3030 connectés
  Linux et OS Alternatifs
  Installation
  [Mandrake] urpmf / urpmq me retournent les paquets updatés en double
n°698045
Nico57
Posté le 25-06-2005 à 02:52:18  profilanswer
C'est un problème que je traine depuis longtemps dans ma Mandrake 10.1 que j'ai et qui devient pénible à la longue. :(
Par exemple:
[root@ing002 samba]# urpmf --summary samba-server
samba-server:Samba (SMB) server programs.
Note : comme aucun des media spécifiés n'utilise de hdlist, urpmf n'a pu retourner de résultat
Vous pouvez utiliser -name pour rechercher le nom d'un paquetage.
Bon là c'est pas encore trop grave.
Mais là où ça devient chiant c'est sur un urpmq -i:
[root@ing002 samba]# urpmq -i samba-server
Version     : 3.0.10
Release     : 0.1.101mdk
Group       : Networking/Other
Size        : 6872035                      Architecture: i586
Summary     : Samba (SMB) server programs.
Description :
Samba provides an SMB server which can be used to provide
network services to SMB (sometimes called "Lan Manager" )
clients, including various versions of MS Windows, OS/2,
and other Linux machines. Samba also provides some SMB
clients, which complement the built-in SMB filesystem
in Linux. Samba uses NetBIOS over TCP/IP (NetBT) protocols
and does NOT need NetBEUI (Microsoft Raw NetBIOS frame)
protocol.
Samba-3.0 features working NT Domain Control capability and
includes the SWAT (Samba Web Administration Tool) that
allows samba's smb.conf file to be remotely managed using your
favourite web browser. For the time being this is being
enabled on TCP port 901 via xinetd. SWAT is now included in
it's own subpackage, samba-swat.
Please refer to the WHATSNEW.txt document for fixup information.
This binary release includes encrypted password support.
Please read the smb.conf file and ENCRYPTION.txt in the
docs directory for implementation details.
Last updated        : Mon Dec 27 10:40:46 2004
Update importance   : security
Reason for update   :
Remote exploitation of an integer overflow vulnerability
in the smbd daemon included in Samba 2.0.x, Samba 2.2.x,
and Samba 3.0.x prior to and including 3.0.9 could
allow an attacker to cause controllable heap corruption,
leading to execution of arbitrary commands with root
privileges.
In order to exploit this vulnerability an attacker must possess
credentials that allow access to a share on the Samba server.
Unsuccessful exploitation attempts will cause the process
serving the request to crash with signal 11, and may leave
evidence of an attack in logs.
The updated packages have been patched to correct this issue.
Version     : 3.0.7
Release     : 2mdk
Size        : 6838827                      Architecture: i586
Description :
protocol.
Reason for update   :
privileges.
Allez faire le tri dans tout ça. :/
En gros il m'affiche deux fois les infos, une fois pour le paquet d'origine, une fois pour le paquet updaté.
Je m'en fous du paquet fourni dans la distrib de base, ce que je veux c'est les infos sur la version actuelle.
Pourtant mon urpmi.conf me semble carré:
[root@ing002 samba]# cat /etc/urpmi/urpmi.cfg
# generated Thu May 12 04:02:09 2005
  downloader: wget
updates ftp://ftp.proxad.net/pub/Distributions_Linux/Mandrakelinux/official/updates/10.1/main_updates {
  hdlist: hdlist.updates.cz
  key-ids: 22458a98
  synthesis
  update
  with_hdlist: media_info/synthesis.hdlist.cz
main ftp://ftp.proxad.net/pub/Distributions_Linux/Mandrakelinux/official/10.1/i586/media/main {
  hdlist: hdlist.main.cz
  key-ids: 70771ff3
  synthesis
contrib ftp://ftp.proxad.net/pub/Distributions_Linux/Mandrakelinux/official/10.1/i586/media/contrib {
  hdlist: hdlist.contrib.cz
  key-ids: 78d019f5
  synthesis
Des idées?
n°698197
VorteX
Posté le 25-06-2005 à 19:38:00  profilanswer
j'essairai de reconstruire la base de données rpm a a ta place
n°699136
Nico57
Posté le 28-06-2005 à 00:42:15  profilanswer
Merci pour ta réponse, mais non ça ne change rien. :(
n°699438
Dark_Schne​ider
Close the World, Open the Net
Posté le 28-06-2005 à 15:41:56  profilanswer
si tu lisais plus attentivement tu verrais que c'est normal.
Version     : 3.0.10
c'est le package samba dispo dans le media updates ( mises à jour de sécu )
Version     : 3.0.7
Release     : 2mdk
c'est le package samba dispo dans le media main ( i.e le package original livré avec la distro ) .
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°700589
Nico57
Posté le 01-07-2005 à 00:20:09  profilanswer
Qui c'est qui ne sait pas lire, hmm? :sarcastic:
  Installation
probleme installation mandrakeprobleme installation mandrake 10.1
[mandrake 10.0 - postgresql][Mandrake] Problème d'installation
[Mandrake 10.0] Pas internet avec terminal Triway...[Mandrake 10.0] problème de DNS
Double crash en moins de 5mn : ya t-il un diagnostic possible ???[mandrake freebox]
Probleme d'installation disque dur usb2 Mandrake 10.1Mandrake LE2005 AMD64 étrange...
Plus de sujets relatifs à : [Mandrake] urpmf / urpmq me retournent les paquets updatés en double
