5260 connectés
  Linux et OS Alternatifs
  Installation
  Drivers ATI & ATI mobility radeon 9000
n°206022
Posté le 29-12-2002 à 15:21:37  answer
Je suis sous slackware 8.1, avec un kernel 2.4.19. J'ai un portable avec une ATI Mobility Radeon 9000. Voici mon XF86Config :
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"   # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the font modules
    Load        "type1"
    Load        "freetype"
    Load        "speedo"
# This loads the GLX module
    Load       "glx"
# ATI ################################################
   Load "dri"
EndSection
Section "DRI"
    Mode 0666
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
    RgbPath     "/usr/X11R6/lib/X11/rgb"
    FontPath   "/usr/X11R6/lib/X11/fonts/local/"
    FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath   "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "ServerFlags"
EndSection
Section "InputDevice"
    Identifier  "Keyboard1"
    Driver      "Keyboard"
    Option "AutoRepeat" "500 30"
    Option "XkbRules"   "xfree86"
    Option "XkbModel"   "pc101"
    Option "XkbLayout"  "fr"
EndSection
    Identifier  "Mouse1"
    Driver      "mouse"
    Option "Protocol"    "PS/2"
    Option "Device"      "/dev/mouse"
EndSection
Section "Monitor"
    Identifier  "My Monitor"
    HorizSync   31.5-50
    VertRefresh 40-90
vendorname "[My Monitor]"
modelname "[My Monitor]"
ModeLine "1024x768/60Hz" 65 1024 1032 1176 1344 768 771 777 806  -HSync -VSync
EndSection
Section "Device"
    Identifier  "ATI Radeon"
 Driver "fglrx"
 # === disable PnP Monitor ===
 #Option "NoDDC"
 # === disable/enable XAA/DRI ===
 Option "no_accel" "no"
 Option "no_dri" "no"
 # === Fire GL DDX driver module specific settings ===
 # === Screen Management ===
 Option "DesktopSetup" "0x00000000"
 # Option "Display2" "0"
 Option "HSync2" "unspecified"
 Option "VRefresh2" "unspecified"
 Option "GammaCorrectionI" "0x00000000"
 Option "GammaCorrectionII" "0x00000000"
 # === OpenGL specific profiles/settings ===
 Option "Capabilities" "0x00000000"
 # === Video Overlay for the Xv extension ===
 Option "VideoOverlay" "on"
 # === OpenGL Overlay ===
 # Note: When OpenGL Overlay is enabled, Video Overlay
 # will be disabled automatically
 Option "OpenGLOverlay" "off"
 BusID "PCI:1:0:0" # vendor=1002, device=514c
EndSection
Section "Screen"
    Identifier  "Screen 1"
    Device      "ATI Radeon"
    Monitor     "My Monitor"
    DefaultColorDepth 24
    Subsection "Display"
        Depth       8
        Modes "1024x768/60Hz" "800x600" "640x480"
                Virtual 0 0
    EndSubsection
        Depth       16
                Virtual 0 0
    EndSubsection
        Depth       24
                Virtual 0 0
    EndSubsection
        Depth       32
                Virtual 0 0
    EndSubsection
EndSection
Section "ServerLayout"
    Identifier  "Simple Layout"
    Screen "Screen 1"
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
        Identifier "Keyboard"
        Option "XkbModel" "pc105"
        Driver "keyboard"
EndSection
Identifier "Mouse"
        Option "Device" "/dev/psaux"
        Driver "mouse"
        Option "Emulate3Buttons"
EndSection
Quand je lance X, il me sort :
root@EvaZion:/home/damien# X -verbose
XFree86 Version 4.2.0 / X Window System
(protocol Version 11, revision 0, vendor release 6600)
Release Date: 18 January 2002
        If the server is older than 6-12 months, or if your card is
        newer than the above date, look for a newer version before
        reporting problems.  (See http://www.XFree86.Org/)
Build Operating System: Linux 2.4.18 i686 [ELF]
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Sun Dec 29 15:17:18 2002
(==) Using config file: "/etc/X11/XF86Config"
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) |   |-->Monitor "My Monitor"
(**) |   |-->Device "ATI Radeon"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) XKB: rules: "xfree86"
(**) XKB: model: "pc101"
(**) XKB: layout: "fr"
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
        compiled for 4.2.0, module version = 1.0.0
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
        compiled for 4.2.0, module version = 0.1.0
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(--) PCI:*(1:0:0) ATI unknown chipset (0x4c66) rev 1, Mem @ 0xe8000000/27, 0xe0800000/16, I/O @ 0x9000/8
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
        compiled for 4.2.0, module version = 1.0.1
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
        compiled for 4.2.0, module version = 1.1.10
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(WW) Warning, couldn't open module fglrx
(EE) Failed to load module "fglrx" (module does not exist, 0)
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
(EE) No drivers available.
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to xfree86@xfree86.org.
et X ne démarre pas. Qu'est-ce qu'il se passe ? j'ai suivi ce guide : http://lea-linux.org/trucs/lire.php3?id=194n le module est bien chargé :
root@EvaZion:/home/damien# lsmod
Module                  Size  Used by    Tainted: P
fglrx                 140360   0  (unused)
et la carte vidéo est bien là :
root@EvaZion:/home/damien# lspci
01:00.0 VGA compatible controller: ATI Technologies Inc: Unknown device 4c66 (rev 01)
Merci de bien vouloir m'aider...
Posté le 29-12-2002 à 15:21:37  profilanswer
n°206027
Jar Jar
Intaigriste
Posté le 29-12-2002 à 15:34:28  profilanswer
Il ne faut pas XFree 4.3 pour les Radeon 9000 ?
« No question is too silly to ask, but, of course, some are too silly to answer. » -- Perl book
n°206029
[Albator]
MDK un jour, MDK toujours !
Posté le 29-12-2002 à 15:47:23  profilanswer
Xfree 4.3 intègre sans doute le driver opensource pour les radeon 9000; mais Ati propose sur son site un driver propriétaire pour XFree 4.2.0, en rpm uniquement ..
n°206038
Posté le 29-12-2002 à 16:14:16  answer
ça a changé...
J'ai lancé l'utilitaire fglrxconfig, j'ai copié le fichier fglrx.o dans /usr/X11R6/lib/modules/ et il me sort ça :
(II) LoadModule: "fglrx"
(II) Loading /usr/X11R6/lib/modules/fglrx.o
Not loading .modinfo
Not loading .rodata.str1.1
Not loading .rodata.str1.32
Not loading __ksymtab
(EE) LoadModule: Module fglrx does not have a fglrxModuleData data object.
(II) UnloadModule: "fglrx"
(II) Unloading /usr/X11R6/lib/modules/fglrx.o
(EE) Failed to load module "fglrx" (invalid module, 0)
(II) LoadModule: "mouse"
        Module class: XFree86 XInput Driver
        ABI class: XFree86 XInput driver, version 0.3
Fatal server error:
no screens found
Mai je ne comprends pas pk il charge le module... Normalement, c par le modprobe kon charge le module, pas par X.... Je ne pige pas...
n°206061
Posté le 29-12-2002 à 18:02:00  answer
Le guide était à chier....
Pour ceux ki ont une slackware et une ATI :
aller choper le rpm ici : http://mirror.ati.com/support/driv [...] dNext=Next
et installez-le comme ceci :
rpm -ivh --nodeps --force *.rpm
puis lancez fglrxconfig pour configurer XFree. Lancez startx et vala, ça rulez  :hello:
n°206081
Posté le 29-12-2002 à 19:07:48  answer
Donc, mon écran fonctionne bien, mais quand je lance X, mes autres consoles, qui st en framebuffer, st déformées :( Z'avez déjà eu ça ?
n°206088
[Albator]
Posté le 29-12-2002 à 19:30:15  profilanswer
Oui.
Je n'utilise plus le framebuffer.
n°206089
Posté le 29-12-2002 à 19:32:02  answer
[Albator] a écrit :
Oui.
bah wé mé c laid sans framebuffer... Cette solution ne me convient pas  :D
  Installation
radeon 8500 et perfs 3D avec les drivers DRIQuel drivers Nvidia?
[debian] Probleme a l'installation des drivers nvidia.[Drivers NVIDIA] Les derniers sont tout pourri !!
[linux] compatibilité et driversNouveaux drivers nVIDIA 41.91 lents et buggés?
Nouveaux drivers Nvidia pour LinuxXFree probleme avec drivers NVIDIA
ATI Radeon 9000 Mobility et drivers Linux ?
Plus de sujets relatifs à : Drivers ATI & ATI mobility radeon 9000
