3742 connectés
 Page :   1  2
Page Suivante
Mon installation de Ubuntu 5.10 [need help]
n°745611
multani
Dépressionnisé
Posté le 27-10-2005 à 18:26:21  profilanswer
Regarde en lancant un strace nom_du_programme pour voir où il recherche les librairies.
n°745618
nxb
Posté le 27-10-2005 à 18:47:16  profilanswer
nicolas@sonata:~$ strace /usr/X11R6/bin/fireglcontrolpanel
execve("/usr/X11R6/bin/fireglcontrolpanel", ["/usr/X11R6/bin/fireglcontrolpane". ..], [/* 30 vars */]) = 0
access("/etc/ld.so.nohwcap", F_OK)      = -1 ENOENT (No such file or directory)
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY)      = 3
open("/usr/lib32/libXmu.so.6", O_RDONLY) = 3
open("/usr/lib32/libXt.so.6", O_RDONLY) = 3
open("/usr/lib32/libICE.so.6", O_RDONLY) = 3
open("/lib/tls/i686/sse2/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such fil e or directory)
stat64(0xffffb170, 0xffffb1f8)          = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/sse2/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such file or direc tory)
open("/lib/tls/sse2/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/i486-linux-gnu/i686/sse2/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT ( No such file or directory)
open("/lib/i486-linux-gnu/i686/sse2/libexpat.so.0", O_RDONLY) = -1 ENOENT (No su ch file or directory)
open("/lib/i486-linux-gnu/i686/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No su ch file or directory)
open("/lib/i486-linux-gnu/i686/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such fi le or directory)
open("/lib/i486-linux-gnu/sse2/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No su ch file or directory)
open("/lib/i486-linux-gnu/sse2/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such fi le or directory)
open("/lib/i486-linux-gnu/cmov/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such fi le or directory)
open("/lib/i486-linux-gnu/libexpat.so.0", O_RDONLY) = -1 ENOENT (No such file or  directory)
writev(2, [{ptrace: umoven: Input/output error
0x21ffffda19, 10021671257}, {ptrace: umoven: Input/output error
0x245556846c, 10021671261}, {ptrace: umoven: Input/output error
0xd556b252f, 10021671252}, {ptrace: umoven: Input/output error
0x1e556b2510, 10021671252}, {ptrace: umoven: Input/output error
0x19555694ee, 5726703977}, {NULL, 0}, {NULL, 0}, {NULL, 0}, {NULL, 0}, {NULL, 0} ], 10/usr/X11R6/bin/fireglcontrolpanel: error while loading shared libraries: li bexpat.so.0: cannot open shared object file: No such file or directory
) = 146
exit_group(127)                         = ?
 [:aaah]
Message édité par nxb le 27-10-2005 à 18:48:29
n°745662
nxb
Posté le 27-10-2005 à 22:47:19  profilanswer
est-ce qu'il faut que je crée un dossier /lib/i486-linux-gnu/?
n°746112
nxb
Posté le 28-10-2005 à 23:12:09  profilanswer
up
n°746150
KikitheKin​g
Kiki le Vrai !
Posté le 28-10-2005 à 23:46:40  profilanswer
Tu devrais arreter de te prendre la tête avec cette version 64bits je pense :o
Passes en 32, ça changera rien ;) enfin si, t'aura plus de prob.
n°746153
nxb
Posté le 28-10-2005 à 23:52:09  profilanswer
effectivement, vu comme ça ;)
Bon, je vais aussi m'acheter une carte vidéo nVidia... :o
Bon, c'est le w-e, j'vais pas me prendre la tete la-dessus, je fais le pont, alors mercredi, ce sera réinstallation en 32bits... [:anathema]
n°747993
nxb
Posté le 02-11-2005 à 22:46:13  profilanswer
cette fois, après réinstallation en 32bits, tout marche:
  • firefox et flash
  • thunderbird pour les mails
  • readpst pour importer les mails d'outlook (installé mais pas encore testé)
  • gstreamer pour les codecs audio/video
  • mplayer pour la lecture multimedia
  • amule, azureus
  • les drivers ati pour la carte vidéo
Seuls problèmes qui subsistent:
  • la sortie TV qui ne fonctionne pas...  :sweat:
  • qq problèmes d'accès à mes disques durs: impossible d'accéder à mon deuxième disque dur (le système me dit qu'il m'est impossible de changer les droits d'accès au disque, qui est en lecture seule  [:queen4ever] ).
  • impossible de démonter un disque externe sans passer par l'utilitaire de gestion des disques (un peu lourd...)
et oui, j'ai toujours besoin d'aide...  [:_jad_]
n°748010
nxb
Posté le 02-11-2005 à 23:27:57  profilanswer
question, aussi... Je pense installer ça: http://gatos.sourceforge.net/ati.2.php
apparement, si je comprends bien, il s'agit de remplacer qq fichiers de XFree.
Un truc me fait un peu peur: "Do _NOT_ mix XFree drivers (i.e. 4.2.0 drivers are meant _only_ for 4.2.0)."
Comment je sais quelle version prendre?
n°748070
nxb
Posté le 03-11-2005 à 09:59:03  profilanswer
up
n°748075
multani
Dépressionnisé
Posté le 03-11-2005 à 10:18:45  profilanswer
  • firefox et flash
  • amule, azureus
Fais voir ton fstab ?
Apparement, c'est dans Universe, donc ça devrait s'installer sans trop de difficultés via synaptic ...
n°748088
belgique
Posté le 03-11-2005 à 11:03:57  profilanswer
Pour les disques externes, il ne faut rien dans son fstab il me semble. Je branche mon disque, il monte les partitions et je démonte simplement moi [:spamafote]
n°748089
nxb
Posté le 03-11-2005 à 11:07:38  profilanswer
je suis au boulot, mais dès que je rentre je te mets ça...
en fait, quand je fais un clic droit sur le disque pour démonter, il me dis que j'ai pas le droit... et si je débranche le disque, qd je le rebranche j'ai perdu pas mal de données...
n°748093
belgique
Posté le 03-11-2005 à 11:11:38  profilanswer
Il de dit que t'as pas le droit où que le truc esst busy? T'as rien mis dans ton fstab ni dans gestion des disques pour gérer tout ça?
Va voir dans utilisateurs si ton utilisateur a bien le droit de monter / démonter des disques.
Message édité par belgique le 03-11-2005 à 11:12:10
n°748104
nxb
Posté le 03-11-2005 à 11:21:41  profilanswer
il me dit "vous n'avez pas les droits"...
n°748297
nxb
Posté le 03-11-2005 à 19:36:15  profilanswer
more /etc/fstab :
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
/dev/hda2       /               ext3    defaults,errors=remount-ro 0       1
/dev/hda5       /home           ext3    defaults        0       2
/dev/hda1       /media/hda1     ntfs    defaults        0       0
/dev/hdb1       /media/hdb1     ntfs    defaults        0       0
/dev/hdb5       /media/hdb5     ntfs    defaults        0       0
/dev/hda6       /wintemp        vfat    defaults        0       0
/dev/hda7       none            swap    sw              0       0
/dev/hdc        /media/cdrom0   udf,iso9660 user,noauto     0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto  0       0
j'ai vu que j'avais "/dev/sda1" qui correspondait à la carte flash que j'avais laissée dans mon lecteur en installant ubuntu... je l'ai viré, comme ça il n' y a plus d'erreur au démarrage.
n°748298
arghbis
salops de dauphins
Posté le 03-11-2005 à 19:38:46  profilanswer
si tu veux écrire sur les partoches ntfs, c'est raté (enfin, tu peux mais c merdique : regardes le topic de MJules à ce sujet)
pour le vfat, tu dois pouvoir normalement
n°748303
nxb
Posté le 03-11-2005 à 19:45:28  profilanswer
pour le ntfs, je sais... mais je peux meme pas lire!
J'ai une icone "HDA1" sur le bureau, qd je double clique dessus il me dit: impossible d'afficher le contenu de ce dossier. Vous n'avez pas les permissions necessaires pour voir le contenu de "hda1"
(pour hdb1 et 2 c'est pareil... et pour hda6 c'est pareil... :| )
n°748480
arghbis
salops de dauphins
Posté le 04-11-2005 à 10:27:49  profilanswer
heu, c'est étonnifiant quand même!
fais un ls -l de /media pour voir
et le résultat de la commande groups aussi
n°753951
nxb
Posté le 19-11-2005 à 16:24:43  profilanswer
C'est bon, j'ai résolu le problème...
J'ai viré mes partitions ?TFS, maintenant elles sont en fat32, c'est pas top pour linux mais au moins, ça me permet d'y accéder depuis windows ou ubuntu...
Et j'ai réussi à installer les drivers ati, j'ai meme le panneau de configuration qui se lance...
Seul problème, la sortie télé. En gros, quand je choisi dans "ati control" l'option TV out, l'écran passe au noir complet puis l'image revient. Mais pas d'image sur la télé.
J'ai essayé en ayant allumé la tv avant de booter, après, après avoir lancer le panneau de config, après avoir lancé l'option tvout du panneau de config...
Qu'est ce que je dois faire?
n°755418
Donzeky
Le bleu c'est la vie.
Posté le 23-11-2005 à 19:13:40  profilanswer
Tu as vérifié que tu étais bien dans le bon mode ?( VHS ou S-VHS).
Sinon, je voulais te demander, ton dual-boot a fonctionné sans problème ?
Tu as utilisé LILO ?
n°755424
nxb
Posté le 23-11-2005 à 19:19:01  profilanswer
j'ai utilisé grub... et oui ça a bien marché...
pour le 'bon mode', j'ai pas de mode vhs il me semble... (suis sous win pour l'instant)
je regarderais mais il me semble...
n°755446
Donzeky
Posté le 23-11-2005 à 20:21:31  profilanswer
Merci pour ta réponse.
J'ai un peu cherché pour la config tv, j'ai rien trouvé, ça a l'air bien galère...
n°755450
nxb
Posté le 23-11-2005 à 21:04:01  profilanswer
hélas, oui, avec une carte ati c'est galère... je commence à envisager sérieusement le changement de carte graph... :(
 Page :   1  2
Page Suivante
[Mandriva] Installation d'un réseau Wifi Ad-hoc[Debian]Probleme Installation a cause de PCMCIA
Pb sur Fedora : l'installation planteDual boot Fedora Core 4 / Ubuntu Breezy : Partage de /home
Pb d'installation Debian netinstPb d'installation Debian netinst
[HELP] Desinstallation d'une mandrakeInstallation PowerChute pour onduleur APC ok, mais apres??
Quel avantage posséde Debian sur Ubuntu pour une utilisation Desktop ?probleme lors de l'installation de pilote graphique, quitter X
Plus de sujets relatifs à : Mon installation de Ubuntu 5.10 [need help]
