3772 connectés
  Hardware - Périphériques
  Webcam / Caméra IP
  FOSCAM FI9802W SUR MON SITE
n°736237
shootingpu​b
Posté le 26-05-2013 à 08:49:35  profilanswer
Bonjour, je m'explique, mon but est de pouvoir visionner le flux d'une camera ip Foscam fi9802W H264 en direct live sur un site internet, pour la partie redirection de ports et autre c'est ok,
Voici   l'url de la cam   http://bh3524.myfoscam.org:12345        user = 1    pas de mot de passe
J'ai trouvé un code url qui me permet de voir uniquement l'image de ma caméra :    http://bh3524.myfoscam.org:12345/c [...] usr=1&pwd= , je recherche un code équivalent mais avec un flux vidéo en live, j'ai essayé cela :  http://bh3524.myfoscam.org:12345/c [...] usr=1&pwd=   j'ai une erreur 404
Je recherche donc une personne qui peux me m'aider .
Merci beaucoup
Fred
n°736253
theuberove​rlord
Posté le 26-05-2013 à 15:15:42  profilanswer
Merci beaucoup
Fred
Currently. These cameras only support four formally logged in long-term, concurrent connections. Which includes, any combination of the following before the same formal logon requests are refused or denied, until one of the four connections is released:
a. Copies of the Standard Camera Interface logged in and running.
b. Video streams directly from the camera.
c. 3rd party software that use formally logged in connections.
Eighty short-term, concurrent connections. Which are not considered formally logged in connections. Before other short-term connection requests are refused or denied. Meaning as one example a .cgi request. Such as an Interface like this uses:
http://foscam.us/forum/free-generi [...] tml#p20338
So. As you can see. If you were to have a publicly accessible camera. Say viewable via a web page. You would want to use the short-term connection methods vs. the formally logged on connections. So that more than 4 concurrent web site visitors, could be viewing the camera at the same time.
Also. If you are using many different things at the same time for a camera, such as copies of the Standard camera interface, video streams directly from the camera, 3rd party software on phones and other 3rd party software at the same time. It can be easy to reach the four long-term connection limit. Even without others having access to your camera.
Don
CV - About Me: Français English Conseils et exemples gratuits pour vos Camera IP Live IP Cam Demos
n°736277
shootingpu​b
Posté le 26-05-2013 à 19:37:30  profilanswer
Bonsoir, et merci pour votre réponse, donc si je comprends bien, cela n'est pas possible pour l'instant.
n°738370
theuberove​rlord
Posté le 20-06-2013 à 00:34:07  profilanswer
It's possible right now: http://foscam.us/forum/free-generi [...] tml#p20338
Don
  Webcam / Caméra IP
Cartouche compatible - avis sur le site et la qualité des cartouchesImages flou sur Foscam FI 8905W
Foscam FI8620 et vision de nuitEnvoi continu mail détection mouvement avec Foscam FI8910W et FI8904W
Site sur les imprimantesfoscam fi8921w mise a jour raté, solution?
Un site qui test des écranPB FOSCAM FI 8910W EN 3G
Raccordement audio sur FOSCAM 18918 wFoscam 18918W pas joignable via web
Plus de sujets relatifs à : FOSCAM FI9802W SUR MON SITE
