3190 connectés
  Linux et OS Alternatifs
  Installation
  plus d'accélération après l'install des derniers drivers ati
n°691909
newportabl​e
Laboris gloria Ludi
Posté le 11-06-2005 à 10:49:15  profilanswer
Ati à sortie un installateur automatique pour ces pilotes http://www2.ati.com/drivers/linux/installernotes.html
Tout ce passe bien mais au reboot plus d'accélération graphique... :cry:
Si ça peut vous aider, voilà mon xorg.conf; je suis sous ubuntu hoary
# XF86Config-4 (XFree86 X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# This file is automatically updated on xserver-xfree86 package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xfree86
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands as root:
#   cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
#   md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
#   dpkg-reconfigure xserver-xfree86
Section "Files"
 FontPath "unix/:7100"   # local font server
 # if the local font server has problems, we can fall back on these
 FontPath "/usr/lib/X11/fonts/misc"
 FontPath "/usr/lib/X11/fonts/cyrillic"
 FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/Type1"
 FontPath "/usr/lib/X11/fonts/CID"
 FontPath "/usr/lib/X11/fonts/Speedo"
 FontPath "/usr/lib/X11/fonts/100dpi"
 FontPath "/usr/lib/X11/fonts/75dpi"
        # paths to defoma fonts
 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
 Load "GLcore"
 Load "bitmap"
 Load "dbe"
 Load "ddc"
 Load "dri"
       #Load    "extmod"
        SubSection "extmod"
        Option    "omit xfree86-dga"
        EndSubSection
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "record"
 Load "speedo"
 Load "type1"
 Load "v4l"
 Load "vbe"
 Load "xtt"
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
 Option  "XkbRules" "xfree86"
 Option  "XkbModel" "pc105"
 Option  "XkbLayout" "fr"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/input/mice"
 Option  "Protocol"  "ImPS/2"
 Option  "Emulate3Buttons" "true"
 Option  "ZAxisMapping"  "4 5"
 Option   "EmulateWheel"
 Option  "EmulateWheelButton" "9"
EndSection
        Identifier      "Synaptics Touchpad"
        Driver          "synaptics"
        Option          "SendCoreEvents"        "true"
        Option          "Device"                "/dev/psaux"
        Option          "Protocol"              "auto-dev"
EndSection
Section "Device"
    Identifier                          "ATI Graphics Adapter"
    Driver                              "fglrx"
    Option "backingstore" "true"
    Option "UseInternalAGPGART" "no"
# ### generic DRI settings ###
# === disable PnP Monitor  ===
    #Option                              "NoDDC"
# === disable/enable XAA/DRI ===
    Option "no_accel"                   "no"
    Option "no_dri"                     "no"
# === misc DRI settings ===
    Option "mtrr"                       "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
    Option "DesktopSetup"               "0x00000100"
    Option "MonitorLayout"              "AUTO, NONE"
    Option "IgnoreEDID"                 "off"
    Option "HSync2"                     "unspecified"
    Option "VRefresh2"                  "unspecified"
    Option "ScreenOverlap"              "0"
# === TV-out Management ===
    Option "NoTV"                       "yes"
    Option "TVStandard"                 "NTSC-M"
    Option "TVHSizeAdj"                 "0"
    Option "TVVSizeAdj"                 "0"
    Option "TVHPosAdj"                  "0"
    Option "TVVPosAdj"                  "0"
    Option "TVHStartAdj"                "0"
    Option "TVColorAdj"                 "0"
    Option "GammaCorrectionI"           "0x06419064"
    Option "GammaCorrectionII"          "0x00000000"
# === OpenGL specific profiles/settings ===
    Option "Capabilities"               "0x00000000"
# === Video Overlay for the Xv extension ===
    Option "VideoOverlay"               "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
#       will be disabled automatically
    Option "OpenGLOverlay"              "off"
# === Center Mode (Laptops only) ===
    Option "CenterMode"                 "off"
# === Pseudo Color Visuals (8-bit visuals) ===
    Option "PseudoColorVisuals"         "off"
# === QBS Management ===
    Option "Stereo"                     "off"
    Option "StereoSyncEnable"           "1"
# === FSAA Management ===
    Option "FSAAEnable"                 "no"
    Option "FSAAScale"                  "1"
    Option "FSAADisableGamma"           "no"
    Option "FSAACustomizeMSPos"         "no"
    Option "FSAAMSPosX0"                "0.000000"
    Option "FSAAMSPosY0"                "0.000000"
    Option "FSAAMSPosX1"                "0.000000"
    Option "FSAAMSPosY1"                "0.000000"
    Option "FSAAMSPosX2"                "0.000000"
    Option "FSAAMSPosY2"                "0.000000"
    Option "FSAAMSPosX3"                "0.000000"
    Option "FSAAMSPosY3"                "0.000000"
    Option "FSAAMSPosX4"                "0.000000"
    Option "FSAAMSPosY4"                "0.000000"
    Option "FSAAMSPosX5"                "0.000000"
    Option "FSAAMSPosY5"                "0.000000"
# === Misc Options ===
    Option "UseFastTLS"                 "2"
    Option "BlockSignalsOnLock"         "on"
    Option "UseInternalAGPGART"         "yes"
    Option "ForceGenericCPU"            "no"
    BusID "PCI:1:0:0"    # vendor=1002, device=4e50
    Screen 0
EndSection
Section "Monitor"
 Identifier "Écran générique"
 HorizSync 30-75
 VertRefresh 50-85
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier "Default Screen"
 Device          "ATI Graphics Adapter"
 Monitor  "Écran générique"
 DefaultDepth 24
 SubSection "Display"
  Depth  1
  Modes  "1600x1200"
 EndSubSection
  Depth  4
  Modes  "1600x1200"
 EndSubSection
  Depth  8
  Modes  "1600x1200"
 EndSubSection
  Depth  15
  Modes  "1600x1200"
 EndSubSection
  Depth  16
  Modes  "1600x1200"
 EndSubSection
  Depth  24
  Modes  "1600x1200"
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 Screen  "Default Screen"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
 InputDevice "Synaptics Touchpad"
EndSection
Section "DRI"
 Mode 0666
EndSection
Merci de votre aide
Adrien
n°691911
dr-freuder​ick
Asymétrie Cognitive.
Posté le 11-06-2005 à 10:55:32  profilanswer
n°691918
newportabl​e
Laboris gloria Ludi
Posté le 11-06-2005 à 11:28:30  profilanswer
Ca marche pas sous ubuntu, tu peux pas avoir tous ces packages :cry:
n°691923
nadjyla
Posté le 11-06-2005 à 11:33:59  profilanswer
Sous ubuntu et synaptic , le nom des packages, c est:
-fglrx-control
-fglrx-kernel-source
-xorg-driver-fglrx
-xorg-driver-fglrx-dev
n°691924
newportabl​e
Laboris gloria Ludi
Posté le 11-06-2005 à 11:37:12  profilanswer
oui je sais mais je voulais les derniers drivers...
n°691926
dr-freuder​ick
Posté le 11-06-2005 à 11:43:48  profilanswer
Ben t'attend un peu ! :o
The Toast, un docu-fiction qui teste la loi de murphy et les films en carton
  Installation
distrib firewall et install de logicielPB install linux sur vmware
[Nvidia]Rien à faire pour installer les drivers !!!(prenom@user)$ .. c'est quoi ça après mon install Mandriva??[RESOLU]
[gentoo] install via clé usb ?[Redhat9]probleme lors d'un make install d'apache
problème install fedorapb de detection lecteur cd a l install ubuntu
[Debian] Galère : affichage sur une TV seult, avec drivers ATI
Plus de sujets relatifs à : plus d'accélération après l'install des derniers drivers ati
