11282 connectés
  Linux et OS Alternatifs
  Installation
  Pb avec les drivers nvidia et kernel 2.4.22
n°326356
Tomate
Posté le 17-09-2003 à 12:20:40  profilanswer
salut,
j ai une mdk cooker et j ai mis le kernel multimedia 2.4.22
pb : les drivers nvidia ne fonctionnent plus :'(
kan je compile j ai ca :
[root@mdk ~/NVIDIA-Linux-x86-1.0-4496-pkg2/usr/src/nv]# make
ld -r -o nvidia.o nv-linux.o nv-kernel.o
depmod: *** Unresolved symbols in /lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol remove_proc_entry_R657cdd06
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol create_proc_entry_R9ec62f7e
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol init_mm_R8f0be0e6
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol irq_stat_R95cc1909
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol devfs_register_chrdev_R67ef03b0
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol proc_root_driver_Rdcef6c66
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol mem_map_Rc870ffbf
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol devfs_unregister_Rc9fc9aef
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol __pollwait_R9c7f9795
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol change_page_attr_Race8cd2f
/lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o: unresolved symbol devfs_register_R19076440
Hint: You are trying to load a module without a GPL compatible license
      and it has unresolved symbols.  The module may be trying to access
      GPLONLY symbols but the problem is more likely to be a coding or
      user error.  Contact the module supplier for assistance, only they
      can help you.
modprobe: insmod /lib/modules/2.4.22-7mm.1mdk/kernel/drivers/video/nvidia.o failed
modprobe: insmod nvidia failed
make: *** [package-install] Erreur 255
voila, je sais pas du tout koi faire la :/
:: Light is Right ::
n°326361
mikala
Souviens toi du 5 Novembre...
Posté le 17-09-2003 à 12:32:12  profilanswer
perso il ne boote pas chez moi le multimédia donc :D
sinon pk tu ne te sers pas de leurs pilotes avec lauto install ?
(enfin je dis cela & je dis rien  :D )
Intermittent du GNU
n°326363
Tomate
Posté le 17-09-2003 à 12:36:03  profilanswer
en fait j ai aussi essaye avec le 2.4.21-0.18 mais ca merde aussi
avec l installer ca fait pareil :/
n°326369
mikala
Posté le 17-09-2003 à 12:46:29  profilanswer
hum :/
bon bein ca marche chez moi :D (avec tous les  kernel < 22.multimedia )
le 22.multimedia je peux pas etre sur car il Panic!!! au boot :D
Intermittent du GNU
n°326388
Tomate
Posté le 17-09-2003 à 13:30:21  profilanswer
Mikala a écrit :
hum :/
oue mais t as pas de nvidia toi :D
n°326391
mikala
Posté le 17-09-2003 à 13:45:14  profilanswer
J'ai pas de nforce mais une GeForce 3 ti 200 :o
Intermittent du GNU
n°326395
Tomate
Posté le 17-09-2003 à 13:56:58  profilanswer
ah bah je comprends po :/
enfin toi si ca fait un kernel panic c ke moi je suis un peu plus loin ke toi :D
n°326427
911GT3
en roue libre
Posté le 17-09-2003 à 15:18:10  profilanswer
c'est normal que la compilation soit aussi courte ? tu as fait un make clean avant ?  :whistle:
n°326429
ldsteph
Posté le 17-09-2003 à 15:19:52  profilanswer
Une idée comme ça
L'agpgart pour nforce est dispo dans le kernel 2.4.22, peut être qu'il est déja compilé et que tu n'as pas besoin d'installer le driver agptruc des pilote nvidia.
Essaye aussi peut être de compiler ton propre kernel à la main.
n°326433
zeb_
Posté le 17-09-2003 à 15:25:56  profilanswer
Essaie avec le kernel 2.4.22-9mdk maintenant (meme si c'est pas garanti non plus).
n°326434
Tomate
Posté le 17-09-2003 à 15:27:00  profilanswer
oue j ai essaye et ca marche !!!!!!
putain trop content la :D
sinon : oue j avais po fe de make clean :D
j ai pas de nforce, juste un cg nvidia ;)
voilou, ca roule c cool :)
  Installation
nvidia geforce 2 mx & DebianKernel 2.4.22 + module scsi --> big problème !!!
[debian]installation de modem avec drivers connexantcompil kernel et log
y-a t'il des drivers via à installer sous LINUX ? mandrakeBesoin d'aide pour installer les drivers Nvidia LINUX
nvidia et kernel 2.6mon kernel est pas réactif
Plus de sujets relatifs à : Pb avec les drivers nvidia et kernel 2.4.22
