6031 connectés
  Linux et OS Alternatifs
  Installation
  conflit de versions libgdal1
n°845959
simogeo
j'ai jamais tué de chats, ...
Posté le 26-09-2006 à 12:09:08  profilanswer
yo !!
sous debian sarge, j'essaie d'installer un package....
magnificbob:/home/simon# dpkg -i libgdal1-1.3.2-grass_1.3.2-1_i386.deb
Selecting previously deselected package libgdal1-1.3.2-grass.
(Reading database ... 47646 files and directories currently installed.)
Unpacking libgdal1-1.3.2-grass (from libgdal1-1.3.2-grass_1.3.2-1_i386.deb) ...
dpkg: dependency problems prevent configuration of libgdal1-1.3.2-grass:
 libgdal1-1.3.2-grass depends on libgdal1-1.3.2; however:
  Package libgdal1-1.3.2 is not installed.
 libgdal1-1.3.2-grass depends on libstdc++6 (>= 4.1.0); however:
  Package libstdc++6 is not installed.
 libgdal1-1.3.2-grass depends on grass (>= 6.0.2-5); however:
  Version of grass on system is 6.0.0-1.
dpkg: error processing libgdal1-1.3.2-grass (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
donc j'installe le-dit package .... :
magnificbob:/home/simon# dpkg -i libgdal1-1.3.2_1.3.2-2_i386.deb
dpkg: considering removing libgdal1 in favour of libgdal1-1.3.2 ...
dpkg: no, cannot remove libgdal1 (--auto-deconfigure will help):
 libgrass depends on libgdal1 (>= 1.2.0)
  libgdal1 is to be removed.
dpkg: regarding libgdal1-1.3.2_1.3.2-2_i386.deb containing libgdal1-1.3.2:
 libgdal1-1.3.2 conflicts with libgdal1
  libgdal1 (version 1.2.6-1) is installed.
dpkg: error processing libgdal1-1.3.2_1.3.2-2_i386.deb (--install):
 conflicting packages - not installing libgdal1-1.3.2
alors que faire? [:dawa]
  Installation
[Résolu]-[réseau][NAS]conflit de droits FTP/MOUNT ?cherche versions linux
conflit kaffeine-mplayerVersions de MySQL sur Mandriva 2006.0
DEBIAN : installation de paquet impossible (conflit de version)carte wifi (pour changer...) et conflit usb
Où trouver les anciennes versions de wine ?Suse et ses versions.
logiciel de suivi des versionscomparer 2 versions de qt
Plus de sujets relatifs à : conflit de versions libgdal1
