4750 connectés
  Linux et OS Alternatifs
  Installation
  debian et /etc/apt/preferences: je comprends plus trop
n°338306
Piksou
Posté le 12-10-2003 à 21:43:39  profilanswer
Sonata:~# cat /etc/apt/sources.list
# the main Debian packages.  Uncomment the deb-src line if you
# want 'apt-get source' to work with most packages.
deb http://ftp.fr.debian.org/debian/ stable main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ stable main contrib non-free
# the non-US Debian packages.  Uncomment the deb-src line if you
# want 'apt-get source' to work with non-US packages.
deb http://ftp.fr.debian.org/debian-non-US stable/non-US main contrib non-free
deb-src http://ftp.fr.debian.org/debian-non-US stable/non-US main contrib non-free
deb http://security.debian.org/ stable/updates main contrib non-free
# sid
deb http://ftp.fr.debian.org/debian/ unstable main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ unstable main contrib non-free
deb http://ftp.fr.debian.org/debian-non-US unstable/non-US main contrib non-free
deb-src http://ftp.fr.debian.org/debian-non-US unstable/non-US main contrib non-free
# Mozilla FIrebird 0.6.1 pour woody
deb http://dpt.tuxfamily.org/pub woody main contrib non-free
# Samba 2.2.8a pour woody
deb http://people.debian.org/~peloy/samba stable main
Sonata:~# cat /etc/apt/preferences
Package: *
Pin: release o=Debian,a=stable
Pin-Priority: 900
Package: *
Pin: release o=Debian,a=unstable
Pin-Priority: 300
Package: *
Pin-Priority: -1
Package:samba
Pin: version 2.2.8a*
Pin-Priority: 1005
Package:smbfs
Pin-Priority: 1005
Package:smbclient
Pin-Priority: 1005
Package:samba-common
Pin-Priority: 1005
Package:mozilla-firebird
Pin: version 0.6.1-0.*
Pin-Priority: 1005
Package:shorewall
Pin: version 1.4.*
Pin-Priority: 1005
Package:dhcp3*
Pin-Priority: 1005
Package:webmin*
Pin-Priority: 1005
Sonata:~#
bon, en bonne logique, on devrait avoir webmin et tous les webmin-foo qui sont prio 1005 pour ceux en unstable et ceux installés (0.97 et des poussières contre 1.0 et des poussières en unstable) en prio 100, donc une maj de webmin et de ses copains
or ça marche pas :/
Pin-Priority: 1005
Sonata:~# apt-get dist-upgrade
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
Calcul de la mise à jour... Fait
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Sonata:~# apt-get upgrade
Sonata:~#
j'ai relu le howto plus 2-3 doc sur le net mais je comprends rien :/ ça devrait marcher :/
q1 à une idée ?
Message édité par Piksou le 12-10-2003 à 21:44:26
« Le verbe "aimer" est le plus compliqué de la langue. Son passé n'est jamais simple, son présent n'est qu'imparfait et son futur toujours conditionnel. » Jean Cocteau
n°338428
void_ppc
Posté le 13-10-2003 à 07:12:07  profilanswer
apt-get install webmin/unstable ou
apt-get install webmin -t unstable
peut-être ? (solution non-élégante)
n°338606
Piksou
Posté le 13-10-2003 à 15:11:15  profilanswer
oui, ça l'installera, c'est sur mais quid des MAJ ? je vais pas refaire un apt-get install webmin -t unstable à chaque apt-get upgrade, c'est pas une solution.... pour que la ùay se fasse, il faut être sur que la prio des paquets unstable est > à celle des stables non ?
n°345909
Jubijub
Parce que je le VD bien
Posté le 28-10-2003 à 12:02:40  profilanswer
j'ai le même pb...
Jubi Photos : Flickr - 500px
  Installation
[Debian] Installation postgresql > cassé ?Packages debian
installation des pilotes nforce2 sur une debian (2.4.18)Installation du sata sous debian avec a7n8x dx, need help plz !!!
[Debian SID] KDE3 et co : installer ksysguardAjout d'une deuxieme carte réseau : help (Debian]
[Debian] Mozilla plante :( Code erreur 11 a priori.[Debian Sid] La fonction C sqrt
Debian testing + KDE 3 (Debian unstable)"Retirer" une install de Speedtouch sur Debian
Plus de sujets relatifs à : debian et /etc/apt/preferences: je comprends plus trop
