3712 connectés
  Linux et OS Alternatifs
  Installation
  j'ai installé debian et...
 Page :   1  2  3  4
Page Précédente
n°509259
ginie
Posté le 24-06-2004 à 13:42:42  profilanswer
bonjour, je viens d'installer debian et :
X refuse de se lancer
je n'arrive pas a pinger des pc windows avec leur noms (seul l'ip marche)
je n'arrive pas a pinger ce pc "linux"
comment trouver l'ip de linux ? (pour que je puisse utiliser ssh, bien plus pratique de de faire des aller retour windows/linux
merci  :hello:
n°509261
ishaor
Posté le 24-06-2004 à 13:47:18  profilanswer
1) montre les log quand tu lances startx
2) met samba
3) ifconfig pour l'ip
n°509263
ginie
Posté le 24-06-2004 à 13:53:20  profilanswer
ça va etre long :D
linux:~# startx
xauth:  creating new authority file /root/.Xauthority
warning: process set to nice value 0 instead of -10 as requested
This is a pre-release version of XFree86, and is not supported in any
way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
        If the server is older than 6-12 months, or if your card is
        newer than the above date, look for a newer version before
        reporting problems.  (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.6.3-bk2 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Thu Jun 24 15:52:36 2004
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Generic Monitor"
(**) |   |-->Device "Generic Video Card"
(**) |-->Input Device "Generic Keyboard"
(**) XKB: rules: "xfree86"
(**) XKB: model: "pc104"
(**) XKB: layout: "fr"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Generic Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
        Entry deleted from font path.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
        compiled for 4.1.0.1, module version = 1.0.0
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
        compiled for 4.1.0.1, module version = 0.1.0
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(--) PCI:*(0:1:0) Intel i810e rev 3, Mem @ 0xe8000000/26, 0xeff80000/19
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
        compiled for 4.1.0.1, module version = 1.1.9
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
        compiled for 4.1.0.1, module version = 1.13.0
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/drivers/i810_drv.o
(II) Module i810: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
(II) I810: Driver for Intel i810 chipset: i810, i810-dc100, i810e, i815
(--) Assigning device section with no busID to primary device
(--) Chipset i810e found
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(**) I810(0): Depth 24, (--) framebuffer bpp 24
(==) I810(0): RGB weight 888
(==) I810(0): Default visual is TrueColor
(II) I810(0): initializing int10
(II) I810(0): Primary V_BIOS segment is: 0xc000
(II) I810(0): VESA BIOS detected
(II) I810(0): VESA VBE DDC supported
(--) I810(0): Chipset: "i810e"
(--) I810(0): Linear framebuffer at 0xE8000000
(--) I810(0): IO registers at addr 0xEFF80000
(EE) Unable to open /dev/agpgart (No such device)
(**) I810(0): Will alloc AGP framebuffer: 8192 kByte
(==) I810(0): Using gamma correction (1.0, 1.0, 1.0)
(II) I810(0): Generic Monitor: Using hsync range of 28.00-50.00 kHz
(II) I810(0): Generic Monitor: Using vrefresh range of 43.00-75.00 Hz
(II) I810(0): Clock range:  12.00 to 136.00 MHz
(II) I810(0): Not using default mode "640x350" (vrefresh out of range)
(II) I810(0): Not using default mode "640x400" (vrefresh out of range)
(II) I810(0): Not using default mode "720x400" (vrefresh out of range)
(II) I810(0): Not using default mode "640x480" (vrefresh out of range)
(II) I810(0): Not using default mode "800x600" (hsync out of range)
(II) I810(0): Not using default mode "1024x768" (unknown reason)
(II) I810(0): Not using default mode "1024x768" (hsync out of range)
(II) I810(0): Not using default mode "1152x864" (hsync out of range)
(II) I810(0): Not using default mode "1280x960" (hsync out of range)
(II) I810(0): Not using default mode "1280x960" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1280x1024" (hsync out of range)
(II) I810(0): Not using default mode "1280x1024" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1600x1200" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
(II) I810(0): Not using default mode "1400x1050" (hsync out of range)
(II) I810(0): Not using default mode "1400x1050" (bad mode clock/interlace/doublescan)
(--) I810(0): Virtual size is 800x600 (pitch 1024)
(**) I810(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) I810(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(++) I810(0): DPI set to (100, 100)
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(==) Depth 24 pixmap format is 32 bpp
(==) I810(0): Write-combining range (0xe8000000,0x4000000)
(II) I810(0): Setting dot clock to 49.5 MHz [ 0x1f 0x6 0x30 ] [ 33 8 3 ]
(II) I810(0): chose watermark 0x22111000: (tab.freq 49.5)
Fatal server error:
AddScreen/ScreenInit failed for driver 0
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
X connection to :0.0 broken (explicit kill or server shutdown).
n°509290
ginie
Posté le 24-06-2004 à 14:21:37  profilanswer
:sweat:
n°509293
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:22:43  profilanswer
modprobe agpgart
n°509294
ginie
Posté le 24-06-2004 à 14:23:31  profilanswer
j'ai la video intégré i810
n°509295
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:23:40  profilanswer
pour pinguer les pc windows avec leur nom, il te faut un serveur dns et renseigner le fichier /etc/resolv.conf avec son ip.
pour pinguer le pc linux, il faut lui donner une ip (dhcp ou statique, au choix)
n°509296
ginie
Posté le 24-06-2004 à 14:23:43  profilanswer
linux:~# modprobe agpgart
modprobe: Can't locate module agpgart
n°509297
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:23:58  profilanswer
et alors?
--edit--
modprobe -l | grep agp
Message édité par arghbis le 24-06-2004 à 14:24:29
n°509298
ginie
Posté le 24-06-2004 à 14:25:38  profilanswer
ok, et apres ?
n°509300
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:26:18  profilanswer
ben quel module il te trouve, tu es en woody/sarge/sid? quel kernel? le bf24 ou le 2.2?
n°509301
ginie
Posté le 24-06-2004 à 14:27:06  profilanswer
woody et kernel 2.4.18 je crois
n°509309
dam1330
Posté le 24-06-2004 à 14:28:44  profilanswer
fais un "uname -r"
n°509310
ginie
Posté le 24-06-2004 à 14:29:10  profilanswer
2.2.20-idepci
n°509313
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:31:37  profilanswer
tu as le net? si oui, apt-cache search --names-only kernel-image
puis apt-get install du dernier 2.4 (ça doit être 2.4.26 ou 27)
n°509314
ginie
Posté le 24-06-2004 à 14:32:34  profilanswer
2.4.18 le dernier
n°509317
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:36:26  profilanswer
ah en woody ouais, il doit être patché
installes le
n°509322
ginie
Posté le 24-06-2004 à 14:37:55  profilanswer
presque terminé
n°509325
dam1330
Posté le 24-06-2004 à 14:39:45  profilanswer
j'ai du mal a comprendre quand meme, debian pourrait au-moins mettre le 2.4 par defaut, tous les gens qui installent une debian pour la premiere fois se plantent et mettent un 2.2
n°509326
ginie
Posté le 24-06-2004 à 14:40:43  profilanswer
parce qu'en plus le 2.4 est inclus ?
n°509329
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:41:58  profilanswer
ben si tu as lu le tuto d'installation, ils te disent que tu peux choisir ton kernel (plusieurs saveurs qu'ils disent).
si tu tape bf24 (ou linux-bf24 chais pu), il te met un 2.4 au lieu d'un 2.2
n°509332
ginie
Posté le 24-06-2004 à 14:42:25  profilanswer
Do you want me to create a link from /boot/initrd.img-2.4.18-1-686 to initrd.img?[Yn]
yes ?
n°509335
arghbis
salops de dauphins
Posté le 24-06-2004 à 14:46:46  profilanswer
yes, il va te remplacer ton noyal par défaut, c'est tout, et te mettre l'actuel en old
n°509336
ginie
Posté le 24-06-2004 à 14:46:53  profilanswer
c'est bon, installé
n°509338
chaica
Posté le 24-06-2004 à 14:52:23  profilanswer
ouais réponds yes, ensuite faut que tu rajoutes une entrée dans ton /etc/lilo.conf de ce style:
Code :
  1. image=/vmlinuz
  2.         initrd=/initrd.img
  3.         label=NouveauNoyau
Tu décommentes aussi "prompt" dans ton /etc/lilo.conf, ça te permet de choisir le noyau avant de booter (sécurité en cas de fausse manip).
Tu vérifies que /initrd.img pointe bien vers quelque chose qui existe, tu tapes "lilo" pour relancer lilo et voir s'il te chie pas une erreur.
Tu rebootes, tu choisis NouveauNoyau, si tu bootes bien c'est bon ( un petit uname -r pour être sûr).
Message édité par chaica le 24-06-2004 à 14:55:20
n°509339
ginie
Posté le 24-06-2004 à 14:53:57  profilanswer
tu fais tout ça comment ?
n°509342
chaica
Posté le 24-06-2004 à 14:55:05  profilanswer
Tu édites ton fichier /etc/lilo.conf avec n'importe quel éditeur de texte (nano, vi...)
n°509343
ginie
Posté le 24-06-2004 à 14:56:01  profilanswer
meme ça je ne sais pas faire :/
en tout cas, pas en texte
n°509346
chaica
Posté le 24-06-2004 à 14:58:59  profilanswer
tu passes en root:
$su
ensuite tu tapes:
$nano /etc/lilo.conf
tu modifies, tu sauves avec ctrl-o et tu quittes avec ctrl-x
tu relances lilo et tu rebootes
n°509350
ginie
Posté le 24-06-2004 à 15:00:53  profilanswer
bash: /etc/lilo.conf: Permission denied
et je suis root
n°509351
arghbis
salops de dauphins
Posté le 24-06-2004 à 15:01:20  profilanswer
nano /etc/lilo.conf
nano c'est l'éditeur de texte
n°509352
chaica
Posté le 24-06-2004 à 15:01:48  profilanswer
T'es pas root
$whoami
n°509353
ginie
Posté le 24-06-2004 à 15:01:51  profilanswer
linux:~# $nano /etc/lilo.conf
n°509354
ginie
Posté le 24-06-2004 à 15:02:18  profilanswer
chaica a écrit :
T'es pas root
$whoami
je viens de me loguer en root
n°509357
chaica
Posté le 24-06-2004 à 15:02:44  profilanswer
Entre pas le $ dans les différentes commandes, c'était pour t'indiquer que c'est une commande shell
n°509359
ginie
Posté le 24-06-2004 à 15:04:25  profilanswer
donc je rajoute
image=/vmlinuz
          initrd=/initrd.img
          label=NouveauNoyau
dedans ?
n°509362
chaica
Posté le 24-06-2004 à 15:05:24  profilanswer
oui tu n'effaces rien, tu ajoutes ces trois nouvelles lignes. Tu enlèves aussi le # devant le mot prompt quelque part dans le fichier.
n°509365
ginie
Posté le 24-06-2004 à 15:06:55  profilanswer
# message=/boot/bootmess.txt
#       prompt
#       single-key
#       delay=100
#       timeout=100
n°509366
chaica
Posté le 24-06-2004 à 15:07:03  profilanswer
Et surtout une fois que tu as sauvé et que tu as quitté le fichier, tu tapes: lilo ,avant de rebooter et tu vois s'il te sort pas une erreur.
n°509368
ginie
Posté le 24-06-2004 à 15:08:05  profilanswer
linux:~# lilo
Added Linux *
Added LinuxOLD
Fatal: open /initrd.img: No such file or directory
 Page :   1  2  3  4
Page Précédente
  Installation
apres un apt-get ou s installe les logiciels sous debian genre mozilla[-DEBIAN-] - xfree installé mais pb de session ....
impossible de trouver imule installé sur une débian[DEBIAN] ou trouver la totalité des CD d'installe pour une Woody ?
[DEBIAN] Qui a installé XFCE3 sur une Woody ?Comment installe kde3.1.x sur une Debian stable
[Debian] Comment lister ce qui est installé ?installe radeon 8500 sur debian en DRM/DRI : pb !!!! ke faire ???
[debian] cd d'installe ![Debian] Woody fraichement installe, trop de port ouvert
Plus de sujets relatifs à : j'ai installé debian et...
