8056 connectés
  Infos CG
Infos CG
n°4474930
becaneenmo​usse
Posté le 28-11-2005 à 21:03:56  profilanswer
Lu tous ....
Je cherche un recapitulatif de cette carte , car j'ai perdu le manuel et j'aimerais avoir des infos : nombres de bip tt ca quoi, ma carte :MSI ms 6382 version 2
Merci Beaucoup
n°4474950
becaneenmo​usse
Posté le 28-11-2005 à 21:13:21  profilanswer
Je cherche aussi ou brancher le speaker.....Merci
n°4474977
ptininoo
Posté le 28-11-2005 à 21:23:35  profilanswer
Features
    * m-ATX Form Factor with PC99 color connector
    * Support Accelerated Graphic Port (AGP) Add-On Card
    * Support AMD ® PGA Socket A Duron™/Athlon™  processors at 200/266MHz System Bus Frequencies
    * Chip Integrated Audio
    * PC Alert System Hardware Monitor
    * Support DMI (Desktop Management Interface) through BIOS
    * LAN Wake Up Function
    * Modem (Internal/External) Ring Wake Up Function
    * Support PCI 2.2
    * Suspend to RAM/Disk
Specifications
CPU
    * Socket A for AMD ® Duron™/Athlon™ processor
    * Support 600MHz up to 1.5GHz processor
Chipset
    * VIA ® VT8366 chipset. (552 BGA)
      » FSB @200/266MHz
      » AGP 4x and high bandwidth Vlink host controller
      » Advanced ECC memory controller support PC100/133 SDRAM and PC200/266 DDR technology
    * VIA ® VT8233 chipset. (376 BGA)
      » High bandwidth Vlink client controller
      » Integrated faster Ethernet controller
      » Direct sound ready AC97 digital audio controller
      » Ultra DMA 33/66/100 master mode EIDE controller
      » Support both ACPI and legacy APM power management
Clock Generator : 100MHz/133MHz clocks are supported
Main Memory
    * Support four memory banks using two 184-pin DDR DIMM
    * Support a maximum memory size of 2GB
    * Support 2.5v SDRAM DIMM
Slots
    * One (Accelerated Graphics Port) AGP slot
      » AGP specification compliant
      » Support AGP 2.0 1x/2x/4x
    * One CNR (Communication Network Riser) slot
    * Three 32-bit Master PCI Bus slots
    * Supports 3.3v/5v PCI bus Interface
On-Board IDE
    * Dual Channel master mode IDE controller on the VIA ® VT8233 Chipset provides
    * IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 33/66/100 operation modes
    * Can connect up to four IDE devices
Audio : Chip Integrated
             » Direct Sound AC97 Audio
ON-Board Peripherals
    * 1 floppy port supports 2 FDD with 360K, 720K, 1.2M,1.44M and 2.88Mbytes
    * 2 serial ports (COMA + COM B)
    * 1 parallel port supports SPP/EPP/ECP mode
    * 6 USB ports (2 Rear Connectors/ 2 USB Front Pin Headers -4 ports)
    * 1 IrDA connector for SIR/CIR/ASKIR/HPSIR
    * 1 Audio/Game port
BIOS
    * The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
    * The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Dimension : ATX Form Factor: 24.3cm x 23.4cm
Mounting : 6 mounting holes  :jap:
PS :
- CG = Carte Graphique
- CM = Carte mère ;)
Le speaker se branche en bas a droite de la carte, c'est indiqué dessus normalement, jete un oeil
n°4474989
becaneenmo​usse
Posté le 28-11-2005 à 21:29:26  profilanswer
Le speaker comporte 4 tiges , et je ne vois a aucun endroit 4 tiges sur la carte mére.....
n°4475004
ptininoo
Posté le 28-11-2005 à 21:34:39  profilanswer
normalement il se branche a l'endroit ou tu branches les led power, hdd, ainsi que le bouton power et reset, il doit resté de la place
n°4475204
becaneenmo​usse
Posté le 28-11-2005 à 22:36:21  profilanswer
Petite question , n'y a t-il pas de risque a faire tourner une alim sans carte mére , juste en shuntant les pins???
n°4484020
becaneenmo​usse
Posté le 03-12-2005 à 03:28:52  profilanswer
Autre question....comment connaitre le socket de son processeur ???*
n°4484038
mightybloo​dknight2
a mort les P4D
Posté le 03-12-2005 à 04:03:46  profilanswer
sur le cpu,il y a son nom..c'est comme ça qu'on sait sur quel socket il va
Message édité par mightybloodknight2 le 03-12-2005 à 04:04:58
n°4485746
becaneenmo​usse
Posté le 04-12-2005 à 02:23:41  profilanswer
J'ai regardé et j'ai rien trouvé.
sinon mon processeur est amd athlon 2000 si ca peut aider
n°4485762
mightybloo​dknight2
a mort les P4D
Posté le 04-12-2005 à 02:50:36  profilanswer
socket a
n°4486294
becaneenmo​usse
Posté le 04-12-2005 à 13:30:25  profilanswer
oki merci !
n°4486436
becaneenmo​usse
Posté le 04-12-2005 à 14:20:08  profilanswer
y-t-il un chiffre qui corresponde au socket a , par excemple 462 .
n°4486958
mightybloo​dknight2
a mort les P4D
Posté le 04-12-2005 à 18:31:04  profilanswer
ouaip,462 = socket a
n°4487191
becaneenmo​usse
Posté le 04-12-2005 à 19:47:59  profilanswer
oki merci
n°4487198
becaneenmo​usse
Posté le 04-12-2005 à 19:50:14  profilanswer
Il faut donc que j'achete forcement une carte mére socket a ( ou 462 )
n°4487204
mightybloo​dknight2
a mort les P4D
Posté le 04-12-2005 à 19:53:31  profilanswer
ou que t'achète un athlon 64 dual core sur socket 939 avec une nouvelle carte graphique (pci-e)  :whistle:
n°4487242
becaneenmo​usse
Posté le 04-12-2005 à 20:05:30  profilanswer
euh....non lol ! de toute facon je veux juste refaire ce pc pour pouvoir a counter strike, jeu qui ne demande pas beaucoup et surfer sans probleme sur le net !
Et le 939 , c le C ?
je m'informe un peu car j'en ai marre de rien comprendre
n°4489311
becaneenmo​usse
Posté le 05-12-2005 à 20:34:09  profilanswer
Comment savoir si j'ai une agp 8x ou 4x ?? comment connaitre son voltage , 3.3 v , 1.5v ?? ps: c'est une radeon 9000
n°4489435
mightybloo​dknight2
a mort les P4D
Posté le 05-12-2005 à 21:14:52  profilanswer
la 9000 (direct x 8.1?) est en agp 8x..mais "backward" compatible avec les cartes mère agp 4x..en gros,si tu met une carte 3d agp 8x sur une carte mère agp 4x,tu vas perdre environ 3-5% en performance..mais vu la marde qu'est la radeon 90..ça changera rien  :whistle:
et c'est du .8v (compatible 1.5v)
n°4489466
becaneenmo​usse
Posté le 05-12-2005 à 21:26:25  profilanswer
Oki, merci!
Ca fait un peu bouillit comme topic mais je pose totut ici pour ne pas encombrer de trop le site....
Qu'est ce qui vaut environ le meme prix pour les memes "performances" qu'une k7s8xe ???
ou peut-on acheter du bon matos informatique sans soucis et a des prix plutot "bas"
n°4489492
mightybloo​dknight2
a mort les P4D
Posté le 05-12-2005 à 21:35:36  profilanswer
une a7n8x non deluxe (ou la a7n8x-x mais sans dual channel)
et pour ce qui est du "matos"..j'habite au québec donc..ça va être dur de répondre  :D
n°4489517
becaneenmo​usse
Posté le 05-12-2005 à 21:48:40  profilanswer
rien d'autre ?
De tte facon je pense qu'une carte a 35£ ~ suffit puisque c'est juste pour counter strike + le net ! je remet sur pied ce pc juste pour dire de rentabiliser mes neons + tour tuning.
  Infos CG
DDe d'infos sur ram compatible avec CM P6BAP-A+demande infos benq Ew1621
[RAM]comparatif/demande d'infosNe pas choisir ATI à cause de directX 9.0c ? Infos SVP ...
Flash bios infosUrgent - demande d'infos
Infos advance@902Infos sur P M 760
Pas taper ! Besoin infos pour achat dd externe
Plus de sujets relatifs à : Infos CG
