6189 connectés
  Linux et OS Alternatifs
  Installation
  Pb compilation drivers Nvidia sous debian testing
n°264244
xwilly
Posté le 18-05-2003 à 13:00:10  profilanswer
Je peux plus ré-installer les driver nvidia que j'avais installé quand j'etait en Woody.
Le soft d install me dit que je n ai pas la meme version de compilateur que celle utilisait pour la compilation de mon noyaux.
Ce qui est normal vu que je suis passer en testing depuis.
Donc je fait comment pour passer outre cette avertissement.
Voila ce que j ai dans nvidia.log
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  no OpenGL header files  : false
  no questions            : false
  silent                  : false
  XFree86 install prefix  : /usr/X11R6
  OpenGL install prefix   : /usr
  Installer install prefix: /usr
  kernel include path     : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp site                : ftp://download.nvidia.com
 You appear to be compiling the NVIDIA kernel module with
   a compiler different from the one that was used to compile
   the running kernel. This may be perfectly fine, but there
   are cases where this can lead to unexpected behaviour and
   system crashes.
   If you know what you are doing and want to override this
   check, you can do so by setting IGNORE_CC_MISMATCH.
   In any other case, set the CC environment variable to the
   name of the compiler that was used to compile the kernel.
   ESC[1;31m*** Failed cc sanity check. Bailing out! ***
   ESC[0mmake: *** [gcc-check] Erreur 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
Donc si vous savez les argument que je dois mettre, je suis preneur.
n°264962
xwilly
Posté le 19-05-2003 à 22:17:07  profilanswer
Ben personne ne connait la solution a mon pb :(
n°264970
Quercus
Posté le 19-05-2003 à 22:28:10  profilanswer
Tu utilises la dernière version des pilotes NVidia ( 43.93 je crois, ou pas loin...) ? Maintenant il y a un script qui s'occupe de tout ( à télécharger chez eux), peut-être qu'il pourrait passer à travers ce problème, avec un peu de chance...
  Sinon bah euh... Tu veux pas recompiler ton noyau ? C'est rapide, c'est pas cher et ça épate les gens qui regardent par dessus ton épaule  ;)
n°264978
eL_Shaman_​__
Plop.
Posté le 19-05-2003 à 22:40:50  profilanswer
Quercus a écrit :
[...]Maintenant il y a un script qui s'occupe de tout ( à télécharger chez eux)[...]
La Debian a des paquets qui s'occupent de maintenir le système...
Et t'as raison, la compil inutile de noyaux sert vraiment à contenter l'abruti.  :ange:
(Moi je dis juste qu'il y a des centaines de personnes qui utilisent une Woody avec une carte nVIDIA et ses drivers proprios, et ça m'étonnerai qu'il ne traine pas des méthodes d'installation sur le net, sur des forums...)
n°265012
chaica
Posté le 20-05-2003 à 01:11:48  profilanswer
Salut!
Même problème avec un noyau pré-compilé quand je lance le NVIDIA-Linux-x86-1.0-4363.run.
SI quelqu'un a la solution ca m'intéresse.
J'adore mon noyau compilé à la mano mais bon... :D
CHaiCA
n°265014
Evadream -​jbd-
Posté le 20-05-2003 à 01:31:53  profilanswer
To check what version of gcc was used to compile your kernel, you
   can examine the output of:
        cat /proc/version
   To check what version of gcc is currently in your $PATH, you can
        gcc -v
Ensuite il faut utiliser la meme version de gcc pour compiler le noyau, donc soit changer le lien ds /usr/bin/gcc temporairement soit changer la varible d'environnement CC, ca devrait fonctionner je pense !
n°265026
Dacal
Posté le 20-05-2003 à 08:43:55  profilanswer
        cat /proc/version
        gcc -v
Je confirme ;)
$> export CC=/usr/bin/gcc-2.95
avant de lancer le script nvidia, et ça devrait fonctionner.
n°265030
Quercus
Posté le 20-05-2003 à 08:59:35  profilanswer
Cher Shaman, je ne sais pas si tu me traites d'abruti ou pas, mais j'ai des doutes... Je ne pense pas que ma proposition le mérite en tout cas: recompiler son noyau s'il l'a déjà fait ( pour une raison moins " inutile"...) et s'il a gardé le fichier de configuration correspondant est vraiment un truc très rapide, alors même si ce n'est pas la meilleure solution et s'il y a certainement moins bourrin ( la preuve avec les autres propositions) je ne pense pas qu'elle me vaille ce qualificatif peu élogieux... Merci de ta considération...
  Les paquets Debian sont à mon avis cent fois plus compliqués à mettre en oeuvre pour les pilotes NVidia que leur install classique...
Et le IGNORE_CC_MISMATCH indiqué, tu l'as essayé Xwilly ?
Message édité par Quercus le 20-05-2003 à 09:00:41
n°265053
Aragorn_1e​r
Le jihad butlérian est proche
Posté le 20-05-2003 à 10:08:33  profilanswer
Bah tu install le packet nvidia-kernel-src, tu regarde la marche à suivre dans le /usr/share/doc/ .
( il te demandera de taper une commande pour genere un packet debian du module pour le kernel du drivers nivdia )
a la fin tu fait un dpkg -i ...
et c bon ;)
A+
  Installation
Prochaine Release de Debian ??Patch AGP pour VIA KT400 sur Debian
[Debian] Compression automatique des logsarrive toujours pas a installer Nvidia G4 4600 sur mandrake 9.1
[debian] problème chroot pure-ftpdebian et adresse IP
[debian]probleme avec CUPS des le debut :(nvidia à reinstaller a chaque boot
[debian]lancement d'un service automatiquement
Plus de sujets relatifs à : Pb compilation drivers Nvidia sous debian testing
