3527 connectés
  Crash IRQL_NOT_LESS_OR_EQUAL
0 %
        0 vote
1.  .
0 %
        0 vote
2.  .
0 %
        0 vote
3.  .
0 %
        0 vote
4.  .
Total : 0 vote (0 vote blanc)
n°10302234
iamseb
Posté le 01-01-2018 à 23:07:22  profilanswer
Bonsoir.
J'ai un soucis avec mon pc dont voici la config:
 Système d'exploitation
Microsoft Windows 10 Famille 64 bit (build 10.0.10240)
MSI B350M GAMING PRO (MS-7A39) 1.0 (BIOS 2.90)
 Processeur
AMD Ryzen 5 1600 3,20 GHz AM4 (AMD64 Family 23 Model 1 Stepping 1)
 Mémoire
Capacité totale : 16 Go
Barrette n° 1 : BLS8G4D26BFSEK.8FBD Channel A (8 Go)
Barrette n° 2 : BLS8G4D26BFSEK.8FBD Channel B (8 Go)
 Stockage
Capacité totale : 1,16 To
Lecteur n° 1 : WDC WD10EZEX-22MFCA0 (931,51 Go)
Lecteur n° 2 : Crucial_CT275MX300SSD1 (256,17 Go)
EVGA GeForce GTX 1060 SC Gaming
Celui ci redemarre avec le code erreur "IRQL_NOT_LESS_OR_EQUAL"
Voici le test de WhoCrashed.
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Mon 01/01/2018 23:01:41 your computer crashed
crash dump file: C:\WINDOWS\Minidump\010118-6546-01.dmp
This was probably caused by the following module: volsnap.sys (volsnap+0x14F9)
Bugcheck code: 0xA (0xE8, 0x2, 0x1, 0xFFFFF800C484FC8F)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\volsnap.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote de cliché instantané du volume
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Conclusion
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
J'ai tout mis à jour via Snappy et windows update.
Quelqu'un a une idée?
"Pourquoi faire simple quand on peut faire compliqué?" Dixit => Sonic ^^
n°10302265
Shippuden5​1
Plop !
Posté le 02-01-2018 à 02:38:21  profilanswer
Bonsoir, à tout hasard tu joues sur ton PC avec une manette ?
n°10302301
iamseb
Posté le 02-01-2018 à 09:57:00  profilanswer
Non du tout
n°10302305
zerist
Posté le 02-01-2018 à 10:10:16  profilanswer
C'est quoi comme barrettes de RAM ?
De l'overclock, ou XMP activé ?
https://www.flickr.com/photos/182924845@N04/
n°10302609
iamseb
Posté le 02-01-2018 à 18:26:03  profilanswer
memtest dit que tout va bien au niveau de la ram:
https://img15.hostingpics.net/pics/5586842654004822254365341489881314685498o.jpg
Zerist comment puis-je vérifier ça?
Message édité par iamseb le 02-01-2018 à 18:31:43
n°10303308
iamseb
Posté le 03-01-2018 à 17:00:03  profilanswer
up plz :(
Crash pc pendant scan bitdefenderProbléme de Crash
PC fixe qui crash de manière randomCrash GTX 1080ti Aorus Xtreme
Crash SSD récurrent sur PC portableCG qui crash, ventilos à 100% et écran noir
Crash PC + odeur brûlé = help me plsBesoin d'aide crash du PC en jeu
Crash PC quand je lance mes jeux.PC Neuf qui crash: écran bleu
Plus de sujets relatifs à : Crash IRQL_NOT_LESS_OR_EQUAL
