5051 connectés
 Page :   1  2  3  4
[debian newb] premiere installation...
n°353852
benji123
Posté le 10-11-2003 à 11:38:16  profilanswer
g recup le fichier...mais sous win, en le lisant avec le bloc not...ca donne un truk infame (pas bien "rangé) :
[G]
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software" ),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"   # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "omit xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the Type1 and FreeType font modules
    Load        "type1"
    Load        "freetype"
# This loads the GLX module
#    Load       "glx"
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db" ).  There is normally
# no need to change the default.
    RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
#    FontPath   "/usr/X11R6/lib/X11/fonts/local/"
    FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath   "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
# The module search path.  The default path is shown here.
#    ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#    Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#    Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
#    Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
#    Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
#    Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
#    Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
#    Option "AllowNonLocalModInDev"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
# For most OSs the protocol can be omitted (it defaults to "Standard" ).
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
#    Option     "Protocol"      "Xqueue"
    Option "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#    Option "Xleds"      "1 2 3"
#    Option "LeftAlt"     "Meta"
#    Option "RightAlt"    "ModeShift"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#    Option "XkbModel"    "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#    Option "XkbModel"    "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#    Option "XkbLayout"   "de"
# or:
#    Option "XkbVariant"  "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#    Option "XkbOptions"  "ctrl:swapcaps"
# These are the default XKB settings for XFree86
#    Option "XkbRules"    "xfree86"
#    Option "XkbModel"    "pc101"
#    Option "XkbLayout"   "us"
#    Option "XkbVariant"  ""
#    Option "XkbOptions"  ""
#    Option "XkbDisable"
    Option "XkbModel" "pc104"
    Option "XkbLayout" "fr"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol"    "PS/2"
    Option "Device"      "/dev/mouse"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
#    Option "BaudRate" "9600"
#    Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
    Option "Emulate3Buttons"
#    Option "Emulate3Timeout"    "50"
# ChordMiddle is an option for some 3-button Logitech mice
#    Option "ChordMiddle"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices.  This is for example only.  Refer
# to the XF86Config man page for a description of the options.
# Section "InputDevice"
#    Identifier  "Mouse2"
#    Driver      "mouse"
#    Option      "Protocol"      "MouseMan"
#    Option      "Device"        "/dev/mouse2"
# EndSection
#    Identifier "spaceball"
#    Driver     "magellan"
#    Option     "Device"        "/dev/cua0"
# EndSection
#    Identifier "spaceball2"
#    Driver     "spaceorb"
# EndSection
#    Identifier "touchscreen0"
#    Driver     "microtouch"
#    Option     "Device"        "/dev/ttyS0"
#    Option     "MinX"          "1412"
#    Option     "MaxX"          "15184"
#    Option     "MinY"          "15372"
#    Option     "MaxY"          "1230"
#    Option     "ScreenNumber"  "0"
#    Option     "ReportingMode" "Scaled"
#    Option     "ButtonNumber"  "1"
#    Option     "SendCoreEvents"
# EndSection
#    Identifier "touchscreen1"
#    Driver     "elo2300"
#    Option     "MinX"          "231"
#    Option     "MaxX"          "3868"
#    Option     "MinY"          "3858"
#    Option     "MaxY"          "272"
#    Option     "ButtonThreshold"       "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
    HorizSync   31.5, 35.15, 35.5
#    HorizSync 30-64         # multisync
#    HorizSync 31.5, 35.2    # multiple fixed sync frequencies
#    HorizSync 15-25, 30-50  # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
    VertRefresh 50-70
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
Section "Device"
    Identifier "Standard VGA"
    VendorName "Unknown"
    BoardName "Unknown"
# The chipset line is optional in most cases.  It can be used to override
# the driver's chipset detection, and should not normally be specified.
#    Chipset "generic"
# The Driver line must be present.  When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module.  Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
    Driver     "vga"
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for.  When this line isn't present, a device
# section can only match up with the primary video device.  For PCI
# devices a line like the following could be used.  This line should not
# normally be included unless there is more than one video device
# intalled.
#    BusID      "PCI:0:10:0"
#    VideoRam 256
#    Clocks 25.2 28.3
EndSection
# Device configured by xf86config:
Section "Device"
    Identifier  "Matrox Millennium G400"
    Driver      "mga"
    #VideoRam    8192
    # Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen 1"
    Device      "Matrox Millennium G400"
    Monitor     "My Monitor"
    DefaultDepth 16
    Subsection "Display"
        Depth       8
        Modes       "640x480" "800x600" "1024x768" "1280x1024"
        ViewPort    0 0
    EndSubsection
        Depth       16
        ViewPort    0 0
    EndSubsection
        Depth       24
        ViewPort    0 0
    EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
    Identifier  "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.  In this example, screen 2 is located to the
# right of screen 1.
    Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection[/G]
voili voilou...
n°353853
benji123
Posté le 10-11-2003 à 11:39:38  profilanswer
Klaimant a écrit :
la cam, tu sous entends netmetting  [:aless]
msn 6.0 le fé "seul", enin peut-etre kil utilise netmeeting pour ca  :??: ... je sais pas faire autrement en tout cas :(
n°353854
GUG
Posté le 10-11-2003 à 11:41:11  profilanswer
et /var/log/Xfreeblabla :D ?
n°353855
Klaimant
Posté le 10-11-2003 à 11:43:13  profilanswer
et avec ca ca démarre pas ??
Fais le ou ne le fais pas, mais il n'y a pas d'essai !!!
n°353856
benji123
Posté le 10-11-2003 à 11:44:09  profilanswer
This is a pre-release version of XFree86, and is not supported in any
way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
 If the server is older than 6-12 months, or if your card is
 newer than the above date, look for a newer version before
 reporting problems.  (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.17 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Mon Nov 10 12:41:31 2003
(++) Using config file: "/etc/X11/newconfig"
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) |   |-->Monitor "My Monitor"
(**) |   |-->Device "Matrox Millennium G400"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "fr"
(**) XKB: layout: "fr"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
 XFree86 ANSI C Emulation: 0.1
 XFree86 Video Driver: 0.4
 XFree86 XInput driver : 0.2
 XFree86 Server Extension : 0.1
 XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.0.0
 Module class: XFree86 Font Renderer
 ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 0.1.0
 ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7190 card 0000,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7191 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:14:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:14:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
(II) PCI: 00:14:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:14:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
(II) PCI: 01:00:0: chip 102b,0525 card 102b,19d8 rev 04 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
 [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
 [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x8c (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
 [0] -1 0 0x40000000 - 0x408fffff (0x900000) MX[B]
(II) Bus 1 prefetchable memory range:
 [0] -1 0 0x42000000 - 0x43ffffff (0x2000000) MX[B]
(II) Bus -1: bridge is at (0:20:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) Matrox MGA G400 AGP rev 4, Mem @ 0x42000000/25, 0x40800000/14, 0x40000000/23
(II) Addressable bus resource ranges are
 [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
 [0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
 [1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
 [2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
 [3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
 [4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
 [5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
 [0] -1 0 0x44000000 - 0x47ffffff (0x4000000) MX[B]E
 [1] -1 0 0x40000000 - 0x407fffff (0x800000) MX[B](B)
 [2] -1 0 0x40800000 - 0x40803fff (0x4000) MX[B](B)
 [3] -1 0 0x42000000 - 0x43ffffff (0x2000000) MX[B](B)
 [4] -1 0 0x00001080 - 0x000010ff (0x80) IX[B]E
 [5] -1 0 0x000010a0 - 0x000010bf (0x20) IX[B]E
(II) PCI I/O resource overlap reduced 0x00001080 from 0x000010ff to 0x0000109f
(II) Active PCI resource ranges after removing overlaps:
 [4] -1 0 0x00001080 - 0x0000109f (0x20) IX[B]E
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
 [5] -1 0 0x44000000 - 0x47ffffff (0x4000000) MX[B]E
 [6] -1 0 0x40000000 - 0x407fffff (0x800000) MX[B](B)
 [7] -1 0 0x40800000 - 0x40803fff (0x4000) MX[B](B)
 [8] -1 0 0x42000000 - 0x43ffffff (0x2000000) MX[B](B)
 [9] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [10] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [11] -1 0 0x00001080 - 0x0000109f (0x20) IX[B]E
 [12] -1 0 0x000010a0 - 0x000010bf (0x20) IX[B]E
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
 Module class: XFree86 Server Extension
 ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "mga"
(II) Loading /usr/X11R6/lib/modules/drivers/mga_drv.o
(II) Module mga: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.0.1
 Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
 Module class: XFree86 XInput Driver
 ABI class: XFree86 XInput driver, version 0.2
(II) MGA: driver for Matrox chipsets: mga2064w, mga1064sg, mga2164w,
 mga2164w AGP, mgag100, mgag100 PCI, mgag200, mgag200 PCI, mgag400
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset mgag400 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
 [9] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
 [10] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
 [11] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
 [12] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [13] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [14] -1 0 0x00001080 - 0x0000109f (0x20) IX[B]E
 [15] -1 0 0x000010a0 - 0x000010bf (0x20) IX[B]E
 [16] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
 [17] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(**) MGA(0): Depth 16, (--) framebuffer bpp 16
(==) MGA(0): RGB weight 565
(II) Loading sub module "mga_hal"
(II) LoadModule: "mga_hal"
(WW) Warning, couldn't open module mga_hal
(II) UnloadModule: "mga_hal"
(EE) MGA: Failed to load module "mga_hal" (module does not exist, 0)
(II) MGA(0): Matrox HAL module not found - using builtin mode setup instead
(--) MGA(0): Chipset: "mgag400"
(==) MGA(0): Using AGP 1x mode
(--) MGA(0): Linear framebuffer at 0x42000000
(--) MGA(0): MMIO registers at 0x40800000
(--) MGA(0): Pseudo-DMA transfer window at 0x40000000
(==) MGA(0): BIOS at 0xC0000
(--) MGA(0): Video BIOS info block at offset 0x07A60
(WW) MGA(0): Video BIOS info block not detected!
(II) MGA(0): MGABios.RamdacType = 0x0
(==) MGA(0): Write-combining range (0x42000000,0x2000000)
(--) MGA(0): VideoRAM: 16384 kByte
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/X11R6/lib/modules/libi2c.a
(II) Module i2c: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.2.0
(==) MGA(0): Write-combining range (0x42000000,0x1000000)
(II) MGA(0): I2C bus "DDC" initialized.
(II) MGA(0): I2C device "DDC:ddc2" registered.
(II) MGA(0): I2C device "DDC:ddc2" removed.
(II) MGA(0): I2C Monitor info: (nil)
(II) MGA(0): end of I2C Monitor info
(--) MGA(0): No DDC signal
(II) MGA(0): DDC Monitor info: (nil)
(II) MGA(0): end of DDC Monitor info
(==) MGA(0): Using gamma correction (1.0, 1.0, 1.0)
(==) MGA(0): Min pixel clock is 12 MHz
(==) MGA(0): Max pixel clock is 300 MHz
(II) MGA(0): My Monitor: Using hsync value of 31.50 kHz
(II) MGA(0): My Monitor: Using hsync value of 35.15 kHz
(II) MGA(0): My Monitor: Using hsync value of 35.50 kHz
(II) MGA(0): My Monitor: Using vrefresh range of 50.00-70.00 Hz
(II) MGA(0): Clock range:  12.00 to 300.00 MHz
(II) MGA(0): Not using default mode "640x350" (hsync out of range)
(II) MGA(0): Not using default mode "640x400" (hsync out of range)
(II) MGA(0): Not using default mode "720x400" (hsync out of range)
(II) MGA(0): Not using default mode "640x480" (hsync out of range)
(II) MGA(0): Not using default mode "800x600" (hsync out of range)
(II) MGA(0): Not using default mode "1024x768" (vrefresh out of range)
(II) MGA(0): Not using default mode "1024x768" (hsync out of range)
(II) MGA(0): Not using default mode "1152x864" (hsync out of range)
(II) MGA(0): Not using default mode "1280x960" (hsync out of range)
(II) MGA(0): Not using default mode "1280x1024" (hsync out of range)
(II) MGA(0): Not using default mode "1600x1200" (hsync out of range)
(II) MGA(0): Not using default mode "1792x1344" (hsync out of range)
(II) MGA(0): Not using default mode "1856x1392" (hsync out of range)
(II) MGA(0): Not using default mode "1920x1440" (hsync out of range)
(II) MGA(0): Not using default mode "1400x1050" (hsync out of range)
(II) MGA(0): Not using mode "1024x768" (no mode of this name)
(II) MGA(0): Not using mode "1280x1024" (no mode of this name)
(--) MGA(0): Virtual size is 800x600 (pitch 800)
(**) MGA(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) MGA(0): Modeline "640x480"   25.20  640 656 752 800  480 490 492 525 -hsync -vsync
(**) MGA(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) MGA(0): Modeline "800x600"   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync
(==) MGA(0): DPI set to (75, 75)
(II) MGA(0): YDstOrg is set to 0
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
 ABI class: XFree86 ANSI C Emulation, version 0.1
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
 [0] 0 0 0x40000000 - 0x407fffff (0x800000) MX[B]
 [1] 0 0 0x40800000 - 0x40803fff (0x4000) MX[B]
 [2] 0 0 0x42000000 - 0x43ffffff (0x2000000) MX[B]
 [3] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
 [4] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
 [5] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
 [6] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
 [7] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
 [8] -1 0 0x44000000 - 0x47ffffff (0x4000000) MX[B]E
 [9] -1 0 0x40000000 - 0x407fffff (0x800000) MX[B](B)
 [10] -1 0 0x40800000 - 0x40803fff (0x4000) MX[B](B)
 [11] -1 0 0x42000000 - 0x43ffffff (0x2000000) MX[B](B)
 [12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
 [13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
 [14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
 [15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
 [16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
 [17] -1 0 0x00001080 - 0x0000109f (0x20) IX[B]E
 [18] -1 0 0x000010a0 - 0x000010bf (0x20) IX[B]E
 [19] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
 [20] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(--) MGA(0): 16 DWORD fifo
(==) MGA(0): Default visual is TrueColor
(II) MGA(0): Using 9885 lines for offscreen memory.
(II) MGA(0): Using XFree86 Acceleration Architecture (XAA)
 Screen to screen bit blits
 Solid filled rectangles
 Solid filled trapezoids
 8x8 mono pattern filled rectangles
 8x8 mono pattern filled trapezoids
 Indirect CPU to Screen color expansion
 Screen to Screen color expansion
 Solid Lines
 Dashed Lines
 Scanline Image Writes
 Offscreen Pixmaps
 Driver provided FillMono8x8PatternRects replacement
 Setting up tile and stipple cache:
  32 128x128 slots
  32 256x256 slots
  16 512x512 slots
(==) MGA(0): Backing store disabled
(==) MGA(0): Silken mouse enabled
(II) MGA(0): Using overlay video
(==) MGA(0): Direct rendering disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(**) Option "Protocol" "PS/2"
(**) Mouse1: Protocol: "PS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/mouse"
(EE) xf86OpenSerial: Cannot open device /dev/mouse
 No such file or directory.
(EE) Mouse1: cannot open input device
(EE) PreInit failed for input device "Mouse1"
(II) UnloadModule: "mouse"
(II) Keyboard "Keyboard1" handled by legacy driver
(WW) No core pointer registered
No core pointer
Fatal server error:
failed to initialize core devices
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
edit : c le bon fichier maintenant
Message édité par benji123 le 10-11-2003 à 11:53:18
n°353857
GUG
Posté le 10-11-2003 à 11:49:27  profilanswer
bah il dit que c'est au niveau de la sourie que ca deconne ...
essaye de remplacer
/dev/mouse par /dev/psaux
Message édité par GUG le 10-11-2003 à 11:50:45
n°353859
Klaimant
Posté le 10-11-2003 à 11:50:01  profilanswer
Section "Module"
    SubSection  "extmod"
    EndSubSection
    Load        "type1"
    Load        "freetype"
    Load        "glx"
EndSection
Section "Files"
    FontPath   "/usr/X11R6/lib/X11/fonts/artwiz/:unscaled"
EndSection
EndSection
    Driver      "Keyboard"
    Option "XkbModel"   "pc105"
EndSection
    Identifier  "Mouse1"
    Driver      "mouse"
    Option  "Protocol"    "ImPS/2"
    Option      "Buttons" "5"
    Option      "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
    Identifier  "liyama"
    HorizSync   65-90
    VertRefresh 75-110
EndSection
Section "Device"
    Identifier  "G3"
   Driver      "nvidia"
#    Driver "nv"
#    VideoRam    65536
#    Option     "DPMS"
#    Option     "NvAgp" "2"
    Option      "NoLogo" "on"
#   Option     "TwinView" "on"
 Option "AGPMode" "4"
 Option  "AGPFastWrite" "True"
 Option "EnablePageFlip" "True"
EndSection
Section "Screen"
    Device      "G3"
    Monitor     "liyama"
    DefaultDepth 24
        Depth       8
        ViewPort    0 0
    EndSubsection
        Depth       16
        Modes       "1280x1024" "640x480" "800x600" "1024x768"
        ViewPort    0 0
    EndSubsection
        Depth       24
        Modes       "1280x1024" "1024x768" "800x600" "640x480"
        ViewPort    0 0
    EndSubsection
EndSection
    Identifier "Main Layout"
    Screen "Screen 1"
EndSection
Mon miens qui marche avec mon 17 '' liyama et ma G3
Message édité par Klaimant le 10-11-2003 à 11:50:35
n°353860
benji123
Posté le 10-11-2003 à 11:50:13  profilanswer
c pas le bion fichier de log...j'edit....
n°353862
Klaimant
Posté le 10-11-2003 à 11:53:35  profilanswer
g mis imPS/2 pour le driver de la souris moi et je suis en ps2 avec une mx 300
n°353866
benji123
Posté le 10-11-2003 à 11:55:11  profilanswer
moi ma souris c une pov logitch 3boutton+roulette..classik :(
n°353869
Klaimant
Posté le 10-11-2003 à 11:56:34  profilanswer
ca a rien à voir j'ai deux boutons et une molette ausssi :D
n°353871
philou_a7
\_o&lt; coin ! &gt;o_/
Posté le 10-11-2003 à 11:59:26  profilanswer
crée un lien vers ton device souris correct dans /dev et ca ira beaucoup mieux ;)
y a des chances pour que ce soit /dev/psaux ou /dev/misc/psaux ;)
le pilote pour ta souris est très probablement "imPS/2"
n°353872
benji123
Posté le 10-11-2003 à 11:59:29  profilanswer
lol
bon bha j'essaye de remplcer /dev/mouse par /dev/psaux....
n°353877
Klaimant
Posté le 10-11-2003 à 12:03:52  profilanswer
    Identifier  "Mouse1"
    Driver      "mouse"
EndSection
Mets ca pour ta souris, je suis sur ke ca marchera mieux
n°353879
philou_a7
Posté le 10-11-2003 à 12:04:46  profilanswer
    Identifier  "Mouse1"
    Driver      "mouse"
EndSection
pas tant qu'il aura pas un truc valide pour sa ligne "Device"
n°353880
GUG
Posté le 10-11-2003 à 12:05:19  profilanswer
essaye de remplacer
n°353881
Klaimant
Posté le 10-11-2003 à 12:05:23  profilanswer
Ben si il a une souris ps2 avec molette c comme moi ...
n°353882
benji123
Posté le 10-11-2003 à 12:05:34  profilanswer
bon... ca avance :D...g un ecran (a vue c du 640)avec un fond noir et blanc (genre tissu..mais vous voyez de koi je parle)...et la souris qui "MARCHE" avec un gros pointeur en forme de croix....
ca c le bon coté...le mové coté c que je ne "que" bouger la souris...rien faire dautre lol...
n°353883
GUG
Posté le 10-11-2003 à 12:06:16  profilanswer
apt-get install fluxbox menu
et pour avoir plus que le 640 il faut que tu specifie en premier avec quelle resolution X demarre par defaut
Message édité par GUG le 10-11-2003 à 12:07:00
n°353884
benji123
Posté le 10-11-2003 à 12:07:32  profilanswer
dans une autre console je fé ca?  :??:
n°353885
Klaimant
Posté le 10-11-2003 à 12:07:52  profilanswer
daccord ton X marche, maintenant il faut que tu installes un windowmanager :D
n°353890
benji123
Posté le 10-11-2003 à 12:10:30  profilanswer
ca me plait de plus en plus :)  :)  :)
n°353891
benji123
Posté le 10-11-2003 à 12:12:28  profilanswer
Reading Package Lists... Done
Building Dependency Tree... Done
E: Couldn't find package fluxbox
lol...
n°353892
Klaimant
sinon tu peux déjà lancer des applis en x :
xterm -display 0:0
n°353893
Klaimant
Posté le 10-11-2003 à 12:12:52  profilanswer
apt-cache search fluxbox, il faut apprendre à trouver seul :D
n°353894
benji123
Posté le 10-11-2003 à 12:13:29  profilanswer
xterm -display 0:0
mdr...une fenetre blanche?
n°353895
Klaimant
Posté le 10-11-2003 à 12:15:06  profilanswer
un xterm :D
xeyes -display 0:0 (aucun interet mais bon :D)
n°353896
benji123
Posté le 10-11-2003 à 12:17:32  profilanswer
Klaimant a écrit :
un xterm :D
wwaououuhhh...c coooll..enfin kchose sur cette machine...ca faisait trois jours que y'a rien lol
n°353897
Klaimant
Posté le 10-11-2003 à 12:22:20  profilanswer
Ya tout sur la machine, mais juste pas en X
n°353898
benji123
Posté le 10-11-2003 à 12:23:17  profilanswer
gnome c pas ca????
gnome c bien "gdm"...j'arrive pas a l'arretr gdm..il demarre au demarage de la machine...komment je peux l'arretr?
n°353899
Klaimant
Posté le 10-11-2003 à 12:26:00  profilanswer
vi
ctrl alt backspace
n°353902
benji123
Posté le 10-11-2003 à 12:29:23  profilanswer
Klaimant a écrit :
vi
ctrl alt backspace
pour rebooter ca non :??:
n°353903
Klaimant
Posté le 10-11-2003 à 12:30:09  profilanswer
pas ctrl alt suppr
ctrl alt backspace dans la fenetre X tue le x
n°353910
benji123
Posté le 10-11-2003 à 12:47:06  profilanswer
sinon gnome c bien un windows manager..cad, y'a "pleins" d'outil "grafik"???
oula..je pars, je re ds la swaree....
n°353912
Klaimant
Posté le 10-11-2003 à 12:48:11  profilanswer
oui c ca, a mon avis gnome c tres bien pour toi :D
n°353914
benji123
Posté le 10-11-2003 à 12:49:03  profilanswer
sinon...komment imposer mon fichier de config a Xfree86????
edit: vu que gdm demarre tout seul au boot...
Message édité par benji123 le 10-11-2003 à 12:50:47
n°353916
benji123
Posté le 10-11-2003 à 12:49:54  profilanswer
bah voui....mdr
n°353922
benji123
Posté le 10-11-2003 à 12:57:18  profilanswer
Klaimant a écrit :
vi
ctrl alt backspace
ca ca me fait un rebboooottttttt :cry:  :cry:  :cry:
n°353927
Klaimant
Posté le 10-11-2003 à 13:03:11  profilanswer
tu le nommes XF86config et c parti :D
n°353928
Klaimant
Posté le 10-11-2003 à 13:03:35  profilanswer
Il faut le faire quand tu es dans ton X :D
n°353949
Jubijub
Parce que je le VD bien
Posté le 10-11-2003 à 13:35:11  profilanswer
remarque moi aussi ca reboot des fois quand je le fais...
au pire, tu peux tjs avoir une console normale en faisant CTRL+ALT+F1 ou F2
tu reviens sous X en allant sur la "console 7" cad CTRL+ALT+F7
Jubi Photos : Flickr - 500px
 Page :   1  2  3  4
probleme pour me connecter a l'adsl sous debian (modem ethernet)[Debian] Ip dynamique
[Debian] Passer de stable à testing[Debian]Installation Alsa, que faut il
configurer une carte son vt8233 sous debian[debian] lister les paquages installer par source
Installation d'un Serveur Internet en Linux Mandrake 9.1[DEBIAN] E: Package XXX has no installation candidat et pourtant...
Plus de sujets relatifs à : [debian newb] premiere installation...
