3171 connectés
  HFR
  [HFR] Actu : Pilotes GeForce 391.24 pour Sea of Thieves
n°10343953
C_Wiz
Profil : Equipe HardWare.fr
Posté le 20-03-2018 à 18:21:23  profilanswer
0Votes positifs
Nvidia propose également aujourd'hui une nouvelle version de ses pilotes GeForce, les 391.24. La nouveauté principale de ces pilotes est un support optimisé ...
Lire la suite ...
n°10343954
Xixou2
0Votes positifs
A noter que si vous atteignez le power limit, le gsync part en couille (stuttering) (mais pas avec les vieux drivers 385.69 ou il y a du tearing mais pas de stuttering). Mon test:
As you know, I'm using my machine for both mining and gaming.
As for mining we reduce the power limit to avoid drawing to much power from the wall
and to protect the graphic cards.
Well, that is the root cause of the gsync tearing and chopiness.
At the moment the power limit is hit, the all SLI Gsync falls appart and it turns like to be a non vsync mode
on a super bad machine, even if fraps stats are not that bad, it is visually horrible.
Below some test showing issue appearing at 70% power limit.
I will also test the limit with the founder edition bios (I did limit more the power for the inno3x x3 bios as they push the Frequencies and so for the voltage and so the power usage).
Drivers 390.77 power limit MSI afterburner v 4.4.2.12263 dated 2017_12_14 (ddr4 interleaving set to die (distributed))
default power magagement mode: optimal power.
2 GTX 1070 in SLI using High Bandwith bridge.
inno3d x3 bios (86.04.50.00.1C):(GPU 1620 MHz, Boost 1823 MHz, GDDR5 2052 MHz)
ichill1070_86_04_50_00_1C_micron.rom
power limit set to 100%. Machine wall power usage at start training place: 440 W
2018-03-11 10:23:07 - Overwatch
Frames: 3508 - Time: 25078ms - Avg: 139.884 - Min: 137 - Max: 141
smooth, no tearing.
power limit set to 90%. Machine wall power usage at start training place: 440 W
2018-03-11 10:29:55 - Overwatch
Frames: 3283 - Time: 23500ms - Avg: 139.702 - Min: 135 - Max: 141
smooth, no tearing.
power limit set to 80%. Machine wall power usage at start training place: 435 W
2018-03-11 10:32:19 - Overwatch
Frames: 3556 - Time: 25422ms - Avg: 139.879 - Min: 138 - Max: 141
smooth, no tearing.
power limit set to 70%. Machine wall power usage at start training place: 400 W
2018-03-11 10:34:36 - Overwatch
Frames: 3217 - Time: 23141ms - Avg: 139.017 - Min: 134 - Max: 141
tears and choppy
founder edition + micron patch (86.04.50.00.60): (GPU 1506 MHz, Boost 1683 MHz, GDDR5 2002 MHz)
Asus.GTX1070.8192.161020_2.rom
2018-03-11 11:01:56 - Overwatch
Frames: 3538 - Time: 25281ms - Avg: 139.947 - Min: 139 - Max: 141
smooth, no tearing.
power limit set to 90%. Machine wall power usage at start training place: 425 W
2018-03-11 11:04:05 - Overwatch
Frames: 3538 - Time: 25328ms - Avg: 139.687 - Min: 137 - Max: 141
tears but smooth
power limit set to 80%. Machine wall power usage at start training place: 396 W
2018-03-11 11:06:30 - Overwatch
Frames: 3420 - Time: 24500ms - Avg: 139.592 - Min: 137 - Max: 142
tears and choppy
drivers 385.69 default power magagement mode: optimal power.
power limit set to 100%. Machine wall power usage at start training place: 442 W
2018-03-11 11:35:28 - Overwatch
Frames: 3449 - Time: 24641ms - Avg: 139.970 - Min: 139 - Max: 141
smooth, no tearing.
power limit set to 90%. Machine wall power usage at start training place: 427 W
2018-03-11 11:37:08 - Overwatch
Frames: 3678 - Time: 26297ms - Avg: 139.864 - Min: 138 - Max: 141
smooth, small tearing.
power limit set to 80%. Machine wall power usage at start training place: 398 W
2018-03-11 11:38:59 - Overwatch
Frames: 3626 - Time: 25968ms - Avg: 139.633 - Min: 136 - Max: 142
smooth, bad tearing.
power limit set to 70%. Machine wall power usage at start training place: 372 W
2018-03-11 11:41:42 - Overwatch
Frames: 3601 - Time: 25765ms - Avg: 139.763 - Min: 137 - Max: 141
power limit set to 60%. Machine wall power usage at start training place: 342 W
2018-03-11 11:44:34 - Overwatch
Frames: 3533 - Time: 25297ms - Avg: 139.661 - Min: 135 - Max: 141
power limit set to 50%. Machine wall power usage at start training place: 310 W
2018-03-11 11:46:23 - Overwatch
Frames: 3280 - Time: 24078ms - Avg: 136.224 - Min: 111 - Max: 141
So for some reason the drivers v385.69 is less affected by the power limit,
so the new way of doing power limitation is making gsync choppy.
Would be good if other users suffering from gsync with new drivers pushes the power limit higher
to see if that solves the problem at their side as well (tearing and stuttering).
Message édité par Xixou2 le 20-03-2018 à 18:22:10
n°10344333
errorsyste​m29
Posté le 21-03-2018 à 14:54:40  profilanswer
0Votes positifs
Pas d'article sur le nvidia GPP? Etonnant!
n°10345533
Syzygy90
Posté le 24-03-2018 à 06:30:53  profilanswer
0Votes positifs
Si t'es un OEM personne te force à signer pour devenir un partenaire mon gars, Intel qui pense remettre le couvert avec les GPU, des solutions sans GPU dédié Intel+AMD et Nvidia comme des cons entrain de perdre des parts de marché.
On est loin du foin de 2009.
n°10352409
sk84life
Posté le 09-04-2018 à 09:56:44  profilanswer
0Votes positifs
Et pas d'annonce sur Nvidia lançant des gt1030 plus lentes avec de la ddr4....
https://www.anandtech.com/show/1261 [...] -ddr4-vram
Message édité par sk84life le 09-04-2018 à 09:57:00
n°10352429
Nono0000
Posté le 09-04-2018 à 10:36:53  profilanswer
0Votes positifs
Visiblement ces cartes portent la mention "D4" dans leur nom commercial.
Comme toujours, cela peut piéger les étourdis...
Cela dit, ce genre de carte est surtout utilisé pour sa partie NVDEC plus que pour ses capacités 3D.
S'il est toujours de la partie (visiblement oui), avec 10W de moins, ces cartes peuvent avoir un réel intérêt... à voir le prix en magasin également...
Message édité par Nono0000 le 09-04-2018 à 10:38:23
CPU: 6950X 4.3Ghz (Uncore: 3.7Ghz) WC HM -- Mem: 4x8Go 3200Mhz 14-16-17-32-1T -- Mobo: Asus X99 Deluxe -- GPU: 4080 (GPU: 3015Mhz, VRAM: 12200Mhz) -- Carte Son: X-Fi Titanium Fatal1ty Professional -- SSD: M.2 PCIE XP941 -- Ecran: DELL AW3423DW QD-OLED
  HFR
[HFR] Actu : Microsoft annonce DirectX Raytracing[HFR] Actu : Radeon Software 18.3.3 beta avec Vulkan 1.1
Geforce 840m compatibilité écran 144Hz[HFR] Actu : Microcode final pour Spectre chez Intel
[HFR] Actu : Des failles de sécurité spécifiques aux Ryzen ?[HFR] Actu : 3 millions de GPU vendus pour le minage
Plus de sujets relatifs à : [HFR] Actu : Pilotes GeForce 391.24 pour Sea of Thieves
