5500 connectés
  Linux et OS Alternatifs
  Installation
  installation du driver graphique
n°622979
carot0
Posté le 19-01-2005 à 18:28:18  profilanswer
slt tlm, voila je vien d'installer le drive de ma CG mais un petit probleme viens d'apparaitre lorsque je fait un glxgear voici les messages
glxgears
libGL error: failed to open DRM: Operation not permitted
libGL error: reverting to (slow) indirect rendering
460 frames in 6.0 seconds = 76.667 FPS
280 frames in 5.0 seconds = 56.000 FPS
408 frames in 6.0 seconds = 68.000 FPS
457 frames in 6.0 seconds = 76.167 FPS
le proc est sur les rotules et surtout la carte en pleine forme sa donne plutot du 700-800 fps
le glxinfo lui me dit ca :
glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context
client glx vendor string: SGI
client glx version string: 1.2
client glx extensions:
GLX extensions:
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.3 Mesa 4.0.4
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  1 24  0 r  .  .  8  8  8  8  0 32  0  0  0  0  0  0 0 None
0x24 24 tc  1 24  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x25 24 tc  1 24  0 r  y  .  8  8  8  8  0 32  0  0  0  0  0  0 0 None
0x26 24 tc  1 24  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x27 24 tc  1 24  0 r  .  .  8  8  8  8  0 32  4  0  0  0  0  0 0 None
0x28 24 tc  1 24  0 r  .  .  8  8  8  8  0 16  4  0  0  0  0  0 0 None
0x29 24 tc  1 24  0 r  y  .  8  8  8  8  0 32  4  0  0  0  0  0 0 None
0x2a 24 tc  1 24  0 r  y  .  8  8  8  8  0 16  4  0  0  0  0  0 0 None
0x2b 24 dc  1 24  0 r  .  .  8  8  8  8  0 32  0  0  0  0  0  0 0 None
0x2c 24 dc  1 24  0 r  .  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x2d 24 dc  1 24  0 r  y  .  8  8  8  8  0 32  0  0  0  0  0  0 0 None
0x2e 24 dc  1 24  0 r  y  .  8  8  8  8  0 16  0  0  0  0  0  0 0 None
0x2f 24 dc  1 24  0 r  .  .  8  8  8  8  0 32  4  0  0  0  0  0 0 None
0x30 24 dc  1 24  0 r  .  .  8  8  8  8  0 16  4  0  0  0  0  0 0 None
0x31 24 dc  1 24  0 r  y  .  8  8  8  8  0 32  4  0  0  0  0  0 0 None
0x32 24 dc  1 24  0 r  y  .  8  8  8  8  0 16  4  0  0  0  0  0 0 None
ma CG c'est une Kyro II
In a world without walls and fences, who needs Windows and Gates
n°623051
Jar Jar
Intaigriste
Posté le 19-01-2005 à 20:04:49  profilanswer
Problème de permissions ? Soit sur /dev/video, soit dans la conf du DRI pour XFree86...
n°623072
carot0
Posté le 19-01-2005 à 20:43:11  profilanswer
comment je peux savoir/resoudre ?
n°623076
Jar Jar
Intaigriste
Posté le 19-01-2005 à 20:47:09  profilanswer
Chez moi j'ai ça dans /dev :
crw-rw----   1 root video    10, 175 2005-01-19 09:37 agpgart
crw-rw----   1 root root    226,   0 2005-01-19 09:39 radeon
Note le video pour agpgart, il faut que l'utilisateur fasse partie du groupe en question.
Et dans ma conf XFree, j'ai ça :
Section "DRI"
        Mode    0666
EndSection
n°623131
ceric35
Posté le 19-01-2005 à 22:03:27  profilanswer
C'est clair,
il est pas lancé
Message édité par ceric35 le 19-01-2005 à 22:03:42
n°623190
carot0
Posté le 19-01-2005 à 23:18:03  profilanswer
Section "DRI"
        Mode    0666
EndSection
alors
pour agpgart -rw-rw----
pour video lrw-rw----
le Section "DRI"
        Mode    0666
EndSection
c'est bon aussi !
par contre je ne sais pas si je fait partie du groupe root
n°623310
Jar Jar
Intaigriste
Posté le 20-01-2005 à 11:52:30  profilanswer
J'espère bien que non ! Par contre il faut faire partie du groupe video.
n°623322
carot0
Posté le 20-01-2005 à 12:27:26  profilanswer
je le sais comment si je fait partie du groupe video ? ( et comment je m'y mets ?)
Message édité par carot0 le 20-01-2005 à 12:27:59
n°623336
mirtouf
Light is right !
Posté le 20-01-2005 à 12:54:12  profilanswer
id te donnes les groupes auxquels tu appartiens.
Tu peux éditer /etc/group en root ou utiliser useradd (adduser aussi ça dépend).
n°623337
carot0
Posté le 20-01-2005 à 12:59:42  profilanswer
id
uid=1000(cobra) gid=1000(cobra) groupes=1000(cobra),20(dialout),24(cdrom),25(floppy),29(audio),44(video)
donc je fais parti du groupe video
le prob vient pas de la !
n°623338
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:00:51  profilanswer
Bon bin utilise strace pour trouver l'opération qui chie.
n°623339
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:01:56  profilanswer
Sinon j'ai ça dans /dev/dri, tu as les mêmes permissions ?
crw-rw-rw-   1 root root 226, 0 2005-01-20 11:17 card0
n°623340
carot0
Posté le 20-01-2005 à 13:02:07  profilanswer
comment ca marche ce truc, je regarde les option et je coimprends rien !
n°623341
carot0
Posté le 20-01-2005 à 13:03:27  profilanswer
moi j'ai ca :
drwxr-x---  2 root root        4096 2005-01-19 19:18 dri
n°623342
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:04:02  profilanswer
Bin tu fais strace glxinfo, et tu regardes les erreurs avant l'affichage du "libGL error: failed to open DRM: Operation not permitted".
n°623343
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:04:52  profilanswer
carot0 a écrit :
moi j'ai ca :
Bon bin y'a un problème là déjà.
n°623345
carot0
Posté le 20-01-2005 à 13:07:56  profilanswer
c bon j'ai ca maintenant :
crw-rw-rw-  1 root root 226, 0 2005-01-19 18:13 card0
drw-rw-rw-  2 root root        4096 2005-01-19 19:18 dri
n°623346
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:09:25  profilanswer
Et ça marche ?
n°623348
carot0
Posté le 20-01-2005 à 13:10:34  profilanswer
Jar Jar a écrit :
Et ça marche ?
bas le glxinfo semble pas se plaindre mais apres un restartx bas j'ai perdu les permissions !
edit : oui ca marche parfaitement, glxgear tourne a fond !!!
edit 2 : par contre pour X c'est pas la joie l'affichage est merdique
edit 3 : je viens de comprendre pkoi les glxinfo et gear allaient  mieux je les ai executer en tant que root ! en root tout va  bien a priori mais mon compte user ne va pas mieux en fait !
edit 4 : j'arrive pas a accorder les permission a mon user en fait c juste ca qui coince ! pourtant je fait un chmod 666 sur dri, c pas bon ?
Message édité par carot0 le 20-01-2005 à 13:16:48
n°623366
carot0
Posté le 20-01-2005 à 13:34:56  profilanswer
personne a une idee pour que je donne les permissions a mon user ?
n°623381
Jar Jar
Intaigriste
Posté le 20-01-2005 à 13:56:46  profilanswer
n°623388
carot0
Posté le 20-01-2005 à 14:04:58  profilanswer
je le trouve pas mais par contre je trouve plein d'erreurs :
open("/dev/dri/card0", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card1", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card2", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card3", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card4", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card5", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card6", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card7", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card8", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card9", O_RDWR)          = -1 EACCES (Permission denied)
open("/dev/dri/card10", O_RDWR)         = -1 EACCES (Permission denied)
open("/dev/dri/card11", O_RDWR)         = -1 EACCES (Permission denied)
open("/dev/dri/card12", O_RDWR)         = -1 EACCES (Permission denied)
open("/dev/dri/card13", O_RDWR)         = -1 EACCES (Permission denied)
open("/dev/dri/card14", O_RDWR)         = -1 EACCES (Permission denied)
open("/dev/pvrcore0", O_RDWR)           = -1 ENOENT (No such file or directory)
n°623393
Jar Jar
Intaigriste
Posté le 20-01-2005 à 14:16:14  profilanswer
Bon bin visiblement les permissions pour celui-là ne sont toujours pas bonnes...
n°623398
carot0
Posté le 20-01-2005 à 14:25:43  profilanswer
a part en root un ls -l /dev/dri me dit que j'ai pas les permissions mais je vois pas comment les avoir j'ai meme mis dri dans un autre group ( video ) mais non ca a pas mieux marché alors je l'ai remis a group root
ls -l /dev/dri
ls: /dev/dri/card0: Permission non accordée
total 0
ls -l /dev/ | grep dri
n°623399
Jar Jar
Intaigriste
Posté le 20-01-2005 à 14:33:48  profilanswer
Si tu n'as pas les droits en exécution, difficile d'accéder au contenu du répertoire...
n°623464
carot0
Posté le 20-01-2005 à 16:33:20  profilanswer
donc comment je fait pour les avoir ?
n°623486
Jar Jar
Intaigriste
Posté le 20-01-2005 à 17:11:58  profilanswer
chmod 755 /dev/dri
chmod 666 /dev/dri/card0
n°623494
carot0
Posté le 20-01-2005 à 17:20:07  profilanswer
Jar Jar a écrit :
chmod 755 /dev/dri
merde j'avais fait chmod 666 pour /dev/dri !!!
n°623506
carot0
Posté le 20-01-2005 à 17:24:19  profilanswer
opengl marche mais ... pas quake III ( il plante sur le lancement d'ogl )
Message édité par carot0 le 21-01-2005 à 01:54:00
  Installation
pb driver smartlink et kpppSoucis avec l installation de SuperKaramba
carte graphique bon marchéInstallation de apache,mysql,et php sur mandrake...
installation internet sagem dual bootDriver Intel Pro Wireless 2200BG sous mandrake 10.1
Installation nvuinstallation mandrake 10.0 officielle??
Installation de BEWAN USB st gris sous fedora c 3problmem d'installation débian LVM+GRUB
Plus de sujets relatifs à : installation du driver graphique
