7406 connectés
  Linux et OS Alternatifs
  Installation
  Pb installation eclipse FC3
n°619596
fazouye
Posté le 13-01-2005 à 10:36:53  profilanswer
Salut, je n'arrive pas à démarrer l'install d'Eclipse sour Fedora Core 3
J'exécute le binaire, j'ai le splashscreen et puis ça plante ...
Code :
  1. $ ./eclipse
  2. org.osgi.framework.BundleException: Unable to find system bundle manifest file.
  3.         at org.eclipse.osgi.framework.adaptor.core.SystemBundleData.createManifest(SystemBundleData.java:73)
  4.         at org.eclipse.osgi.framework.adaptor.core.SystemBundleData.<init>(SystemBundleData.java:34)
  5.         at org.eclipse.osgi.framework.adaptor.core.AbstractFrameworkAdaptor.createSystemBundleData(AbstractFrameworkAdaptor.java:294)
  6.         at org.eclipse.osgi.framework.internal.core.SystemBundle.<init>(SystemBundle.java:41)
  7.         at org.eclipse.osgi.framework.internal.core.Framework.createSystemBundle(Framework.java:187)
  8.         at org.eclipse.osgi.framework.internal.core.Framework.initialize(Framework.java:152)
  9.         at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:95)
  10.         at org.eclipse.osgi.framework.internal.core.OSGi.createFramework(OSGi.java:90)
  11.         at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
  12.         at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:215)
  13.         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:127)
  14.         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  15.         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
  16.         at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
  17.         at java.lang.reflect.Method.invoke(Method.java:324)
  18.         at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
  19.         at org.eclipse.core.launcher.Main.run(Main.java:704)
  20.         at org.eclipse.core.launcher.Main.main(Main.java:688)
pourtant, je pense avoir bien  configuré la jvm ... :
$ set |grep -i java
Code :
  1. JAVACMD=/usr/java/j2sdk1.4.2_04/bin/java
  2. JAVA_HOME=/usr/java/j2sdk1.4.2_04/
  3. PATH=/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/java/j2sdk1.4.2_04/bin/:/home/toto/bin/
help
n°620020
fazouye
Posté le 14-01-2005 à 08:37:48  profilanswer
:cry: up
n°620163
bobuse
Posté le 14-01-2005 à 13:55:28  profilanswer
tu as téléchargé et installé quel fichier ?
get amaroK plugin
n°621709
fazouye
Posté le 17-01-2005 à 14:34:35  profilanswer
j'ai téléchargé ça : eclipse-SDK-3.0.1-linux-gtk.zip
unzipé,
et exécuté eclipse (le fichier)
après le splashscreen, il se plante et m'indique qu'il écrit un fichier de log ... donc le contenu est copié/collé dans mon précédent message ...
ce qui est étrange, c'est qu'avant sous FC2 tout fonctionnait... je ne m'en suis pas servi pdt un certain temps, et qd je l'ai relancé, j'avais cette erreur. J'ai donc voulu le réinstaller de 0, après avoir viré les traces laissées dans mon répertoire home
voilà, merci
n°621717
bobuse
Posté le 17-01-2005 à 15:13:37  profilanswer
pour le lancer, tu te mets bien de le repertoire d'eclipse dans une console, et tu lance ./eclipse ?
get amaroK plugin
n°621734
busOman
Hiver.
Posté le 17-01-2005 à 15:40:47  profilanswer
Oui, sinon il ne pourrait même pas avoir le splashscreen.
n°621746
fazouye
Posté le 17-01-2005 à 15:55:29  profilanswer
oui je confirme
n°621749
fazouye
Posté le 17-01-2005 à 15:56:09  profilanswer
Ce qui me gène, c'est que je ne sais pas interpréter cette erreur : Unable to find system bundle manifest file.
n°621753
busOman
Hiver.
Posté le 17-01-2005 à 16:11:36  profilanswer
Peut-être un problème de droits.
En root, Eclipse démarre ? :D
n°621801
ceric35
Posté le 17-01-2005 à 17:27:08  profilanswer
Essaye de supprimer le dossier ".eclipse" du repertoire HOME
rm -Rf $HOME/.eclipse
n°622013
fazouye
Posté le 17-01-2005 à 21:01:04  profilanswer
déjà fait comme marqué plus haut
n°622020
ceric35
Posté le 17-01-2005 à 21:09:13  profilanswer
:ouch:  je doit pas bien voir alors !!!
n°622032
fazouye
Posté le 17-01-2005 à 21:23:51  profilanswer
ouaip, j'avais pensé que l'ancienne installation avait mis le souk donc j'avais fait le ménage
là je le dl sur une autre machine , toujours en FC3 (x86_64) ... peut etre que j'y verrai plus clair
n°622037
ceric35
Posté le 17-01-2005 à 21:34:03  profilanswer
En effet, excuse [:aurelie22]
n°622045
fazouye
Posté le 17-01-2005 à 21:39:19  profilanswer
pas de pb ;)
bon bin , ca tourne sur un système 64 bits, avec jdk 1.5 et eclipse fraichement installé ...
j'ai du laisser la ***** qq part ...
  Installation
Pb connection adsl + FC3installation linux
Enième pb après l'installation des pilotes ATI sous UbuntuINSTALLATION DE SOFTS
Probleme d'installation webcam logitgech quickcam expresspb installation mandrake 10.1
[Debian] pbm installation[Mdk10.1] Plantage d'installation
Installation Antivir sous FC3
Plus de sujets relatifs à : Pb installation eclipse FC3
