4244 connectés
  Linux et OS Alternatifs
  Installation
  xorg ne se lance pas, probleme de souris?
n°866850
dams78
développateur
Posté le 28-11-2006 à 20:07:34  profilanswer
bonsoir,
voila je suis passé a xorg, mais j'arrive plus a lancer un session x
voila ce que j'ai dans mes log qui a mon avis démontre que c'est ma souris qui fait tout planter
(**) Option "Protocol" "ExplorerPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ExplorerPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(EE) xf86OpenSerial: Cannot open device /dev/input/mice
 No such device.
(EE) Configured Mouse: cannot open input device
(EE) PreInit failed for input device "Configured Mouse"
(II) UnloadModule: "mouse"
(WW) No core pointer registered
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
    xkb_keycodes             { include "xfree86+aliases(azerty)" };
    xkb_types                { include "complete" };
    xkb_compatibility        { include "complete" };
    xkb_symbols              { include "pc(pc105)+fr" };
    xkb_geometry             { include "pc(pc105)" };
No core pointer
Fatal server error:
failed to initialize core devices
de plus quand je vais un hwinfo --mouse
il ne me dectecte rien (ma souris est en ps2)
je branche donc un souris de secours en usb
la hwinfo me donne ceci:
44: USB 00.0: 10503 USB Mouse
  [Created at usb.122]
  UDI: /org/freedesktop/Hal/devices/usb_device_45e_40_noserial_if0
  Unique ID: FKGF.KY9pIXcTJP0
  Parent ID: pBe4.BlTq++yJD64
  SysFS ID: /devices/pci0000:00/0000:00:10.1/usb2/2-1/2-1:1.0
  SysFS BusID: 2-1:1.0
  Hardware Class: mouse
  Model: "Microsoft Wheel Mouse Optical"
  Hotplug: USB
  Vendor: usb 0x045e "Microsoft Corp."
  Device: usb 0x0040 "Wheel Mouse Optical"
  Revision: "1.21"
  Compatible to: int 0x0200 0x0001 "Generic USB Mouse"
  Speed: 1.5 Mbps
  Driver Info #0:
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #38 (Hub)
j'ai donc essayer dans mon fichier xorg.conf de mettre
Section "InputDevice"
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "Protocol"  "ImPS/2"
 Option  "Emulate3Buttons" "true"
EndSection
ou alors
 Driver  "mouse"
 Option  "Device"  "/dev/psaux"
EndSection
mais rien ne marche...
merci de me venir en aide :)
dam's (debianer), ma galerie Flickr
n°866937
Combi_A_Ve​ndre
Posté le 29-11-2006 à 10:19:28  profilanswer
Si tu fait 'cat /dev/input/mice' et que tu bouges la souris, il se passe quelque chose?
The best way to accelerate a computer running windows is at 9.8m.s-2
n°867149
dams78
développateur
Posté le 29-11-2006 à 20:54:40  profilanswer
il me dit Aucun périphérique de ce type...
  Installation
probleme lors mise à jourProbleme de débit avec connection vdsl sous debian
[DEBIAN]Problème installation debian + carte réseauprobleme dual screen
live cd kaella 3 et unbuntu 6.1 probleme de résolutionProblème d'accès à mysql : #2002 - Le serveur ne répond pas.
ESX 2.5.2 Vidéo et souris lag sur VM XPprobleme apache2
Serveur de messagerie - SME7 - Nouveau probleme \o/gros probleme demarrage
Plus de sujets relatifs à : xorg ne se lance pas, probleme de souris?
