4653 connectés
  Linux et OS Alternatifs
  Installation
  Pb de configuration modem USB
n°334984
filou75
Posté le 05-10-2003 à 17:06:06  profilanswer
Je suis allé sur la FAQ http://eciadsl.flashtux.org/faq.php mais je  n'arrive toujours pas à configurer mon modem.
Si quelqu'un peut m'aider via ce message, merci beaucoup !
[philippe@Betton philippe]$ su root
Password:
[root@Betton philippe]# eciconf.sh
[root@Betton philippe]# startmodem
setting up USB support (1/5)..
ehci-hcd seems to be present trying to remove it...
ehci-hcd removed successfully
loading OHCI support
/lib/modules/2.4.21-0.13mdk/kernel/drivers/usb/usb-ohci.o.gz: init_module: No such device
Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
      You may find more information in syslog or the output from dmesg
modprobe: insmod /lib/modules/2.4.21-0.13mdk/kernel/drivers/usb/usb-ohci.o.gz failed
modprobe: insmod usb-ohci failed
couldn't load usb-ohci module
n_hdlc loaded successfully
loading firmware (2/5)..
/proc/bus/usb/002/000: No such file or directory
/proc/bus/usb/002/003: No such file or directory
GlobeSpan USB ADSL WAN Modem compatible modem found (in 2015ms)
ECI load 1: success
firmware loaded successfully
setting up modem (3/5)..
ECI load 2: success
synchronization successful
connecting modem (4/5)..
using channel 1
Using interface ppp0
Connect: ppp0 <--> /dev/pts/2
Looking for secret in /etc/ppp/pap-secrets for client garphilippe server (null)
Got client garphilippe
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
Looking for secret in /etc/ppp/chap-secrets for client garphilippe server (null)
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xd7fea5a4>]
rcvd [LCP ConfReq id=0x7d <mru 1500> <auth chap MD5> <magic 0x85c0004>]
sent [LCP ConfAck id=0x7d <mru 1500> <auth chap MD5> <magic 0x85c0004>]
rcvd [LCP ConfRej id=0x1 <asyncmap 0x0>]
sent [LCP ConfReq id=0x2 <magic 0xd7fea5a4>]
rcvd [LCP ConfAck id=0x2 <magic 0xd7fea5a4>]
rcvd [CHAP Challenge id=0x1 <0d896188c3c5f3309486e06215754fe8>, name = "BSREN202"]
Looking for secret in /etc/ppp/chap-secrets for client garphilippe server BSREN202
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [CHAP Response id=0x1 <13af27539faf2890b9692eccf295db2f>, name = "garphilippe"]
rcvd [CHAP Failure id=0x1 "Authentication Failed."]
Remote message: Authentication Failed.
CHAP authentication failed
sent [LCP TermReq id=0x3 "Failed to authenticate ourselves to peer"]
rcvd [LCP TermReq id=0x7e]
sent [LCP TermAck id=0x7e]
rcvd [LCP TermReq id=0xff]
sent [LCP TermAck id=0xff]
sent [LCP TermReq id=0x4 "Failed to authenticate ourselves to peer"]
Connection terminated.
using channel 2
Connect: ppp0 <--> /dev/pts/3
Script /usr/local/bin/pppoeci -vpi 8 -vci 35 -vendor 0x0915 -product 0x8000 -mode VCM_RFC2364 finished (pid 5222), status = 0x0
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [LCP ConfReq id=0x5 <asyncmap 0x0> <magic 0x86fcb2a9>]
rcvd [LCP ConfReq id=0x72 <mru 1500> <auth chap MD5> <magic 0x85c0207>]
sent [LCP ConfAck id=0x72 <mru 1500> <auth chap MD5> <magic 0x85c0207>]
rcvd [LCP ConfRej id=0x5 <asyncmap 0x0>]
sent [LCP ConfReq id=0x6 <magic 0x86fcb2a9>]
rcvd [LCP ConfAck id=0x6 <magic 0x86fcb2a9>]
rcvd [CHAP Challenge id=0x1 <f2456b620632be694f9596db7ffa43dc>, name = "BSREN202"]
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [CHAP Response id=0x1 <1192857050218c28ad9a1b9d2b85fd52>, name = "garphilippe"]
sent [LCP TermReq id=0x7 "Failed to authenticate ourselves to peer"]
rcvd [LCP TermReq id=0x73]
sent [LCP TermAck id=0x73]
sent [LCP TermReq id=0x8 "Failed to authenticate ourselves to peer"]
using channel 3
Script /usr/local/bin/pppoeci -vpi 8 -vci 35 -vendor 0x0915 -product 0x8000 -mode VCM_RFC2364 finished (pid 5237), status = 0x0
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [LCP ConfReq id=0x9 <asyncmap 0x0> <magic 0xbde041d>]
rcvd [LCP ConfReq id=0xa0 <mru 1500> <auth chap MD5> <magic 0x85c0407>]
sent [LCP ConfAck id=0xa0 <mru 1500> <auth chap MD5> <magic 0x85c0407>]
rcvd [LCP ConfRej id=0x9 <asyncmap 0x0>]
sent [LCP ConfReq id=0xa <magic 0xbde041d>]
rcvd [LCP ConfAck id=0xa <magic 0xbde041d>]
rcvd [CHAP Challenge id=0x1 <83fdd61636a474ef53873e1aea69b7ca>, name = "BSREN202"]
Got server *
Got secret *
Got auth_addr *
Got server *
Got secret *
Got client *
sent [CHAP Response id=0x1 <6fef0c53c68d9d36db5c5dd16b54fb4b>, name = "garphilippe"]
sent [LCP TermReq id=0xb "Failed to authenticate ourselves to peer"]
rcvd [LCP TermReq id=0xa1]
sent [LCP TermAck id=0xa1]
sent [LCP TermReq id=0xc "Failed to authenticate ourselves to peer"]
using channel 4
ioctl(PPPIOCGFLAGS): Inappropriate ioctl for device
failed to connect
n°335015
mirtouf
Light is right !
Posté le 05-10-2003 à 17:49:19  profilanswer
Faudrait compiler usb-ohci et le mettre en module. [:spamafote]
et puis fais voir le /etc/fstab
Message édité par mirtouf le 05-10-2003 à 17:49:46
n°335041
filou75
Posté le 05-10-2003 à 18:46:32  profilanswer
Voilà le fichier /etc/fstab :
/dev/hda11 / ext2 defaults 1 1
none /dev/pts devpts mode=0620 0 0
/dev/hda12 /home ext2 defaults 1 2
none /mnt/cdrom supermount dev=/dev/hdc,fs=auto,ro,--,iocharset=iso8859-15,codepage=850,umask=0 0 0
none /mnt/cdrom2 supermount dev=/dev/scd0,fs=auto,ro,--,iocharset=iso8859-15,codepage=850,umask=0 0 0
none /mnt/floppy supermount dev=/dev/fd0,fs=auto,--,iocharset=iso8859-15,sync,codepage=850,umask=0 0 0
/dev/hda1 /mnt/win_c vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
/dev/hda5 /mnt/win_d vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
/dev/hda6 /mnt/win_e vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
/dev/hda7 /mnt/win_f vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
/dev/hda8 /mnt/win_g vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
/dev/hda9 /mnt/win_h vfat iocharset=iso8859-15,codepage=850,umask=0 0 0
none /proc proc defaults 0 0
/dev/hda10 swap swap defaults 0
n°335050
filou75
Posté le 05-10-2003 à 19:12:33  profilanswer
C 'est bon, j'ai réussi à faire ma première connection après qq heures...trop content !!!
Mon erreur venait juste de mon login...oublier de rajouter @clubadsl1 après mon login...
  Installation
cohabitation impossible entre modem fast 800 et carte reseau[résolu] MDK9.1 Problème de configuration réseau/internet (DHCP)
obliger de brancher le modem sur linux ?Mdk et Speedtouch USB --> Ce qui a marché pour moi
avez vous des liens sur la configuration de openldap et pam_ldap[Mandrake 8.2] driver modem adsl inexistant ?
Configuration de Bind9 pour réseau localBeWan ADSL USB st sur Linux Debian
Encore ce fichu modem usb eci adsl qui fait des siennes ...Connexion modem ECI USB qui failed [résolu]
Plus de sujets relatifs à : Pb de configuration modem USB
