5293 connectés
  Hardware - Périphériques
  Webcam / Caméra IP
  MayGion MIPS ipcamera LDR file deleted
n°761750
nip2k2
Posté le 04-03-2014 à 06:38:53  profilanswer
Can someone send me the file LDR for my maygion mips mpeg ipcam?
I accidentaly deleted from \tmp\eye dir.
Thanks!
n°761796
paillassou
Posté le 04-03-2014 à 16:19:41  profilanswer
BE sure with the right ip camera model number
http://www.maygion.com/downloads/2 [...] m_mips.htm
if your ipcam is an H.264 ip camera CN-WIP604MW or H502W dericam
http://www.gadgetvictims.com/2013/ [...] amera.html
http://forum.hardware.fr/forum2.ph [...] 0&filter=1
Message édité par paillassou le 04-03-2014 à 16:23:30
n°761828
nip2k2
Posté le 04-03-2014 à 21:51:18  profilanswer
Sorry, my ipcam its a maygion mips mpeg (no H.264). I delete the hidden file ldr in \tmp\eye directory. I need that file to unbrick my cam. I didnt find it in the links you post.
Can anyone send me or upload the file.
Thanks again!
n°761930
paillassou
Posté le 06-03-2014 à 09:35:13  profilanswer
n°761986
nip2k2
Posté le 06-03-2014 à 15:51:23  profilanswer
Thanks paillassou but Ive already search and post there with no luck!
n°761992
paillassou
Posté le 06-03-2014 à 16:11:40  profilanswer
n°762205
nip2k2
Posté le 07-03-2014 à 20:46:00  profilanswer
thanks again! I already try all that but without the ldr file I cannot repair.
n°765334
pi511
Posté le 15-04-2014 à 15:42:33  profilanswer
I have got the file ldr for Maygion IP601-A from maygion support.
i will upload after i ask for permission to share it.
n°768611
nip2k2
Posté le 19-05-2014 à 01:14:30  profilanswer
Can you  upload please? i cant use the cam without the file.
you can do it in sendspace or similar?
Thanks!
  Webcam / Caméra IP
Maygion IP CamRicoh Aficio pb file d'attente
Problème file d'attente HP 2050camera maygion
Fichier bloqué dans file d'impression hp 5940file d'attente plotter stika
DELETEDimpression dans file d'attente incapable d'effacer help!
File d'impression bloqué sur impriméImpression sous Linux: .ppd et file d'impression
Plus de sujets relatifs à : MayGion MIPS ipcamera LDR file deleted
