4835 connectés
 Page :   1  2
Page Suivante
[Mandrake 10] Plantage Centre de Contrôle Linux
n°528712
dajay
Compassion leads to happiness
Posté le 27-07-2004 à 19:13:26  profilanswer
glxinfo
name of display: :0.0
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context
client glx vendor string: SGI
client glx version string: 1.2
client glx extensions:
GLX extensions:
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.3 Mesa 4.0.4
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  1 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x24 24 tc  1 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x25 24 tc  1 24  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x26 24 tc  1 24  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x27 24 dc  1 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x28 24 dc  1 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x29 24 dc  1 24  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x2a 24 dc  1 24  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
Bon ben je crois que je vais télécharger les drivers ATI moa :sweat:
n°528747
dajay
Posté le 27-07-2004 à 20:07:20  profilanswer
Je vais installer les drivers.
Cependant mon kernel-source est en version kernel-source-2.6.3-15mdk.i586 alors que mon kernel est un 2.6.3-7mdk-i686-up-4GB.
C'est grave si je configure avec cette différence les pilotes ati ?
n°528749
Mjules
Parle dans le vide
Posté le 27-07-2004 à 20:08:37  profilanswer
si, ils ne s'installeront pas correctement
mets à jour ton noyau (urpmi -p kernel puis rebootes ) ou installe la bonne version des kernel sources
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°528756
dajay
Posté le 27-07-2004 à 20:17:21  profilanswer
impossible de la trouver la bonne version des kernel sources :/
Il ne me propose que la version proposée préalablement.
Pour le kernel il me propose ça...
urpmi -p kernel
Un des paquetages suivants est nécessaire :
 1- kernel-2.6.3.7mdk-1-1mdk.i586
 2- kernel-i686-up-4GB-2.6.3.7mdk-1-1mdk.i586
Que choisissez-vous ? (1-2)
Message édité par dajay le 27-07-2004 à 20:18:28
n°528761
dajay
Posté le 27-07-2004 à 20:22:27  profilanswer
J'ai trouvé une version du kernel source en kernel-source-2.6.3-7mdk.i586
L'autre était x.i686...
C'est bon ?
Message édité par dajay le 27-07-2004 à 20:22:36
n°528775
leto
Posté le 27-07-2004 à 20:39:42  profilanswer
n°528776
dajay
Posté le 27-07-2004 à 20:40:36  profilanswer
Bah vi... la i586 j'ai trouvé :) (cf. post précédent)
C'est la i686 que je n'ai pas trouvé... ça change quelque chose ?
Allez j'y vais on verra bien !  [:belokan]
Message édité par dajay le 27-07-2004 à 20:40:55
n°528777
leto
Posté le 27-07-2004 à 20:43:11  profilanswer
le kernel-up4GB-i686 est utile si tu as plus de 800Mo de RAM . Sinon autant rester avec le kernel normal .
Verifie que tu as bien configuré urpmi , notamment la source updates . Normalement tu devrais avoir un kernel -15 .
n°528779
dajay
Posté le 27-07-2004 à 20:45:56  profilanswer
J'ai 1,5 Go de Ram ;)
n°528789
dajay
Posté le 27-07-2004 à 21:05:57  profilanswer
glxinfo
direct rendering: Yes
client glx vendor string: ATI
client glx version string: 1.3
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
    GLX_ATI_render_texture
GLX extensions:
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9800 Generic
OpenGL version string: 1.3 (X4.3.0-3.9.0)
OpenGL extensions:
    GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
    GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_multisample,
    GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_shadow,
    GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_cube_map,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
    GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_vertex_program,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_element_array,
    GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer,
    GL_ATI_separate_stencil, GL_ATI_texture_env_combine3,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once,
    GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object,
    GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3,
    GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size,
    GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal,
    GL_EXT_secondary_color, GL_EXT_separate_specular_color,
    GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection,
    GL_EXT_texture3D, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader,
    GL_HP_occlusion_test, GL_NV_texgen_reflection, GL_NV_blend_square,
    GL_NV_occlusion_query, GL_NV_point_sprite, GL_ARB_point_sprite,
    GL_SGI_color_matrix, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_lod,
    GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SUN_multi_draw_arrays
glu version: 1.3
glu extensions:
0x23 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x24 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x25 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x26 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x27 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x28 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x29 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x2a 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x2b 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x2c 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x2d 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x2e 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x2f 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  2 1 None
0x30 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  2 1 None
0x31 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  2 1 None
0x32 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  2 1 None
0x33 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x34 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x35 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x36 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x37 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  4 1 None
0x38 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  4 1 None
0x39 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  4 1 None
0x3a 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  4 1 None
0x3b 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x3c 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x3d 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x3e 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x3f 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  6 1 None
0x40 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  6 1 None
0x41 24 tc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  6 1 None
0x42 24 tc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  6 1 None
0x43 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x44 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x45 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x46 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x47 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x48 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  1 0 None
0x49 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x4a 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  1 0 None
0x4b 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x4c 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x4d 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x4e 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x4f 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  2 1 None
0x50 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  2 1 None
0x51 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  2 1 None
0x52 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  2 1 None
0x53 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x54 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x55 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x56 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x57 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  4 1 None
0x58 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  4 1 None
0x59 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  4 1 None
0x5a 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  4 1 None
0x5b 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x5c 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  1 0 None
0x5d 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x5e 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  1 0 None
0x5f 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  6 1 None
0x60 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  6 1 None
0x61 24 dc  0 24  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  6 1 None
0x62 24 dc  0 24  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  6 1 None
Mission réussie !
Tout ça grâce à ce topic très bien fait.
I'm happy ! Je crois que j'ai tout configuré là :D (je touche du bois)
n°528801
dajay
Posté le 27-07-2004 à 21:26:19  profilanswer
A L'AIDE
J4ai joué au c*n en voulant remettre "pour voir" mon écran Belinea 10 17 15 dans le choix des écran du Mandrake Control Center.
Résultat startx ne fonctionne plus, il ne trouve plus de "screen"...
Comment arranger cela en mode console ?
n°528810
dajay
Posté le 27-07-2004 à 21:52:36  profilanswer
[Mode Evolution Pokemon Dajay -> Dragojay]
Ca y est... Fini le reflexe réinstall ou call d'un ami quand ça plante... Ca marchait pas... ben je suis allé jouer dans le Xconfig a coup de su[/b] et autres [i]vi et devinez quoi... Je m'en suis tiré tout seul comme un grand...
A force de galérer sous d'autre truc et de comprendre ce que je fais, ben le bug je l'ai réglé tout seul en reconfigurant à la main le XFree86... chui fier de moi :D
[/Mode Evolution Pokemon Dajay -> Dragojay]
Dajay has evolved !
Message édité par dajay le 27-07-2004 à 21:52:59
n°528817
Mjules
Parle dans le vide
Posté le 27-07-2004 à 22:05:15  profilanswer
et t'as appris une nouvelle attaque ?
n°529113
dajay
Posté le 28-07-2004 à 09:37:57  profilanswer
Vi ! L'attaque VIsation...  [:a vampire]
Sinon nouveau problême bizarre... lorsque je mets un DVD, totem se lance puis me disqu'il ne trouve pas le lecteur dvd :/
Hors lorsque je rentre dans mon mnt/cdrom, je trouve bien le dvd et en cliquant sur les vob ben des vidéos se lancent...  [:b vampire]
Faut juste que je rajoute un lien symbolique du lecteur de cd vers le dvd ?
Autre chose, lorsque j'essaie de lire un mp3 avec le lecteur par défaut ça ne passe pas... Alors que tout le reste des sons passent. Enfin ça passe pas, le lecteur se lance, la piste découle... le seul truc c'est qu'il n'y pas de son qui sort.
Bah y'a trop peu d'information pour que vous m'aidiez je pense. J'ai vu ça à la maison ce matin avant de partir au boulot. Plus d'info ce soir...
Faut que je me mette à Telnet moi pour modifier ma machine à distance.
Pour le moment c'est autoformation Java. [:alph-one]
Message édité par dajay le 28-07-2004 à 09:38:17
n°529455
Dark_Schne​ider
Close the World, Open the Net
Posté le 28-07-2004 à 14:17:04  profilanswer
regarde dans la conf de totem, notamment vers où il va chercher le "lecteur optique"
as tu un périphérique nommé : /dev/dvd ?
et n'utilise pas telnet mais ssh.
c'est koi le lecteur par défaut ? si c'est xmms, installe le plugin arts de xmms pour qu'il utilise le système de son de kde ( xmms-arts ) et dans les plugins de sorties, tu sélectionnes Arts.
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°529729
dajay
Posté le 28-07-2004 à 21:52:31  profilanswer
Effectivement je n'ai pas de /dev/dvd :/
Mon lecteur par défaut c'est KsCD.
Au fait ce sont des "vrais " CD, pas des cd de mp3, je mettais trompé préalablement.
n°529790
dajay
Posté le 28-07-2004 à 23:46:46  profilanswer
Voici l'erreur exacte de Totem
Une erreur est survenue
Le film « /dev/cdroms/cdrom0 » ne peut pas être lu..
Totem n'a pas pu lire « dvd:/ ».
Il n'y a aucun greffon pour gérer ce film.
n°529795
dajay
Posté le 28-07-2004 à 23:49:58  profilanswer
Sous Xine j'ai
xine engine failed to start.
No input plugin found.
Maybe the file does not exist, has wrong permissions or
url syntax error
Read error from: /dev/dvd
A noter que j'ai créé un lien symbolique entre /dev/hde et /dev/dvd/
n°529810
dajay
Posté le 29-07-2004 à 01:07:29  profilanswer
Réglé il me manquait la librairie de lecture de dvd...
n°529813
leto
Posté le 29-07-2004 à 01:09:46  profilanswer
Donc en clair tout marche maintenant :??: Ca fait plaisir de voir qu'il y'a des débutants qui ont de la volonté et qui n'abandonnent pas au premier problème . J'espere que tu regrette pas .
n°529814
dajay
Posté le 29-07-2004 à 01:12:00  profilanswer
Carrément pas !
C'est géant comme expérience et je ne compte pas m'arrêter en si bon chemin ;)
Me manque juste un tout petit truc a régler, la lecture des CDs audios...
J'ai mis arts et ça ne passe pas :/
n°530055
Dark_Schne​ider
Posté le 29-07-2004 à 12:33:23  profilanswer
les CD audios normaux se lisent avec kscd et il faut le cable du lecteur de CDROM vers la carte son. et bien sûr il faut activer dans la table de mixage ( kmix ) la bonne entrée ( CD ou Aux ).
si tu veux en numérique ( sans le cable ), il faut utiliser xmms ou totem et dans xmms configurer le plugin cd audio, puis aller dans le CD audio.
n°531060
dajay
Posté le 30-07-2004 à 17:49:54  profilanswer
Totem lis les CD Audio mais ni xmms ni KsCD... Bizarre...
Je n'arrive pas à récupérer les paramètres qu'utilise Totem.
Où est ce que je peux trouver ça ?
n°531078
Dark_Schne​ider
Posté le 30-07-2004 à 18:12:37  profilanswer
utilises le plugin cdread de xmms ,
tu n'as pas de cable entre ton lecteur de cd et ta carte son.
kscd ne marche qu'en analogique ( i.e il faut le cable )
xmms peut lire en numérique mais tu dois conf le plugin cdread de xmms.
 Page :   1  2
Page Suivante
lecteur mp3/ogg iRiver avec mémoire flash sur Linux ?Modem tele2 et linux
probleme curseur souris avec mandrake 10.0nouvelles classes java sous linux
Synchroniser 2 linuxMandrake 10 et souris USB
[Mandrake 10] Problème bizzareConfigurer et Activer Wifi - Mandrake 10
[ MANDRAKE 10 ] Un Newbie Débarque et sa fait mal !plus possible de lire la partition win_c à partir de linux
Plus de sujets relatifs à : [Mandrake 10] Plantage Centre de Contrôle Linux
