7414 connectés
  Linux et OS Alternatifs
  Installation
  [debian sid] pb apt lors du passage woody - sid
n°256275
chaos0007
Posté le 30-04-2003 à 01:01:24  profilanswer
bonjour voila je viens de me racheter un dd car le dernier a mouru :-( et j'ai reinstalle une sid dessus. malheureusement g une erreur lorsque je passe de la woody a la sid : qd je fais apt-get dist-upgrade g :
Reading Package Lists... Done
Building Dependency Tree... Done
Calculating Upgrade... Done
3 packages upgraded, 0 newly installed, 0 to remove and 0  not upgraded.
87 packages not fully installed or removed.
Need to get 0B/2347kB of archives. After unpacking 77.8kB will be used.
Do you want to continue? [Y/n] y
(Reading database ... 21324 files and directories currently installed.)
Preparing to replace python2.1 2.1.3-3 (using .../python2.1_2.1.3-18_i386.deb) ...
Unpacking replacement python2.1 ...
update-menus: relocation error: update-menus: symbol _ZNSt9basic_iosIcSt11char_traitsIcEE4initEPSt15basic_streambufIcS1_E, version GLIBCPP_3.2 not defined in file libstdc++.so.5 with link time reference
dpkg: warning - old post-removal script returned error exit status 127
dpkg - trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/python2.1_2.1.3-18_i386.deb (--unpack):
 subprocess new post-removal script returned error exit status 127
dpkg: error while cleaning up:
 subprocess post-removal script returned error exit status 127
Preparing to replace xchat 1.8.9-0woody2 (using .../xchat_2.0.1-3_i386.deb) ...
Unpacking replacement xchat ...
dpkg: error processing /var/cache/apt/archives/xchat_2.0.1-3_i386.deb (--unpack):
Preparing to replace xterm 4.1.0-16 (using .../xterm_4.2.1-6_i386.deb) ...
Unpacking replacement xterm ...
dpkg: error processing /var/cache/apt/archives/xterm_4.2.1-6_i386.deb (--unpack):
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
je ne peux pas retirer ces packages g essayé de virer libstdc mais ca a foiré avt de le supprimer
est ce que c un défaut temporaire qui va etre corrige ou ca vient de ma config ??
n°256277
911GT3
en roue libre
Posté le 30-04-2003 à 01:09:49  profilanswer
j'ai le même problème sur d'autres packages utilisant la libstdc++5
doit simplement y avoir un raté ;)
n°256334
Jar Jar
Intaigriste
Posté le 30-04-2003 à 10:30:28  profilanswer
http://lists.debian.org/debian-dev [...] 02308.html
« No question is too silly to ask, but, of course, some are too silly to answer. » -- Perl book
n°256375
chaos0007
Posté le 30-04-2003 à 12:37:44  profilanswer
ca marche impeccable merci bcp
  Installation
[Debian]Lecture numérique des CD audio ?debian : quelques petits soucis : apmd, gdm, et d'autres ensuite...
[Debian] Probleme de Kernel...debian linux : bienvenue dans le monde des dépendances
Problemes pour lancer mplyer sur une debian woody [Debian] Probleme de clavier
Debian - Carte Reseau a l'install ...kernel panic avec 2.4.20 debian + preempt
[Debian-Sarge] Pb dependance avec apt-get
Plus de sujets relatifs à : [debian sid] pb apt lors du passage woody - sid
