3810 connectés
  Linux et OS Alternatifs
  Débats
  Problem d'installation d'Openoffice
n°117100
madsurfer
Boulet's eradicator
Posté le 25-06-2002 à 13:00:38  profilanswer
Slt,
J'ai une debian Woody flambante neuve !
J'ai télécharger les sources d'Openoffice.
D'après la doc : (http://tools.openoffice.org/qa/assertions/install/install02.html), il faut lancé l'installeur ./setup /net, mais je ne le trouve pas !
Voila les sources :
madsurfer:/temp/oo_1.0_src# ls
MathMLDTD      cppu           forms          jtools          padmin         sax       sot        udkapi
UnoControls    cppuhelper     fpicker        jurt            product        sc        starmath   unoil
XmlSearch      cpputools      framework      jut             psprint        scaddins  stlport    unotools
automation     dbaccess       freetype       ldapber         rdbmaker       sch       stoc       unzip
basctl         desktop        goodies        lingu           readlicense    scp       store      uui
basic          dmake          helpcontent    lingucomponent  registry       scptools  svtools    vcl
berkeleydb     drafts         i18n           linguistic      remotebridges  sd        svx        vos
bridges        dtrans         i18npool       moz             res            setup2    sw         wizards
chaos          eventattacher  idl            nas             ridljar        sfx2      sysui      xml2cmp
codemaker      ext_log4j      idlc           offapi          rsc            shell     toolkit    xmlhelp
comphelper     extensions     inet           officecfg       sablot         sj2       tools      xmloff
config_office  external       instsetoo      offmgr          sal            so3       transex3   xmlscript
configmgr      extras         io             offuh           salhelper      solenv    ucb        zlib
connectivity   fileaccess     javaunohelper  package         sandbox        soltools  ucbhelper
madsurfer:/temp/oo_1.0_src# find . |grep -w "setup"
./setup2/res/setup.ico
./setup2/script/setup.sh
./setup2/util/setup.ico
./setup2/util/setup.inf
./setup2/util/setup.os2
./setup2/util/setup.r
./dmake/qssl/setup
./unoil/com/sun/star/setup
./unoil/com/sun/star/setup/CVS
./unoil/com/sun/star/setup/CVS/Root
./unoil/com/sun/star/setup/CVS/Repository
./unoil/com/sun/star/setup/CVS/Entries
./unoil/com/sun/star/setup/CVS/Tag
./unoil/com/sun/star/setup/makefile.mk
./offapi/com/sun/star/setup
./offapi/com/sun/star/setup/CVS
./offapi/com/sun/star/setup/CVS/Root
./offapi/com/sun/star/setup/CVS/Repository
./offapi/com/sun/star/setup/CVS/Entries
./offapi/com/sun/star/setup/CVS/Tag
./offapi/com/sun/star/setup/CopyFileAction.idl
./offapi/com/sun/star/setup/ActionType.idl
./offapi/com/sun/star/setup/BaseAction.idl
./offapi/com/sun/star/setup/DeleteFolderItemAction.idl
./offapi/com/sun/star/setup/DeleteDirAction.idl
./offapi/com/sun/star/setup/DeleteFileAction.idl
./offapi/com/sun/star/setup/DeleteFolderAction.idl
./offapi/com/sun/star/setup/InstallEnvironment.idl
./offapi/com/sun/star/setup/DownloadAction.idl
./offapi/com/sun/star/setup/FontAction.idl
./offapi/com/sun/star/setup/MakeFolderItemAction.idl
./offapi/com/sun/star/setup/InstallResponse.idl
./offapi/com/sun/star/setup/InstallType.idl
./offapi/com/sun/star/setup/MakeDirAction.idl
./offapi/com/sun/star/setup/MakeFolderAction.idl
./offapi/com/sun/star/setup/MakeShortcutAction.idl
./offapi/com/sun/star/setup/MirrorEntry.idl
./offapi/com/sun/star/setup/ModuleInfo.idl
./offapi/com/sun/star/setup/ModuleState.idl
./offapi/com/sun/star/setup/OSType.idl
./offapi/com/sun/star/setup/ProfileItemAction.idl
./offapi/com/sun/star/setup/Setup.idl
./offapi/com/sun/star/setup/SizeInfo.idl
./offapi/com/sun/star/setup/UnzipAction.idl
./offapi/com/sun/star/setup/UpdateType.idl
./offapi/com/sun/star/setup/VersionIdentifier.idl
./offapi/com/sun/star/setup/WindowsRegistryAction.idl
./offapi/com/sun/star/setup/XSetup.idl
./offapi/com/sun/star/setup/makefile.mk
n°117103
Jar Jar
Intaigriste
Posté le 25-06-2002 à 13:05:02  profilanswer
Pourquoi tu ne prends pas les paquets Debian ?
http://www.linux-debian.de/openoffice/
« No question is too silly to ask, but, of course, some are too silly to answer. » -- Perl book
n°117112
Martinez
Posté le 25-06-2002 à 13:21:18  profilanswer
mdr !!
t'as pris les sources
tu vas donc installer gcc3.1 et le compiler :)
ou alors prendre un binaire précompilé ;)
n°117154
x540
fenetre8.com
Posté le 25-06-2002 à 14:33:43  profilanswer
arf cool ! encore eut-il fallu que l'on connaissiasse l'adresse  :p
www.fenetre8.com
n°117460
madsurfer
Boulet's eradicator
Posté le 26-06-2002 à 09:38:24  profilanswer
Slt,
J'ai pris la solution de Jar Jar !
Lorsque je lance openoffice, je vois le logo openoffice puis j'ai une erreur (-> aborded).
J'ai fait un ./setup puis réparation pour voir le problème.
Voici les messages de l'installeur:
-Erreur de la copie du fichier mytexts.bau vers /root/.openoffice/user/autotext
-Erreur de la copie du fichier arrowhd.soe vers /root/.openoffice/user/config
-Erreur de la copie du fichier classic.sog vers /root/.openoffice/user/config
-Erreur de la copie du fichier hatching.soh vers /root/.openoffice/user/config
-Erreur de la copie du fichier modern.sog vers /root/.openoffice/user/config
-Erreur de la copie du fichier palette.soc vers /root/.openoffice/user/config
-Erreur de la copie du fichier styles.sod vers /root/.openoffice/user/config
n°117463
Jar Jar
Intaigriste
Posté le 26-06-2002 à 09:41:14  profilanswer
Nom de dieu.
ON NE SE LOGUE PAS EN ROOT, ON NE SE LOGUE JAMAIS EN ROOT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
POURQUOI TU CROIS QUE LES GENS SE SONT FAIT CHIER À SÉPARER UN COMPTE ROOT ET DES COMPTES PAS ROOT ? POUR FAIRE MUMUSE ?
ET ON LANCE ENCORE MOINS UNE USINE À GAZ COMME OPENOFFICE.ORG EN ROOT !!!!!!!!!!!!!!!!
Message édité par Jar Jar le 26-06-2002 à 09:41:57
n°117467
R@NNIS
Tout est possible ou presque.
Posté le 26-06-2002 à 09:53:21  profilanswer
Nom de dieu.
tiens je sens k il va bientot changer sa signature jar jar a for ce de se repeter ;)
Mes News
n°117503
madsurfer
Boulet's eradicator
Posté le 26-06-2002 à 11:08:02  profilanswer
Nom de dieu.
Promis je ne ferais plus ce genre de chose en root !
(T'énerve pas comme ça ! Sinon tu va mourir jeune -> spa bon pour le coeur! )
En user le setup se lance bien !
Mais au cour de l'install, j'obtient se message :
"No ressource : Error message not available"
"Function :'Langage Select' Line: 6"
Pour info, j'ai pris la version française d'OpenOffice (fichier openoffice.org-l10n-fr).
Quelqu'un a une idée ?
PS: j'ai 1,9 Go de libre sur ma partition !
Si j'appuie sur OK, l'installation se poursuit, mais les fichiers ne sont pas copiés ! :(
Message édité par madsurfer le 26-06-2002 à 11:12:25
n°117555
Jar Jar
Intaigriste
Posté le 26-06-2002 à 12:31:28  profilanswer
Avec les paquets, il ne faut pas lancer l'installation, mais juste le programme openoffice.
  Débats
Une Woody simple d'installation ...Installation Debian Sid par ftp (avec le 1er cd)
[Help !!!] Installation d'1 debian Woody sur une KT7-RAIDInstallation de RPMs sour Mdk 8.2... Pb :(
Installation de Bind 8 à partir des sourcespetit problem !!
cups + openofficeProblème d'installation de la Mandrake 8.2
Mozilla installationInstallation imprimante canons630 usb sous Linux
Plus de sujets relatifs à : Problem d'installation d'Openoffice
