5595 connectés
  Linux et OS Alternatifs
  Installation
  [Debian][X][Ordinosaure] Impossible de lancer X
n°473393
Toucouch
Posté le 07-05-2004 à 14:51:06  profilanswer
J'essaie depuis un certain temps déjà d'installer une Debian sur un vieux Cyrix 166+ (133MHz, 32Mo RAM, 1,5Go DD). J'ai déjà réussi à installer un système qui fonctionne pas trop mal ainsi que quelques applications texte comme Vim (on ne rit pas!).
Lors de l'install', "l'assistant" Debian m'a proposé d'installer X, ce que j'ai accepté. Mais ne fois l'install' complète, quand je fais startx j'obtiens:
warning: process set to nice value 0 instead of -10 as requested
This is a pre-release version of XFree86, and is not supported in any
way.  Bugs may be reported to XFree86@XFree86.Org and patches submitted
to fixes@XFree86.Org.  Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
 If the server is older than 6-12 months, or if your card is
 newer than the above date, look for a newer version before
 reporting problems.  (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.17 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Thu Apr 29 19:30:30 2004
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Generic Monitor"
(**) |   |-->Device "Generic Video Card"
(**) |-->Input Device "Generic Keyboard"
(**) XKB: rules: "xfree86"
(**) XKB: model: "pc104"
(**) XKB: layout: "fr"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Generic Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
 Entry deleted from font path.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.0.0
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 0.1.0
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(--) PCI:*(0:9:0) S3 ViRGE rev 6, Mem @ 0xf4000000/26
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.1.9
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libpex5.a
(II) Module pex5: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 1.13.0
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/extensions/libxie.a
(II) Module xie: vendor="The XFree86 Project"
(II) Loading /usr/X11R6/lib/modules/drivers/vga_drv.o
(II) Module vga: vendor="The XFree86 Project"
 compiled for 4.1.0.1, module version = 4.0.0
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
(II) VGA: Generic VGA driver (version 4.0) for chipsets: generic
(--) Assigning device section with no busID to primary device
(--) Chipset generic found
(**) VGA(0): Depth 16, (--) framebuffer bpp 16
(==) VGA(0): RGB weight 565
(==) VGA(0): Default visual is TrueColor
(==) VGA(0): Using gamma correction (1.0, 1.0, 1.0)
(==) VGA(0): videoRam: 256 kBytes.
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
(--) VGA(0): Pixel clocks available:
(--) VGA(0): pixel clocks:  25.180  28.322  25.180  28.450
(II) VGA(0): Generic Monitor: Using hsync range of 28.00-38.00 kHz
(II) VGA(0): Generic Monitor: Using vrefresh range of 43.00-72.00 Hz
(II) VGA(0): Not using default mode "640x350" (insufficient memory for mode)
(II) VGA(0): Not using default mode "640x400" (insufficient memory for mode)
(II) VGA(0): Not using default mode "720x400" (insufficient memory for mode)
(II) VGA(0): Not using default mode "640x480" (insufficient memory for mode)
(II) VGA(0): Not using default mode "800x600" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1024x768" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1152x864" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1280x960" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1280x1024" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1600x1200" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1792x1344" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1856x1392" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1920x1440" (insufficient memory for mode)
(II) VGA(0): Not using default mode "1400x1050" (insufficient memory for mode)
(WW) VGA(0): Mode pool is empty
(==) VGA(0): Virtual size is 320x200 (pitch 320)
(**) VGA(0): Built-in mode "Generic 320x200 default mode": 12.6 MHz (scaled from 25.2 MHz), 31.5 kHz, 70.2 Hz (VScan)
(++) VGA(0): DPI set to (100, 100)
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
Fatal server error:
AddScreen/ScreenInit failed for driver 0
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
X connection to :0.0 broken (explicit kill or server shutdown).
Donc si j'en crois le log, il s'agit d'un problème de pilote.
J'ai bien essayé de reconfigurer XFree en précisant bien quelle état ma carte graphique (Stealth 3D 2000: elle est bien dans la liste des cartes de xf86config), mais ça n'a rien changé...
Des idées?
D'avance merci.
n°473410
danny92
To beer or not to beer
Posté le 07-05-2004 à 15:00:20  profilanswer
T'es sûr que ta carte n'a que 256Ko de mémoire vidéo ?
Parce que là avec aussi peu de mémoire vidéo définie dans le fichier de config et en mode TrueColor (16M de couleurs), il te rejette tous les modes videos.
Mets la bonne valeur pour la mémoire vidéo (Essaye 4Mo déjà...) ou sinon descends en 16 ou 256 couleurs dans ton XF86Config-4 pour commencer.
Sinon t'as le driver VGA de base, essaye de trouver ta carte avec XF86Config
Message édité par danny92 le 07-05-2004 à 15:08:35
n°473429
Toucouch
Posté le 07-05-2004 à 15:12:31  profilanswer
Bien vu!
C'est bizarre, il me semblait l'avoir configuré en 256 couleurs... :??: Enfin, vu que j'ai dû le reconfigurer 3 ou 4 fois...
Ceci dit, je suis en 640x480 (ou peut-être même moins!): c'est ignoble!!!
n°473432
Toucouch
Posté le 07-05-2004 à 15:13:20  profilanswer
Au fait, merci pour ton aide! :jap:
Et je vais quand même tâcher de faire mieux!
  Installation
pb pour lancer kmail, korganiser... sous mandrake10 [reglé][resolu] Debian, ext3 reboot en continue
[Debian] Pk il l'active pas ma partition...Impossible d'accéder à l'interface graphique de Cups
accélération 3D sous debian testing avec le driver nvidia propriolancer un programme dans un terminal
[Debian Sid][2.6.5] Freeze USB[Debian] Quelle image télécharger ?
Boot Debian & WinXP qui sont sur deux HD différents avec Lilo
Plus de sujets relatifs à : [Debian][X][Ordinosaure] Impossible de lancer X
