yes
;   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# Replace 'ntadmin' with the name of the group your admin users are
# members of.
;   write list = root, @ntadmin
# A sample share for sharing your CD-ROM with others.
;[cdrom]
;   comment = Samba server's CD-ROM
;   writable = no
;   locking = no
;   path = /cdrom
;   public = yes
# The next two parameters show how to auto-mount a CD-ROM when the
# cdrom share is accesed. For this to work /etc/fstab must contain
# an entry like this:
#       /dev/scd0   /cdrom  iso9660 defaults,noauto,ro,user   0 0
# The CD-ROM gets unmounted automatically after the connection to the
# If you don't want to use auto-mounting/unmounting make sure the CD
# is mounted on /cdrom
;   preexec = /bin/mount /cdrom
;   postexec = /bin/umount /cdrom
n°901201
zecrazytux
Posté le 07-04-2007 à 12:08:42  profilanswer
faudrais lire un peu la doc...
en particulier security et les options des partages, comme browseable, writeable, etc
Blog photo/récits activités en montagne http://planetcaravan.net
n°901202
jaymzwise
Posté le 07-04-2007 à 12:08:46  profilanswer
Dans la déclaration de ton partage mets Browseable = Yes.
Si cette option est sur No tu ne verras pas ton partage dans le voisinage réseau.
n°901203
zecrazytux
Posté le 07-04-2007 à 12:09:13  profilanswer
grillaÿd :D
n°901205
acetone802​000
Posté le 07-04-2007 à 12:21:52  profilanswer
vi dsl, j'ai lu la doc mais je n'avais pas compris le browsable =yes.
n°913359
aspire1520
Posté le 16-05-2007 à 20:16:47  profilanswer
salut ! je relance le sujet,
moi quand j'accedes via mon favoris reseau sous windows, je ne peux pas creer un dossier ou bien y placer un fichier... il me dit que je ne suis pas autorisé.
que faire?
n°913363
acetone802​000
Posté le 16-05-2007 à 20:28:35  profilanswer
tu regardes dans ton fichier de configuration tu dois avoir writable=no
tu mets yes et ça devrait être bon.
n°913366
aspire1520
Posté le 16-05-2007 à 20:43:20  profilanswer
No justement j'ai tout mis en writable = yes je sais pas ce qu'il se passe?
Les espaces peut etre ?
n°913458
acetone802​000
Posté le 17-05-2007 à 07:54:57  profilanswer
le dossier que tu partages a bien les autorisations qui permettent d'écrire (par exemple un chmod 777) ?
n°913530
aspire1520
Posté le 17-05-2007 à 12:19:13  profilanswer
salut ! heu en fait je n'y comprend rien a ces chmod 777 / 700 / 600,
hier j'ai trouvé cette astuce sur internet et j'ai fais une gaffe... directement dans la console j'ai mis chmod 777 /
c'est a dire appliqué a tout les dossiers...
mais pour tout les dossiers je veux bien un read mais pas write... :s
n°913695
acetone802​000
Posté le 17-05-2007 à 22:10:47  profilanswer
ouille pour récupérer ça mis à part une réinstall je ne vois pas ( suis pas un expert de linux )
chmod 777 /tonrépertoire
permet d'avoir un répertoire en lecture écriture pour tous les utilisateurs.
  Installation
Mrtg/Bind9 probleme de statsLive CD + Réseau + Samba + NTFS
probleme d'affichage suse10.2Problème de réseau
[Ubuntu] Problème lors de la copie des fichiers à l'installProbléme de lecture MKV sous mac
problème de configuration de sambaconfiguration de samba
Problème de configuration SambaProblème de configuration de Samba
Plus de sujets relatifs à : Problème de Configuration Samba
