7908 connectés
  Linux et OS Alternatifs
  Installation
  ASUS P5L1394 : activer lan sous Mandriva 2007 ?
n°885015
vthand
Posté le 08-02-2007 à 10:07:58  profilanswer
la prise ETHERNET n'est pas activée, le module n'est pas chargé. Sur le CD il y a un dossier drivers Linux, avec une procédure d'install qui m'a l'air assez compliquée.
Pas moyen de faire plus simple avec URPMI ?
Le réseau, c'est du Gigabyte.
Voici ce qui figura sur le CD :
To build a binary RPM* package of this driver, run 'rpmbuild -tb
<filename.tar.gz>'. Replace <filename.tar.gz> with the specific filename of
the driver.
NOTE: For the build to work properly, the currently running kernel MUST match
      the version and configuration of the installed kernel sources. If you
      have just recompiled the kernel reboot the system now.
      RPM functionality has only been tested in Red Hat distributions.
1. Move the base driver tar file to the directory of your choice. For example,
   use /home/username/atl1 or /usr/local/src/atl1.
2. Untar/unzip archive:
     tar zxf atl1-x.x.x.tar.gz
3. Change to the driver src directory:
     cd atl1-x.x.x/src/
4. Compile the driver module:
     make install
   The binary will be installed as:
     /lib/modules/<KERNEL VERSION>/kernel/drivers/net/atl1.[k]o
   The install locations listed above are the default locations. They might not be correct for certain Linux distributions. For more information, see the ldistrib.txt file included in the driver tar.
5. Install the module:
     insmod atl1 <parameter>=<value>
6. Assign an IP address to the interface by entering the following, where
   x is the interface number:
     ifconfig ethx <IP_address>
7. Verify that the interface works. Enter the following, where <IP_address>
   is the IP address for another machine on the same subnet as the interface
   that is being tested:
     ping  <IP_address>
n°885027
memaster
M.arc a volé mon 62
Posté le 08-02-2007 à 11:01:27  profilanswer
avant de pouvoir compiler un driver il te faut installer les kernel-source :
1) verifie ta version de kernel (#uname -a)
2) urpmi kernel-source-taversiondekernel
ensuite tu pourras essayer de compiler soit par rpmbuild soit par make ;)
n°885028
vthand
Posté le 08-02-2007 à 11:02:49  profilanswer
Bon, je vais me lancer ce soir ...
n°885182
vthand
Posté le 08-02-2007 à 20:01:10  profilanswer
J'ai installé  urpmi kernel-source-2.6.17.10mdv
C'est ça ?
Mais premier problème : je ne vois pas quel fichier décompresser. Voici le contenu du dossier Lan dans Drivers Linux :
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/CVS
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/src
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/atl1.7
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/atl1.spec
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/ldistrib.txt
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/license
file:///mnt/cdrom/LinuxDrivers/LAN/AtL1Linux_v0.1.40.8/readme
et dans le dossier CVS :entries
repository
root
c'est quel fichier ?
n°885225
guepe
J'ai du noir sur la truffe ?
Posté le 08-02-2007 à 21:27:28  profilanswer
Comment ca quel fichier à décompresser ???
urpmi télécharge, décompresse et installe normalement non  :??: Je suis sur ubuntu, mais je pense que mandriva a un gestionnaire de paquet correct ??
Normalement, tu n'as rien d'autre a faire pour installer... c'est fait !!
Tu peut passer à la suite..
Au fait, tu compile un driver... tu n'as pas trouve les packages mandriva ? c'est plus simple et devrait toujours etre la solution retenue !
Un blog qu'il est bien
n°885366
vthand
Posté le 09-02-2007 à 13:09:58  profilanswer
J'ai du mal m'exprimer.
Pour l'install du kernel, c'est fait.
Le fichier que je ne trouve pas, c'est celui des drivers pour Le lan Gigabyte
n°886388
vthand
Posté le 13-02-2007 à 21:44:55  profilanswer
up
  Installation
erreur demarrage mandriva 2007 freeActiver le module ip_tables
problème installation Mandriva[resolu] mandriva 2007 , installation erreur
Installation Mandriva et Geforce 6800GSInstallation Linux Mandriva
[mandriva] resolution pas tout a fait normale ! Avec Metisse, Mandriva renouvelle le bureau 3D de Linux
Plus de sujets relatifs à : ASUS P5L1394 : activer lan sous Mandriva 2007 ?
