2663 connectés
  Linux et OS Alternatifs
  Installation
  mise à jour xorg
mise à jour xorg
n°921632
rene34
Posté le 10-06-2007 à 21:48:11  profilanswer
Je suis sous freeBSD depuis peu, et viens de mettre à jour xorg, je refais mon xorg.conf mais impossible de relancer l'interface graphique
voici le message que j'ai quand je lance l'interface graphique
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: FreeBSD 6.2-RELEASE i386
Current Operating System: FreeBSD .rregistre.net 6.2-RELEASE FreeBSD 6.2-RELEASE #0: Fri Jan 12 10:40:27 UTC 2007     root@dessler.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC i386
Build Date: 10 June 2007
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 10 21:44:35 2007
(==) Using config file: "/etc/X11/xorg.conf"
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
>                   Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Fatal server error:
could not open default font 'fixed'
X connection to :0.0 broken (explicit kill or server shutdown).
voici mes paquet installés
pkg_info | grep xorg
linux-xorg-libs-6.8.2_5 Xorg libraries, linux binaries
xorg-7.2            X.Org complete distribution metaport
xorg-apps-7.2       X.org apps meta-port
xorg-cf-files-1.0.2_2 X.org cf files for use with imake builds
xorg-clients-6.9.0_3 X client programs and related files from X.Org
xorg-docs-1.3,1     X.org documentation files
xorg-drivers-7.2    X.org drivers meta-port
xorg-fonts-100dpi-7.2 X.Org 100dpi bitmap fonts
xorg-fonts-7.2      X.org fonts meta-port
xorg-fonts-75dpi-7.2 X.Org 75dpi bitmap fonts
xorg-fonts-cyrillic-7.2 X.Org Cyrillic bitmap fonts
xorg-fonts-miscbitmaps-7.2 X.Org miscellaneous bitmap fonts
xorg-fonts-truetype-7.2 X.Org TrueType fonts
xorg-fonts-type1-7.2 X.Org Type1 fonts
xorg-fontserver-6.9.0_1 X font server from X.Org
xorg-libraries-6.9.0 X11 libraries and headers from X.Org
xorg-libraries-7.2_1 X.org libraries meta-port
xorg-nestserver-6.9.0_1 Nesting X server from X.Org
xorg-printserver-6.9.0_2 X Print server from X.Org
xorg-protos-7.2     X.org protos meta-port
xorg-server-1.2.0_2,1 X.Org X server and related programs
xorg-server-6.9.0_6 X.Org X server and related programs
xorg-vfbserver-1.2.0,1 X virtual framebuffer server from X.Org
xorg-vfbserver-6.9.0_2 X virtual framebuffer server from X.Org
quelqu'un aurait une idée ?
n°921728
Combi_A_Ve​ndre
Posté le 11-06-2007 à 09:00:24  profilanswer
Essaye un truc de ce genre:
cd /usr/ports/x11-fonts/xorg-fonts-miscbitmaps && make install clean
vw
n°921732
fighting_f​alcon
Posté le 11-06-2007 à 09:08:15  profilanswer
Fatal server error:
tu as un problème de polices ...
Vérifies les paquets installés (pkg_info|grep font), tu dois notamment avoir le serveur de fonts (xfs) d'installé ...
n°922126
rene34
Posté le 11-06-2007 à 21:08:53  profilanswer
tout ça j'avais déja fait.
en fait j'ai complètement merdé ma maj de xorg, j'éssaie de ratrapper le coup mais a mon avi ça va me couter une reinstall.
voila le message  quand je fais
cd /usr/ports/x11/xorg/ && make install clean
./include/X11/extensions/Xrender.h:508: error: syntax error before '*' token
../include/X11/extensions/Xrender.h:514: error: syntax error before '*' token
../include/X11/extensions/Xrender.h:520: error: syntax error before '*' token
In file included from AddTrap.c:28:
Xrenderint.h:37: error: syntax error before "Visual"
Xrenderint.h:76: error: syntax error before "Display"
Xrenderint.h:92: error: syntax error before '*' token
AddTrap.c:33: error: syntax error before '*' token
AddTrap.c: In function `XRenderAddTraps':
AddTrap.c:40: error: `dpy' undeclared (first use in this function)
AddTrap.c:40: error: (Each undeclared identifier is reported only once
AddTrap.c:40: error: for each function it appears in.)
AddTrap.c:46: error: structure has no member named `codes'
AddTrap.c:48: error: `ntrap' undeclared (first use in this function)
AddTrap.c:50: error: `RenderAddTraps' undeclared (first use in this function)
AddTrap.c:51: error: structure has no member named `codes'
AddTrap.c:53: error: `picture' undeclared (first use in this function)
AddTrap.c:54: error: `xOff' undeclared (first use in this function)
AddTrap.c:55: error: `yOff' undeclared (first use in this function)
AddTrap.c:64: error: `traps' undeclared (first use in this function)
*** Error code 1
Stop in /usr/ports/x11/libXrender/work/libXrender-0.9.2/src.
*** Error code 1
Stop in /usr/ports/x11/libXrender/work/libXrender-0.9.2.
*** Error code 1
*** Error code 1
Stop in /usr/ports/x11/libXrender.
*** Error code 1
Stop in /usr/ports/x11/libXcursor.
*** Error code 1
Stop in /usr/ports/x11/xcursorgen.
*** Error code 1
Stop in /usr/ports/x11-themes/xcursor-themes.
*** Error code 1
Stop in /usr/ports/x11/xorg.
n°944176
vlack
Posté le 17-08-2007 à 19:42:22  profilanswer
rene34 a écrit :
Fatal server error:
Juste pour dire que je viens d'avoir le même soucis que j'ai réglé en réinstallant les paquets suivants :
font-misc-misc
font-cursor-misc
J'ai trouvé la réponce là :
http://www.nabble.com/&#034;Could- [...] 12706.html
En tapant ""could not open default font 'fixed'" +freebsd" dans google ;)
  Installation
  mise à jour xorg
Mise en place d'un serveur Proxymise à jour qui fait bugger???
MàJ FreeBSD (intégration Xorg 7.2)[Résolu] Problème de fonts
Problème pour mettre à jour Office 2003[Feisty] Xorg 7.3 et Xorg.conf ?
freeplayer = ca marchera un jour ?Probleme xorg
Knoppix Kaella 3.1 Beta1 Fr mise a jour pilote graphique ?comment faire la mise a jour de xorg ?
Plus de sujets relatifs à : mise à jour xorg
