4396 connectés
  Linux et OS Alternatifs
  Installation
  pb pour installer les drivers CG nvidia, fedora C3 x86-64
n°620629
shaker114
Lost in translation
Posté le 15-01-2005 à 16:10:39  profilanswer
Bonjour à tous,
Mon FC 3 86-64 refuse d'installer les drivers CG nvidia...
Il me semble, en liant les logs, que c'est un pb de lib manquantes, mais lesquelles et où les trouver ???
Voici des traces :
   NVIDIA: left KBUILD.
-> done.
-> Kernel module compilation complete.
-> Installing both new and classic TLS OpenGL libraries.
-> Installing classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32bit compatibility OpenGL libraries? (Answer: No)
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64'
   (1.0-6629):
   executing: './usr/src/nv/makedevices.sh'...
   executing: '/sbin/ldconfig'...
   /sbin/ldconfig: Input file /usr/X11R6/lib64/libXvMCNVIDIA.so.1.0.6629 not fo
   und.
   /sbin/ldconfig: Input file /usr/lib64/libnvidia-tls.so.1.0.6629 not found.
   /sbin/ldconfig: Input file /usr/lib64/libGL.so.1.0.6629 not found.
   /sbin/ldconfig: Input file /usr/lib64/libGLcore.so.1.0.6629 not found.
   /sbin/ldconfig: Input file /usr/lib64/tls/libnvidia-tls.so.1.0.6629 not foun
   d.
   executing: '/sbin/depmod -aq'...
-> done.
-> Driver file installation is complete.
-> Running post-install sanity check:
ERROR: Unable to get file properties for '/usr/lib64/libGL.so.1' (No such file
       or directory).
WARNING: The symbolic link '/usr/lib64/libGL.so.1' does not exist.  This is
         necessary for correct operation of the NVIDIA Accelerated Graphics
         Driver for Linux-x86_64.  You can create this symbolic link manually
         by executing `ln -sf libGL.so.1.0.6629 /usr/lib64/libGL.so.1`.
ERROR: Unable to get file properties for '/usr/lib64/libGLcore.so.1' (No such
       file or directory).
WARNING: The symbolic link '/usr/lib64/libGLcore.so.1' does not exist.  This is
         by executing `ln -sf libGLcore.so.1.0.6629
         /usr/lib64/libGLcore.so.1`.
ERROR: Unable to get file properties for '/usr/lib64/libnvidia-tls.so.1' (No
       such file or directory).
WARNING: The symbolic link '/usr/lib64/libnvidia-tls.so.1' does not exist.
         This is necessary for correct operation of the NVIDIA Accelerated
         Graphics Driver for Linux-x86_64.  You can create this symbolic link
         manually by executing `ln -sf libnvidia-tls.so.1.0.6629
         /usr/lib64/libnvidia-tls.so.1`.
ERROR: Unable to get file properties for '/usr/lib64/tls/libnvidia-tls.so.1'
       (No such file or directory).
WARNING: The symbolic link '/usr/lib64/tls/libnvidia-tls.so.1' does not exist.
         /usr/lib64/tls/libnvidia-tls.so.1`.
       '/usr/X11R6/lib64/libXvMCNVIDIA_dynamic.so.1' (No such file or
       directory).
WARNING: The symbolic link '/usr/X11R6/lib64/libXvMCNVIDIA_dynamic.so.1' does
         not exist.  This is necessary for correct operation of the NVIDIA
         Accelerated Graphics Driver for Linux-x86_64.  You can create this
         symbolic link manually by executing `ln -sf libXvMCNVIDIA.so.1.0.6629
         /usr/X11R6/lib64/libXvMCNVIDIA_dynamic.so.1`.
-> done.
-> Post-install sanity check failed.
-> Shared memory test passed.
-> Running runtime sanity check:
ERROR: The runtime configuration check failed for library 'libGL.so.1.0.6629'
       (expected: '/usr/lib64/libGL.so.1', found: 'not').  The most likely
       reason for this is that conflicting OpenGL libraries are installed in a
       location not inspected by nvidia-installer.  Please be sure you have
       uninstalled any third-party OpenGL and third-party graphics driver
       packages.
-> done.
-> Runtime sanity check failed.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
Pourtant j'ai certains des fichiers qui posent pb, dois-je créer les liens à la main ?? :
[root@FC3 log]# ll /usr/X11R6/lib64/libXvMCNVIDIA.so.1.0.6629
-rwxr-xr-x  1 root root 191616 jan 15 15:53 /usr/X11R6/lib64/libXvMCNVIDIA.so.1.0.6629
[root@FC3 log]# ll /usr/lib64/libnvidia-tls.so.1.0.6629
-rwxr-xr-x  1 root root 3312 jan 15 15:53 /usr/lib64/libnvidia-tls.so.1.0.6629
[root@FC3 log]# ll /usr/lib64/libGL.so.1.0.6629
-rwxr-xr-x  1 root root 600408 jan 15 15:53 /usr/lib64/libGL.so.1.0.6629
[root@FC3 log]# ll /usr/lib64/libGLcore.so.1.0.6629
-rwxr-xr-x  1 root root 6675104 jan 15 15:53 /usr/lib64/libGLcore.so.1.0.6629
[root@FC3 log]# ll /usr/lib64/tls/libnvidia-tls.so.1.0.6629
-rwxr-xr-x  1 root root 3024 jan 15 15:53 /usr/lib64/tls/libnvidia-tls.so.1.0.6629
ls: /usr/lib64/libGL.so.1: Aucun fichier ou répertoire de ce type
ls: /usr/lib64/libGLcore.so.1: Aucun fichier ou répertoire de ce type
ls: /usr/lib64/libnvidia-tls.so.1: Aucun fichier ou répertoire de ce type
n°621005
shaker114
Lost in translation
Posté le 16-01-2005 à 15:35:20  profilanswer
up svp, personne ?
n°622989
shaker114
Lost in translation
Posté le 19-01-2005 à 18:51:01  profilanswer
personne ???
n°628188
stisoas
Posté le 28-01-2005 à 21:00:48  profilanswer
shaker114 a écrit :
Bonjour à tous,
Voici des traces :
-> done.
   (1.0-6629):
   und.
   d.
-> done.
       or directory).
       file or directory).
       directory).
-> done.
       packages.
-> done.
l installateur ne trouve pas tes libraries GL ...
commence deja par les chercher. find / -name 'libGL*'
je sais pas , mais , il se peut que les liens symbolic soit pas crée dans /usr/lib64.
j ai pas d install 64bit, mais je sais par contre qu une distro source te permettrait de cerner plus facilement les choses , ...dans un premiers temps .
ps : quand tu sais lire l anglais , et que tu est confronté a un probleme comme le tiens, je vois pas l interet d appeler au secours AVANT de chercher un minimum par toi meme. en tout amitié hein :)
EDIT: merde :/ , j a pas tout lu  [:aha] , bah ouais il te suggere de créer un des liens par toi meme  [:itm] .
crée les liens demandé , ca devrait "passer"  si il t en manque , tu les rajoutes au fur  et a mesure.
Message édité par stisoas le 28-01-2005 à 21:05:48
n°628190
Mjules
Parle dans le vide
Posté le 28-01-2005 à 21:02:49  profilanswer
sous Mandrake si faut installer libMesaGLU1-devel ; cherche le paquet qui correspond sous fedora
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°638648
shaker114
Lost in translation
Posté le 18-02-2005 à 16:50:40  profilanswer
bon bah pb résolu avec un patch trouvé dans les forums du site nvidia... patch des drivers car ils semblent incompatible avec 2.6.10.
sinon nouveau pb, le serveur x n'arrive pas à se lancer au démarrage, je dois faire un modprobe nvidia, startx à la main...
message d'erreur : no usable screen found je crois
n°642450
darck ppc
Posté le 27-02-2005 à 15:20:06  profilanswer
Désinstalle les drivers (sh blabla --uninstall)
Ensuite fait ça : rm -rf /usr/X11R6/lib64
puis : ln -s /usr/X11R6/lib /usr/X11R6/lib64
Tu réinstalles les drivers nvidia, et tu lances X...
  Installation
installer une carte ethernet Intel Pro 1000 F sous Redhat 9Pb avec Grub sous Fedora Core 3
[Resolu]Problème INEDIT, drivers pour carte nVidia "No screens found"pb de boot avec fedora
shared memory et Fedora - kernel 2.6Installation de BEWAN USB st gris sous fedora c 3
Quelle distrib de Linux pour installer Apache,MySQL,PHP[Installer Drivers ATI] 3D et 2D | Mise à jour 8.12.10-1
Plus de sujets relatifs à : pb pour installer les drivers CG nvidia, fedora C3 x86-64
