10847 connectés
  Linux et OS Alternatifs
  Installation
  [nvidia] Comment virer l'anti aliasing pour une Geforce4 sous linux
n°203833
trictrac
Posté le 20-12-2002 à 23:25:52  profilanswer
Pour jouer a UT2003, j'aimerai voir s'il est possible de virer l'anti aliasing comme sous windows, avec une petite boite de dialog ou autre.. histoire de gagner qqs fps, parce que la ....
n°203841
Tux Le Pen​guin
Posté le 20-12-2002 à 23:51:53  profilanswer
d'après la doc :
__________________________________________________________________________
(app-e) APPENDIX E: OPENGL ENVIRONMENT VARIABLE SETTINGS
FULL SCENE ANTI-ALIASING
Anti-aliasing is a technique used to smooth the edges of objects in a
scene to reduce the jagged "stairstep" effect that sometimes appears.
Full scene anti-aliasing is supported on GeForce or newer hardware.
By setting the appropriate environment variable, you can enable full
scene anti-aliasing in any OpenGL application on these GPUs.
Several anti-aliasing methods are available and you can select between
them by setting the __GL_FSAA_MODE environment variable appropriately.
Note that increasing the number of samples taken during FSAA rendering
may decrease performance.
The following tables describe the possible values for __GL_FSAA_MODE
and their effect on various NVIDIA GPUs.
__GL_FSAA_MODE  GeForce, GeForce2, Quadro, and Quadro2 Pro
  0             FSAA disabled
  1             FSAA disabled
  2             FSAA disabled
  3             1.5 x 1.5 Supersampling
  4             2 x 2 Supersampling
  5             FSAA disabled
__GL_FSAA_MODE  GeForce4 MX, Quadro4 500/550 XGL, and
                Quadro4 200/400 NVS
  0             FSAA disabled
  1             2x Bilinear Multisampling
  2             2x Quincunx Multisampling
  3             FSAA disabled
  5             FSAA disabled
__GL_FSAA_MODE  GeForce3, Quadro DCC, GeForce4 Ti, Quadro4 700 XGL,
                Quadro4 750 XGL, and Quadro4 900 XGL
  0             FSAA disabled
  3             FSAA disabled
  4             4x Bilinear Multisampling
  5             4x Gaussian Multisampling
Please note that to use FSAA on Quadro-family products, you must disable
UBB (please see APPENDIX M: PAGE FLIPPING, WINDOW FLIPPING, AND UBB
for details).
je crois pas que ce soit activé par défaut
comment tu vois ça ?
n°203885
trictrac
Posté le 21-12-2002 à 13:35:12  profilanswer
disosn que quand je joue, j'ai des perfs minable pour ma config dixit quelqu'un qui y a deja joué sous win.... et il m'a dit que ce serit peut etre lié a ca.
Mais ma question, c'etait globalement, est-ce qu'il ont pas un jolie interface grafik sous linux comme ils ont sous win pour faire tous ces reglalges?? Comme matrox koi!!
Lors d'un tro^?^?^?débat quelqu'un m'avait assurer que les drviers nvidiai avaient un bo panneau pour la conf ...
n°203897
Tux Le Pen​guin
Posté le 21-12-2002 à 14:25:41  profilanswer
ben j'en ai pas vu moi, d'interface
et ils en parlent nul part dans la doc, donc j'ai quand même un doute là [:wam]
n°203919
trictrac
Posté le 21-12-2002 à 15:54:15  profilanswer
mais ils sont tout nul ces drivers alors (troll mis a part !! )
Par exemple pour activer le dual head, doit bien avoir un truc plus simple que de se taper les fichier de conf a la mano ???
Avec ma G400-Max j'avais juste a cliquer et lui dire que j'avais deux ecran, et CT tout... il y avait presk exactement le meme soft que sous win.
Quand j'entend comme bocou venerent les drivers nvidia par ici, je pensais au moins qu'il y avait ca :(
M'enfin bon.. je vais me taper la doc pour voir ou il faut modifier ce que tu m'a montré :(
n°203920
Tux Le Pen​guin
Posté le 21-12-2002 à 16:01:55  profilanswer
bah je pense que s'il existait une interface officiel, j'en aurais entendu parler quand même ...
par contre, peut-être qu'il existe une interface fait par un utilisateur ...
et peut-être que ça existe sous mdk (l'activation du dual-head par interface graphique)
sinon, ça vaudrait le coup d'en faire une, parce que c'est vrai qu'il y a beaucoup d'option, quand même ...
n°207528
LoninoL
Posté le 04-01-2003 à 16:31:34  profilanswer
Effectivement, il existe une interface faite par un utilisateur, YanC :  http://yanc.sourceforge.net/index-en.html  ;)
Message édité par LoninoL le 04-01-2003 à 16:32:30
n°367460
vyse
Yaissssseee
Posté le 30-11-2003 à 09:01:39  profilanswer
désolé de remonter un topic si vieux, mais ce logiciel m'interesse, quelqu'un l'utilise?
Ca a l'air d'etre plutot pas mal  [:meganne]
  Installation
[P2P] Emule existe sous Linuxcomment ouvris des port sous linux et demem sur le firewall ..... ??
Comment installer des polices de caractères sous Linux ?config apache sur linux
[Debian Sarge] Virer GNOME2 et mettre KDE3[ok]Peut on utiliser la même part. SWAP pour deux install de linux ?
newbie Linux : comment démarrer KDE sur Mandrake 9 ?Linux sur un PC portable Compaq Presario 915
quelle distribution linuxquelle distribution linux pour de la 3D + post prod
Plus de sujets relatifs à : [nvidia] Comment virer l'anti aliasing pour une Geforce4 sous linux
